Hi
when using Manjaro on a Huawei Matebook 14 D and doing some light tasks, the system sometimes freezes and the fans turn up to 100%. If this happens, a connection via ssh is not possible, but the machine responds to pings.
Output from uname -a
Linux DN-Laptop 5.10.56-1-MANJARO #1 SMP PREEMPT Thu Aug 5 10:51:27 UTC 2021 x86_64 GNU/Linux
The laptop has a Ryzen 2500u, 8 GB RAM. I am using the video-linux driver for the graphics card. Here is the output from journalctl -b -1 -e
✘ daniel@DN-Laptop ~ journalctl -b -1 -e
Aug 12 15:25:33 DN-Laptop systemd[1]: Starting Locale Service...
Aug 12 15:25:33 DN-Laptop kernel: audit: type=1334 audit(1628774733.982:183): prog-id=36 op=LOAD
Aug 12 15:25:33 DN-Laptop kernel: audit: type=1334 audit(1628774733.982:184): prog-id=37 op=LOAD
Aug 12 15:25:33 DN-Laptop kernel: audit: type=1334 audit(1628774733.982:185): prog-id=38 op=LOAD
Aug 12 15:25:34 DN-Laptop dbus-daemon[477]: [system] Successfully activated service 'org.freedesktop.locale1'
Aug 12 15:25:34 DN-Laptop systemd[1]: Started Locale Service.
Aug 12 15:25:34 DN-Laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd>
Aug 12 15:25:34 DN-Laptop kernel: audit: type=1130 audit(1628774734.025:186): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="sy>
Aug 12 15:26:00 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-66 noise=9999 txrate=650000
Aug 12 15:26:07 DN-Laptop systemd[1]: systemd-localed.service: Deactivated successfully.
Aug 12 15:26:07 DN-Laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/>
Aug 12 15:26:07 DN-Laptop kernel: audit: type=1131 audit(1628774767.108:187): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="sy>
Aug 12 15:26:07 DN-Laptop audit: BPF prog-id=38 op=UNLOAD
Aug 12 15:26:07 DN-Laptop audit: BPF prog-id=37 op=UNLOAD
Aug 12 15:26:07 DN-Laptop audit: BPF prog-id=36 op=UNLOAD
Aug 12 15:26:07 DN-Laptop kernel: audit: type=1334 audit(1628774767.258:188): prog-id=38 op=UNLOAD
Aug 12 15:26:07 DN-Laptop kernel: audit: type=1334 audit(1628774767.258:189): prog-id=37 op=UNLOAD
Aug 12 15:26:07 DN-Laptop kernel: audit: type=1334 audit(1628774767.258:190): prog-id=36 op=UNLOAD
Aug 12 15:31:10 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=780000
Aug 12 15:31:10 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=780000
Aug 12 15:32:16 DN-Laptop plasmashell[1270]: libkcups: Renew-Subscription last error: 0 successful-ok
Aug 12 15:34:13 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-68 noise=9999 txrate=650000
Aug 12 15:34:13 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-68 noise=9999 txrate=650000
Aug 12 15:34:59 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-68 noise=9999 txrate=650000
Aug 12 15:34:59 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-68 noise=9999 txrate=650000
Aug 12 15:38:57 DN-Laptop dbus-daemon[477]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.serv>
Aug 12 15:38:57 DN-Laptop audit: BPF prog-id=39 op=LOAD
Aug 12 15:38:57 DN-Laptop audit: BPF prog-id=40 op=LOAD
Aug 12 15:38:57 DN-Laptop audit: BPF prog-id=41 op=LOAD
Aug 12 15:38:57 DN-Laptop systemd[1]: Starting Locale Service...
Aug 12 15:38:57 DN-Laptop kernel: audit: type=1334 audit(1628775537.425:191): prog-id=39 op=LOAD
Aug 12 15:38:57 DN-Laptop kernel: audit: type=1334 audit(1628775537.425:192): prog-id=40 op=LOAD
Aug 12 15:38:57 DN-Laptop kernel: audit: type=1334 audit(1628775537.425:193): prog-id=41 op=LOAD
Aug 12 15:38:57 DN-Laptop dbus-daemon[477]: [system] Successfully activated service 'org.freedesktop.locale1'
Aug 12 15:38:57 DN-Laptop systemd[1]: Started Locale Service.
Aug 12 15:38:57 DN-Laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd>
Aug 12 15:38:57 DN-Laptop kernel: audit: type=1130 audit(1628775537.465:194): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="sy>
Aug 12 15:39:27 DN-Laptop systemd[1]: systemd-localed.service: Deactivated successfully.
Aug 12 15:39:27 DN-Laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/>
Aug 12 15:39:27 DN-Laptop kernel: audit: type=1131 audit(1628775567.498:195): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="sy>
Aug 12 15:39:27 DN-Laptop audit: BPF prog-id=41 op=UNLOAD
Aug 12 15:39:27 DN-Laptop audit: BPF prog-id=40 op=UNLOAD
Aug 12 15:39:27 DN-Laptop audit: BPF prog-id=39 op=UNLOAD
Aug 12 15:39:27 DN-Laptop kernel: audit: type=1334 audit(1628775567.712:196): prog-id=41 op=UNLOAD
Aug 12 15:39:27 DN-Laptop kernel: audit: type=1334 audit(1628775567.712:197): prog-id=40 op=UNLOAD
Aug 12 15:39:27 DN-Laptop kernel: audit: type=1334 audit(1628775567.712:198): prog-id=39 op=UNLOAD
Aug 12 15:40:29 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=650000
Aug 12 15:40:29 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=650000
Aug 12 15:42:32 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-68 noise=9999 txrate=650000
Aug 12 15:42:32 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-68 noise=9999 txrate=650000
Aug 12 15:45:08 DN-Laptop upowerd[1323]: energy 51,733200 bigger than full 51,687600
Aug 12 15:39:27 DN-Laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termi>
Aug 12 15:39:27 DN-Laptop kernel: audit: type=1131 audit(1628775567.498:195): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/sys>
Aug 12 15:46:52 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=325000
Aug 12 15:46:52 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=325000
Aug 12 15:47:19 DN-Laptop kdeconnectd[1298]: QMetaObject::invokeMethod: No such method KIO::StoredTransferJob::slotDataReqFromDevice()
Aug 12 15:47:20 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-66 noise=9999 txrate=650000
Aug 12 15:47:20 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-66 noise=9999 txrate=650000
Aug 12 15:47:23 DN-Laptop kwin_x11[1207]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41600, resource id: 35652149, major code: 19 (DeleteProperty), minor code: 0
Aug 12 15:47:23 DN-Laptop kwin_x11[1207]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41603, resource id: 35652149, major code: 19 (DeleteProperty), minor code: 0
Aug 12 15:47:23 DN-Laptop kwin_x11[1207]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41604, resource id: 35652149, major code: 18 (ChangeProperty), minor code: 0
Aug 12 15:47:23 DN-Laptop kwin_x11[1207]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41605, resource id: 35652149, major code: 19 (DeleteProperty), minor code: 0
Aug 12 15:47:23 DN-Laptop kwin_x11[1207]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41606, resource id: 35652149, major code: 19 (DeleteProperty), minor code: 0
Aug 12 15:47:23 DN-Laptop kwin_x11[1207]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41607, resource id: 35652149, major code: 19 (DeleteProperty), minor code: 0
Aug 12 15:47:23 DN-Laptop kwin_x11[1207]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41608, resource id: 35652149, major code: 7 (ReparentWindow), minor code: 0
Aug 12 15:47:23 DN-Laptop kwin_x11[1207]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41609, resource id: 35652149, major code: 6 (ChangeSaveSet), minor code: 0
Aug 12 15:47:23 DN-Laptop kwin_x11[1207]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41610, resource id: 35652149, major code: 2 (ChangeWindowAttributes), minor code:>
Aug 12 15:47:23 DN-Laptop kwin_x11[1207]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41611, resource id: 35652149, major code: 10 (UnmapWindow), minor code: 0
Aug 12 15:50:48 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=650000
Aug 12 15:50:48 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=650000
Aug 12 15:51:19 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=650000
Aug 12 15:51:19 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=650000
Aug 12 15:51:48 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=650000
Aug 12 15:51:48 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=650000
Aug 12 15:52:14 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=780000
Aug 12 15:52:14 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=780000
Aug 12 15:53:01 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=650000
Aug 12 15:53:01 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=650000
Aug 12 15:53:35 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=650000
...skipping...
Aug 12 15:57:23 DN-Laptop wpa_supplicant[673]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-74 noise=9999 txrate=520000
Aug 12 15:57:29 DN-Laptop plasmashell[1270]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detecte>
Aug 12 15:57:39 DN-Laptop kdeconnectd[1298]: kdeconnect.plugin.contacts: handleResponseVCards: Unable to open "/home/daniel/.local/share/kpeoplevcard/kdeconnect-3ad64b7a8f3a3a41/3789r2054>
Aug 12 15:57:39 DN-Laptop kdeconnectd[1298]: kdeconnect.plugin.contacts: handleResponseVCards: Unable to open "/home/daniel/.local/share/kpeoplevcard/kdeconnect-3ad64b7a8f3a3a41/1220eac55>
Aug 12 15:57:39 DN-Laptop kdeconnectd[1298]: kdeconnect.plugin.contacts: handleResponseVCards: Unable to open "/home/daniel/.local/share/kpeoplevcard/kdeconnect-3ad64b7a8f3a3a41/3585r2179>
Aug 12 15:57:39 DN-Laptop kdeconnectd[1298]: kdeconnect.plugin.contacts: handleResponseVCards: Unable to open "/home/daniel/.local/share/kpeoplevcard/kdeconnect-3ad64b7a8f3a3a41/3789r1912>
Aug 12 15:58:15 DN-Laptop kwin_x11[1207]: file:///usr/share/kwin/aurorae/MenuButton.qml:11: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
