Random Freezing (KDE Plasma, Nvidia Graphics)
Hello, I’ve been having random freezing ever since my Manjaro install ~3 weeks ago. I’m very new to linux so any help would be appreciated. I haven’t been able to get REISUB to work but I fear that might just be to me not doing it right as I don’t have a sysreq key on my keyboard and when I try the other keybinds when my system is not frozen nothing pops up giving me an indication that it is working.
Here is my system information and a journalctl of my last frozen session. Thank you for any help!
  Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
    root=UUID=bac419f9-11d4-41cb-9966-76749dcaa343 rw rootflags=subvol=@ quiet
    apparmor=1 security=apparmor
    resume=UUID=ad465df4-9fce-428f-8caa-2316c668b386 udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: MSI model: Z170A GAMING M5 (MS-7977) v: 1.0
    serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 1.A0
    date: 07/22/2016
  Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
    family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEC
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 799 high: 800 min/max: 800/4200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 799 6: 800 7: 800 8: 800 bogomips: 64026
  Type: l1tf
  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: eVga.com.
    driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5760x1080 s-dpi: 92 s-size: 1590x301mm (62.60x11.85")
    s-diag: 1618mm (63.71")
  Monitor-1: DP-1 pos: primary,center res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: DP-3 pos: right res: 1920x1080 hz: 60 dpi: 93
  Monitor-3: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 93
  OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
    v: 4.6.0 NVIDIA 510.54 direct render: Yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
    chip-ID: 8086:a170 class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio vendor: eVga.com.
    bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
  Device-3: Corsair VOID PRO Wireless Gaming Headset type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:2 chip-ID: 1b1c:0a14
    class-ID: 0300
  Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: yes
  Device-1: Qualcomm Atheros Killer E2400 Gigabit Ethernet
    vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 1969:e0a1 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: half mac: <filter>
  Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  IF-ID-2: virbr0 state: down mac: <filter>
    bus-ID: 1-10:3 chip-ID: 8087:0a2b class-ID: e001
  Local Storage: total: 5 TiB used: 2.15 TiB (43.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
    type: SSD serial: <filter> rev: 2B6Q scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD130 size: 2.73 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
    rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA200
    type: HDD rpm: 7200 serial: <filter> rev: ABS0 scheme: MBR
  ID-1: / raw-size: 448.61 GiB size: 448.61 GiB (100.00%)
    used: 57.27 GiB (12.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw-size: 448.61 GiB size: 448.61 GiB (100.00%)
  ID-3: /var/log raw-size: 448.61 GiB size: 448.61 GiB (100.00%)
  ID-1: swap-1 type: partition size: 17.15 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 29.8 C pch: 37.5 C mobo: 27.8 C gpu: nvidia
    temp: 63 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 10%
  Processes: 273 Uptime: 35m wakeups: 0 Memory: 15.59 GiB
  used: 2.4 GiB (15.4%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1314 lib: 366 flatpak: 0
  Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Mar 28 15:46:32 LavaGrenade sddm-greeter[790]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assi>
Mar 28 15:46:35 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:35 [Debug] picking servers for OPENVPN technology
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [Info] starting network configuration
Mar 28 15:46:36 LavaGrenade audit[923]: NETFILTER_CFG table=filter family=2 entries=32 op=xt_replace pid=923 subj==>
Mar 28 15:46:36 LavaGrenade audit[923]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=55f1>
Mar 28 15:46:36 LavaGrenade audit: PROCTITLE proctitle=69707461626C6573002D4900494E505554002D6900656E70337330002D6A>
Mar 28 15:46:36 LavaGrenade audit[924]: NETFILTER_CFG table=filter family=2 entries=33 op=xt_replace pid=924 subj==>
Mar 28 15:46:36 LavaGrenade audit[924]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=555e>
Mar 28 15:46:36 LavaGrenade audit: PROCTITLE proctitle=69707461626C6573002D49004F5554505554002D6F00656E70337330002D>
Mar 28 15:46:36 LavaGrenade kernel: kauditd_printk_skb: 29 callbacks suppressed
Mar 28 15:46:36 LavaGrenade kernel: audit: type=1325 audit(1648507596.594:139): table=filter family=2 entries=32 op>
Mar 28 15:46:36 LavaGrenade kernel: audit: type=1300 audit(1648507596.594:139): arch=c000003e syscall=54 success=ye>
Mar 28 15:46:36 LavaGrenade kernel: audit: type=1327 audit(1648507596.594:139): proctitle=69707461626C6573002D49004>
Mar 28 15:46:36 LavaGrenade kernel: audit: type=1325 audit(1648507596.594:140): table=filter family=2 entries=33 op>
Mar 28 15:46:36 LavaGrenade kernel: audit: type=1300 audit(1648507596.594:140): arch=c000003e syscall=54 success=ye>
Mar 28 15:46:36 LavaGrenade kernel: audit: type=1327 audit(1648507596.594:140): proctitle=69707461626C6573002D49004>
Mar 28 15:46:36 LavaGrenade kernel: audit: type=1325 audit(1648507596.597:141): table=filter family=2 entries=34 op>
Mar 28 15:46:36 LavaGrenade kernel: audit: type=1300 audit(1648507596.597:141): arch=c000003e syscall=54 success=ye>
Mar 28 15:46:36 LavaGrenade kernel: audit: type=1327 audit(1648507596.597:141): proctitle=69707461626C6573002D49004>
Mar 28 15:46:36 LavaGrenade audit[925]: NETFILTER_CFG table=filter family=2 entries=34 op=xt_replace pid=925 subj==>
Mar 28 15:46:36 LavaGrenade audit[925]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=55b3>
Mar 28 15:46:36 LavaGrenade audit: PROCTITLE proctitle=69707461626C6573002D4900494E505554002D6900776C70347330002D6A>
Mar 28 15:46:36 LavaGrenade audit[926]: NETFILTER_CFG table=filter family=2 entries=35 op=xt_replace pid=926 subj==>
Mar 28 15:46:36 LavaGrenade audit[926]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=55d1>
Mar 28 15:46:36 LavaGrenade audit: PROCTITLE proctitle=69707461626C6573002D49004F5554505554002D6F00776C70347330002D>
Mar 28 15:46:36 LavaGrenade audit[928]: NETFILTER_CFG table=filter family=10 entries=19 op=xt_replace pid=928 subj=>
Mar 28 15:46:36 LavaGrenade audit[928]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=29 a2=40 a3=55e>
Mar 28 15:46:36 LavaGrenade audit: PROCTITLE proctitle=6970367461626C6573002D4900494E505554002D6900656E70337330002D>
Mar 28 15:46:36 LavaGrenade audit[929]: NETFILTER_CFG table=filter family=10 entries=20 op=xt_replace pid=929 subj=>
Mar 28 15:46:36 LavaGrenade audit[929]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=29 a2=40 a3=559>
Mar 28 15:46:36 LavaGrenade audit: PROCTITLE proctitle=6970367461626C6573002D49004F5554505554002D6F00656E7033733000>
Mar 28 15:46:36 LavaGrenade kernel: audit: type=1325 audit(1648507596.597:142): table=filter family=2 entries=35 op>
Mar 28 15:46:36 LavaGrenade audit[930]: NETFILTER_CFG table=filter family=10 entries=21 op=xt_replace pid=930 subj=>
Mar 28 15:46:36 LavaGrenade audit[930]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=29 a2=40 a3=55b>
Mar 28 15:46:36 LavaGrenade audit: PROCTITLE proctitle=6970367461626C6573002D4900494E505554002D6900776C70347330002D>
Mar 28 15:46:36 LavaGrenade audit[931]: NETFILTER_CFG table=filter family=10 entries=22 op=xt_replace pid=931 subj=>
Mar 28 15:46:36 LavaGrenade audit[931]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=29 a2=40 a3=55a>
Mar 28 15:46:36 LavaGrenade audit: PROCTITLE proctitle=6970367461626C6573002D49004F5554505554002D6F00776C7034733000>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [Info] opening firewall to the vpn server
Mar 28 15:46:36 LavaGrenade audit[933]: NETFILTER_CFG table=filter family=2 entries=36 op=xt_replace pid=933 subj==>
Mar 28 15:46:36 LavaGrenade audit[933]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=5577>
Mar 28 15:46:36 LavaGrenade audit: PROCTITLE proctitle=69707461626C6573002D4900494E505554002D6900656E70337330002D73>
Mar 28 15:46:36 LavaGrenade audit[934]: NETFILTER_CFG table=filter family=2 entries=37 op=xt_replace pid=934 subj==>
Mar 28 15:46:36 LavaGrenade audit[934]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=5619>
Mar 28 15:46:36 LavaGrenade audit[935]: NETFILTER_CFG table=filter family=2 entries=38 op=xt_replace pid=935 subj==>
Mar 28 15:46:36 LavaGrenade audit[935]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=55bb>
Mar 28 15:46:36 LavaGrenade audit: PROCTITLE proctitle=69707461626C6573002D4900494E505554002D6900776C70347330002D73>
Mar 28 15:46:36 LavaGrenade audit[936]: NETFILTER_CFG table=filter family=2 entries=39 op=xt_replace pid=936 subj==>
Mar 28 15:46:36 LavaGrenade audit[936]: SYSCALL arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=5630>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [Info] starting vpn
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 DEPRECATED OPTION: --cipher set to 'AES-256-C>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 DEPRECATED OPTION: --ciph>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 OpenVPN 2.5.3 x86_64-pc-linux-gnu [SSL (OpenS>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 OpenVPN 2.5.3 x86_64-pc-l>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 library versions: OpenSSL 1.1.1i  8 Dec 2020,>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 library versions: OpenSSL>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 MANAGEMENT: Connected to management server at>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 MANAGEMENT: Connected to >
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 MANAGEMENT: CMD 'state on'
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 MANAGEMENT: CMD 'state on'
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 MANAGEMENT: CMD 'username "Auth" kjLz5adGQeNH>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 MANAGEMENT: CMD 'username>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 MANAGEMENT: CMD 'password [...]'
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 MANAGEMENT: CMD 'password>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 Outgoing Control Channel Authentication: Usin>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 Outgoing Control Channel >
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 Incoming Control Channel Authentication: Usin>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 Incoming Control Channel >
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 TCP/UDP: Preserving recently used remote addr>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 TCP/UDP: Preserving recen>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 Socket Buffers: R=[212992->212992] S=[212992->
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 Socket Buffers: R=[212992>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 UDP link local: (not bound)
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 UDP link local: (not boun>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 UDP link remote: [AF_INET]212.102.47.86:1194
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 UDP link remote: [AF_INET>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 MANAGEMENT: >STATE:1648507596,WAIT,,,,,,
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 MANAGEMENT: >STATE:164850>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 MANAGEMENT: >STATE:1648507596,AUTH,,,,,,
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 TLS: Initial packet from [AF_INET]212.102.47.>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 TLS: Initial packet from >
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordV>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 VERIFY OK: depth=2, C=PA,>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 VERIFY OK: depth=1, C=PA, O=NordVPN, CN=NordV>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 VERIFY OK: depth=1, C=PA,>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 VERIFY KU OK
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 VERIFY KU OK
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 Validating certificate extended key usage
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 Validating certificate ex>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 ++ Certificate has EKU (str) TLS Web Server A>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 ++ Certificate has EKU (s>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 VERIFY EKU OK
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 VERIFY EKU OK
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 VERIFY OK: depth=0, CN=us8265.nordvpn.com
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 VERIFY OK: depth=0, CN=us>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 WARNING: 'link-mtu' is used inconsistently, l>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 WARNING: 'link-mtu' is us>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 WARNING: 'comp-lzo' is present in remote conf>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 WARNING: 'comp-lzo' is pr>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 Control Channel: TLSv1.3,>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:36 [us8265.nordvpn.com] Peer Connection Initiate>
Mar 28 15:46:36 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:36 [INFO] 2022-03-28 15:46:36 [us8265.nordvpn.com] Peer>
Mar 28 15:46:37 LavaGrenade systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 28 15:46:37 LavaGrenade audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=>
Mar 28 15:46:37 LavaGrenade systemd[1]: pkgfile-update.service: Deactivated successfully.
Mar 28 15:46:37 LavaGrenade systemd[1]: Finished pkgfile database update.
Mar 28 15:46:37 LavaGrenade systemd[1]: Startup finished in 1.761s (kernel) + 12.937s (userspace) = 14.698s.
Mar 28 15:46:37 LavaGrenade audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg>
Mar 28 15:46:37 LavaGrenade systemd[1]: pkgfile-update.service: Consumed 2.077s CPU time.
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 MANAGEMENT: >STATE:1648507598,GET_CONFIG,,,,,,
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 MANAGEMENT: >STATE:164850>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 SENT CONTROL [us8265.nordvpn.com]: 'PUSH_REQU>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 SENT CONTROL [us8265.nord>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 PUSH: Received control message: 'PUSH_REPLY,r>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 PUSH: Received control me>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 Pushed option removed by filter: 'redirect-ga>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 Pushed option removed by >
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 OPTIONS IMPORT: timers and/or timeouts modifi>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 OPTIONS IMPORT: timers an>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 OPTIONS IMPORT: explicit notify parm(s) modif>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 OPTIONS IMPORT: explicit >
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 OPTIONS IMPORT: compression parms modified
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 OPTIONS IMPORT: compressi>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 OPTIONS IMPORT: --sndbuf/--rcvbuf options mod>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 OPTIONS IMPORT: --sndbuf/>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 Socket Buffers: R=[212992->425984] S=[212992->
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 Socket Buffers: R=[212992>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 OPTIONS IMPORT: --ifconfig/up options modified
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 OPTIONS IMPORT: --ifconfi>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 OPTIONS IMPORT: route-related options modified
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 OPTIONS IMPORT: route-rel>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 OPTIONS IMPORT: --ip-win32 and/or --dhcp-opti>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 OPTIONS IMPORT: --ip-win3>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 OPTIONS IMPORT: peer-id set
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 OPTIONS IMPORT: peer-id s>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 OPTIONS IMPORT: adjusting link_mtu to 1656
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 OPTIONS IMPORT: adjusting>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 OPTIONS IMPORT: data channel crypto options m>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 OPTIONS IMPORT: data chan>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 Data Channel: using negotiated cipher 'AES-25>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 Data Channel: using negot>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 Outgoing Data Channel: Cipher 'AES-256-GCM' i>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 Outgoing Data Channel: Ci>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 Incoming Data Channel: Cipher 'AES-256-GCM' i>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 Incoming Data Channel: Ci>
Mar 28 15:46:38 LavaGrenade kernel: tun: Universal TUN/TAP device driver, 1.6
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 TUN/TAP device tun0 opened
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 TUN/TAP device tun0 opened
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 MANAGEMENT: >STATE:1648507598,ASSIGN_IP,,10.8>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 /sbin/ip link set dev tun0 up mtu 1500
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 /sbin/ip link set dev tun>
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <info>  [1648507598.2002] manager: (tun0): new Tun device (/org/fr>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 /sbin/ip addr add dev tun0 10.8.0.10/24
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 /sbin/ip addr add dev tun>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 WARNING: this configuration may cache passwor>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 WARNING: this configurati>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 Initialization Sequence Completed
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [INFO] 2022-03-28 15:46:38 Initialization Sequence C>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: debug: 2022-03-28 15:46:38 MANAGEMENT: >STATE:1648507598,CONNECTED,SUCCE>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [Info] Setting the routing rules up
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <info>  [1648507598.2099] device (tun0): state change: unmanaged ->
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <info>  [1648507598.2104] device (tun0): state change: unavailable>
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <info>  [1648507598.2109] device (tun0): Activation: starting conn>
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <info>  [1648507598.2112] device (tun0): state change: disconnecte>
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <info>  [1648507598.2115] device (tun0): state change: prepare -> >
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <info>  [1648507598.2117] device (tun0): state change: config -> i>
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <info>  [1648507598.2121] device (tun0): state change: ip-config ->
Mar 28 15:46:38 LavaGrenade dbus-daemon[519]: [system] Activating via systemd: service name='org.freedesktop.nm_dis>
Mar 28 15:46:38 LavaGrenade systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 28 15:46:38 LavaGrenade dbus-daemon[519]: [system] Successfully activated service 'org.freedesktop.nm_dispatche>
Mar 28 15:46:38 LavaGrenade systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 28 15:46:38 LavaGrenade audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg>
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <info>  [1648507598.2205] device (tun0): state change: ip-check ->>
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <info>  [1648507598.2207] device (tun0): state change: secondaries>
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <info>  [1648507598.2212] device (tun0): Activation: successful, d>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [Info] setting dns to 103.86.96.100 103.86.99.100
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 [Info] using resolvconf
Mar 28 15:46:38 LavaGrenade dnsmasq[741]: reading /etc/resolv.conf
Mar 28 15:46:38 LavaGrenade dnsmasq[741]: using nameserver 103.86.96.100#53
Mar 28 15:46:38 LavaGrenade dnsmasq[741]: using nameserver 103.86.99.100#53
Mar 28 15:46:38 LavaGrenade avahi-daemon[516]: Got SIGHUP, reloading.
Mar 28 15:46:38 LavaGrenade avahi-daemon[516]: No service file found in /etc/avahi/services.
Mar 28 15:46:38 LavaGrenade avahi-daemon[516]: Withdrawing address record for ::1 on lo.
Mar 28 15:46:38 LavaGrenade avahi-daemon[516]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
Mar 28 15:46:38 LavaGrenade avahi-daemon[516]: Interface lo.IPv6 no longer relevant for mDNS.
Mar 28 15:46:38 LavaGrenade avahi-daemon[516]: Withdrawing address record for fe80::cf27:4f35:3120:60b5 on enp3s0.
Mar 28 15:46:38 LavaGrenade avahi-daemon[516]: Leaving mDNS multicast group on interface enp3s0.IPv6 with address f>
Mar 28 15:46:38 LavaGrenade avahi-daemon[516]: Interface enp3s0.IPv6 no longer relevant for mDNS.
Mar 28 15:46:38 LavaGrenade NetworkManager[575]: <warn>  [1648507598.4919] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:46:38 LavaGrenade audit[1021]: USER_AUTH pid=1021 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m>
Mar 28 15:46:38 LavaGrenade audit[1021]: USER_ACCT pid=1021 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m>
Mar 28 15:46:38 LavaGrenade su[1021]: (to austin) root on none
Mar 28 15:46:38 LavaGrenade audit[1021]: CRED_ACQ pid=1021 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms>
Mar 28 15:46:38 LavaGrenade su[1021]: pam_unix(su:session): session opened for user austin(uid=1000) by (uid=0)
Mar 28 15:46:38 LavaGrenade audit[1021]: USER_START pid=1021 uid=0 auid=4294967295 ses=4294967295 subj==unconfined >
Mar 28 15:46:38 LavaGrenade su[1021]: pam_unix(su:session): session closed for user austin
Mar 28 15:46:38 LavaGrenade audit[1021]: USER_END pid=1021 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms>
Mar 28 15:46:38 LavaGrenade audit[1021]: CRED_DISP pid=1021 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 2022/03/28 15:46:38 POST_CONNECT system info:
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: Routes for ipv4:
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: default dev tun0 table 205 scope link
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: default via 192.168.1.1 dev enp3s0 proto dhcp metric 100
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 10.8.0.0/24 dev tun0 proto kernel scope link src 10.8.0.10
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 192.168.1.0/24 dev enp3s0 proto kernel scope link src 192.168.1.115 metr>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 192.168.122.0/24 dev virbr0 proto kernel scope link src 192.168.122.1 li>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: local 10.8.0.10 dev tun0 table local proto kernel scope host src 10.8.0.>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: broadcast 10.8.0.255 dev tun0 table local proto kernel scope link src 10>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: local 127.0.0.0/8 dev lo table local proto kernel scope host src 127.0.0>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: local 127.0.0.1 dev lo table local proto kernel scope host src 127.0.0.1
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: broadcast 127.255.255.255 dev lo table local proto kernel scope link src>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: local 192.168.1.115 dev enp3s0 table local proto kernel scope host src 1>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: broadcast 192.168.1.255 dev enp3s0 table local proto kernel scope link s>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: local 192.168.122.1 dev virbr0 table local proto kernel scope host src 1>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: broadcast 192.168.122.255 dev virbr0 table local proto kernel scope link>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: IP rules for ipv4:
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 0:        from all lookup local
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 32764:        from all lookup main suppress_prefixlength 0
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 32765:        not from all fwmark 0xe1f1 lookup 205
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 32766:        from all lookup main
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: 32767:        from all lookup default
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: Routes for ipv6:
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: IP rules for ipv6:
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: IP tables for ipv4:
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: filter:
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -P INPUT ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -P FORWARD ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -P OUTPUT ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -N LIBVIRT_FWI
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -N LIBVIRT_FWO
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -N LIBVIRT_FWX
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -N LIBVIRT_INP
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -N LIBVIRT_OUT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A INPUT -s 212.102.47.86/32 -i wlp4s0 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A INPUT -s 212.102.47.86/32 -i enp3s0 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A INPUT -i wlp4s0 -j DROP
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A INPUT -i enp3s0 -j DROP
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A INPUT -j LIBVIRT_INP
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A FORWARD -j LIBVIRT_FWX
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A FORWARD -j LIBVIRT_FWI
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A FORWARD -j LIBVIRT_FWO
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A OUTPUT -d 212.102.47.86/32 -o wlp4s0 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A OUTPUT -d 212.102.47.86/32 -o enp3s0 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A OUTPUT -o wlp4s0 -j DROP
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A OUTPUT -o enp3s0 -j DROP
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A OUTPUT -j LIBVIRT_OUT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_FWI -d 192.168.122.0/24 -o virbr0 -m conntrack --ctstate RELA>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_FWI -o virbr0 -j REJECT --reject-with icmp-port-unreachable
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_FWO -s 192.168.122.0/24 -i virbr0 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_FWO -i virbr0 -j REJECT --reject-with icmp-port-unreachable
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_FWX -i virbr0 -o virbr0 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_INP -i virbr0 -p udp -m udp --dport 53 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_INP -i virbr0 -p tcp -m tcp --dport 53 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_INP -i virbr0 -p udp -m udp --dport 67 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_INP -i virbr0 -p tcp -m tcp --dport 67 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_OUT -o virbr0 -p udp -m udp --dport 53 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_OUT -o virbr0 -p tcp -m tcp --dport 53 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_OUT -o virbr0 -p udp -m udp --dport 68 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_OUT -o virbr0 -p tcp -m tcp --dport 68 -j ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: nat:
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -P PREROUTING ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -P POSTROUTING ACCEPT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -N LIBVIRT_PRT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A POSTROUTING -j LIBVIRT_PRT
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_PRT -s 192.168.122.0/24 -d 224.0.0.0/24 -j RETURN
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_PRT -s 192.168.122.0/24 -d 255.255.255.255/32 -j RETURN
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_PRT -s 192.168.122.0/24 ! -d 192.168.122.0/24 -p tcp -j MASQU>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_PRT -s 192.168.122.0/24 ! -d 192.168.122.0/24 -p udp -j MASQU>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_PRT -s 192.168.122.0/24 ! -d 192.168.122.0/24 -j MASQUERADE
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: mangle:
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: -A LIBVIRT_PRT -o virbr0 -p udp -m udp --dport 68 -j CHECKSUM --checksum>
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: raw:
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: security:
Mar 28 15:46:38 LavaGrenade nordvpnd[808]: IP tables for ipv6:
Mar 28 15:46:40 LavaGrenade NetworkManager[575]: <warn>  [1648507600.4896] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:46:41 LavaGrenade NetworkManager[575]: <warn>  [1648507601.6810] ndisc[0x5610270d6400,"enp3s0"]: solicit:>
Mar 28 15:46:42 LavaGrenade snapd[521]: daemon.go:509: gracefully waiting for running hooks
Mar 28 15:46:42 LavaGrenade snapd[521]: daemon.go:511: done waiting for running hooks
Mar 28 15:46:42 LavaGrenade snapd[521]: daemon stop requested to wait for socket activation
Mar 28 15:46:42 LavaGrenade systemd[1]: snapd.service: Deactivated successfully.
Mar 28 15:46:42 LavaGrenade kernel: kauditd_printk_skb: 36 callbacks suppressed
Mar 28 15:46:42 LavaGrenade kernel: audit: type=1131 audit(1648507602.134:161): pid=1 uid=0 auid=4294967295 ses=429>
Mar 28 15:46:42 LavaGrenade audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=>
Mar 28 15:46:42 LavaGrenade NetworkManager[575]: <warn>  [1648507602.4911] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:46:43 LavaGrenade sddm-greeter[790]: Reading from "/usr/share/xsessions/plasma.desktop"
Mar 28 15:46:43 LavaGrenade sddm[601]: Message received from greeter: Login
Mar 28 15:46:43 LavaGrenade sddm[601]: Reading from "/usr/share/xsessions/plasma.desktop"
Mar 28 15:46:43 LavaGrenade sddm[601]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/s>
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: [PAM] Starting...
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: [PAM] Authenticating...
Mar 28 15:46:43 LavaGrenade dbus-daemon[519]: [system] Activating via systemd: service name='org.freedesktop.home1'>
Mar 28 15:46:43 LavaGrenade dbus-daemon[519]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop>
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: pam_systemd_home(sddm:auth): systemd-homed is not available: Unit db>
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: [PAM] Preparing to converse...
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: [PAM] Conversation with 1 messages
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: [PAM] returning.
Mar 28 15:46:43 LavaGrenade audit[1040]: USER_AUTH pid=1040 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m>
Mar 28 15:46:43 LavaGrenade audit[1040]: USER_ACCT pid=1040 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m>
Mar 28 15:46:43 LavaGrenade sddm[601]: Authenticated successfully
Mar 28 15:46:43 LavaGrenade sddm-greeter[790]: Message received from daemon: LoginSucceeded
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Mar 28 15:46:43 LavaGrenade audit[1040]: CRED_ACQ pid=1040 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms>
Mar 28 15:46:43 LavaGrenade audit[1040]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7fff2364a930 a2>
Mar 28 15:46:43 LavaGrenade audit: PROCTITLE proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F>
Mar 28 15:46:43 LavaGrenade kernel: audit: type=1100 audit(1648507603.707:162): pid=1040 uid=0 auid=4294967295 ses=>
Mar 28 15:46:43 LavaGrenade kernel: audit: type=1101 audit(1648507603.707:163): pid=1040 uid=0 auid=4294967295 ses=>
Mar 28 15:46:43 LavaGrenade kernel: audit: type=1103 audit(1648507603.707:164): pid=1040 uid=0 auid=4294967295 ses=>
Mar 28 15:46:43 LavaGrenade kernel: audit: type=1006 audit(1648507603.707:165): pid=1040 uid=0 subj==unconfined old>
Mar 28 15:46:43 LavaGrenade kernel: audit: type=1300 audit(1648507603.707:165): arch=c000003e syscall=1 success=yes>
Mar 28 15:46:43 LavaGrenade kernel: audit: type=1327 audit(1648507603.707:165): proctitle=2F7573722F6C69622F7364646>
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: pam_unix(sddm:session): session opened for user austin(uid=1000) by >
Mar 28 15:46:43 LavaGrenade systemd[1]: Created slice User Slice of UID 1000.
Mar 28 15:46:43 LavaGrenade systemd[1]: Starting User Runtime Directory /run/user/1000...
Mar 28 15:46:43 LavaGrenade systemd-logind[523]: New session 2 of user austin.
Mar 28 15:46:43 LavaGrenade systemd[1]: Finished User Runtime Directory /run/user/1000.
Mar 28 15:46:43 LavaGrenade audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg>
Mar 28 15:46:43 LavaGrenade systemd[1]: Starting User Manager for UID 1000...
Mar 28 15:46:43 LavaGrenade kernel: audit: type=1130 audit(1648507603.724:166): pid=1 uid=0 auid=4294967295 ses=429>
Mar 28 15:46:43 LavaGrenade systemd[1042]: pam_systemd_home(systemd-user:account): systemd-homed is not available: >
Mar 28 15:46:43 LavaGrenade systemd[1042]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 s>
Mar 28 15:46:43 LavaGrenade kernel: audit: type=1101 audit(1648507603.727:167): pid=1042 uid=0 auid=4294967295 ses=>
Mar 28 15:46:43 LavaGrenade kernel: audit: type=1103 audit(1648507603.727:168): pid=1042 uid=0 auid=4294967295 ses=>
Mar 28 15:46:43 LavaGrenade audit[1042]: USER_ACCT pid=1042 uid=0 auid=4294967295 ses=4294967295 subj==unconfined m>
Mar 28 15:46:43 LavaGrenade audit[1042]: CRED_ACQ pid=1042 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms>
Mar 28 15:46:43 LavaGrenade audit[1042]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffc31127bf0 a2>
Mar 28 15:46:43 LavaGrenade audit: PROCTITLE proctitle="(systemd)"
Mar 28 15:46:43 LavaGrenade systemd[1042]: pam_unix(systemd-user:session): session opened for user austin(uid=1000)>
Mar 28 15:46:43 LavaGrenade systemd[1042]: pam_env(systemd-user:session): deprecated reading of user environment en>
Mar 28 15:46:43 LavaGrenade audit[1042]: USER_START pid=1042 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:ses>
Mar 28 15:46:43 LavaGrenade audit: BPF prog-id=27 op=LOAD
Mar 28 15:46:43 LavaGrenade audit[1042]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7fff5a9bf600 >
Mar 28 15:46:43 LavaGrenade audit: BPF prog-id=0 op=UNLOAD
Mar 28 15:46:43 LavaGrenade sddm-helper[776]: [PAM] Closing session
Mar 28 15:46:43 LavaGrenade sddm-helper[776]: pam_unix(sddm-greeter:session): session closed for user sddm
Mar 28 15:46:43 LavaGrenade audit[776]: USER_END pid=776 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=>
Mar 28 15:46:43 LavaGrenade audit[776]: CRED_DISP pid=776 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg>
Mar 28 15:46:43 LavaGrenade sddm-helper[776]: [PAM] Ended.
Mar 28 15:46:43 LavaGrenade sddm[601]: Auth: sddm-helper exited successfully
Mar 28 15:46:43 LavaGrenade sddm[601]: Greeter stopped.
Mar 28 15:46:43 LavaGrenade systemd[1]: session-c1.scope: Deactivated successfully.
Mar 28 15:46:43 LavaGrenade systemd[1]: session-c1.scope: Consumed 2.059s CPU time.
Mar 28 15:46:43 LavaGrenade systemd-logind[523]: Session c1 logged out. Waiting for processes to exit.
Mar 28 15:46:43 LavaGrenade systemd-logind[523]: Removed session c1.
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: pam_env(sddm:session): deprecated reading of user environment enabled
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Mar 28 15:46:43 LavaGrenade systemd[1]: Started User Manager for UID 1000.
Mar 28 15:46:43 LavaGrenade systemd[1]: Started Session 2 of User austin.
Mar 28 15:46:43 LavaGrenade audit[1040]: USER_START pid=1040 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:ses>
Mar 28 15:46:43 LavaGrenade sddm-helper[1040]: Starting: "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x>
Mar 28 15:46:43 LavaGrenade sddm[601]: Session started
Mar 28 15:46:44 LavaGrenade NetworkManager[575]: <warn>  [1648507604.4918] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:46:45 LavaGrenade NetworkManager[575]: <info>  [1648507605.9727] agent-manager: agent[f354bbb4760fb6a7,:1>
Mar 28 15:46:46 LavaGrenade kernel: ntfs3: Max link count 4000
Mar 28 15:46:46 LavaGrenade kernel: ntfs3: Enabled Linux POSIX ACLs support
Mar 28 15:46:46 LavaGrenade kernel: ntfs3: Read-only LZX/Xpress compression included
Mar 28 15:46:46 LavaGrenade kernel: ntfs3: Unknown parameter 'windows_names'
Mar 28 15:46:46 LavaGrenade dbus-daemon[519]: [system] Activating via systemd: service name='org.freedesktop.Realti>
Mar 28 15:46:46 LavaGrenade systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Mar 28 15:46:46 LavaGrenade dbus-daemon[519]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Mar 28 15:46:46 LavaGrenade audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg>
Mar 28 15:46:46 LavaGrenade systemd[1]: Started RealtimeKit Scheduling Policy Service.
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Successfully called chroot.
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Successfully dropped privileges.
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Successfully limited resources.
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Canary thread running.
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Running.
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Watchdog thread running.
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Successfully made thread 1170 of process 1170 owned by '1000' high >
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Supervising 1 threads of 1 processes of 1 users.
Mar 28 15:46:46 LavaGrenade kernel: Bluetooth: RFCOMM TTY layer initialized
Mar 28 15:46:46 LavaGrenade kernel: Bluetooth: RFCOMM socket layer initialized
Mar 28 15:46:46 LavaGrenade kernel: Bluetooth: RFCOMM ver 1.11
Mar 28 15:46:46 LavaGrenade polkitd[520]: Registered Authentication Agent for unix-session:2 (system bus name :1.52>
Mar 28 15:46:46 LavaGrenade NetworkManager[575]: <warn>  [1648507606.4928] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:46:46 LavaGrenade dbus-daemon[519]: [system] Activating service name='org.kde.powerdevil.discretegpuhelpe>
Mar 28 15:46:46 LavaGrenade dbus-daemon[519]: [system] Successfully activated service 'org.kde.powerdevil.discreteg>
Mar 28 15:46:46 LavaGrenade dbus-daemon[519]: [system] Activating service name='org.kde.powerdevil.chargethresholdh>
Mar 28 15:46:46 LavaGrenade ntfs-3g[1243]: Version 2021.8.22 external FUSE 29
Mar 28 15:46:46 LavaGrenade ntfs-3g[1243]: Mounted /dev/sdc1 (Read-Write, label "2TB Drive", NTFS 3.1)
Mar 28 15:46:46 LavaGrenade ntfs-3g[1243]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper>
Mar 28 15:46:46 LavaGrenade ntfs-3g[1243]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatim>
Mar 28 15:46:46 LavaGrenade ntfs-3g[1243]: Global ownership and permissions enforced, configuration type 7
Mar 28 15:46:46 LavaGrenade udisksd[797]: Mounted /dev/sdc1 at /run/media/austin/2TB Drive on behalf of uid 1000
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Successfully made thread 1245 of process 1170 owned by '1000' RT at>
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Supervising 2 threads of 1 processes of 1 users.
Mar 28 15:46:46 LavaGrenade dbus-daemon[519]: [system] Successfully activated service 'org.kde.powerdevil.chargethr>
Mar 28 15:46:46 LavaGrenade dbus-daemon[519]: [system] Activating service name='org.kde.powerdevil.backlighthelper'>
Mar 28 15:46:46 LavaGrenade backlighthelper[1255]: org.kde.powerdevil: no kernel backlight interface found
Mar 28 15:46:46 LavaGrenade dbus-daemon[519]: [system] Successfully activated service 'org.kde.powerdevil.backlight>
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Successfully made thread 1265 of process 1170 owned by '1000' RT at>
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Supervising 3 threads of 1 processes of 1 users.
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Successfully made thread 1268 of process 1170 owned by '1000' RT at>
Mar 28 15:46:46 LavaGrenade rtkit-daemon[1195]: Supervising 4 threads of 1 processes of 1 users.
Mar 28 15:46:46 LavaGrenade ntfs-3g[1272]: Version 2021.8.22 external FUSE 29
Mar 28 15:46:46 LavaGrenade ntfs-3g[1272]: Mounted /dev/sdb1 (Read-Write, label "3TB Drive", NTFS 3.1)
Mar 28 15:46:46 LavaGrenade ntfs-3g[1272]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper>
Mar 28 15:46:46 LavaGrenade ntfs-3g[1272]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatim>
Mar 28 15:46:46 LavaGrenade udisksd[797]: Mounted /dev/sdb1 at /run/media/austin/3TB Drive on behalf of uid 1000
Mar 28 15:46:46 LavaGrenade ntfs-3g[1272]: Global ownership and permissions enforced, configuration type 7
Mar 28 15:46:47 LavaGrenade rtkit-daemon[1195]: Supervising 4 threads of 1 processes of 1 users.
Mar 28 15:46:47 LavaGrenade rtkit-daemon[1195]: Successfully made thread 1276 of process 1170 owned by '1000' RT at>
Mar 28 15:46:47 LavaGrenade rtkit-daemon[1195]: Supervising 5 threads of 1 processes of 1 users.
Mar 28 15:46:47 LavaGrenade bluetoothd[517]: Endpoint registered: sender=:1.68 path=/MediaEndpoint/A2DPSource/ldac_>
Mar 28 15:46:47 LavaGrenade bluetoothd[517]: Endpoint registered: sender=:1.68 path=/MediaEndpoint/A2DPSink/aptx_hd
Mar 28 15:46:47 LavaGrenade bluetoothd[517]: Endpoint registered: sender=:1.68 path=/MediaEndpoint/A2DPSource/aptx_>
Mar 28 15:46:47 LavaGrenade bluetoothd[517]: Endpoint registered: sender=:1.68 path=/MediaEndpoint/A2DPSink/sbc
Mar 28 15:46:47 LavaGrenade bluetoothd[517]: Endpoint registered: sender=:1.68 path=/MediaEndpoint/A2DPSource/sbc
Mar 28 15:46:47 LavaGrenade bluetoothd[517]: Endpoint registered: sender=:1.68 path=/MediaEndpoint/A2DPSink/sbc_xq_>
Mar 28 15:46:47 LavaGrenade bluetoothd[517]: Endpoint registered: sender=:1.68 path=/MediaEndpoint/A2DPSource/sbc_x>
Mar 28 15:46:47 LavaGrenade rtkit-daemon[1195]: Successfully made thread 1339 of process 1339 owned by '1000' high >
Mar 28 15:46:47 LavaGrenade rtkit-daemon[1195]: Supervising 6 threads of 2 processes of 1 users.
Mar 28 15:46:47 LavaGrenade rtkit-daemon[1195]: Successfully made thread 1341 of process 1340 owned by '1000' RT at>
Mar 28 15:46:47 LavaGrenade rtkit-daemon[1195]: Supervising 7 threads of 3 processes of 1 users.
Mar 28 15:46:47 LavaGrenade rtkit-daemon[1195]: Successfully made thread 1342 of process 1339 owned by '1000' RT at>
Mar 28 15:46:47 LavaGrenade rtkit-daemon[1195]: Supervising 8 threads of 3 processes of 1 users.
Mar 28 15:46:48 LavaGrenade systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 28 15:46:48 LavaGrenade audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=>
Mar 28 15:46:48 LavaGrenade kernel: kauditd_printk_skb: 13 callbacks suppressed
Mar 28 15:46:48 LavaGrenade kernel: audit: type=1131 audit(1648507608.224:178): pid=1 uid=0 auid=4294967295 ses=429>
Mar 28 15:46:48 LavaGrenade NetworkManager[575]: <warn>  [1648507608.4942] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:46:54 LavaGrenade systemd[1]: Stopping User Manager for UID 962...
Mar 28 15:46:54 LavaGrenade systemd[778]: Activating special unit Exit the Session...
Mar 28 15:46:54 LavaGrenade systemd[778]: Stopped target Main User Target.
Mar 28 15:46:54 LavaGrenade systemd[778]: Stopping D-Bus User Message Bus...
Mar 28 15:46:54 LavaGrenade systemd[778]: Stopped D-Bus User Message Bus.
Mar 28 15:46:54 LavaGrenade systemd[778]: Removed slice User Core Session Slice.
Mar 28 15:46:54 LavaGrenade systemd[778]: Stopped target Basic System.
Mar 28 15:46:54 LavaGrenade systemd[778]: Stopped target Paths.
Mar 28 15:46:54 LavaGrenade systemd[778]: Stopped target Sockets.
Mar 28 15:46:54 LavaGrenade systemd[778]: Stopped target Timers.
Mar 28 15:46:54 LavaGrenade systemd[778]: Closed D-Bus User Message Bus Socket.
Mar 28 15:46:54 LavaGrenade systemd[778]: Closed GnuPG network certificate management daemon.
Mar 28 15:46:54 LavaGrenade systemd[778]: Closed GCR ssh-agent wrapper.
Mar 28 15:46:54 LavaGrenade systemd[778]: Closed GnuPG cryptographic agent and passphrase cache (access for web bro>
Mar 28 15:46:54 LavaGrenade systemd[778]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Mar 28 15:46:54 LavaGrenade systemd[778]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Mar 28 15:46:54 LavaGrenade systemd[778]: Closed GnuPG cryptographic agent and passphrase cache.
Mar 28 15:46:54 LavaGrenade systemd[778]: Closed p11-kit server.
Mar 28 15:46:54 LavaGrenade systemd[778]: Closed PipeWire Multimedia System Socket.
Mar 28 15:46:54 LavaGrenade systemd[778]: Closed Sound System.
Mar 28 15:46:54 LavaGrenade systemd[778]: Removed slice User Application Slice.
Mar 28 15:46:54 LavaGrenade systemd[778]: Reached target Shutdown.
Mar 28 15:46:54 LavaGrenade systemd[778]: Finished Exit the Session.
Mar 28 15:46:54 LavaGrenade systemd[778]: Reached target Exit the Session.
Mar 28 15:46:54 LavaGrenade systemd[779]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 se>
Mar 28 15:46:54 LavaGrenade systemd[1]: user@962.service: Deactivated successfully.
Mar 28 15:46:54 LavaGrenade systemd[1]: Stopped User Manager for UID 962.
Mar 28 15:46:54 LavaGrenade audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=>
Mar 28 15:46:54 LavaGrenade kernel: audit: type=1131 audit(1648507614.094:179): pid=1 uid=0 auid=4294967295 ses=429>
Mar 28 15:46:54 LavaGrenade systemd[1]: Stopping User Runtime Directory /run/user/962...
Mar 28 15:46:54 LavaGrenade systemd[1]: run-user-962.mount: Deactivated successfully.
Mar 28 15:46:54 LavaGrenade systemd[1]: user-runtime-dir@962.service: Deactivated successfully.
Mar 28 15:46:54 LavaGrenade systemd[1]: Stopped User Runtime Directory /run/user/962.
Mar 28 15:46:54 LavaGrenade systemd[1]: Removed slice User Slice of UID 962.
Mar 28 15:46:54 LavaGrenade systemd[1]: user-962.slice: Consumed 2.309s CPU time.
Mar 28 15:46:54 LavaGrenade kernel: audit: type=1131 audit(1648507614.107:180): pid=1 uid=0 auid=4294967295 ses=429>
Mar 28 15:46:57 LavaGrenade systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Mar 28 15:46:56 LavaGrenade kernel: audit: type=1131 audit(1648507617.124:181): pid=1 uid=0 auid=4294967295 ses=429>
Mar 28 15:46:56 LavaGrenade kernel: audit: type=1334 audit(1648507617.284:182): prog-id=0 op=UNLOAD
Mar 28 15:46:56 LavaGrenade kernel: audit: type=1334 audit(1648507617.284:183): prog-id=0 op=UNLOAD
Mar 28 15:46:56 LavaGrenade kernel: audit: type=1334 audit(1648507617.284:184): prog-id=0 op=UNLOAD
Mar 28 15:46:56 LavaGrenade systemd-journald[299]: Time jumped backwards, rotating.
Mar 28 15:46:57 LavaGrenade audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=>
Mar 28 15:46:57 LavaGrenade audit: BPF prog-id=0 op=UNLOAD
Mar 28 15:46:56 LavaGrenade systemd-timesyncd[473]: Initial synchronization to time server 216.229.4.69:123 (2.manj>
Mar 28 15:46:57 LavaGrenade NetworkManager[575]: <warn>  [1648507617.0675] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:46:57 LavaGrenade rtkit-daemon[1195]: Supervising 8 threads of 3 processes of 1 users.
Mar 28 15:46:57 LavaGrenade rtkit-daemon[1195]: Successfully made thread 1600 of process 1456 owned by '1000' RT at>
Mar 28 15:46:57 LavaGrenade rtkit-daemon[1195]: Supervising 9 threads of 4 processes of 1 users.
Mar 28 15:46:58 LavaGrenade rtkit-daemon[1195]: Supervising 9 threads of 4 processes of 1 users.
Mar 28 15:46:59 LavaGrenade NetworkManager[575]: <warn>  [1648507619.0691] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:01 LavaGrenade NetworkManager[575]: <warn>  [1648507621.0698] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:02 LavaGrenade rtkit-daemon[1195]: Supervising 9 threads of 4 processes of 1 users.
Mar 28 15:47:03 LavaGrenade NetworkManager[575]: <warn>  [1648507623.0723] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:03 LavaGrenade rtkit-daemon[1195]: Supervising 9 threads of 4 processes of 1 users.
Mar 28 15:47:03 LavaGrenade rtkit-daemon[1195]: Successfully made thread 1944 of process 1706 owned by '1000' RT at>
Mar 28 15:47:03 LavaGrenade rtkit-daemon[1195]: Supervising 10 threads of 5 processes of 1 users.
Mar 28 15:47:04 LavaGrenade NetworkManager[575]: <info>  [1648507624.6722] manager: NetworkManager state is now CON>
Mar 28 15:47:04 LavaGrenade dbus-daemon[519]: [system] Activating via systemd: service name='org.freedesktop.nm_dis>
Mar 28 15:47:04 LavaGrenade systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 28 15:47:04 LavaGrenade dbus-daemon[519]: [system] Successfully activated service 'org.freedesktop.nm_dispatche>
Mar 28 15:47:04 LavaGrenade systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 28 15:47:04 LavaGrenade audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg>
Mar 28 15:47:04 LavaGrenade kernel: audit: type=1130 audit(1648507624.677:185): pid=1 uid=0 auid=4294967295 ses=429>
Mar 28 15:47:05 LavaGrenade NetworkManager[575]: <warn>  [1648507625.0734] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:07 LavaGrenade NetworkManager[575]: <warn>  [1648507627.0749] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:07 LavaGrenade systemd[1]: systemd-timedated.service: Deactivated successfully.
Mar 28 15:47:07 LavaGrenade audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=>
Mar 28 15:47:07 LavaGrenade kernel: audit: type=1131 audit(1648507627.127:186): pid=1 uid=0 auid=4294967295 ses=429>
Mar 28 15:47:07 LavaGrenade audit: BPF prog-id=0 op=UNLOAD
Mar 28 15:47:07 LavaGrenade kernel: audit: type=1334 audit(1648507627.157:187): prog-id=0 op=UNLOAD
Mar 28 15:47:07 LavaGrenade kernel: audit: type=1334 audit(1648507627.157:188): prog-id=0 op=UNLOAD
Mar 28 15:47:07 LavaGrenade kernel: audit: type=1334 audit(1648507627.157:189): prog-id=0 op=UNLOAD
Mar 28 15:47:09 LavaGrenade NetworkManager[575]: <warn>  [1648507629.0761] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:47:14 LavaGrenade systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 28 15:47:14 LavaGrenade audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=>
Mar 28 15:47:14 LavaGrenade kernel: audit: type=1131 audit(1648507634.690:190): pid=1 uid=0 auid=4294967295 ses=429>
Mar 28 15:47:19 LavaGrenade NetworkManager[575]: <warn>  [1648507639.0796] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:21 LavaGrenade NetworkManager[575]: <warn>  [1648507641.0810] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:23 LavaGrenade NetworkManager[575]: <warn>  [1648507643.0828] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:25 LavaGrenade NetworkManager[575]: <warn>  [1648507645.0843] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:27 LavaGrenade NetworkManager[575]: <warn>  [1648507647.0857] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:29 LavaGrenade NetworkManager[575]: <warn>  [1648507649.0865] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:31 LavaGrenade NetworkManager[575]: <warn>  [1648507651.0871] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:47:41 LavaGrenade NetworkManager[575]: <warn>  [1648507661.0900] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:43 LavaGrenade NetworkManager[575]: <warn>  [1648507663.0930] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:45 LavaGrenade NetworkManager[575]: <warn>  [1648507665.0956] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:47 LavaGrenade NetworkManager[575]: <warn>  [1648507667.0967] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:49 LavaGrenade NetworkManager[575]: <warn>  [1648507669.0992] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:51 LavaGrenade NetworkManager[575]: <warn>  [1648507671.1011] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:47:53 LavaGrenade NetworkManager[575]: <warn>  [1648507673.1025] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:48:03 LavaGrenade NetworkManager[575]: <warn>  [1648507683.1102] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:05 LavaGrenade NetworkManager[575]: <warn>  [1648507685.1100] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:07 LavaGrenade NetworkManager[575]: <warn>  [1648507687.1125] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:09 LavaGrenade NetworkManager[575]: <warn>  [1648507689.1147] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:11 LavaGrenade NetworkManager[575]: <warn>  [1648507691.1168] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:13 LavaGrenade NetworkManager[575]: <warn>  [1648507693.1197] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:15 LavaGrenade NetworkManager[575]: <warn>  [1648507695.1220] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:48:25 LavaGrenade NetworkManager[575]: <warn>  [1648507705.1302] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:25 LavaGrenade systemd[1]: libvirtd.service: Deactivated successfully.
Mar 28 15:48:25 LavaGrenade audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=>
Mar 28 15:48:25 LavaGrenade systemd[1]: libvirtd.service: Unit process 741 (dnsmasq) remains running after unit sto>
Mar 28 15:48:25 LavaGrenade kernel: audit: type=1131 audit(1648507705.840:191): pid=1 uid=0 auid=4294967295 ses=429>
Mar 28 15:48:25 LavaGrenade systemd[1]: libvirtd.service: Unit process 742 (dnsmasq) remains running after unit sto>
Mar 28 15:48:27 LavaGrenade NetworkManager[575]: <warn>  [1648507707.1324] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:29 LavaGrenade NetworkManager[575]: <warn>  [1648507709.1335] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:31 LavaGrenade NetworkManager[575]: <warn>  [1648507711.1366] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:33 LavaGrenade NetworkManager[575]: <warn>  [1648507713.1383] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:35 LavaGrenade NetworkManager[575]: <warn>  [1648507715.1400] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:37 LavaGrenade NetworkManager[575]: <warn>  [1648507717.1405] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:48:38 LavaGrenade rtkit-daemon[1195]: Supervising 9 threads of 4 processes of 1 users.
Mar 28 15:48:39 LavaGrenade rtkit-daemon[1195]: Supervising 9 threads of 4 processes of 1 users.
Mar 28 15:48:39 LavaGrenade rtkit-daemon[1195]: Successfully made thread 2703 of process 1875 owned by '1000' RT at>
Mar 28 15:48:39 LavaGrenade rtkit-daemon[1195]: Supervising 10 threads of 5 processes of 1 users.
Mar 28 15:48:40 LavaGrenade rtkit-daemon[1195]: Supervising 10 threads of 5 processes of 1 users.
Mar 28 15:48:46 LavaGrenade audit: BPF prog-id=0 op=UNLOAD
Mar 28 15:48:46 LavaGrenade kernel: audit: type=1334 audit(1648507726.466:192): prog-id=0 op=UNLOAD
Mar 28 15:48:47 LavaGrenade NetworkManager[575]: <warn>  [1648507727.1436] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:49 LavaGrenade NetworkManager[575]: <warn>  [1648507729.1458] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:51 LavaGrenade NetworkManager[575]: <warn>  [1648507731.1476] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:53 LavaGrenade NetworkManager[575]: <warn>  [1648507733.1497] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:55 LavaGrenade NetworkManager[575]: <warn>  [1648507735.1517] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:57 LavaGrenade NetworkManager[575]: <warn>  [1648507737.1531] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:48:59 LavaGrenade NetworkManager[575]: <warn>  [1648507739.1553] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:49:09 LavaGrenade NetworkManager[575]: <warn>  [1648507749.1634] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:11 LavaGrenade NetworkManager[575]: <warn>  [1648507751.1656] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:13 LavaGrenade NetworkManager[575]: <warn>  [1648507753.1669] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:15 LavaGrenade NetworkManager[575]: <warn>  [1648507755.1686] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:17 LavaGrenade NetworkManager[575]: <warn>  [1648507757.1705] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:19 LavaGrenade NetworkManager[575]: <warn>  [1648507759.1729] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:21 LavaGrenade NetworkManager[575]: <warn>  [1648507761.1751] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:49:31 LavaGrenade NetworkManager[575]: <warn>  [1648507771.1831] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:33 LavaGrenade NetworkManager[575]: <warn>  [1648507773.1850] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:35 LavaGrenade NetworkManager[575]: <warn>  [1648507775.1867] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:37 LavaGrenade NetworkManager[575]: <warn>  [1648507777.1895] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:39 LavaGrenade NetworkManager[575]: <warn>  [1648507779.1921] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:41 LavaGrenade NetworkManager[575]: <warn>  [1648507781.1929] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:43 LavaGrenade NetworkManager[575]: <warn>  [1648507783.1938] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:49:53 LavaGrenade NetworkManager[575]: <warn>  [1648507793.2032] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:55 LavaGrenade NetworkManager[575]: <warn>  [1648507795.2059] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:57 LavaGrenade NetworkManager[575]: <warn>  [1648507797.2086] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:49:59 LavaGrenade NetworkManager[575]: <warn>  [1648507799.2095] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:01 LavaGrenade NetworkManager[575]: <warn>  [1648507801.2115] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:03 LavaGrenade NetworkManager[575]: <warn>  [1648507803.2132] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:05 LavaGrenade NetworkManager[575]: <warn>  [1648507805.2155] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:50:15 LavaGrenade NetworkManager[575]: <warn>  [1648507815.2231] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:17 LavaGrenade NetworkManager[575]: <warn>  [1648507817.2257] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:19 LavaGrenade NetworkManager[575]: <warn>  [1648507819.2273] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:21 LavaGrenade NetworkManager[575]: <warn>  [1648507821.2300] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:23 LavaGrenade NetworkManager[575]: <warn>  [1648507823.2331] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:25 LavaGrenade NetworkManager[575]: <warn>  [1648507825.2363] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:27 LavaGrenade NetworkManager[575]: <warn>  [1648507827.2388] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:50:37 LavaGrenade NetworkManager[575]: <warn>  [1648507837.2499] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:39 LavaGrenade NetworkManager[575]: <warn>  [1648507839.2521] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:41 LavaGrenade NetworkManager[575]: <warn>  [1648507841.2552] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:43 LavaGrenade NetworkManager[575]: <warn>  [1648507843.2583] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:45 LavaGrenade NetworkManager[575]: <warn>  [1648507845.2615] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:47 LavaGrenade NetworkManager[575]: <warn>  [1648507847.2637] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:50:49 LavaGrenade NetworkManager[575]: <warn>  [1648507849.2652] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:50:59 LavaGrenade NetworkManager[575]: <warn>  [1648507859.2675] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:01 LavaGrenade NetworkManager[575]: <warn>  [1648507861.2705] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:03 LavaGrenade NetworkManager[575]: <warn>  [1648507863.2736] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:05 LavaGrenade NetworkManager[575]: <warn>  [1648507865.2761] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:07 LavaGrenade NetworkManager[575]: <warn>  [1648507867.2788] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:09 LavaGrenade NetworkManager[575]: <warn>  [1648507869.2801] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:11 LavaGrenade NetworkManager[575]: <warn>  [1648507871.2826] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:51:21 LavaGrenade NetworkManager[575]: <warn>  [1648507881.2838] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:23 LavaGrenade NetworkManager[575]: <warn>  [1648507883.2865] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:25 LavaGrenade NetworkManager[575]: <warn>  [1648507885.2893] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:27 LavaGrenade NetworkManager[575]: <warn>  [1648507887.2899] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:29 LavaGrenade NetworkManager[575]: <warn>  [1648507889.2925] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:31 LavaGrenade NetworkManager[575]: <warn>  [1648507891.2951] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:33 LavaGrenade NetworkManager[575]: <warn>  [1648507893.2961] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:51:43 LavaGrenade NetworkManager[575]: <warn>  [1648507903.3002] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:45 LavaGrenade NetworkManager[575]: <warn>  [1648507905.3020] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:47 LavaGrenade NetworkManager[575]: <warn>  [1648507907.3029] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:49 LavaGrenade NetworkManager[575]: <warn>  [1648507909.3058] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:51 LavaGrenade NetworkManager[575]: <warn>  [1648507911.3092] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:53 LavaGrenade NetworkManager[575]: <warn>  [1648507913.3097] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:51:55 LavaGrenade NetworkManager[575]: <warn>  [1648507915.3120] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:52:05 LavaGrenade NetworkManager[575]: <warn>  [1648507925.3197] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:07 LavaGrenade NetworkManager[575]: <warn>  [1648507927.3221] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:09 LavaGrenade NetworkManager[575]: <warn>  [1648507929.3230] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:11 LavaGrenade NetworkManager[575]: <warn>  [1648507931.3254] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:13 LavaGrenade NetworkManager[575]: <warn>  [1648507933.3264] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:15 LavaGrenade NetworkManager[575]: <warn>  [1648507935.3288] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:17 LavaGrenade NetworkManager[575]: <warn>  [1648507937.3293] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:52:27 LavaGrenade NetworkManager[575]: <warn>  [1648507947.3396] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:29 LavaGrenade NetworkManager[575]: <warn>  [1648507949.3412] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:31 LavaGrenade NetworkManager[575]: <warn>  [1648507951.3431] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:33 LavaGrenade NetworkManager[575]: <warn>  [1648507953.3457] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:35 LavaGrenade NetworkManager[575]: <warn>  [1648507955.3466] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:37 LavaGrenade NetworkManager[575]: <warn>  [1648507957.3491] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:39 LavaGrenade NetworkManager[575]: <warn>  [1648507959.3514] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:52:49 LavaGrenade NetworkManager[575]: <warn>  [1648507969.3595] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:51 LavaGrenade NetworkManager[575]: <warn>  [1648507971.3605] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:53 LavaGrenade NetworkManager[575]: <warn>  [1648507973.3635] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:55 LavaGrenade NetworkManager[575]: <warn>  [1648507975.3652] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:57 LavaGrenade NetworkManager[575]: <warn>  [1648507977.3661] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:52:59 LavaGrenade NetworkManager[575]: <warn>  [1648507979.3686] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:01 LavaGrenade NetworkManager[575]: <warn>  [1648507981.3700] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:53:11 LavaGrenade NetworkManager[575]: <warn>  [1648507991.3795] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:13 LavaGrenade NetworkManager[575]: <warn>  [1648507993.3818] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:15 LavaGrenade NetworkManager[575]: <warn>  [1648507995.3829] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:16 LavaGrenade NetworkManager[575]: <info>  [1648507996.6728] device (wlp4s0): set-hw-addr: set MAC ad>
Mar 28 15:53:16 LavaGrenade NetworkManager[575]: <info>  [1648507996.7052] device (wlp4s0): supplicant interface st>
Mar 28 15:53:16 LavaGrenade NetworkManager[575]: <info>  [1648507996.7052] device (p2p-dev-wlp4s0): supplicant mana>
Mar 28 15:53:17 LavaGrenade NetworkManager[575]: <warn>  [1648507997.3837] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:17 LavaGrenade rtkit-daemon[1195]: Supervising 10 threads of 5 processes of 1 users.
Mar 28 15:53:19 LavaGrenade NetworkManager[575]: <warn>  [1648507999.3854] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:21 LavaGrenade rtkit-daemon[1195]: Supervising 10 threads of 5 processes of 1 users.
Mar 28 15:53:21 LavaGrenade NetworkManager[575]: <warn>  [1648508001.3862] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:21 LavaGrenade rtkit-daemon[1195]: Successfully made thread 4698 of process 2650 owned by '1000' RT at>
Mar 28 15:53:21 LavaGrenade rtkit-daemon[1195]: Supervising 11 threads of 6 processes of 1 users.
Mar 28 15:53:23 LavaGrenade NetworkManager[575]: <warn>  [1648508003.3873] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:53:28 LavaGrenade rtkit-daemon[1195]: Supervising 11 threads of 6 processes of 1 users.
Mar 28 15:53:28 LavaGrenade rtkit-daemon[1195]: Successfully made thread 4809 of process 2744 owned by '1000' RT at>
Mar 28 15:53:28 LavaGrenade rtkit-daemon[1195]: Supervising 12 threads of 7 processes of 1 users.
Mar 28 15:53:33 LavaGrenade NetworkManager[575]: <warn>  [1648508013.3935] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:35 LavaGrenade NetworkManager[575]: <warn>  [1648508015.3943] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:35 LavaGrenade rtkit-daemon[1195]: Supervising 12 threads of 7 processes of 1 users.
Mar 28 15:53:37 LavaGrenade rtkit-daemon[1195]: Supervising 12 threads of 7 processes of 1 users.
Mar 28 15:53:37 LavaGrenade rtkit-daemon[1195]: Successfully made thread 4985 of process 4655 owned by '1000' RT at>
Mar 28 15:53:37 LavaGrenade rtkit-daemon[1195]: Supervising 13 threads of 8 processes of 1 users.
Mar 28 15:53:37 LavaGrenade NetworkManager[575]: <warn>  [1648508017.3969] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:39 LavaGrenade NetworkManager[575]: <warn>  [1648508019.3990] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:41 LavaGrenade NetworkManager[575]: <warn>  [1648508021.4022] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:43 LavaGrenade NetworkManager[575]: <warn>  [1648508023.4021] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:45 LavaGrenade NetworkManager[575]: <warn>  [1648508025.4026] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:53:55 LavaGrenade NetworkManager[575]: <warn>  [1648508035.4135] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:57 LavaGrenade NetworkManager[575]: <warn>  [1648508037.4138] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:53:59 LavaGrenade NetworkManager[575]: <warn>  [1648508039.4167] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:01 LavaGrenade NetworkManager[575]: <warn>  [1648508041.4198] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:03 LavaGrenade NetworkManager[575]: <warn>  [1648508043.4228] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:05 LavaGrenade NetworkManager[575]: <warn>  [1648508045.4255] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:07 LavaGrenade NetworkManager[575]: <warn>  [1648508047.4278] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:54:17 LavaGrenade NetworkManager[575]: <warn>  [1648508057.4287] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:19 LavaGrenade NetworkManager[575]: <warn>  [1648508059.4299] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:21 LavaGrenade NetworkManager[575]: <warn>  [1648508061.4331] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:23 LavaGrenade NetworkManager[575]: <warn>  [1648508063.4330] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:25 LavaGrenade NetworkManager[575]: <warn>  [1648508065.4356] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:27 LavaGrenade NetworkManager[575]: <warn>  [1648508067.4365] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:29 LavaGrenade NetworkManager[575]: <warn>  [1648508069.4388] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:54:39 LavaGrenade NetworkManager[575]: <warn>  [1648508079.4497] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:41 LavaGrenade NetworkManager[575]: <warn>  [1648508081.4529] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:43 LavaGrenade NetworkManager[575]: <warn>  [1648508083.4531] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:45 LavaGrenade NetworkManager[575]: <warn>  [1648508085.4560] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:47 LavaGrenade NetworkManager[575]: <warn>  [1648508087.4574] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:49 LavaGrenade NetworkManager[575]: <warn>  [1648508089.4599] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:54:51 LavaGrenade NetworkManager[575]: <warn>  [1648508091.4594] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:55:01 LavaGrenade NetworkManager[575]: <warn>  [1648508101.4711] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:03 LavaGrenade NetworkManager[575]: <warn>  [1648508103.4743] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:05 LavaGrenade NetworkManager[575]: <warn>  [1648508105.4775] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:05 LavaGrenade rtkit-daemon[1195]: Supervising 13 threads of 8 processes of 1 users.
Mar 28 15:55:07 LavaGrenade NetworkManager[575]: <warn>  [1648508107.4797] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:09 LavaGrenade NetworkManager[575]: <warn>  [1648508109.4831] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:11 LavaGrenade NetworkManager[575]: <warn>  [1648508111.4835] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:13 LavaGrenade NetworkManager[575]: <warn>  [1648508113.4851] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:55:23 LavaGrenade NetworkManager[575]: <warn>  [1648508123.4930] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:25 LavaGrenade NetworkManager[575]: <warn>  [1648508125.4965] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:27 LavaGrenade NetworkManager[575]: <warn>  [1648508127.4962] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:29 LavaGrenade NetworkManager[575]: <warn>  [1648508129.4974] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:31 LavaGrenade NetworkManager[575]: <warn>  [1648508131.4988] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:33 LavaGrenade NetworkManager[575]: <warn>  [1648508133.5000] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:35 LavaGrenade NetworkManager[575]: <warn>  [1648508135.5014] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:55:45 LavaGrenade NetworkManager[575]: <warn>  [1648508145.5102] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:47 LavaGrenade NetworkManager[575]: <warn>  [1648508147.5106] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:49 LavaGrenade NetworkManager[575]: <warn>  [1648508149.5130] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:51 LavaGrenade NetworkManager[575]: <warn>  [1648508151.5136] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:53 LavaGrenade NetworkManager[575]: <warn>  [1648508153.5157] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:55 LavaGrenade NetworkManager[575]: <warn>  [1648508155.5190] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:55:57 LavaGrenade NetworkManager[575]: <warn>  [1648508157.5193] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:56:07 LavaGrenade NetworkManager[575]: <warn>  [1648508167.5303] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:09 LavaGrenade NetworkManager[575]: <warn>  [1648508169.5324] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:11 LavaGrenade NetworkManager[575]: <warn>  [1648508171.5353] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:13 LavaGrenade NetworkManager[575]: <warn>  [1648508173.5366] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:15 LavaGrenade NetworkManager[575]: <warn>  [1648508175.5400] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:17 LavaGrenade NetworkManager[575]: <warn>  [1648508177.5419] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:19 LavaGrenade NetworkManager[575]: <warn>  [1648508179.5427] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
Mar 28 15:56:29 LavaGrenade NetworkManager[575]: <warn>  [1648508189.5463] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:31 LavaGrenade NetworkManager[575]: <warn>  [1648508191.5495] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:33 LavaGrenade NetworkManager[575]: <warn>  [1648508193.5499] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:35 LavaGrenade NetworkManager[575]: <warn>  [1648508195.5532] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:37 LavaGrenade NetworkManager[575]: <warn>  [1648508197.5555] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:39 LavaGrenade NetworkManager[575]: <warn>  [1648508199.5566] platform-linux: do-add-ip6-address[2: fe>
Mar 28 15:56:41 LavaGrenade NetworkManager[575]: <warn>  [1648508201.5589] ipv6ll[3168f26c4187dc41,ifindex=2]: chan>
dress Detection failures (back off)
Curious, what are you using in your Grub default? You might have to add the pcie_aspm=off option, if the Nvidia card is the culprit for your random freezes.
I’m not sure if it’s the Nvidia card or not, I’ve just heard that they tend to not play nicely with Linux in general. How would I go about adding the pcie_aspm=off option to my grub?
Are you familiar with using nano?
If so, edit the file /etc/default/grub and add the option pcie_aspm=off to the GRUB_CMDLINE_LINUX_DEFAULT line.
Then update grub.
sudo update-grub
In addition to this, try using the Nvidia card at “Prefer Maximum Performance” at all times, and see if it spares the random freezes.
Two ideas:
  • do you have any sort of overclocking applied (RAM, CPU, video card)?
  • can you try to disable IPV6 completely?
Also, can you post a proper journal log? Yours is like a copy paste from terminal, this is not good. Export to a file directly, example sudo journalctl -p3 -xb-1 > journal_log will generate a file in the current working directory of terminal (usually your home folder when you open the terminal), this command is to collect from previous boot (-1) the errors in journal.
Thank you both for the advice! I have implemented Winnie’s advice and will update on whether that has fixed the issue. I have also created the journal file requested by Omano. I don’t have any overclocking currently applied to any system components. I will see if I can to disable IPV6, I will have to look up how as I am still learning where all the settings live.
I think I got the IPV6 disabled, I just selected “method: disabled” in the KDE system settings, under the connections tab. Please let me know if that is not the proper way to disable that.
Mar 28 21:38:48 LavaGrenade kernel: x86/cpu: SGX disabled by BIOS.
Mar 28 21:38:49 LavaGrenade systemd[1]: Failed to start Apply Kernel Variables.
░░ Subject: A start job for unit systemd-sysctl.service has failed
░░ Defined-By: systemd
░░ A start job for unit systemd-sysctl.service has finished with a failure.
░░ The job identifier is 28 and the job result is failed.
Mar 28 21:40:57 LavaGrenade kernel: ntfs3: Unknown parameter 'windows_names'
Unfortunately, it does not look like my problem has been solved with those fixes as I just had another freeze. I printed another journal using the command provided by Omano and will attach it below.
I’m going to look up the “system-sysctl.service” and see if I can find anything about that as it is in both of the journal printouts. Thank you again for your advice!
Mar 28 21:53:09 LavaGrenade kernel: x86/cpu: SGX disabled by BIOS.
Mar 28 21:53:10 LavaGrenade systemd[1]: Failed to start Apply Kernel Variables.
░░ The job identifier is 11 and the job result is failed.
Mar 28 21:53:26 LavaGrenade kernel: ntfs3: Unknown parameter 'windows_names'
I see multiple errors, that may not be related to your problem, but still it should be fixed. Please post your /etc/default/grub file as it has maybe errors. Please also post your /etc/fstab file as it definitely has errors.
For the IPV6 it is possible to disable it in the grub config file, by adding the ipv6.disable=1 parameter. I think disabling it in Network Manager will not fully disable it, but I’m not sure. The IPV6 suggestion was because you had a ton of lines regarding that in your terminal copy/paste journal, and the last line, which probably was missing a piece, lead me to issues on Google regarding IPV6 by assuming the first cut word was “address”.
Do I just add the ipv6.disable=1 anywhere in the grub file? I have attached my current grub file and my fstab file below. Thank you
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=ad465df4-9fce-428f-8caa-2316c668b386 udev.log_priority=3 pcie_aspm=off"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
#GRUB_SAVEDEFAULT="true"
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=bac419f9-11d4-41cb-9966-76749dcaa343 /              btrfs   subvol=/@,defaults,discard=async 0 0
UUID=bac419f9-11d4-41cb-9966-76749dcaa343 /home          btrfs   subvol=/@home,defaults,discard=async 0 0
UUID=bac419f9-11d4-41cb-9966-76749dcaa343 /var/cache     btrfs   subvol=/@cache,defaults,discard=async 0 0
UUID=bac419f9-11d4-41cb-9966-76749dcaa343 /var/log       btrfs   subvol=/@log,defaults,discard=async 0 0
UUID=ad465df4-9fce-428f-8caa-2316c668b386 swap           swap    defaults,noatime 0 0
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
Something is off regarding the NTFS3 error
There is no trace of the NTFS disk in your fstab file. Are you manually mounting the NTFS disk?
For the IPV6 parameter, it goes with all the other parameters in the GRUB_CMDLINE_LINUX_DEFAULT line (and after that, you do an sudo update-grub command to apply the parameter).
By curiosity, did you have the error about sysctl service before you added the aspm parameter to the grub config? Check by looking at previous boots (change the -1 in the journalctl command to -5 or whatever the number of reboot you did before adding the parameter).
Also, maybe check what it says when you do a systemctl status systemd-sysctl.service command, maybe it will spit the exact erroneous parameter it fails to load/apply.
I am not manually mounting an NTFS disk. However, I have 2 additional internal HDD’s that have data from when I switched from windows. They show up in my files automatically though so I just assumed they worked. I was told that if I changed their file system I would lose the data so they are still NTFS.
I have had the systemctl issue before I added the aspm parameter to the grub file. It shows up on boot with an error reading “failed to start Apply Kernal Variables”, I have attached the status requested below. Thank you
I have also added the IPV6 parameter to the grub file
systemd-sysctl.service - Apply Kernel Variables
     Loaded: loaded (/usr/lib/systemd/system/systemd-sysctl.service; static)
     Active: failed (Result: exit-code) since Mon 2022-03-28 22:39:54 PDT; 51min ago
       Docs: man:systemd-sysctl.service(8)
             man:sysctl.d(5)
    Process: 513 ExecStart=/usr/lib/systemd/systemd-sysctl (code=exited, status=1/FAILURE)
   Main PID: 513 (code=exited, status=1/FAILURE)
        CPU: 4ms
Mar 28 22:39:54 LavaGrenade systemd[1]: Starting Apply Kernel Variables...
Mar 28 22:39:54 LavaGrenade systemd-sysctl[513]: /etc/sysctl.d/99-sysctl.conf:2: Line is not an assignment, ignorin>
Mar 28 22:39:54 LavaGrenade systemd[1]: systemd-sysctl.service: Main process exited, code=exited, status=1/FAILURE
Mar 28 22:39:54 LavaGrenade systemd[1]: systemd-sysctl.service: Failed with result 'exit-code'.
Mar 28 22:39:54 LavaGrenade systemd[1]: Failed to start Apply Kernel Variables.
Can you list the content of /etc/sysctl.d/ (the list of file, and the content for each file)?
I have one file name 99-sysctl.conf
It contains
sudo update-grub
kernel.sysrq=1
OK. Remove everything but the last line in this file. It should fix the sysctl issue.
It is weird that it auto mounts the NTFS disks with the NTFS3 driver, and with invalid parameters from the old ntfs-3g driver :\ Something to look at later I think, maybe should disable the auto mount, or reconfigure the auto mount, or even better manually adding the mount in the fstab file.
Yes, because to change the file system you would need to format them, obviously, so you would need to do backups of the files you want to keep first before formatting the disk.
I have edited the 99-sysctl.conf file with just the last line. I will look up how to add the mounting in the fstab file. Thank you!
Here you go Fstab - Manjaro
Here for example how I configured my NTFS mounts (maybe not the real proper way, but it works for me, (I created the /media/xxx/ mount points manually and gave ownership to my user initially, as I’m using the computer as single user it is OK).
UUID=1ECAE670CAE6441D   /media/SSD_500Go   ntfs3   defaults,noatime,uid=omano,gid=omano 0 0
UUID=2220AFC020AF98F5   /media/Windows10   ntfs3   defaults,noatime,uid=omano,gid=omano,noauto 0 0
UUID=186CF07D6CF056CA   /media/HDD_500Go   ntfs3   defaults,noatime,uid=omano,gid=omano,noauto 0 0
The SSD_500Go disk is mounted on boot, the two other ones are not (noauto), and are mounted with these options when I access them from the file manager.
But now I am out of ideas if it still crashes. Anyway I don’t think the sysctl error, or not NTFS3 wrong mount options were the culprit, but it is still good to fix that anyway to discard them from the equation. The IPV6 was my best bet, test and report.
Thank you! I really appreciate all the help! The example Fstab lines make it much easier to understand. I have added the IPV6 line to the grub file and will update on whether the issue persists or goes away.
Since you made the updates, can you paste the output of:
cat /proc/cmdline
Did you make sure that Nvidia is set to “Prefer Maximum Performance”? (It will revert to the default of “Adaptive” with each reboot and logout.)
Yep! I haven’t experience any freezing since applying the updates. Thank you both so much for your help!
BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64 root=UUID=bac419f9-11d4-41cb-9966-76749dcaa343 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor resume=UUID=ad465df4-9fce-428f-8caa-2316c668b386 udev.log_priority=3 pcie_aspm=off ipv6.disable=1
So I’m a little bit confused, what did fix the issue in the end? Do you even know? From all the posts I can’t really find what solved it :rofl:
