Hi! I have a problem where when I write files sometimes the whole folder where I wrote the files becomes ‘Read Only’ and some of the files disappear. This happens very frequently and I don’t know why.
It is 100% not a hardware issue as it happens on multiple drives I have and the SMART on them is perfect. I’m so sick of losing hours and hours of progess I don’t understand why this happens. Please help!
can ou report
sudo parted -l
df -Th
sudo journalctl -p3
filesystem issues is not an exact science - but usually it boils down to
- hardware
- filesystem
- configuration
filesystem permissions doesn’t change - just like that … for that to happen the kernel has to have experienced a lot of write errors - which may trigger this - but it is rare
If the files disappear they may have only existed in cache and if cache has been corrupted the cache is cleared
Since we are at the cache - cache is memory and if your RAM is generating the errors - then it may explain why files disappear.
sudo parted -l
Model: ATA Samsung SSD 860 (scsi)
Disk /dev/sda: 1000GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 1075MB 1074MB fat32 boot, esp
2 1075MB 64.0GB 62.9GB ext4
3 64.0GB 1000GB 936GB
Model: ATA WDC WD30EZRZ-00G (scsi)
Disk /dev/sdb: 3001GB
Sector size (logical/physical): 512B/4096B
Disk Flags:
1 1049kB 2463GB 2463GB
2 2463GB 3001GB 538GB ntfs WindowsFiles msftdata
Model: ATA WDC WD40EFAX-68J (scsi)
Disk /dev/sdc: 4001GB
Disk Flags:
1 1049kB 4001GB 4001GB
Disk /dev/sdd: 4001GB
Disk Flags:
Model: Seagate USB (scsi)
Disk /dev/sde: 1000GB
Disk Flags:
1 1049kB 1000GB 1000GB
Model: ADATA SX8200PNP (nvme)
Disk /dev/nvme0n1: 2048GB
Disk Flags:
1 1049kB 2048GB 2048GB ext4
Error: /dev/md0: unrecognised disk label
Model: Linux Software RAID Array (md)
Disk /dev/md0: 4001GB
Partition Table: unknown
Disk Flags:
Model: NE-256 (nvme)
Disk /dev/nvme1n1: 256GB
Disk Flags:
1 1049kB 256GB 256GB ntfs Basic data partition msftdata
df - Th
Filesystem Type Size Used Avail Use% Mounted on
dev devtmpfs 63G 0 63G 0% /dev
run tmpfs 63G 2.1M 63G 1% /run
/dev/sda2 ext4 58G 47G 7.8G 86% /
tmpfs tmpfs 63G 106M 63G 1% /dev/shm
tmpfs tmpfs 63G 25M 63G 1% /tmp
/dev/sda1 vfat 1022M 26M 997M 3% /boot/efi
/dev/mapper/ehome ext4 858G 597G 218G 74% /home
/dev/mapper/Main2 ext4 2.3T 1.8T 321G 86% /media/manjaro/Main2
/dev/mapper/Storage4tb ext4 3.6T 2.4T 1.1T 70% /media/manjaro/Storage4tb
tmpfs tmpfs 13G 64K 13G 1% /run/user/1000
/dev/nvme0n1p1 ext4 1.9T 974G 808G 55% /run/media/manjaro/NVME_2tb
sudo journalctl -p3
just returns internet browser coredump, probably unrelated
sudo journalctl -p1
Dec 27 02:58:12 dmitriy-allseries systemd[1]: Caught <SEGV> from unknown sender process.
Dec 27 02:58:12 dmitriy-allseries systemd[1]: Caught <SEGV>, dumped core as pid 174056.
Dec 27 02:58:12 dmitriy-allseries systemd[1]: Freezing execution.
-- Boot bc19503b6dd9450293f916cbe6044c1d --
Jan 28 21:08:21 dmitriy-allseries kernel: BUG: Bad page map in process qbittorrent pte:1000000000000 pmd:fbf83e067
Jan 28 21:08:21 dmitriy-allseries kernel: addr:00007ea6a9f7e000 vm_flags:0c0000d1 anon_vma:0000000000000000 mapping:ffff946a1373b630 index:7d37e
Jan 28 21:08:21 dmitriy-allseries kernel: file:module-datasets.tar.zst fault:filemap_fault mmap:ext4_file_mmap [ext4] read_folio:ext4_read_folio [ext4]
Jan 28 21:08:22 dmitriy-allseries kernel: BUG: Bad rss-counter state mm:00000000913fda6e type:MM_SWAPENTS val:-1
-- Boot 78055f1ae1294a55afaa1709cff693ee --
Jan 31 16:21:14 dmitriy-allseries kernel: EXT4-fs (dm-2): failed to convert unwritten extents to written extents -- potential data loss! (inode 58735447, error -30)
-- Boot ccf9b7539a614f88a6cef9c16e8d6dfe --
Feb 09 20:56:21 dmitriy-allseries kernel: Fixing recursive fault but reboot is needed!
Feb 09 20:56:21 dmitriy-allseries kernel: BUG: kernel NULL pointer dereference, address: 0000000000000000
-- Boot 2b594b010a534f9e835cd5c6aafe29a8 --
Feb 10 18:08:56 dmitriy-allseries sudo[5500]: manjaro : 1 incorrect password attempt ; TTY=pts/0 ; PWD=/home/manjaro ; USER=root ; COMMAND=/usr/bin/dmesg
As you stated
The other explanation is RAM
Perhaps it could be RAM yea. Is there any way to tell for sure?
reboot and run memtest+ from grub
That is understandable.
Most users think that sourcecode management tools like git is only for coding - it’s not - it can be used for all kinds of versioning - especially where disk content changes often.
One has to consider if the data one is working with - if they contain proprietary stuff or personal information.
I cant really use git when it’s terrabytes of training data for AI. Also I think it was ram, I ran the test and it says Fail.
It was probably a faulty XMP profile combined with the retarded nvidia heatsink design that pushes all hot air right onto ram sticks
It would be nice to know where those /dev/mapper/xxx devices are mounted from, eg. what their backing file system locations are…fe:
Shows he has mounted his SSD inside the /run dir which is by default a tmpfs eg a directory inside RAM, which is ofcourse a BAD mount point…
I unmounted it after it got corruption. Thunar mounts stuff under /run/media by default if u click on a disk
No matter if thunar does that, it’s still bad, it should mount under /media/username/xxx…
Anyhow how about the info about the /dev/mapper/xxx mounts…
(Plus you never told us on which filesystem / mount-point the problem occurred…)
