Hi guys,
I installed the Manjaro 21.0 Gnome version. It works well and I keep Gnome 3.38 version (I don’t upgrade some packages to Gnome 40). My system has the last stable updates without Gnome 40 Apps stable updates.
My problem is that the system freeze sometimes. As I’ve got a Baytrail hardware, I enabled the ‘intel_idle.max_cstate=1’ option in /etc/default/grub. Despite it, the system freezes sometimes. I don’t know why it happens. The processor is an Intel.
Have you got an idea of the problem ? Is there a workaround to avoid it ?
Thanks for your help.
Note: I’ve got 2Gb ram, Wayland is default, the memory is 50% used by default (1.0Gb on 1.9Gb). I enabled zram with the help of systemd-swap (no swap partition made). Kernel 5.10.x is used.
