Random Freeze after updating to Gnome 48
Hi,
This is my first post as I just registered. I have installed Manjaro Gnome on my newly purchased Lenovo laptop. Everything was working silky smooth till yesterday when I found there is an update for the OS. I updated the OS to Gnome 48 and since yesterday my laptop freezes at boot randomly. I have to force shutdown my laptop by long pressing the power button and start again, I have no idea what is wrong. Here is the output of inix -Fazy:
  Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=b46cd848-d6d2-4003-810d-f8247dc1238e rw quiet splash apparmor=1
  Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 48.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 21MR v: ThinkBook 14 G7 IML
    serial: <superuser required> Chassis: type: 10 v: ThinkBook 14 G7 IML
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    part-nu: LENOVO_MT_21MR_BU_idea_FM_ThinkBook 14 G7 IML
    uuid: <superuser required> UEFI: LENOVO v: P3CN46WW date: 12/27/2024
  ID-1: BAT0 charge: 47.8 Wh (79.7%) condition: 60.0/60.0 Wh (100.0%)
    volts: 15.6 min: 15.4 model: BYD2022 L22B4PE0 type: Li-poly serial: <filter>
    status: not charging cycles: 3
  Device-1: hidpp_battery_0 model: Logitech Signature M650 L Mouse
    serial: <filter> charge: 40% rechargeable: yes status: discharging
  Info: model: Intel Core Ultra 7 155H bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x20
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
    st: 10 smt: enabled cache: L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64
    KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 400 min/max: 400/4500:4800:3800:2500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
    bogomips: 131824
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Lenovo
    driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
    built: 2023+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
  Device-2: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 30c9:00c5
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1457 built: 2022 res: 1920x1200
    dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4") diag: 355mm (14")
    ratio: 16:10 modes: 1920x1200
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
    device-ID: 8086:7d55 memory: 14.97 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop
  Device-1: Intel Meteor Lake-P HD Audio vendor: Lenovo
    driver: sof-audio-pci-intel-mtl
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
    chip-ID: 8086:7e28 class-ID: 0401
  API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
  Device-2: Intel vendor: Lenovo driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:550b class-ID: 0200
  IF: eno0 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 1.38 TiB used: 192.03 GiB (13.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SK Hynix model: HFS512GEJ4X112N
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 51040C31 temp: 36.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 32.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 107.38 GiB (22.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4
    used: 6.3 MiB (2.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
  System Temperatures: cpu: 42.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 32 GiB note: est. available: 30.66 GiB used: 2.66 GiB (8.7%)
  Processes: 415 Power: uptime: 44m states: freeze,mem,disk suspend: s2idle
    image: 12.25 GiB services: gsd-power, power-profiles-daemon, upowerd
  Packages: pm: pacman pkgs: 1317 libs: 363 tools: gnome-software,pamac
    pm: flatpak pkgs: 0 Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: gnome-terminal inxi: 3.3.37
