Hey, thank you @SomeGuy for the help! Yeah, I mostly wanted to know if there was a way to get more details about the crashes, cause even though I am no expert the logs had very little or no info at all.
So I knew it was not going to be easy.
But regarding your questions, I had used Ubuntu before, can’t remember exactly but probably 20.04 LTS. I tried Kubuntu too, cause I prefer KDE but that was really buggy. So mostly Ubuntu and it crashed sometimes but way less frequently. To the point I never really cared that much.
Hardware was almost identical. Only difference is the KVM USB switch that I have now. Everything else I had already. Mouse has changed but yesterday it was being used by the laptop, not the PC when it crashed so…
Graphics card has been upgraded recently, but Manjaro was crashing with the old one too so I don’t think that was the problem.
I do have Windows installed too, mostly for gaming but I don’t use it that much. But when I use it it’s fine, or as fine as windows can be hehe. So, no crashes.
I will paste the output from inxi -Fazy at the end. Most of the hardware is pretty normal I would say. And the things that could be a bit special like a bluetooth usb and the network card are disabled all the time. They are connected but wifi is disabled, bluetooth is disabled. I have removed the bluetooth thingy for now anyways, see how long it takes before the next crash.
Also I have removed all the plasmoids? widgets? that I had on the desktop with the CPU/GPU/network/disk usage graphs. Would be surprising if those actually could freeze the entire system I guess, but at this point I am just getting rid of everything I can think of before I give up on Manjaro.
I could try and physically remove the network card too, as I don’t use it.
And also the KVM USB switch but that would be a pain in the ass, having to connect keyboard, mouse and webcam to the laptop and back every single day…
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=63a90eaa-1325-4dae-8428-9feb978e9dbd rw quiet apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: AB350 Pro4 serial: <superuser required>
UEFI: American Megatrends v: P4.90 date: 06/14/2018
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001137
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1671 high: 3383 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1376 2: 1445
3: 3383 4: 2878 5: 1356 6: 1392 7: 1374 8: 1372 9: 1373 10: 1371 11: 1373
12: 1369 bogomips: 76668
disabled, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Gigabyte
driver: amdgpu v: kernel bus-ID: 28:00.0 chip-ID: 1002:73bf class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4.1:3 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DisplayPort-0 res: 2560x1440 dpi: 93
size: 697x392mm (27.4x15.4") diag: 800mm (31.5")
OpenGL: renderer: AMD Radeon RX 6800 XT (SIENNA_CICHLID DRM 3.42.0
5.15.7-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 28:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 2a:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Device-1: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
vendor: ASUSTeK driver: rtl8821ae v: kernel port: e000 bus-ID: 23:00.0
chip-ID: 10ec:8812 class-ID: 0280
IF: wlp35s0 state: down mac: <filter>
vendor: ASRock driver: r8168 v: 8.049.02-NAPI modules: r8169 port: c000
bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 57.2 GiB (6.1%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 45.9 C scheme: GPT
ID-1: / raw-size: 93.13 GiB size: 91.11 GiB (97.83%) used: 57.17 GiB (62.7%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
used: 33.9 MiB (35.3%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 46.0 C mem: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 300 Uptime: 2h 37m wakeups: 0 Memory: 15.62 GiB
used: 3.62 GiB (23.2%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1371 pacman: 1369 lib: 361 flatpak: 0 snap: 2
Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
