Random crashes without warning
My laptop keeps crashing randomly and without warning. I first noticed it after switching to the testing branch with the July Gnome 40 release.
Things I have tried:
  • Reinstalled Manjaro: Ensured I was no longer on the testing branch but it didn’t help.
  • Use LTS kernel: didn’t help, crashes still happen.
Things I didn’t try:
  • Use Windows to narrow down if it’s a hardware issue. Can’t bear to use windows anymore unless I am gaming :sweat_smile:
Some logs:
inxi
  Kernel: 5.13.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=a78a2b34-6b4a-4b3f-b902-6a2989c51e5e rw apparmor=1
  Console: tty pts/0 wm: gnome-shell DM: GDM 40.1 Distro: Manjaro Linux
  base: Arch Linux
  Type: Laptop System: LENOVO product: 81NW v: Lenovo IdeaPad S740-15IRH Touch
  serial: <filter> Chassis: type: 10 v: Lenovo IdeaPad S740-15IRH Touch
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
  UEFI: LENOVO v: BKCN23WW(V1.05) date: 03/16/2021
  ID-1: BAT1 charge: 32.0 Wh (49.9%) condition: 64.1/69.0 Wh (92.9%)
  volts: 15.1 min: 15.4 model: 0x53 0x75 0x6E 0x77 0x6F 0x64 0x PABAS0241231
  type: Li-ion serial: <filter> status: Discharging cycles: 187
  RAM: total: 15.35 GiB used: 4.07 GiB (26.5%)
  Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
  note: est.
  Device-1: ChannelA-DIMM0 size: 8 GiB speed: 2667 MT/s type: DDR4
  detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Ramaxel
  part-no: RMSA3260ME78HAF-2666 serial: <filter>
  Device-2: ChannelB-DIMM0 size: 8 GiB speed: 2667 MT/s type: DDR4
  Info: 8-Core model: Intel Core i9-9880H socket: BGA1440 (U3E1) note: check
  bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
  model-id: 9E (158) stepping: D (13) microcode: EA cache: L2: 16 MiB
  bogomips: 73625
  Speed: 800 MHz min/max: 800/4800 MHz base/boost: 2178/8300 volts: 0.8 V
  ext-clock: 100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
  6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800
  16: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
  popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap
  smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: srbds mitigation: TSX disabled
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
  driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0302
  Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:2
  chip-ID: 5986:114e class-ID: 0e02 serial: <filter>
  Display: server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: intel,modesetting,nouveau alternate: fbdev,nv,vesa
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.6
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo
  driver: sof-audio-pci-intel-cnl
  alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  chip-ID: 8086:a348 class-ID: 0401
  Sound Server-1: ALSA v: k5.13.8-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: no
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  port: 4000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
  Local Storage: total: 953.87 GiB used: 28.59 GiB (3.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000L2
  size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: 3L1QEXF7 temp: 38.9 C scheme: GPT
  ID-1: / raw-size: 349.48 GiB size: 342.92 GiB (98.13%)
  used: 28.57 GiB (8.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
  maj-min: 259:5 label: N/A uuid: a78a2b34-6b4a-4b3f-b902-6a2989c51e5e
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 28.9 MiB (11.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
  maj-min: 259:1 label: SYSTEM_DRV uuid: 6CE6-3DA4
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
  uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 603.15 GiB fs: ntfs
  label: Windows-SSD uuid: AC68E6F068E6B86A
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: WINRE_DRV
  uuid: A0D2E77DD2E755D6
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-4:2 info: Acer Integrated Camera type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:114e
  Device-2: 1-5:3 info: Synaptics type: <vendor specific> driver: N/A
  interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00be
  class-ID: ff00 serial: <filter>
  Device-3: 1-14:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 50.0 C mobo: N/A gpu: nouveau temp: 42.0 C
  Processes: 374 Uptime: 20m wakeups: 4119 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: 1200 pacman: 1193 lib: 299
  flatpak: 0 snap: 7 Shell: Bash (sudo) v: 5.1.8 running-in: tilix
  inxi: 3.3.06
dmesg
[    0.000000] microcode: microcode updated early to revision 0xea, date = 2021-01-05
[    0.000000] Linux version 5.13.8-1-MANJARO (builduser@development) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Thu Aug 5 09:47:52 UTC 2021
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=a78a2b34-6b4a-4b3f-b902-6a2989c51e5e rw apparmor=1 security=apparmor udev.log_priority=3
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000279f6fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000279f7000-0x00000000282f6fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000282f7000-0x000000003e50dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000003e50e000-0x000000003e70dfff] type 20
[    0.000000] BIOS-e820: [mem 0x000000003e70e000-0x000000003f10dfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000003f10e000-0x000000003fc8dfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000003fc8e000-0x000000003fd0dfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000003fd0e000-0x000000003fd0efff] usable
[    0.000000] BIOS-e820: [mem 0x000000003fd0f000-0x000000004d7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff600000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000004b07fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.60 by INSYDE Corp.
[    0.000000] efi: ACPI=0x3fd0d000 ACPI 2.0=0x3fd0d014 TPMFinalLog=0x3f0e5000 SMBIOS=0x3e822000 SMBIOS 3.0=0x3e820000 ESRT=0x3e823218
[    0.000000] SMBIOS 3.0.1 present.
[    0.000000] DMI: LENOVO 81NW/LNVNB161216, BIOS BKCN23WW(V1.05) 03/16/2021
[    0.000000] tsc: Detected 2300.000 MHz processor
[    0.000000] tsc: Detected 2299.968 MHz TSC
[    0.000010] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000018] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000028] last_pfn = 0x4b0800 max_arch_pfn = 0x400000000
[    0.000224] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001399] last_pfn = 0x3fd0f max_arch_pfn = 0x400000000
[    0.011123] esrt: Reserving ESRT space from 0x000000003e823218 to 0x000000003e8232c8.
[    0.011134] Using GB pages for direct mapping
[    0.011717] Secure boot disabled
[    0.011718] RAMDISK: [mem 0x36435000-0x37211fff]
[    0.011723] ACPI: Early table checksum verification disabled
[    0.011726] ACPI: RSDP 0x000000003FD0D014 000024 (v02 LENOVO)
[    0.011731] ACPI: XSDT 0x000000003FCEE188 000114 (v01 LENOVO CB-01    00000001      01000013)
[    0.011737] ACPI: FACP 0x000000003FCED000 00010C (v05 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011744] ACPI: DSDT 0x000000003FCAA000 03F64E (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011747] ACPI: FACS 0x000000003FBED000 000040
[    0.011751] ACPI: UEFI 0x000000003FD0C000 000236 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011754] ACPI: SSDT 0x000000003FD0B000 0000E6 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011758] ACPI: SSDT 0x000000003FD09000 001B5F (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011761] ACPI: SSDT 0x000000003FD05000 0031C6 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011765] ACPI: SSDT 0x000000003FD02000 002032 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011769] ACPI: UEFI 0x000000003FD01000 000042 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011772] ACPI: SSDT 0x000000003FD00000 00045A (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011776] ACPI: SSDT 0x000000003FCFF000 000046 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011779] ACPI: TPM2 0x000000003FCFE000 000034 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011784] ACPI: MSDM 0x000000003FCFD000 000055 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011787] ACPI: SSDT 0x000000003FCF8000 004051 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011791] ACPI: LPIT 0x000000003FCF7000 000094 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011795] ACPI: WSMT 0x000000003FCF6000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011798] ACPI: SSDT 0x000000003FCF5000 000C2F (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011802] ACPI: SSDT 0x000000003FCF3000 0013FF (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011805] ACPI: DBGP 0x000000003FCF2000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011809] ACPI: DBG2 0x000000003FCF1000 000054 (v00 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011813] ACPI: SSDT 0x000000003FCF0000 000F80 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011816] ACPI: ASF! 0x000000003FCEF000 0000A5 (v32 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011820] ACPI: HPET 0x000000003FCEC000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011823] ACPI: APIC 0x000000003FCEB000 00012C (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011827] ACPI: MCFG 0x000000003FCEA000 00003C (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011830] ACPI: SSDT 0x000000003FCA8000 0017D0 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011834] ACPI: DMAR 0x000000003FCA7000 0000A8 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011837] ACPI: SSDT 0x000000003FCA2000 0045E5 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011841] ACPI: SSDT 0x000000003FCA1000 000123 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011845] ACPI: NHLT 0x000000003FC9F000 0017F1 (v00 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011848] ACPI: FPDT 0x000000003FC9E000 000044 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011852] ACPI: BGRT 0x000000003FC9D000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011855] ACPI: Reserving FACP table memory at [mem 0x3fced000-0x3fced10b]
[    0.011857] ACPI: Reserving DSDT table memory at [mem 0x3fcaa000-0x3fce964d]
[    0.011858] ACPI: Reserving FACS table memory at [mem 0x3fbed000-0x3fbed03f]
[    0.011859] ACPI: Reserving UEFI table memory at [mem 0x3fd0c000-0x3fd0c235]
[    0.011860] ACPI: Reserving SSDT table memory at [mem 0x3fd0b000-0x3fd0b0e5]
[    0.011862] ACPI: Reserving SSDT table memory at [mem 0x3fd09000-0x3fd0ab5e]
[    0.011863] ACPI: Reserving SSDT table memory at [mem 0x3fd05000-0x3fd081c5]
[    0.011864] ACPI: Reserving SSDT table memory at [mem 0x3fd02000-0x3fd04031]
[    0.011865] ACPI: Reserving UEFI table memory at [mem 0x3fd01000-0x3fd01041]
[    0.011866] ACPI: Reserving SSDT table memory at [mem 0x3fd00000-0x3fd00459]
[    0.011867] ACPI: Reserving SSDT table memory at [mem 0x3fcff000-0x3fcff045]
[    0.011869] ACPI: Reserving TPM2 table memory at [mem 0x3fcfe000-0x3fcfe033]
[    0.011870] ACPI: Reserving MSDM table memory at [mem 0x3fcfd000-0x3fcfd054]
[    0.011871] ACPI: Reserving SSDT table memory at [mem 0x3fcf8000-0x3fcfc050]
[    0.011872] ACPI: Reserving LPIT table memory at [mem 0x3fcf7000-0x3fcf7093]
[    0.011873] ACPI: Reserving WSMT table memory at [mem 0x3fcf6000-0x3fcf6027]
[    0.011874] ACPI: Reserving SSDT table memory at [mem 0x3fcf5000-0x3fcf5c2e]
[    0.011876] ACPI: Reserving SSDT table memory at [mem 0x3fcf3000-0x3fcf43fe]
[    0.011877] ACPI: Reserving DBGP table memory at [mem 0x3fcf2000-0x3fcf2033]
[    0.011878] ACPI: Reserving DBG2 table memory at [mem 0x3fcf1000-0x3fcf1053]
[    0.011879] ACPI: Reserving SSDT table memory at [mem 0x3fcf0000-0x3fcf0f7f]
[    0.011880] ACPI: Reserving ASF! table memory at [mem 0x3fcef000-0x3fcef0a4]
[    0.011882] ACPI: Reserving HPET table memory at [mem 0x3fcec000-0x3fcec037]
[    0.011883] ACPI: Reserving APIC table memory at [mem 0x3fceb000-0x3fceb12b]
[    0.011884] ACPI: Reserving MCFG table memory at [mem 0x3fcea000-0x3fcea03b]
[    0.011885] ACPI: Reserving SSDT table memory at [mem 0x3fca8000-0x3fca97cf]
[    0.011887] ACPI: Reserving DMAR table memory at [mem 0x3fca7000-0x3fca70a7]
[    0.011888] ACPI: Reserving SSDT table memory at [mem 0x3fca2000-0x3fca65e4]
[    0.011889] ACPI: Reserving SSDT table memory at [mem 0x3fca1000-0x3fca1122]
[    0.011890] ACPI: Reserving NHLT table memory at [mem 0x3fc9f000-0x3fca07f0]
[    0.011892] ACPI: Reserving FPDT table memory at [mem 0x3fc9e000-0x3fc9e043]
[    0.011893] ACPI: Reserving BGRT table memory at [mem 0x3fc9d000-0x3fc9d037]
[    0.011908] ACPI: Local APIC address 0xfee00000
[    0.012180] No NUMA configuration found
[    0.012181] Faking a node at [mem 0x0000000000000000-0x00000004b07fffff]
[    0.012186] NODE_DATA(0) allocated [mem 0x4b07fc000-0x4b07fffff]
[    0.012224] Zone ranges:
[    0.012225]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.012227]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.012230]   Normal   [mem 0x0000000100000000-0x00000004b07fffff]
[    0.012231]   Device   empty
[    0.012233] Movable zone start for each node
[    0.012234] Early memory node ranges
[    0.012234]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.012236]   node   0: [mem 0x0000000000100000-0x00000000279f6fff]
[    0.012238]   node   0: [mem 0x00000000282f7000-0x000000003e50dfff]
[    0.012239]   node   0: [mem 0x000000003fd0e000-0x000000003fd0efff]
[    0.012240]   node   0: [mem 0x0000000100000000-0x00000004b07fffff]
[    0.012244] Initmem setup node 0 [mem 0x0000000000001000-0x00000004b07fffff]
[    0.012247] On node 0 totalpages: 4121517
[    0.012249]   DMA zone: 64 pages used for memmap
[    0.012250]   DMA zone: 158 pages reserved
[    0.012251]   DMA zone: 3998 pages, LIFO batch:0
[    0.012253]   DMA32 zone: 3889 pages used for memmap
[    0.012254]   DMA32 zone: 248847 pages, LIFO batch:63
[    0.012255]   Normal zone: 60448 pages used for memmap
[    0.012256]   Normal zone: 3868672 pages, LIFO batch:63
[    0.012259] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.012286] On node 0, zone DMA: 97 pages in unavailable ranges
[    0.013921] On node 0, zone DMA32: 2304 pages in unavailable ranges
[    0.014001] On node 0, zone DMA32: 6144 pages in unavailable ranges
[    0.039772] On node 0, zone Normal: 753 pages in unavailable ranges
[    0.040148] On node 0, zone Normal: 30720 pages in unavailable ranges
[    0.040151] x86/hpet: Will disable the HPET for this platform because it's not reliable
[    0.040184] Reserving Intel graphics memory at [mem 0x49800000-0x4d7fffff]
[    0.041475] ACPI: PM-Timer IO Port: 0x1808
[    0.041478] ACPI: Local APIC address 0xfee00000
[    0.041485] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.041487] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.041488] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.041489] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.041490] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.041491] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.041492] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.041493] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.041494] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.041495] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.041496] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.041497] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.041498] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.041499] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.041500] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.041501] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.041562] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.041566] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.041568] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.041572] ACPI: IRQ0 used by override.
[    0.041574] ACPI: IRQ9 used by override.
[    0.041577] Using ACPI (MADT) for SMP configuration information
[    0.041578] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.041585] e820: update [mem 0x2e235000-0x2e601fff] usable ==> reserved
[    0.041595] TSC deadline timer available
[    0.041596] smpboot: Allowing 16 CPUs, 0 hotplug CPUs
[    0.041621] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.041624] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.041627] PM: hibernation: Registered nosave memory: [mem 0x279f7000-0x282f6fff]
[    0.041629] PM: hibernation: Registered nosave memory: [mem 0x2e235000-0x2e601fff]
[    0.041631] PM: hibernation: Registered nosave memory: [mem 0x3e50e000-0x3e70dfff]
[    0.041632] PM: hibernation: Registered nosave memory: [mem 0x3e70e000-0x3f10dfff]
[    0.041633] PM: hibernation: Registered nosave memory: [mem 0x3f10e000-0x3fc8dfff]
[    0.041634] PM: hibernation: Registered nosave memory: [mem 0x3fc8e000-0x3fd0dfff]
[    0.041637] PM: hibernation: Registered nosave memory: [mem 0x3fd0f000-0x4d7fffff]
[    0.041638] PM: hibernation: Registered nosave memory: [mem 0x4d800000-0xdfffffff]
[    0.041639] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.041640] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.041641] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.041641] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfed0ffff]
[    0.041642] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[    0.041643] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[    0.041644] PM: hibernation: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[    0.041645] PM: hibernation: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[    0.041646] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.041647] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff5fffff]
[    0.041648] PM: hibernation: Registered nosave memory: [mem 0xff600000-0xffffffff]
[    0.041650] [mem 0x4d800000-0xdfffffff] available for PCI devices
[    0.041652] Booting paravirtualized kernel on bare hardware
[    0.041654] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.047993] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
[    0.048435] percpu: Embedded 57 pages/cpu s196608 r8192 d28672 u262144
[    0.048445] pcpu-alloc: s196608 r8192 d28672 u262144 alloc=1*2097152
[    0.048448] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.048482] Built 1 zonelists, mobility grouping on.  Total pages: 4056958
[    0.048484] Policy zone: Normal
[    0.048486] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=a78a2b34-6b4a-4b3f-b902-6a2989c51e5e rw apparmor=1 security=apparmor udev.log_priority=3
[    0.049641] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.050215] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.050370] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[    0.090904] Memory: 15993552K/16486068K available (14344K kernel code, 2075K rwdata, 9156K rodata, 1796K init, 4076K bss, 492256K reserved, 0K cma-reserved)
[    0.090910] random: get_random_u64 called from __kmem_cache_create+0x2a/0x580 with crng_init=0
[    0.091073] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[    0.091090] ftrace: allocating 42490 entries in 166 pages
[    0.109116] ftrace: allocated 166 pages with 4 groups
[    0.109246] rcu: Preemptible hierarchical RCU implementation.
[    0.109248] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.109248] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[    0.109250] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.109251] 	Trampoline variant of Tasks RCU enabled.
[    0.109252] 	Rude variant of Tasks RCU enabled.
[    0.109252] 	Tracing variant of Tasks RCU enabled.
[    0.109253] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.109254] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[    0.114195] NR_IRQS: 20736, nr_irqs: 2184, preallocated irqs: 16
[    0.114936] Console: colour dummy device 80x25
[    0.114956] printk: console [tty0] enabled
[    0.114982] ACPI: Core revision 20210331
[    0.115443] APIC: Switch to symmetric I/O mode setup
[    0.115446] DMAR: Host address width 39
[    0.115447] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.115453] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.115456] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.115460] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.115462] DMAR: RMRR base: 0x0000003f0ed000 end: 0x0000003f10cfff
[    0.115464] DMAR: RMRR base: 0x00000049000000 end: 0x0000004d7fffff
[    0.115466] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.115468] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.115469] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.118670] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.118672] x2apic enabled
[    0.118703] Switched APIC routing to cluster x2apic.
[    0.127945] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x212717146a7, max_idle_ns: 440795291431 ns
[    0.127960] Calibrating delay loop (skipped), value calculated using timer frequency.. 4601.60 BogoMIPS (lpj=7666560)
[    0.127963] pid_max: default: 32768 minimum: 301
[    0.131291] LSM: Security Framework initializing
[    0.131291] landlock: Up and running.
[    0.131291] Yama: becoming mindful.
[    0.131291] AppArmor: AppArmor initialized
[    0.131291] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.131291] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.131291] CPU0: Thermal monitoring enabled (TM1)
[    0.131291] process: using mwait in idle threads
[    0.131291] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.131291] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.131291] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.131291] Spectre V2 : Mitigation: Enhanced IBRS
[    0.131291] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.131291] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.131291] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.131291] TAA: Mitigation: TSX disabled
[    0.131291] SRBDS: Mitigation: TSX disabled
[    0.131291] Freeing SMP alternatives memory: 36K
[    0.131291] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 2048
[    0.131291] smpboot: CPU0: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz (family: 0x6, model: 0x9e, stepping: 0xd)
[    0.131291] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.131291] ... version:                4
[    0.131291] ... bit width:              48
[    0.131291] ... generic registers:      4
[    0.131291] ... value mask:             0000ffffffffffff
[    0.131291] ... max period:             00007fffffffffff
[    0.131291] ... fixed-purpose events:   3
[    0.131291] ... event mask:             000000070000000f
[    0.131291] rcu: Hierarchical SRCU implementation.
[    0.131291] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.131291] smp: Bringing up secondary CPUs ...
[    0.131291] x86: Booting SMP configuration:
[    0.131291] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
[    0.162143] smp: Brought up 1 node, 16 CPUs
[    0.162143] smpboot: Max logical packages: 1
[    0.162143] smpboot: Total of 16 processors activated (73628.60 BogoMIPS)
[    0.165272] devtmpfs: initialized
[    0.165272] x86/mm: Memory block size: 128MB
[    0.165684] PM: Registering ACPI NVS region [mem 0x3f10e000-0x3fc8dfff] (12058624 bytes)
[    0.165684] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.165684] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.165684] pinctrl core: initialized pinctrl subsystem
[    0.165684] PM: RTC time: 18:44:18, date: 2021-08-13
[    0.165684] NET: Registered protocol family 16
[    0.165780] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.165936] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.166091] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.166098] audit: initializing netlink subsys (disabled)
[    0.166106] audit: type=2000 audit(1628880258.036:1): state=initialized audit_enabled=0 res=1
[    0.168047] thermal_sys: Registered thermal governor 'fair_share'
[    0.168049] thermal_sys: Registered thermal governor 'bang_bang'
[    0.168050] thermal_sys: Registered thermal governor 'step_wise'
[    0.168051] thermal_sys: Registered thermal governor 'user_space'
[    0.168052] thermal_sys: Registered thermal governor 'power_allocator'
[    0.168064] cpuidle: using governor ladder
[    0.168068] cpuidle: using governor menu
[    0.168098] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.168098] ACPI: bus type PCI registered
[    0.168098] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.168098] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.168098] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.168107] PCI: Using configuration type 1 for base access
[    0.168689] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.169095] Kprobes globally optimized
[    0.169099] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.169099] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.169099] ACPI: Added _OSI(Module Device)
[    0.169099] ACPI: Added _OSI(Processor Device)
[    0.169099] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.169099] ACPI: Added _OSI(Processor Aggregator Device)
[    0.169099] ACPI: Added _OSI(Linux-Dell-Video)
[    0.169099] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.169099] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.243666] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._ON], AE_ALREADY_EXISTS (20210331/dswload2-326)
[    0.243682] fbcon: Taking over console
[    0.243689] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210331/psobject-220)
[    0.243695] ACPI: Skipping parse of AML opcode: Method (0x0014)
[    0.243698] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._OFF], AE_ALREADY_EXISTS (20210331/dswload2-326)
[    0.243705] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210331/psobject-220)
[    0.243708] ACPI: Skipping parse of AML opcode: Method (0x0014)
[    0.243711] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP.SGPO], AE_ALREADY_EXISTS (20210331/dswload2-326)
[    0.243717] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210331/psobject-220)
[    0.243720] ACPI: Skipping parse of AML opcode: Method (0x0014)
[    0.243904] ACPI: 14 ACPI AML tables successfully acquired and loaded
[    0.313423] ACPI: Dynamic OEM Table Load:
[    0.313439] ACPI: SSDT 0xFFFF9F0F01AAC700 0000F4 (v02 PmRef  Cpu0Psd  00003000 INTL 20160422)
[    0.314829] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    0.318105] ACPI: Dynamic OEM Table Load:
[    0.318115] ACPI: SSDT 0xFFFF9F0F013E2000 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.319659] ACPI: Dynamic OEM Table Load:
[    0.319668] ACPI: SSDT 0xFFFF9F0F01AF2000 00051E (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.321745] ACPI: Dynamic OEM Table Load:
[    0.321755] ACPI: SSDT 0xFFFF9F0F01AF1800 0005FC (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.323595] ACPI: Dynamic OEM Table Load:
[    0.323605] ACPI: SSDT 0xFFFF9F0F0007E000 000AB0 (v02 PmRef  ApPsd    00003000 INTL 20160422)
[    0.326015] ACPI: Dynamic OEM Table Load:
[    0.326023] ACPI: SSDT 0xFFFF9F0F013E2C00 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.337497] ACPI: EC: EC started
[    0.337499] ACPI: EC: interrupt blocked
[    0.338384] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.338387] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.338388] ACPI: Interpreter enabled
[    0.338450] ACPI: (supports S0 S3 S4 S5)
[    0.338451] ACPI: Using IOAPIC for interrupt routing
[    0.338505] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.341161] ACPI: Enabled 9 GPEs in block 00 to 7F
[    0.343942] ACPI: PM: Power Resource [PG00] (on)
[    0.344294] ACPI: PM: Power Resource [PG01] (on)
[    0.344794] ACPI: PM: Power Resource [PG02] (on)
[    0.351676] ACPI: PM: Power Resource [BTPR] (off)
[    0.353216] ACPI: PM: Power Resource [USBC] (on)
[    0.363690] ACPI: PM: Power Resource [PXP] (on)
[    0.368825] ACPI: PM: Power Resource [V0PR] (on)
[    0.369081] ACPI: PM: Power Resource [V1PR] (on)
[    0.369329] ACPI: PM: Power Resource [V2PR] (on)
[    0.377506] ACPI: PM: Power Resource [WRST] (on)
[    0.378331] ACPI: PM: Power Resource [PIN] (off)
[    0.378959] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.378969] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.802226] acpi PNP0A08:00: _OSC: platform does not support [AER]
[    1.638890] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
[    1.638892] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    1.646029] PCI host bridge to bus 0000:00
[    1.646031] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    1.646034] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    1.646036] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    1.646038] pci_bus 0000:00: root bus resource [mem 0x4d800000-0xdfffffff window]
[    1.646039] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[    1.646041] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    1.646043] pci_bus 0000:00: root bus resource [bus 00-fe]
[    1.646066] pci 0000:00:00.0: [8086:3e20] type 00 class 0x060000
[    1.647520] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    1.647568] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    1.649017] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[    1.649027] pci 0000:00:02.0: reg 0x10: [mem 0x604a000000-0x604affffff 64bit]
[    1.649034] pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[    1.649039] pci 0000:00:02.0: reg 0x20: [io  0x4000-0x403f]
[    1.649059] pci 0000:00:02.0: BAR 2: assigned to efifb
[    1.650542] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    1.650553] pci 0000:00:04.0: reg 0x10: [mem 0x604b100000-0x604b107fff 64bit]
[    1.652220] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[    1.652231] pci 0000:00:08.0: reg 0x10: [mem 0x604b118000-0x604b118fff 64bit]
[    1.653702] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[    1.653739] pci 0000:00:12.0: reg 0x10: [mem 0x604b117000-0x604b117fff 64bit]
[    1.655333] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[    1.655371] pci 0000:00:14.0: reg 0x10: [mem 0x63200000-0x6320ffff 64bit]
[    1.655528] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    1.657339] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[    1.657375] pci 0000:00:14.2: reg 0x10: [mem 0x604b110000-0x604b111fff 64bit]
[    1.657399] pci 0000:00:14.2: reg 0x18: [mem 0x604b116000-0x604b116fff 64bit]
[    1.658983] pci 0000:00:14.3: [8086:a370] type 00 class 0x028000
[    1.659115] pci 0000:00:14.3: reg 0x10: [mem 0x604b10c000-0x604b10ffff 64bit]
[    1.659821] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[    1.661972] pci 0000:00:15.0: [8086:a368] type 00 class 0x0c8000
[    1.662548] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.666881] pci 0000:00:15.1: [8086:a369] type 00 class 0x0c8000
[    1.667456] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.671437] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[    1.671471] pci 0000:00:16.0: reg 0x10: [mem 0x604b113000-0x604b113fff 64bit]
[    1.671597] pci 0000:00:16.0: PME# supported from D3hot
[    1.673671] pci 0000:00:1b.0: [8086:a340] type 01 class 0x060400
[    1.675200] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    1.675282] pci 0000:00:1b.0: PTM enabled (root), 4ns granularity
[    1.676421] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[    1.676662] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    1.676746] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[    1.679097] pci 0000:00:1d.4: [8086:a334] type 01 class 0x060400
[    1.679332] pci 0000:00:1d.4: PME# supported from D0 D3hot D3cold
[    1.679416] pci 0000:00:1d.4: PTM enabled (root), 4ns granularity
[    1.681757] pci 0000:00:1f.0: [8086:a30d] type 00 class 0x060100
[    1.683666] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040100
[    1.683726] pci 0000:00:1f.3: reg 0x10: [mem 0x604b108000-0x604b10bfff 64bit]
[    1.683801] pci 0000:00:1f.3: reg 0x20: [mem 0x604b000000-0x604b0fffff 64bit]
[    1.683963] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    1.686372] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[    1.686543] pci 0000:00:1f.4: reg 0x10: [mem 0x604b112000-0x604b1120ff 64bit]
[    1.686758] pci 0000:00:1f.4: reg 0x20: [io  0x4040-0x405f]
[    1.688610] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[    1.688638] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    1.690136] pci 0000:01:00.0: [10de:1f91] type 00 class 0x030200
[    1.690148] pci 0000:01:00.0: reg 0x10: [mem 0x62000000-0x62ffffff]
[    1.690158] pci 0000:01:00.0: reg 0x14: [mem 0x50000000-0x5fffffff 64bit pref]
[    1.690168] pci 0000:01:00.0: reg 0x1c: [mem 0x60000000-0x61ffffff 64bit pref]
[    1.690175] pci 0000:01:00.0: reg 0x24: [io  0x3000-0x307f]
[    1.690182] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[    1.690237] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    1.690279] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    1.690597] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    1.690601] pci 0000:00:01.0:   bridge window [io  0x3000-0x3fff]
[    1.690603] pci 0000:00:01.0:   bridge window [mem 0x62000000-0x62ffffff]
[    1.690607] pci 0000:00:01.0:   bridge window [mem 0x50000000-0x61ffffff 64bit pref]
[    1.690741] pci 0000:06:00.0: [8086:15d3] type 01 class 0x060400
[    1.690834] pci 0000:06:00.0: enabling Extended Tags
[    1.690999] pci 0000:06:00.0: supports D1 D2
[    1.691001] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.691261] pci 0000:00:1b.0: PCI bridge to [bus 06-6f]
[    1.691271] pci 0000:00:1b.0:   bridge window [mem 0x64000000-0x920fffff]
[    1.691280] pci 0000:00:1b.0:   bridge window [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.691399] pci 0000:07:00.0: [8086:15d3] type 01 class 0x060400
[    1.691493] pci 0000:07:00.0: enabling Extended Tags
[    1.691656] pci 0000:07:00.0: supports D1 D2
[    1.691657] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.691856] pci 0000:07:01.0: [8086:15d3] type 01 class 0x060400
[    1.691950] pci 0000:07:01.0: enabling Extended Tags
[    1.692115] pci 0000:07:01.0: supports D1 D2
[    1.692117] pci 0000:07:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.692309] pci 0000:07:02.0: [8086:15d3] type 01 class 0x060400
[    1.692403] pci 0000:07:02.0: enabling Extended Tags
[    1.692560] pci 0000:07:02.0: supports D1 D2
[    1.692561] pci 0000:07:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.692782] pci 0000:07:04.0: [8086:15d3] type 01 class 0x060400
[    1.692876] pci 0000:07:04.0: enabling Extended Tags
[    1.693038] pci 0000:07:04.0: supports D1 D2
[    1.693039] pci 0000:07:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.693244] pci 0000:06:00.0: PCI bridge to [bus 07-6f]
[    1.693258] pci 0000:06:00.0:   bridge window [mem 0x64000000-0x920fffff]
[    1.693268] pci 0000:06:00.0:   bridge window [mem 0x6000000000-0x380117aa49ffffff 64bit pref]
[    1.693372] pci 0000:08:00.0: [8086:15d2] type 00 class 0x088000
[    1.693400] pci 0000:08:00.0: reg 0x10: [mem 0x92000000-0x9203ffff]
[    1.693417] pci 0000:08:00.0: reg 0x14: [mem 0x92040000-0x92040fff]
[    1.693503] pci 0000:08:00.0: enabling Extended Tags
[    1.693661] pci 0000:08:00.0: supports D1 D2
[    1.693662] pci 0000:08:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.693852] pci 0000:07:00.0: PCI bridge to [bus 08]
[    1.693866] pci 0000:07:00.0:   bridge window [mem 0x92000000-0x920fffff]
[    1.693876] pci 0000:07:00.0:   bridge window [mem 0xfff00000-0x380117aa000fffff 64bit pref]
[    1.693945] pci 0000:07:01.0: PCI bridge to [bus 09-3b]
[    1.693959] pci 0000:07:01.0:   bridge window [mem 0x64000000-0x7aefffff]
[    1.693969] pci 0000:07:01.0:   bridge window [mem 0x6000000000-0x380117aa24ffffff 64bit pref]
[    1.694089] pci 0000:3c:00.0: [8086:15d4] type 00 class 0x0c0330
[    1.694121] pci 0000:3c:00.0: reg 0x10: [mem 0x7af00000-0x7af0ffff]
[    1.694391] pci 0000:3c:00.0: supports D1 D2
[    1.694392] pci 0000:3c:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.694518] pci 0000:3c:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:07:02.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[    1.694632] pci 0000:07:02.0: PCI bridge to [bus 3c]
[    1.694646] pci 0000:07:02.0:   bridge window [mem 0x7af00000-0x7affffff]
[    1.694656] pci 0000:07:02.0:   bridge window [mem 0xfff00000-0x380117aa000fffff 64bit pref]
[    1.694717] pci 0000:07:04.0: PCI bridge to [bus 3d-6f]
[    1.694731] pci 0000:07:04.0:   bridge window [mem 0x7b000000-0x91ffffff]
[    1.694741] pci 0000:07:04.0:   bridge window [mem 0x6025000000-0x380117aa49ffffff 64bit pref]
[    1.695045] pci 0000:70:00.0: [144d:a808] type 00 class 0x010802
[    1.695081] pci 0000:70:00.0: reg 0x10: [mem 0x63100000-0x63103fff 64bit]
[    1.695672] pci 0000:00:1d.0: PCI bridge to [bus 70]
[    1.695682] pci 0000:00:1d.0:   bridge window [mem 0x63100000-0x631fffff]
[    1.695804] pci 0000:71:00.0: [1217:8621] type 00 class 0x080501
[    1.695833] pci 0000:71:00.0: reg 0x10: [mem 0x63001000-0x63001fff]
[    1.695849] pci 0000:71:00.0: reg 0x14: [mem 0x63000000-0x630007ff]
[    1.696056] pci 0000:71:00.0: PME# supported from D3hot D3cold
[    1.708068] pci 0000:00:1d.4: PCI bridge to [bus 71]
[    1.708079] pci 0000:00:1d.4:   bridge window [mem 0x63000000-0x630fffff]
[    1.741343] acpi LNXPOWER:0a: Turning OFF
[    1.741350] acpi LNXPOWER:09: Turning OFF
[    1.741433] ACPI: EC: interrupt unblocked
[    1.741434] ACPI: EC: event unblocked
[    1.741457] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    1.741458] ACPI: EC: GPE=0x14
[    1.741460] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
[    1.741462] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[    1.741530] iommu: Default domain type: Translated
[    1.741543] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    1.741543] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    1.741543] pci 0000:00:02.0: vgaarb: bridge control possible
[    1.741543] vgaarb: loaded
[    1.741543] SCSI subsystem initialized
[    1.741543] libata version 3.00 loaded.
[    1.741543] ACPI: bus type USB registered
[    1.741543] usbcore: registered new interface driver usbfs
[    1.741543] usbcore: registered new interface driver hub
[    1.741543] usbcore: registered new device driver usb
[    1.741543] pps_core: LinuxPPS API ver. 1 registered
[    1.741543] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.741543] PTP clock support registered
[    1.741543] EDAC MC: Ver: 3.0.0
[    1.743648] Registered efivars operations
[    1.743648] NetLabel: Initializing
[    1.743648] NetLabel:  domain hash size = 128
[    1.743648] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.743648] NetLabel:  unlabeled traffic allowed by default
[    1.743648] PCI: Using ACPI for IRQ routing
[    1.796110] PCI: pci_cache_line_size set to 64 bytes
[    1.796113] pci 0000:06:00.0: can't claim BAR 15 [mem 0x6000000000-0x380117aa49ffffff 64bit pref]: no compatible bridge window
[    1.796117] pci 0000:06:00.0: [mem 0x6000000000-0x380117aa49ffffff 64bit pref] clipped to [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.796126] pci 0000:06:00.0:   bridge window [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.796134] pci 0000:07:00.0: can't claim BAR 15 [mem 0xfff00000-0x380117aa000fffff 64bit pref]: no compatible bridge window
[    1.796136] pci 0000:07:00.0: [mem 0xfff00000-0x380117aa000fffff 64bit pref] clipped to [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.796140] pci 0000:07:00.0:   bridge window [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.796148] pci 0000:07:01.0: can't claim BAR 15 [mem 0x6000000000-0x380117aa24ffffff 64bit pref]: no compatible bridge window
[    1.796150] pci 0000:07:01.0: [mem 0x6000000000-0x380117aa24ffffff 64bit pref] clipped to [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.796154] pci 0000:07:01.0:   bridge window [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.796162] pci 0000:07:01.0: can't claim BAR 15 [mem 0x6000000000-0x6049ffffff 64bit pref]: address conflict with PCI Bus 0000:08 [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.796165] pci 0000:07:02.0: can't claim BAR 15 [mem 0xfff00000-0x380117aa000fffff 64bit pref]: no compatible bridge window
[    1.796167] pci 0000:07:02.0: [mem 0xfff00000-0x380117aa000fffff 64bit pref] clipped to [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.796171] pci 0000:07:02.0:   bridge window [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.796178] pci 0000:07:02.0: can't claim BAR 15 [mem 0x6000000000-0x6049ffffff 64bit pref]: address conflict with PCI Bus 0000:08 [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.796181] pci 0000:07:04.0: can't claim BAR 15 [mem 0x6025000000-0x380117aa49ffffff 64bit pref]: no compatible bridge window
[    1.796183] pci 0000:07:04.0: [mem 0x6025000000-0x380117aa49ffffff 64bit pref] clipped to [mem 0x6025000000-0x6049ffffff 64bit pref]
[    1.796187] pci 0000:07:04.0:   bridge window [mem 0x6025000000-0x6049ffffff 64bit pref]
[    1.796195] pci 0000:07:04.0: can't claim BAR 15 [mem 0x6025000000-0x6049ffffff 64bit pref]: address conflict with PCI Bus 0000:08 [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.798269] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    1.798271] e820: reserve RAM buffer [mem 0x279f7000-0x27ffffff]
[    1.798272] e820: reserve RAM buffer [mem 0x2e235000-0x2fffffff]
[    1.798273] e820: reserve RAM buffer [mem 0x3e50e000-0x3fffffff]
[    1.798275] e820: reserve RAM buffer [mem 0x3fd0f000-0x3fffffff]
[    1.798276] e820: reserve RAM buffer [mem 0x4b0800000-0x4b3ffffff]
[    1.802647] clocksource: Switched to clocksource tsc-early
[    1.809638] VFS: Disk quotas dquot_6.6.0
[    1.809662] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.809817] AppArmor: AppArmor Filesystem Enabled
[    1.809874] pnp: PnP ACPI init
[    1.810024] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
[    1.810035] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.810589] system 00:01: [io  0x1800-0x18fe] has been reserved
[    1.810595] system 00:01: [mem 0xfd000000-0xfd69ffff] has been reserved
[    1.810600] system 00:01: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[    1.810604] system 00:01: [mem 0xfd6f0000-0xfdffffff] has been reserved
[    1.810607] system 00:01: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    1.810611] system 00:01: [mem 0xfe200000-0xfe7fffff] has been reserved
[    1.810615] system 00:01: [mem 0xfc7e0000-0xfc7e0fff] has been reserved
[    1.810618] system 00:01: [mem 0xff000000-0xffffffff] could not be reserved
[    1.810627] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.811168] system 00:02: [io  0x2000-0x20fe] has been reserved
[    1.811176] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.811355] system 00:03: [io  0x0680-0x069f] has been reserved
[    1.811358] system 00:03: [io  0x164e-0x164f] has been reserved
[    1.811360] system 00:03: [io  0xfd60-0xfd63] has been reserved
[    1.811365] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.811433] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[    1.811559] system 00:05: [io  0x1854-0x1857] has been reserved
[    1.811564] system 00:05: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    1.811612] pnp 00:06: Plug and Play ACPI device, IDs PNP0303 (active)
[    1.813343] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.814506] system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
[    1.814510] system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
[    1.814513] system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
[    1.814517] system 00:08: [mem 0xe0000000-0xefffffff] has been reserved
[    1.814519] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[    1.814521] system 00:08: [mem 0xfed90000-0xfed93fff] could not be reserved
[    1.814523] system 00:08: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    1.814525] system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
[    1.814530] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.815113] pnp: PnP ACPI: found 9 devices
[    1.820753] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    1.820818] NET: Registered protocol family 2
[    1.821005] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.823255] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    1.823356] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    1.823562] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    1.823642] TCP: Hash tables configured (established 131072 bind 65536)
[    1.823733] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[    1.823801] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    1.823851] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    1.823925] NET: Registered protocol family 1
[    1.823929] NET: Registered protocol family 44
[    1.823933] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[    1.823939] pci 0000:07:01.0: bridge window [io  0x1000-0x0fff] to [bus 09-3b] add_size 1000
[    1.823942] pci 0000:07:01.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 09-3b] add_size 200000 add_align 100000
[    1.823946] pci 0000:07:04.0: bridge window [io  0x1000-0x0fff] to [bus 3d-6f] add_size 1000
[    1.823948] pci 0000:07:04.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 3d-6f] add_size 200000 add_align 100000
[    1.823951] pci 0000:06:00.0: bridge window [io  0x1000-0x0fff] to [bus 07-6f] add_size 2000
[    1.823954] pci 0000:00:1b.0: bridge window [io  0x1000-0x0fff] to [bus 06-6f] add_size 3000
[    1.823962] pci 0000:00:15.0: BAR 0: assigned [mem 0x4010000000-0x4010000fff 64bit]
[    1.824234] pci 0000:00:15.1: BAR 0: assigned [mem 0x4010001000-0x4010001fff 64bit]
[    1.824503] pci 0000:00:1b.0: BAR 13: assigned [io  0x5000-0x7fff]
[    1.824506] pci 0000:01:00.0: BAR 6: no space for [mem size 0x00080000 pref]
[    1.824508] pci 0000:01:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
[    1.824510] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[    1.824512] pci 0000:00:01.0:   bridge window [io  0x3000-0x3fff]
[    1.824515] pci 0000:00:01.0:   bridge window [mem 0x62000000-0x62ffffff]
[    1.824518] pci 0000:00:01.0:   bridge window [mem 0x50000000-0x61ffffff 64bit pref]
[    1.824522] pci 0000:06:00.0: BAR 13: assigned [io  0x5000-0x6fff]
[    1.824527] pci 0000:07:01.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[    1.824529] pci 0000:07:01.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[    1.824531] pci 0000:07:04.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[    1.824533] pci 0000:07:04.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[    1.824534] pci 0000:07:01.0: BAR 13: assigned [io  0x5000-0x5fff]
[    1.824536] pci 0000:07:04.0: BAR 13: assigned [io  0x6000-0x6fff]
[    1.824539] pci 0000:07:04.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[    1.824540] pci 0000:07:04.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[    1.824543] pci 0000:07:01.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[    1.824544] pci 0000:07:01.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[    1.824546] pci 0000:07:00.0: PCI bridge to [bus 08]
[    1.824558] pci 0000:07:00.0:   bridge window [mem 0x92000000-0x920fffff]
[    1.824564] pci 0000:07:00.0:   bridge window [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.824574] pci 0000:07:01.0: PCI bridge to [bus 09-3b]
[    1.824577] pci 0000:07:01.0:   bridge window [io  0x5000-0x5fff]
[    1.824585] pci 0000:07:01.0:   bridge window [mem 0x64000000-0x7aefffff]
[    1.824599] pci 0000:07:02.0: PCI bridge to [bus 3c]
[    1.824606] pci 0000:07:02.0:   bridge window [mem 0x7af00000-0x7affffff]
[    1.824620] pci 0000:07:04.0: PCI bridge to [bus 3d-6f]
[    1.824623] pci 0000:07:04.0:   bridge window [io  0x6000-0x6fff]
[    1.824657] pci 0000:07:04.0:   bridge window [mem 0x7b000000-0x91ffffff]
[    1.824685] pci 0000:06:00.0: PCI bridge to [bus 07-6f]
[    1.824688] pci 0000:06:00.0:   bridge window [io  0x5000-0x6fff]
[    1.824696] pci 0000:06:00.0:   bridge window [mem 0x64000000-0x920fffff]
[    1.824701] pci 0000:06:00.0:   bridge window [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.824711] pci 0000:00:1b.0: PCI bridge to [bus 06-6f]
[    1.824715] pci 0000:00:1b.0:   bridge window [io  0x5000-0x7fff]
[    1.824722] pci 0000:00:1b.0:   bridge window [mem 0x64000000-0x920fffff]
[    1.824727] pci 0000:00:1b.0:   bridge window [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.824738] pci 0000:00:1d.0: PCI bridge to [bus 70]
[    1.824747] pci 0000:00:1d.0:   bridge window [mem 0x63100000-0x631fffff]
[    1.824761] pci 0000:00:1d.4: PCI bridge to [bus 71]
[    1.824770] pci 0000:00:1d.4:   bridge window [mem 0x63000000-0x630fffff]
[    1.824784] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    1.824786] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    1.824788] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    1.824789] pci_bus 0000:00: resource 7 [mem 0x4d800000-0xdfffffff window]
[    1.824791] pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
[    1.824793] pci_bus 0000:00: resource 9 [mem 0xfc800000-0xfe7fffff window]
[    1.824794] pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
[    1.824796] pci_bus 0000:01: resource 1 [mem 0x62000000-0x62ffffff]
[    1.824797] pci_bus 0000:01: resource 2 [mem 0x50000000-0x61ffffff 64bit pref]
[    1.824799] pci_bus 0000:06: resource 0 [io  0x5000-0x7fff]
[    1.824800] pci_bus 0000:06: resource 1 [mem 0x64000000-0x920fffff]
[    1.824802] pci_bus 0000:06: resource 2 [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.824804] pci_bus 0000:07: resource 0 [io  0x5000-0x6fff]
[    1.824805] pci_bus 0000:07: resource 1 [mem 0x64000000-0x920fffff]
[    1.824806] pci_bus 0000:07: resource 2 [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.824808] pci_bus 0000:08: resource 1 [mem 0x92000000-0x920fffff]
[    1.824809] pci_bus 0000:08: resource 2 [mem 0x6000000000-0x6049ffffff 64bit pref]
[    1.824811] pci_bus 0000:09: resource 0 [io  0x5000-0x5fff]
[    1.824813] pci_bus 0000:09: resource 1 [mem 0x64000000-0x7aefffff]
[    1.824815] pci_bus 0000:3c: resource 1 [mem 0x7af00000-0x7affffff]
[    1.824817] pci_bus 0000:3d: resource 0 [io  0x6000-0x6fff]
[    1.824818] pci_bus 0000:3d: resource 1 [mem 0x7b000000-0x91ffffff]
[    1.824820] pci_bus 0000:70: resource 1 [mem 0x63100000-0x631fffff]
[    1.824822] pci_bus 0000:71: resource 1 [mem 0x63000000-0x630fffff]
[    1.825027] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    1.826687] pci 0000:06:00.0: CLS mismatch (64 != 128), using 64 bytes
[    1.827286] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.827287] software IO TLB: mapped [mem 0x0000000039dae000-0x000000003ddae000] (64MB)
[    1.827310] Trying to unpack rootfs image as initramfs...
[    1.827335] sgx: EPC section 0x40200000-0x45f7ffff
[    1.829232] Initialise system trusted keyrings
[    1.829246] Key type blacklist registered
[    1.829278] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    1.830468] zbud: loaded
[    1.840900] Key type asymmetric registered
[    1.840902] Asymmetric key parser 'x509' registered
[    1.840909] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    1.840945] io scheduler mq-deadline registered
[    1.840946] io scheduler kyber registered
[    1.840983] io scheduler bfq registered
[    1.845460] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[    1.845597] pcieport 0000:00:1b.0: PME: Signaling with IRQ 123
[    1.845637] pcieport 0000:00:1b.0: pciehp: Slot #16 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[    1.846042] pcieport 0000:00:1d.0: PME: Signaling with IRQ 124
[    1.846414] pcieport 0000:00:1d.4: PME: Signaling with IRQ 125
[    1.847250] pcieport 0000:07:01.0: pciehp: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[    1.847865] pcieport 0000:07:04.0: pciehp: Slot #4 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[    1.848117] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.848148] efifb: probing for efifb
[    1.848163] efifb: framebuffer at 0x4000000000, using 32448k, total 32448k
[    1.848165] efifb: mode is 3840x2160x32, linelength=15360, pages=1
[    1.848167] efifb: scrolling: redraw
[    1.848168] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.848282] Console: switching to colour frame buffer device 240x67
[    1.865322] fb0: EFI VGA frame buffer device
[    1.866535] ACPI: AC: AC Adapter [ACAD] (off-line)
[    1.866603] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/PNP0C0D:00/input/input0
[    1.866621] ACPI: button: Lid Switch [LID0]
[    1.866661] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    1.868052] ACPI: button: Power Button [PWRB]
[    1.868102] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    1.871330] ACPI: button: Power Button [PWRF]
[    1.872877] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    1.874666] hpet_acpi_add: no address or irqs in _CRS
[    1.874711] Non-volatile memory driver v1.3
[    1.874712] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.874713] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    1.876398] nvme nvme0: pci function 0000:70:00.0
[    1.876456] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.876460] ehci-pci: EHCI PCI platform driver
[    1.876467] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.876469] ohci-pci: OHCI PCI platform driver
[    1.876477] uhci_hcd: USB Universal Host Controller Interface driver
[    1.876510] usbcore: registered new interface driver usbserial_generic
[    1.876514] usbserial: USB Serial support registered for generic
[    1.876759] rtc_cmos 00:04: RTC can wake from S4
[    1.878329] rtc_cmos 00:04: registered as rtc0
[    1.878725] rtc_cmos 00:04: setting system clock to 2021-08-13T18:44:20 UTC (1628880260)
[    1.878740] rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram
[    1.879402] intel_pstate: Intel P-state driver initializing
[    1.880466] intel_pstate: Disabling energy efficiency optimization
[    1.880467] intel_pstate: HWP enabled
[    1.881105] ledtrig-cpu: registered to indicate activity on CPUs
[    1.881228] hid: raw HID events driver (C) Jiri Kosina
[    1.881268] ashmem: initialized
[    1.881331] intel_pmc_core INT33A1:00:  initialized
[    1.881420] drop_monitor: Initializing network drop monitor service
[    1.881557] Initializing XFRM netlink socket
[    1.881618] NET: Registered protocol family 10
[    1.885313] nvme nvme0: missing or invalid SUBNQN field.
[    1.885323] nvme nvme0: Shutdown timeout set to 8 seconds
[    1.892093] ACPI: battery: Slot [BAT1] (battery present)
[    1.902523] nvme nvme0: 16/0/0 default/read/poll queues
[    1.905030]  nvme0n1: p1 p2 p3 p4 p5
[    1.941814] Freeing initrd memory: 14196K
[    1.945259] Segment Routing with IPv6
[    1.945260] RPL Segment Routing with IPv6
[    1.945276] NET: Registered protocol family 17
[    1.946626] microcode: sig=0x906ed, pf=0x20, revision=0xea
[    1.947101] microcode: Microcode Update Driver: v2.2.
[    1.947104] IPI shorthand broadcast: enabled
[    1.947126] sched_clock: Marking stable (1933290316, 13238084)->(1973205352, -26676952)
[    1.947494] registered taskstats version 1
[    1.947500] Loading compiled-in X.509 certificates
[    1.949417] Loaded X.509 cert 'Build time autogenerated kernel key: 3cdf61a8f3aee51000c5ed0ac234a13b1afc7867'
[    1.951178] zswap: loaded using pool zstd/z3fold
[    1.951530] Key type ._fscrypt registered
[    1.951531] Key type .fscrypt registered
[    1.951531] Key type fscrypt-provisioning registered
[    1.951555] AppArmor: AppArmor sha1 policy hashing enabled
[    1.951725] PM:   Magic number: 1:583:746
[    1.951942] RAS: Correctable Errors collector initialized.
[    1.952591] Freeing unused decrypted memory: 2036K
[    1.952806] Freeing unused kernel image (initmem) memory: 1796K
[    2.001716] Write protecting the kernel read-only data: 26624k
[    2.002404] Freeing unused kernel image (text/rodata gap) memory: 2036K
[    2.002741] Freeing unused kernel image (rodata/data gap) memory: 1084K
[    2.011731] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    2.011734] rodata_test: all tests were successful
[    2.011737] Run /init as init process
[    2.011738]   with arguments:
[    2.011738]     /init
[    2.011739]   with environment:
[    2.011739]     HOME=/
[    2.011740]     TERM=linux
[    2.011740]     BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64
[    2.208284] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    2.208291] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    2.208827] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    2.208830] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    2.209374] serio: i8042 KBD port at 0x60,0x64 irq 1
[    2.209414] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[    2.209538] sdhci: Secure Digital Host Controller Interface driver
[    2.209539] sdhci: Copyright(c) Pierre Ossman
[    2.209658] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
[    2.209661] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.209663] usb usb1: Product: xHCI Host Controller
[    2.209664] usb usb1: Manufacturer: Linux 5.13.8-1-MANJARO xhci-hcd
[    2.209665] usb usb1: SerialNumber: 0000:00:14.0
[    2.209744] hub 1-0:1.0: USB hub found
[    2.209768] hub 1-0:1.0: 16 ports detected
[    2.211043] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    2.211046] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    2.211048] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    2.211073] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
[    2.211075] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.211076] usb usb2: Product: xHCI Host Controller
[    2.211076] usb usb2: Manufacturer: Linux 5.13.8-1-MANJARO xhci-hcd
[    2.211077] usb usb2: SerialNumber: 0000:00:14.0
[    2.211138] hub 2-0:1.0: USB hub found
[    2.211158] hub 2-0:1.0: 8 ports detected
[    2.211279] usb: port power management may be unreliable
[    2.211593] xhci_hcd 0000:3c:00.0: xHCI Host Controller
[    2.211599] xhci_hcd 0000:3c:00.0: new USB bus registered, assigned bus number 3
[    2.212045] sdhci-pci 0000:71:00.0: SDHCI controller found [1217:8621] (rev 1)
[    2.214044] xhci_hcd 0000:3c:00.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000200009810
[    2.214266] mmc0: SDHCI controller on PCI [0000:71:00.0] using ADMA
[    2.214323] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
[    2.214325] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.214326] usb usb3: Product: xHCI Host Controller
[    2.214327] usb usb3: Manufacturer: Linux 5.13.8-1-MANJARO xhci-hcd
[    2.214327] usb usb3: SerialNumber: 0000:3c:00.0
[    2.214382] hub 3-0:1.0: USB hub found
[    2.214395] hub 3-0:1.0: 2 ports detected
[    2.216259] xhci_hcd 0000:3c:00.0: xHCI Host Controller
[    2.216261] xhci_hcd 0000:3c:00.0: new USB bus registered, assigned bus number 4
[    2.216262] xhci_hcd 0000:3c:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    2.216287] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
[    2.216288] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.216289] usb usb4: Product: xHCI Host Controller
[    2.216290] usb usb4: Manufacturer: Linux 5.13.8-1-MANJARO xhci-hcd
[    2.216291] usb usb4: SerialNumber: 0000:3c:00.0
[    2.216352] hub 4-0:1.0: USB hub found
[    2.216365] hub 4-0:1.0: 2 ports detected
[    2.234663] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[    2.271158] random: fast init done
[    2.458010] usb 1-4: new high-speed USB device number 2 using xhci_hcd
[    2.626048] usb 1-4: New USB device found, idVendor=5986, idProduct=114e, bcdDevice=55.21
[    2.626051] usb 1-4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    2.626052] usb 1-4: Product: Integrated Camera
[    2.626053] usb 1-4: Manufacturer: Bison
[    2.626054] usb 1-4: SerialNumber: 200901010001
[    2.748018] usb 1-5: new full-speed USB device number 3 using xhci_hcd
[    2.844664] tsc: Refined TSC clocksource calibration: 2303.998 MHz
[    2.844670] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2135f5e6f15, max_idle_ns: 440795231538 ns
[    2.844781] clocksource: Switched to clocksource tsc
[    2.845467] EXT4-fs (nvme0n1p5): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    2.889597] usb 1-5: New USB device found, idVendor=06cb, idProduct=00be, bcdDevice= 0.00
[    2.889602] usb 1-5: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[    2.889605] usb 1-5: SerialNumber: 55bb36005fb5
[    2.935579] systemd[1]: systemd 248.7-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    2.951778] systemd[1]: Detected architecture x86-64.
[    2.953275] systemd[1]: Hostname set to <ameen-81nw>.
[    3.014678] usb 1-14: new full-speed USB device number 4 using xhci_hcd
[    3.073662] random: lvmconfig: uninitialized urandom read (4 bytes read)
[    3.136203] systemd[1]: Queued start job for default target Graphical Interface.
[    3.137332] systemd[1]: Created slice Slice /system/getty.
[    3.137516] systemd[1]: Created slice Slice /system/modprobe.
[    3.137717] systemd[1]: Created slice Slice /system/systemd-fsck.
[    3.137848] systemd[1]: Created slice User and Session Slice.
[    3.137903] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.138037] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.138076] systemd[1]: Reached target Login Prompts.
[    3.138188] systemd[1]: Reached target Remote File Systems.
[    3.138223] systemd[1]: Reached target Slice Units.
[    3.138281] systemd[1]: Reached target Swaps.
[    3.138329] systemd[1]: Reached target Local Verity Integrity Protected Volumes.
[    3.138405] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    3.138582] systemd[1]: Listening on LVM2 poll daemon socket.
[    3.139313] systemd[1]: Listening on Process Core Dump Socket.
[    3.139422] systemd[1]: Listening on Journal Audit Socket.
[    3.139489] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.139582] systemd[1]: Listening on Journal Socket.
[    3.139937] systemd[1]: Listening on udev Control Socket.
[    3.140003] systemd[1]: Listening on udev Kernel Socket.
[    3.140492] systemd[1]: Mounting Huge Pages File System...
[    3.140981] systemd[1]: Mounting POSIX Message Queue File System...
[    3.141527] systemd[1]: Mounting Kernel Debug File System...
[    3.142040] systemd[1]: Mounting Kernel Trace File System...
[    3.142863] systemd[1]: Mounting Temporary Directory /tmp...
[    3.143402] systemd[1]: Starting Load AppArmor profiles...
[    3.143920] systemd[1]: Starting Create List of Static Device Nodes...
[    3.144401] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    3.144951] systemd[1]: Starting Load Kernel Module configfs...
[    3.145446] systemd[1]: Starting Load Kernel Module drm...
[    3.145926] systemd[1]: Starting Load Kernel Module fuse...
[    3.146310] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    3.146335] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    3.146454] random: lvm: uninitialized urandom read (4 bytes read)
[    3.147093] systemd[1]: Starting Load Kernel Modules...
[    3.147560] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.147613] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[    3.148032] systemd[1]: Starting Coldplug All udev Devices...
[    3.148492] systemd[1]: Starting Setup Virtual Console...
[    3.149408] Linux agpgart interface v0.103
[    3.149838] systemd[1]: Mounted Huge Pages File System.
[    3.149959] systemd[1]: Mounted POSIX Message Queue File System.
[    3.150064] systemd[1]: Mounted Kernel Debug File System.
[    3.150170] systemd[1]: Mounted Kernel Trace File System.
[    3.150279] systemd[1]: Mounted Temporary Directory /tmp.
[    3.150501] systemd[1]: Finished Create List of Static Device Nodes.
[    3.150725] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    3.150873] systemd[1]: Finished Load Kernel Module configfs.
[    3.151264] EXT4-fs (nvme0n1p5): re-mounted. Opts: (null). Quota mode: none.
[    3.151505] systemd[1]: Mounting Kernel Configuration File System...
[    3.152190] systemd[1]: Finished Remount Root and Kernel File Systems.
[    3.152284] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[    3.152564] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    3.153008] systemd[1]: Starting Load/Save Random Seed...
[    3.153058] systemd[1]: Condition check resulted in Create System Users being skipped.
[    3.153432] systemd[1]: Starting Create Static Device Nodes in /dev...
[    3.153722] i2c /dev entries driver
[    3.153830] systemd[1]: Mounted Kernel Configuration File System.
[    3.154135] systemd[1]: Finished Load Kernel Modules.
[    3.154579] systemd[1]: Starting Apply Kernel Variables...
[    3.156173] fuse: init (API version 7.34)
[    3.156717] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[    3.156719] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.156958] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    3.157070] systemd[1]: Finished Load Kernel Module fuse.
[    3.159514] systemd[1]: Finished Apply Kernel Variables.
[    3.161159] systemd[1]: Mounting FUSE Control File System...
[    3.162994] systemd[1]: Starting CLI Netfilter Manager...
[    3.167300] systemd[1]: Mounted FUSE Control File System.
[    3.175216] systemd[1]: Finished Create Static Device Nodes in /dev.
[    3.180268] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[    3.184296] systemd[1]: Starting Journal Service...
[    3.187563] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    3.189788] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    3.190041] systemd[1]: Finished Load Kernel Module drm.
[    3.192183] systemd[1]: Finished Setup Virtual Console.
[    3.194216] audit: type=1130 audit(1628880261.809:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-vconsole-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.194466] systemd[1]: Finished CLI Netfilter Manager.
[    3.199573] audit: type=1130 audit(1628880261.816:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.232695] systemd[1]: Finished Coldplug All udev Devices.
[    3.232753] audit: type=1130 audit(1628880261.849:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.236806] audit: type=1400 audit(1628880261.852:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=371 comm="apparmor_parser"
[    3.237487] audit: type=1400 audit(1628880261.852:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=371 comm="apparmor_parser"
[    3.243952] systemd[1]: Started Rule-based Manager for Device Events and Files.
[    3.243991] audit: type=1130 audit(1628880261.859:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.244635] systemd[1]: Starting Show Plymouth Boot Screen...
[    3.260127] audit: type=1400 audit(1628880261.876:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=370 comm="apparmor_parser"
[    3.269069] systemd[1]: Started Show Plymouth Boot Screen.
[    3.269168] audit: type=1130 audit(1628880261.886:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=plymouth-start comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.269303] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[    3.269442] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[    3.269503] systemd[1]: Reached target Local Encrypted Volumes.
[    3.269724] systemd[1]: Started Journal Service.
[    3.273540] audit: type=1130 audit(1628880261.889:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.281427] systemd-journald[382]: Received client request to flush runtime journal.
[    3.312548] random: mktemp: uninitialized urandom read (6 bytes read)
[    3.320407] input: Intel HID events as /devices/platform/INT33D5:00/input/input4
[    3.321041] intel-hid INT33D5:00: platform supports 5 button array
[    3.321140] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input5
[    3.328224] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    3.328232] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    3.328236] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    3.328240] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    3.328733] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[    3.411660] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    3.412037] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    3.412076] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    3.422601] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    3.422695] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    3.423475] input: PC Speaker as /devices/platform/pcspkr/input/input6
[    3.432958] intel-spi 0000:00:1f.5: XM25QH128A (16384 Kbytes)
[    3.433295] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[    3.433326] intel_rapl_common: Found RAPL domain package
[    3.433328] intel_rapl_common: Found RAPL domain dram
[    3.435094] Creating 1 MTD partitions on "0000:00:1f.5":
[    3.435097] 0x000000000000-0x000001000000 : "BIOS"
[    3.462390] i2c i2c-0: 2/2 memory slots populated (from DMI)
[    3.462922] i2c i2c-0: Successfully instantiated SPD at 0x50
[    3.469543] random: crng init done
[    3.469545] random: 5 urandom warning(s) missed due to ratelimiting
[    3.528811] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input7
[    3.528821] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    3.529164] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    3.688930] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    3.688932] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    3.688932] RAPL PMU: hw unit of domain package 2^-14 Joules
[    3.688933] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    3.688933] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    3.774136] input: MSFT0001:02 06CB:CD3E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:02/0018:06CB:CD3E.0001/input/input8
[    3.774187] input: MSFT0001:02 06CB:CD3E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:02/0018:06CB:CD3E.0001/input/input9
[    3.774226] hid-generic 0018:06CB:CD3E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:02 06CB:CD3E] on i2c-MSFT0001:02
[    3.830848] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.832633] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.917639] cryptd: max_cpu_qlen set to 1000
[    3.927114] checking generic (4000000000 1fb0000) vs hw (604a000000 1000000)
[    3.927124] checking generic (4000000000 1fb0000) vs hw (4000000000 10000000)
[    3.927130] fb0: switching to inteldrmfb from EFI VGA
[    3.937714] Console: switching to colour dummy device 80x25
[    3.937814] i915 0000:00:02.0: vgaarb: deactivate vga console
[    3.945379] AVX2 version of gcm_enc/dec engaged.
[    3.945423] AES CTR mode by8 optimization enabled
[    3.995165] ideapad_acpi VPC2004:00: DYTC interface is not available
[    3.998595] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    3.999407] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[    4.011299] i915 0000:00:02.0: [drm] [ENCODER:102:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
[    4.015191] i915 0000:00:02.0: [drm] [ENCODER:118:DDI C/PHY C] is disabled/in DSI mode with an ungated DDI clock, gate it
[    4.041661] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[    4.042392] ACPI: video: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[    4.042403] ACPI: video: Video Device [PEGP] (multi-head: yes  rom: yes  post: no)
[    4.042421] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input11
[    4.043915] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    4.044057] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input12
[    4.044802] iTCO_vendor_support: vendor-support=0
[    4.107474] fbcon: i915drmfb (fb0) is primary device
[    4.129620] Intel(R) Wireless WiFi driver for Linux
[    4.134666] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[    4.134674] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[    4.134678] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[    4.134681] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[    4.134683] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[    4.134686] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[    4.134690] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[    4.134693] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[    4.134696] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[    4.134700] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[    4.134702] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[    4.134706] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[    4.134709] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[    4.134713] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[    4.134716] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[    4.134720] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[    4.134722] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[    4.135396] iwlwifi 0000:00:14.3: loaded firmware version 46.6b541b68.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[    4.140442] Bluetooth: Core ver 2.22
[    4.140475] NET: Registered protocol family 31
[    4.140476] Bluetooth: HCI device and connection manager initialized
[    4.140481] Bluetooth: HCI socket layer initialized
[    4.140484] Bluetooth: L2CAP socket layer initialized
[    4.140488] Bluetooth: SCO socket layer initialized
[    4.143885] intel_rapl_common: Found RAPL domain package
[    4.143889] intel_rapl_common: Found RAPL domain core
[    4.143891] intel_rapl_common: Found RAPL domain uncore
[    4.143893] intel_rapl_common: Found RAPL domain dram
[    4.145568] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[    4.145599] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[    4.146032] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[    4.214677] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[    4.214841] ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210331/nsarguments-61)
[    4.214917] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210331/nsarguments-61)
[    4.218792] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[    4.219151] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    4.229935] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[    4.229946] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.PEG0.PEGP handle
[    4.229949] nouveau: detected PR support, will not use DSM
[    4.229996] nouveau 0000:01:00.0: enabling device (0106 -> 0107)
[    4.292243] input: MSFT0001:02 06CB:CD3E Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:02/0018:06CB:CD3E.0001/input/input13
[    4.292402] input: MSFT0001:02 06CB:CD3E Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:02/0018:06CB:CD3E.0001/input/input14
[    4.292533] hid-multitouch 0018:06CB:CD3E.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:02 06CB:CD3E] on i2c-MSFT0001:02
[    4.382364] usbcore: registered new interface driver btusb
[    4.383385] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
[    4.384377] Bluetooth: hci0: Device revision is 2
[    4.384387] Bluetooth: hci0: Secure boot is enabled
[    4.384393] Bluetooth: hci0: OTP lock is enabled
[    4.384396] Bluetooth: hci0: API lock is enabled
[    4.384399] Bluetooth: hci0: Debug lock is disabled
[    4.384404] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    4.386819] Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
[    4.402715] mousedev: PS/2 mouse device common for all mice
[    4.514791] loop: module loaded
[    4.523815] loop0: detected capacity change from 0 to 133320
[    4.524072] loop1: detected capacity change from 0 to 337424
[    4.524378] loop2: detected capacity change from 0 to 691192
[    4.524692] loop3: detected capacity change from 0 to 113536
[    4.525009] loop4: detected capacity change from 0 to 66144
[    4.525240] loop5: detected capacity change from 0 to 620696
[    4.525490] loop6: detected capacity change from 0 to 113544
[    4.572303] intel_tcc_cooling: Programmable TCC Offset detected
[    4.699287] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    4.710704] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz, REV=0x318
[    4.717580] thermal thermal_zone9: failed to read out thermal zone (-61)
[    4.768007] iwlwifi 0000:00:14.3: base HW address: 14:f6:d8:26:a8:9a
[    4.836212] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    4.840592] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[    4.913247] snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[    4.913261] snd_soc_skl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[    4.968895] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[    4.968905] sof-audio-pci-intel-cnl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[    4.968920] sof-audio-pci-intel-cnl 0000:00:1f.3: enabling device (0000 -> 0002)
[    4.969048] sof-audio-pci-intel-cnl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[    5.241236] Console: switching to colour frame buffer device 240x67
[    5.257904] sof-audio-pci-intel-cnl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    5.264854] sof-audio-pci-intel-cnl 0000:00:1f.3: use msi interrupt mode
[    5.297088] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[    5.297390] kauditd_printk_skb: 15 callbacks suppressed
[    5.297395] audit: type=1130 audit(1628880263.912:23): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.297657] nouveau 0000:01:00.0: NVIDIA TU117 (167000a1)
[    5.338786] audit: type=1130 audit(1628880263.956:24): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=plymouth-read-write comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.361152] audit: type=1130 audit(1628880263.976:25): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.363199] audit: type=1334 audit(1628880263.979:26): prog-id=10 op=LOAD
[    5.376668] audit: type=1127 audit(1628880263.992:27): pid=905 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[    5.376741] audit: type=1130 audit(1628880263.992:28): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.384562] audit: type=1130 audit(1628880263.999:29): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.410274] sof-audio-pci-intel-cnl 0000:00:1f.3: hda codecs found, mask 5
[    5.410276] sof-audio-pci-intel-cnl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[    5.410279] sof-audio-pci-intel-cnl 0000:00:1f.3: DMICs detected in NHLT tables: 2
[    5.411042] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware info: version 1:8:0-9e7a8
[    5.411044] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware: ABI 3:18:1 Kernel ABI 3:18:0
[    5.411047] sof-audio-pci-intel-cnl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[    5.418949] audit: type=1130 audit(1628880264.036:30): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.422812] audit: type=1130 audit(1628880264.039:31): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.425799] audit: type=1334 audit(1628880264.042:32): prog-id=11 op=LOAD
[    5.443838] nouveau 0000:01:00.0: bios: version 90.17.2c.00.0e
[    5.447132] nouveau 0000:01:00.0: pmu: firmware unavailable
[    5.450500] nouveau 0000:01:00.0: fb: 4096 MiB GDDR5
[    5.499201] vga_switcheroo: enabled
[    5.499222] nouveau 0000:01:00.0: DRM: VRAM: 4096 MiB
[    5.499224] nouveau 0000:01:00.0: DRM: GART: 536870912 MiB
[    5.499226] nouveau 0000:01:00.0: DRM: BIT table 'A' not found
[    5.499227] nouveau 0000:01:00.0: DRM: BIT table 'L' not found
[    5.499229] nouveau 0000:01:00.0: DRM: Pointer to TMDS table not found
[    5.499230] nouveau 0000:01:00.0: DRM: DCB version 4.1
[    5.499551] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[    5.499687] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
[    5.499690] nouveau 0000:01:00.0: DRM: Disabling PCI power management to avoid bug
[    5.500600] loop7: detected capacity change from 0 to 8
[    5.528840] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware info: version 1:8:0-9e7a8
[    5.528855] sof-audio-pci-intel-cnl 0000:00:1f.3: Firmware: ABI 3:18:1 Kernel ABI 3:18:0
[    5.581909] sof-audio-pci-intel-cnl 0000:00:1f.3: Topology: ABI 3:18:1 Kernel ABI 3:18:0
[    5.583690] mc: Linux media interface: v0.10
[    5.603804] sof-audio-pci-intel-cnl 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
[    5.625644] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC285: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[    5.625655] snd_hda_codec_realtek ehdaudio0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    5.625660] snd_hda_codec_realtek ehdaudio0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    5.625665] snd_hda_codec_realtek ehdaudio0D0:    mono: mono_out=0x0
[    5.625668] snd_hda_codec_realtek ehdaudio0D0:    inputs:
[    5.625670] snd_hda_codec_realtek ehdaudio0D0:      Mic=0x19
[    5.648892] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    5.648894] Bluetooth: BNEP filters: protocol multicast
[    5.648896] Bluetooth: BNEP socket layer initialized
[    5.651802] videodev: Linux video capture interface: v2.00
[    5.712262] snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
[    5.712267] snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
[    5.712364] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
[    5.712368] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
[    5.712371] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
[    5.712373] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
[    5.712375] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
[    5.712379] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
[    5.712382] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
[    5.712386] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
[    5.712390] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
[    5.712394] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
[    5.712397] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
[    5.724069] input: sof-hda-dsp Mic as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input16
[    5.724143] input: sof-hda-dsp Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input17
[    5.724176] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input18
[    5.724200] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input19
[    5.724229] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input20
[    5.782566] usb 1-4: Found UVC 1.10 device Integrated Camera (5986:114e)
[    5.787895] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/input/input21
[    5.787931] usbcore: registered new interface driver uvcvideo
[    6.009861] Bluetooth: hci0: Waiting for firmware download to complete
[    6.010357] Bluetooth: hci0: Firmware loaded in 1585476 usecs
[    6.010494] Bluetooth: hci0: Waiting for device to boot
[    6.024394] Bluetooth: hci0: Device booted in 13645 usecs
[    6.024586] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-17-16-1.ddc
[    6.026388] Bluetooth: hci0: Applying Intel DDC parameters completed
[    6.029396] Bluetooth: hci0: Firmware revision 0.1 build 6 week 12 2021
[    6.088371] Bluetooth: hci0: MSFT filter_enable is already on
[    6.112812] NET: Registered protocol family 38
[    7.718757] rfkill: input handler disabled
[   10.576494] kauditd_printk_skb: 55 callbacks suppressed
[   10.576501] audit: type=1131 audit(1628880269.192:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.613661] audit: type=1100 audit(1628880271.229:83): pid=1582 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="ameenshake" exe="/usr/lib/gdm-session-worker" hostname=ameen-81nw addr=? terminal=/dev/tty1 res=success'
[   12.615114] audit: type=1101 audit(1628880271.232:84): pid=1582 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="ameenshake" exe="/usr/lib/gdm-session-worker" hostname=ameen-81nw addr=? terminal=/dev/tty1 res=success'
[   12.615948] audit: type=1103 audit(1628880271.232:85): pid=1582 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="ameenshake" exe="/usr/lib/gdm-session-worker" hostname=ameen-81nw addr=? terminal=/dev/tty1 res=success'
[   12.618704] audit: type=1006 audit(1628880271.236:86): pid=1582 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[   12.618707] audit: type=1300 audit(1628880271.236:86): arch=c000003e syscall=1 success=yes exit=4 a0=a a1=7fff2d5fcf90 a2=4 a3=3e8 items=0 ppid=944 pid=1582 auid=1000 uid=0 gid=1000 euid=0 suid=0 fsuid=0 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=3 comm="gdm-session-wor" exe="/usr/lib/gdm-session-worker" subj==unconfined key=(null)
[   12.618708] audit: type=1327 audit(1628880271.236:86): proctitle=67646D2D73657373696F6E2D776F726B6572205B70616D2F67646D2D70617373776F72645D
[   12.629327] audit: type=1130 audit(1628880271.246:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.633111] audit: type=1101 audit(1628880271.249:88): pid=1592 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="ameenshake" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.633114] audit: type=1103 audit(1628880271.249:89): pid=1592 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="ameenshake" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   12.839395] wlp0s20f3: authenticate with 8e:15:54:ab:bd:55
[   12.844473] wlp0s20f3: send auth to 8e:15:54:ab:bd:55 (try 1/3)
[   12.897303] wlp0s20f3: authenticated
[   12.898085] wlp0s20f3: associate with 8e:15:54:ab:bd:55 (try 1/3)
[   12.900752] wlp0s20f3: RX AssocResp from 8e:15:54:ab:bd:55 (capab=0x1501 status=0 aid=20)
[   12.902864] wlp0s20f3: associated
[   12.903256] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
[   12.911128] wlp0s20f3: Limiting TX power to 27 (30 - 3) dBm as advertised by 8e:15:54:ab:bd:55
[   13.026913] rfkill: input handler enabled
[   15.222250] Bluetooth: RFCOMM TTY layer initialized
[   15.222259] Bluetooth: RFCOMM socket layer initialized
[   15.222264] Bluetooth: RFCOMM ver 1.11
[   15.399533] rfkill: input handler disabled
[   16.018682] kauditd_printk_skb: 16 callbacks suppressed
[   16.018689] audit: type=1131 audit(1628880274.636:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.272349] audit: type=1106 audit(1628880275.889:103): pid=978 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=ameen-81nw addr=? terminal=/dev/tty1 res=success'
[   17.272521] audit: type=1104 audit(1628880275.889:104): pid=978 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=ameen-81nw addr=? terminal=/dev/tty1 res=success'
[   27.668720] audit: type=1131 audit(1628880286.286:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   27.673298] audit: type=1131 audit(1628880286.289:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   38.121030] audit: type=1131 audit(1628880296.659:107): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   38.270901] audit: type=1334 audit(1628880296.806:108): prog-id=23 op=UNLOAD
[   46.201794] audit: type=1131 audit(1628880304.542:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   46.205654] audit: type=1131 audit(1628880304.546:110): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   46.345760] audit: type=1334 audit(1628880304.684:111): prog-id=16 op=UNLOAD
[   46.345774] audit: type=1334 audit(1628880304.684:112): prog-id=15 op=UNLOAD
[   46.345782] audit: type=1334 audit(1628880304.684:113): prog-id=14 op=UNLOAD
[   46.471527] audit: type=1334 audit(1628880304.809:114): prog-id=20 op=UNLOAD
[   46.471541] audit: type=1334 audit(1628880304.809:115): prog-id=19 op=UNLOAD
[   46.471547] audit: type=1334 audit(1628880304.809:116): prog-id=18 op=UNLOAD
[   68.393992] audit: type=1131 audit(1628880326.633:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  812.856284] audit: type=1101 audit(1628881071.114:118): pid=4523 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ameenshake" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  812.856685] audit: type=1110 audit(1628881071.114:119): pid=4523 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  812.858290] audit: type=1105 audit(1628881071.114:120): pid=4523 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  812.880429] audit: type=1106 audit(1628881071.138:121): pid=4523 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  812.880565] audit: type=1104 audit(1628881071.138:122): pid=4523 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  833.211336] audit: type=1101 audit(1628881091.468:123): pid=4945 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ameenshake" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  835.691204] audit: type=1101 audit(1628881093.948:124): pid=5000 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ameenshake" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  835.691646] audit: type=1110 audit(1628881093.948:125): pid=5000 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  835.699012] audit: type=1105 audit(1628881093.958:126): pid=5000 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  905.988853] audit: type=1130 audit(1628881164.246:127): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  905.988867] audit: type=1131 audit(1628881164.246:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1040.863064] audit: type=1106 audit(1628881299.125:129): pid=5000 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1040.863196] audit: type=1104 audit(1628881299.125:130): pid=5000 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1056.585547] audit: type=1101 audit(1628881314.844:131): pid=5501 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ameenshake" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1056.585924] audit: type=1110 audit(1628881314.844:132): pid=5501 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1056.591769] audit: type=1105 audit(1628881314.851:133): pid=5501 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1056.917635] audit: type=1106 audit(1628881315.177:134): pid=5501 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1056.917638] audit: type=1104 audit(1628881315.177:135): pid=5501 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1071.550720] audit: type=1101 audit(1628881329.810:136): pid=5597 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ameenshake" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1071.550829] audit: type=1110 audit(1628881329.810:137): pid=5597 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1071.552667] audit: type=1105 audit(1628881329.810:138): pid=5597 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1079.376702] audit: type=1106 audit(1628881337.633:139): pid=5597 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1079.376706] audit: type=1104 audit(1628881337.633:140): pid=5597 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1150.222666] audit: type=1101 audit(1628881408.481:141): pid=6296 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ameenshake" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1150.222745] audit: type=1110 audit(1628881408.481:142): pid=6296 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1150.224146] audit: type=1105 audit(1628881408.481:143): pid=6296 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1176.133791] audit: type=1334 audit(1628881434.391:144): prog-id=25 op=LOAD
[ 1176.133940] audit: type=1334 audit(1628881434.391:145): prog-id=26 op=LOAD
[ 1176.134099] audit: type=1334 audit(1628881434.391:146): prog-id=27 op=LOAD
[ 1176.156429] audit: type=1130 audit(1628881434.414:147): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1206.208173] audit: type=1131 audit(1628881464.464:148): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1206.326800] audit: type=1334 audit(1628881464.584:149): prog-id=27 op=UNLOAD
[ 1206.326813] audit: type=1334 audit(1628881464.584:150): prog-id=26 op=UNLOAD
[ 1206.326820] audit: type=1334 audit(1628881464.584:151): prog-id=25 op=UNLOAD
[ 1628.134562] audit: type=1334 audit(1628881886.390:152): prog-id=28 op=LOAD
[ 1628.170963] audit: type=1130 audit(1628881886.426:153): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1630.406401] audit: type=1100 audit(1628881888.660:154): pid=6742 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="ameenshake" exe="/usr/lib/gdm-session-worker" hostname=ameen-81nw addr=? terminal=/dev/tty1 res=success'
[ 1630.410450] audit: type=1101 audit(1628881888.663:155): pid=6742 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="ameenshake" exe="/usr/lib/gdm-session-worker" hostname=ameen-81nw addr=? terminal=/dev/tty1 res=success'
[ 1630.412933] audit: type=1110 audit(1628881888.666:156): pid=6742 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="ameenshake" exe="/usr/lib/gdm-session-worker" hostname=ameen-81nw addr=? terminal=/dev/tty1 res=success'
[ 1658.407322] audit: type=1131 audit(1628881916.663:157): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1658.554015] audit: type=1334 audit(1628881916.810:158): prog-id=28 op=UNLOAD
[ 1840.800502] audit: type=1101 audit(1628882099.058:159): pid=7234 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ameenshake" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1840.800896] audit: type=1110 audit(1628882099.058:160): pid=7234 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1840.807355] audit: type=1105 audit(1628882099.065:161): pid=7234 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
** dmesg usb only**
[    1.741543] usbcore: registered new interface driver usbfs
[    1.741543] usbcore: registered new interface driver hub
[    1.741543] usbcore: registered new device driver usb
dmesg --level emerg,alert,crit,err,warn
[    0.168689] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.243666] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._ON], AE_ALREADY_EXISTS (20210331/dswload2-326)
[    0.243689] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210331/psobject-220)
[    0.243698] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._OFF], AE_ALREADY_EXISTS (20210331/dswload2-326)
[    0.243705] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210331/psobject-220)
[    0.243711] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP.SGPO], AE_ALREADY_EXISTS (20210331/dswload2-326)
[    0.243717] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210331/psobject-220)
journalctl --catalog --priority=3 --boot=-1
-- Journal begins at Mon 2021-08-09 17:05:25 PDT, ends at Fri 2021-08-13 12:18:11 PDT. --
Aug 12 16:56:39 ameen-81nw kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._ON], AE_ALREADY_EXISTS (20210331/dswload2-326)
Aug 12 16:56:39 ameen-81nw kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210331/psobject-220)
Aug 12 16:56:39 ameen-81nw kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._OFF], AE_ALREADY_EXISTS (20210331/dswload2-326)
Aug 12 16:56:39 ameen-81nw kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP.SGPO], AE_ALREADY_EXISTS (20210331/dswload2-326)
Aug 12 16:56:41 ameen-81nw kernel: snd_hda_codec_hdmi ehdaudio0D2: Monitor plugged-in, Failed to power up codec ret=[-13]
Aug 12 16:56:41 ameen-81nw wpa_supplicant[1122]: nl80211: kernel reports: Attribute failed policy validation
Aug 12 16:56:41 ameen-81nw wpa_supplicant[1122]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 12 16:56:41 ameen-81nw wpa_supplicant[1122]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 12 16:56:43 ameen-81nw bluetoothd[1194]: Failed to set mode: Blocked through rfkill (0x12)
Aug 12 16:56:56 ameen-81nw gdm-password][1823]: gkr-pam: unable to locate daemon control file
Aug 12 16:57:01 ameen-81nw gdm-launch-environment][1003]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Aug 12 16:57:14 ameen-81nw kernel: Bluetooth: hci0: unexpected event for opcode 0xfc1e
Aug 12 16:57:29 ameen-81nw pulseaudio[2015]: org.freedesktop.DBus.Properties.Get /org/bluez/hci0/dev_1C_52_16_C1_EE_4C/sep1/fd0 Volume failed: org.freedesktop.DBus.Error.InvalidArgs: No such property 'Volume'
Aug 12 17:13:29 ameen-81nw bluetoothd[1194]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Aug 12 17:28:29 ameen-81nw bluetoothd[1194]: src/service.c:btd_service_connect() a2dp-sink profile connect failed for 1C:52:16:C1:EE:4C: Device or resource busy
Aug 12 17:28:30 ameen-81nw pulseaudio[2015]: org.freedesktop.DBus.Properties.Get /org/bluez/hci0/dev_1C_52_16_C1_EE_4C/sep1/fd1 Volume failed: org.freedesktop.DBus.Error.InvalidArgs: No such property 'Volume'
Aug 12 17:37:44 ameen-81nw bluetoothd[1194]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Aug 12 17:38:17 ameen-81nw bluetoothd[1194]: src/service.c:btd_service_connect() a2dp-sink profile connect failed for 1C:52:16:C1:EE:4C: Device or resource busy
Aug 12 17:38:18 ameen-81nw pulseaudio[2015]: org.freedesktop.DBus.Properties.Get /org/bluez/hci0/dev_1C_52_16_C1_EE_4C/sep1/fd2 Volume failed: org.freedesktop.DBus.Error.InvalidArgs: No such property 'Volume'
Aug 12 17:38:47 ameen-81nw bluetoothd[1194]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Aug 12 17:38:55 ameen-81nw bluetoothd[1194]: src/service.c:btd_service_connect() a2dp-sink profile connect failed for 1C:52:16:C1:EE:4C: Device or resource busy
Aug 12 17:38:56 ameen-81nw pulseaudio[2015]: org.freedesktop.DBus.Properties.Get /org/bluez/hci0/dev_1C_52_16_C1_EE_4C/sep1/fd3 Volume failed: org.freedesktop.DBus.Error.InvalidArgs: No such property 'Volume'
Aug 12 17:40:38 ameen-81nw bluetoothd[1194]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Aug 12 17:41:09 ameen-81nw bluetoothd[1194]: src/service.c:btd_service_connect() a2dp-sink profile connect failed for 1C:52:16:C1:EE:4C: Device or resource busy
Aug 12 17:41:10 ameen-81nw pulseaudio[2015]: org.freedesktop.DBus.Properties.Get /org/bluez/hci0/dev_1C_52_16_C1_EE_4C/sep1/fd4 Volume failed: org.freedesktop.DBus.Error.InvalidArgs: No such property 'Volume'
Aug 12 17:42:02 ameen-81nw bluetoothd[1194]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Aug 12 17:42:04 ameen-81nw bluetoothd[1194]: src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to 1C:52:16:C1:EE:4C: Connection refused (111)
Aug 12 17:42:04 ameen-81nw bluetoothd[1194]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 1C:52:16:C1:EE:4C: Connection refused (111)
Aug 12 17:42:17 ameen-81nw pulseaudio[2015]: org.freedesktop.DBus.Properties.Get /org/bluez/hci0/dev_1C_52_16_C1_EE_4C/sep1/fd5 Volume failed: org.freedesktop.DBus.Error.InvalidArgs: No such property 'Volume'
Aug 12 17:45:28 ameen-81nw bluetoothd[1194]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Aug 12 18:17:11 ameen-81nw wpa_supplicant[1122]: nl80211: kernel reports: Attribute failed policy validation
Aug 12 18:17:11 ameen-81nw wpa_supplicant[1122]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 12 18:17:11 ameen-81nw wpa_supplicant[1122]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 12 22:04:04 ameen-81nw wpa_supplicant[1122]: nl80211: kernel reports: Attribute failed policy validation
Aug 12 22:04:04 ameen-81nw wpa_supplicant[1122]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 12 22:04:04 ameen-81nw wpa_supplicant[1122]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 12 23:14:10 ameen-81nw kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPCB.EC0._Q37.POWS], AE_NOT_FOUND (20210331/psargs-330)
Aug 12 23:14:10 ameen-81nw kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q37 due to previous error (AE_NOT_FOUND) (20210331/psparse-529)
Aug 12 23:14:11 ameen-81nw wpa_supplicant[1122]: nl80211: kernel reports: Attribute failed policy validation
Aug 12 23:14:11 ameen-81nw wpa_supplicant[1122]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 12 23:14:11 ameen-81nw wpa_supplicant[1122]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 12 23:14:12 ameen-81nw kernel: i915 0000:00:02.0: [drm] *ERROR* failed to enable link training
Aug 12 23:14:30 ameen-81nw systemd-coredump[16283]: Process 16261 (node) of user 1000 dumped core.
                                                    Stack trace of thread 16261:
                                                    #0  0x00007ff732dd7d22 n/a (n/a + 0x0)
░░ Subject: Process 16261 (node) dumped core
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Process 16261 (node) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Aug 12 23:14:31 ameen-81nw systemd-coredump[16294]: Process 7355 (node) of user 1000 dumped core.
                                                    Stack trace of thread 7355:
                                                    #0  0x00007f61d4494d22 raise (libc.so.6 + 0x3cd22)
                                                    #1  0x00007f61d447e862 abort (libc.so.6 + 0x26862)
                                                    #2  0x0000000000a1a651 n/a (/home/ameenshake/.nvm/versions/node/v12.22.4/bin/node + 0x61a651)
                                                    #3  0x0000000000a1a6be n/a (/home/ameenshake/.nvm/versions/node/v12.22.4/bin/node + 0x61a6be)
                                                    #4  0x00000000009e6db0 n/a (/home/ameenshake/.nvm/versions/node/v12.22.4/bin/node + 0x5e6db0)
                                                    #5  0x0000000000a5d5ca n/a (/home/ameenshake/.nvm/versions/node/v12.22.4/bin/node + 0x65d5ca)
                                                    #6  0x00000000009eab6c n/a (/home/ameenshake/.nvm/versions/node/v12.22.4/bin/node + 0x5eab6c)
                                                    #7  0x00007f61d447fb25 __libc_start_main (libc.so.6 + 0x27b25)
                                                    #8  0x0000000000982005 n/a (/home/ameenshake/.nvm/versions/node/v12.22.4/bin/node + 0x582005)
░░ Subject: Process 7355 (node) dumped core
░░ Process 7355 (node) crashed and dumped core.
Aug 13 07:58:54 ameen-81nw systemd[1]: Failed to start pkgfile database update.
░░ Subject: A start job for unit pkgfile-update.service has failed
░░ A start job for unit pkgfile-update.service has finished with a failure.
░░ The job identifier is 2647 and the job result is failed.
Aug 13 07:58:54 ameen-81nw wpa_supplicant[1122]: nl80211: kernel reports: Attribute failed policy validation
Aug 13 07:58:54 ameen-81nw wpa_supplicant[1122]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 13 07:58:54 ameen-81nw wpa_supplicant[1122]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 13 07:59:03 ameen-81nw kernel: usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
Aug 13 07:59:07 ameen-81nw kernel: usb usb4-port2: Cannot enable. Maybe the USB cable is bad?
Aug 13 08:00:57 ameen-81nw pulseaudio[2015]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Aug 13 08:00:57 ameen-81nw pulseaudio[2015]: Most likely this is a bug in the ALSA driver 'snd_usb_audio'. Please report this issue to the ALSA developers.
Aug 13 08:00:57 ameen-81nw pulseaudio[2015]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Aug 13 09:01:29 ameen-81nw kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPCB.EC0._Q37.POWS], AE_NOT_FOUND (20210331/psargs-330)
Aug 13 09:01:29 ameen-81nw kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q37 due to previous error (AE_NOT_FOUND) (20210331/psparse-529)
Aug 13 10:03:43 ameen-81nw kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPCB.EC0._Q37.POWS], AE_NOT_FOUND (20210331/psargs-330)
Aug 13 10:03:43 ameen-81nw kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC0._Q37 due to previous error (AE_NOT_FOUND) (20210331/psparse-529)
Aug 13 10:03:45 ameen-81nw kernel: usb 1-3: device descriptor read/64, error -71
Aug 13 10:27:00 ameen-81nw wpa_supplicant[1122]: nl80211: kernel reports: Attribute failed policy validation
Aug 13 10:27:00 ameen-81nw wpa_supplicant[1122]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 13 10:27:00 ameen-81nw wpa_supplicant[1122]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
More logs
cat /var/log/Xorg.1.log
[    69.528] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[    69.528] _XSERVTransMakeAllCOTSServerListeners: server already running
[    69.528] (--) Log file renamed from "/var/log/Xorg.pid-1564.log" to "/var/log/Xorg.1.log"
[    69.528] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[    69.528]
X.Org X Server 1.20.13
[    69.528] Build Operating System: Linux Manjaro Linux
[    69.528] Current Operating System: Linux ameen-81nw 5.10.56-1-MANJARO #1 SMP PREEMPT Thu Aug 5 10:51:27 UTC 2021 x86_64
[    69.528] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a78a2b34-6b4a-4b3f-b902-6a2989c51e5e rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[    69.528] Build Date: 29 July 2021  08:07:46PM
[    69.528]
[    69.528] Current version of pixman: 0.40.0
[    69.528] 	Before reporting problems, check http://wiki.x.org
[    69.528] Markers: (--) probed, (**) from config file, (==) default setting,
[    69.528] (==) Log file: "/var/log/Xorg.1.log", Time: Mon Aug  9 22:14:31 2021
[    69.528] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    69.528] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    69.528] (==) No Layout section.  Using the first Screen section.
[    69.528] (==) No screen section available. Using defaults.
[    69.528] (**) |-->Screen "Default Screen Section" (0)
[    69.528] (**) |   |-->Monitor "<default monitor>"
[    69.529] (==) No monitor specified for screen "Default Screen Section".
[    69.529] (==) Automatically adding devices
[    69.529] (==) Automatically enabling devices
[    69.529] (==) Automatically adding GPU devices
[    69.529] (==) Automatically binding GPU devices
[    69.529] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    69.529] (WW) The directory "/usr/share/fonts/misc" does not exist.
[    69.529] 	Entry deleted from font path.
[    69.529] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    69.529] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    69.529] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    69.529] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    69.529] (==) FontPath set to:
	/usr/share/fonts/TTF
[    69.529] (==) ModulePath set to "/usr/lib/xorg/modules"
[    69.529] (II) The server relies on udev to provide the list of input devices.
[    69.529] (II) Module ABI versions:
[    69.529] 	X.Org ANSI C Emulation: 0.4
[    69.529] 	X.Org Video Driver: 24.1
[    69.529] 	X.Org XInput driver : 24.1
[    69.529] 	X.Org Server Extension : 10.0
[    69.529] (++) using VT number 2
[    69.531] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_36
[    69.531] (II) xfree86: Adding drm device (/dev/dri/card1)
[    69.531] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[    69.531] (II) xfree86: Adding drm device (/dev/dri/card0)
[    69.532] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[    69.533] (--) PCI:*(0@0:2:0) 8086:3e9b:17aa:3f1a rev 2, Mem @ 0x604a000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[    69.533] (--) PCI: (1@0:0:0) 10de:1f91:17aa:3f1a rev 161, Mem @ 0x62000000/16777216, 0x50000000/268435456, 0x60000000/33554432, I/O @ 0x00003000/128
[    69.533] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    69.533] (II) LoadModule: "glx"
[    69.533] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    69.534] (II) Module glx: vendor="X.Org Foundation"
[    69.534] 	compiled for 1.20.13, module version = 1.0.0
[    69.534] 	ABI class: X.Org Server Extension, version 10.0
[    69.534] (==) Matched intel as autoconfigured driver 0
[    69.534] (==) Matched nouveau as autoconfigured driver 1
[    69.534] (==) Matched nv as autoconfigured driver 2
[    69.534] (==) Matched modesetting as autoconfigured driver 3
[    69.534] (==) Matched fbdev as autoconfigured driver 4
[    69.534] (==) Matched vesa as autoconfigured driver 5
[    69.534] (==) Assigned the driver to the xf86ConfigLayout
[    69.534] (II) LoadModule: "intel"
[    69.534] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[    69.534] (II) Module intel: vendor="X.Org Foundation"
[    69.534] 	compiled for 1.20.10, module version = 2.99.917
[    69.534] 	Module class: X.Org Video Driver
[    69.534] 	ABI class: X.Org Video Driver, version 24.1
[    69.534] (II) LoadModule: "nouveau"
[    69.534] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    69.535] (II) Module nouveau: vendor="X.Org Foundation"
[    69.535] 	compiled for 1.20.10, module version = 1.0.17
[    69.535] 	Module class: X.Org Video Driver
[    69.535] 	ABI class: X.Org Video Driver, version 24.1
[    69.535] (II) LoadModule: "nv"
[    69.535] (WW) Warning, couldn't open module nv
[    69.535] (EE) Failed to load module "nv" (module does not exist, 0)
[    69.535] (II) LoadModule: "modesetting"
[    69.535] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    69.535] (II) Module modesetting: vendor="X.Org Foundation"
[    69.535] 	compiled for 1.20.13, module version = 1.20.13
[    69.535] (II) LoadModule: "fbdev"
[    69.535] (WW) Warning, couldn't open module fbdev
[    69.535] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    69.535] (II) LoadModule: "vesa"
[    69.535] (WW) Warning, couldn't open module vesa
[    69.535] (EE) Failed to load module "vesa" (module does not exist, 0)
[    69.535] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[    69.535] (II) intel: Driver for Intel(R) HD Graphics
[    69.535] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[    69.535] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[    69.535] (II) NOUVEAU driver
[    69.535] (II) NOUVEAU driver for NVIDIA chipset families :
[    69.535] 	RIVA TNT            (NV04)
[    69.535] 	RIVA TNT2           (NV05)
[    69.536] 	GeForce 256         (NV10)
[    69.536] 	GeForce 2           (NV11, NV15)
[    69.536] 	GeForce 4MX         (NV17, NV18)
[    69.536] 	GeForce 3           (NV20)
[    69.536] 	GeForce 4Ti         (NV25, NV28)
[    69.536] 	GeForce FX          (NV3x)
[    69.536] 	GeForce 6           (NV4x)
[    69.536] 	GeForce 7           (G7x)
[    69.536] 	GeForce 8           (G8x)
[    69.536] 	GeForce 9           (G9x)
[    69.536] 	GeForce GTX 2xx/3xx (GT2xx)
[    69.536] 	GeForce GTX 4xx/5xx (GFxxx)
[    69.536] 	GeForce GTX 6xx/7xx (GKxxx)
[    69.536] 	GeForce GTX 9xx     (GMxxx)
[    69.536] 	GeForce GTX 10xx    (GPxxx)
[    69.536] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    69.536] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200917
[    69.536] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[    69.552] (WW) Falling back to old probe method for modesetting
[    69.552] (II) [drm] nouveau interface version: 1.3.1
[    69.552] (EE) Unknown chipset: NV167
[    69.552] (II) modeset(G0): using drv /dev/dri/card1
[    69.552] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[    69.552] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 8 threads
[    69.552] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    69.552] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[    69.552] (==) intel(0): RGB weight 888
[    69.552] (==) intel(0): Default visual is TrueColor
[    69.552] (II) intel(0): Output eDP1 has no monitor section
[    69.553] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[    69.553] (II) intel(0): Enabled output eDP1
[    69.553] (II) intel(0): Output DP1 has no monitor section
[    69.553] (II) intel(0): Enabled output DP1
[    69.553] (II) intel(0): Output HDMI1 has no monitor section
[    69.553] (II) intel(0): Enabled output HDMI1
[    69.553] (II) intel(0): Output DP2 has no monitor section
[    69.553] (II) intel(0): Enabled output DP2
[    69.553] (II) intel(0): Output HDMI2 has no monitor section
[    69.553] (II) intel(0): Enabled output HDMI2
[    69.553] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[    69.553] (II) intel(0): Output VIRTUAL1 has no monitor section
[    69.553] (II) intel(0): Enabled output VIRTUAL1
[    69.553] (--) intel(0): Output eDP1 using initial mode 3840x2160 on pipe 0
[    69.553] (==) intel(0): TearFree enabled
[    69.553] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[    69.553] (==) intel(0): DPI set to (96, 96)
[    69.553] (II) Loading sub module "dri3"
[    69.553] (II) LoadModule: "dri3"
[    69.553] (II) Module "dri3" already built-in
[    69.553] (II) Loading sub module "dri2"
[    69.553] (II) LoadModule: "dri2"
[    69.553] (II) Module "dri2" already built-in
[    69.553] (II) Loading sub module "present"
[    69.553] (II) LoadModule: "present"
[    69.553] (II) Module "present" already built-in
[    69.553] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    69.553] (==) modeset(G0): RGB weight 888
[    69.553] (==) modeset(G0): Default visual is TrueColor
[    69.553] (II) Loading sub module "glamoregl"
[    69.553] (II) LoadModule: "glamoregl"
[    69.553] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    69.556] (II) Module glamoregl: vendor="X.Org Foundation"
[    69.556] 	compiled for 1.20.13, module version = 1.0.1
[    69.556] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    69.583] (II) modeset(G0): glamor X acceleration enabled on NV167
[    69.583] (II) modeset(G0): glamor initialized
[    69.583] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    69.583] (==) modeset(G0): DPI set to (96, 96)
[    69.583] (II) Loading sub module "fb"
[    69.583] (II) LoadModule: "fb"
[    69.583] (II) Loading /usr/lib/xorg/modules/libfb.so
[    69.583] (II) Module fb: vendor="X.Org Foundation"
[    69.583] 	compiled for 1.20.13, module version = 1.0.0
[    69.583] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    69.583] (II) intel(0): SNA initialized with Coffeelake (gen9) backend
[    69.583] (==) intel(0): Backing store enabled
[    69.583] (==) intel(0): Silken mouse disabled
[    69.583] (II) intel(0): HW Cursor enabled
[    69.583] (==) intel(0): DPMS enabled
[    69.583] (==) intel(0): Display hotplug detection enabled
[    69.583] (II) intel(0): [DRI2] Setup complete
[    69.583] (II) intel(0): [DRI2]   DRI driver: i965
[    69.583] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[    69.583] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[    69.583] (II) intel(0): hardware support for Present enabled
[    69.592] (==) modeset(G0): Backing store enabled
[    69.592] (==) modeset(G0): Silken mouse disabled
[    69.592] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[    69.592] (==) modeset(G0): DPMS enabled
[    69.592] (II) modeset(G0): [DRI2] Setup complete
[    69.592] (II) modeset(G0): [DRI2]   DRI driver: nouveau
[    69.592] (II) modeset(G0): [DRI2]   VDPAU driver: nouveau
[    69.592] (II) Initializing extension Generic Event Extension
[    69.592] (II) Initializing extension SHAPE
[    69.592] (II) Initializing extension MIT-SHM
[    69.592] (II) Initializing extension XInputExtension
[    69.592] (II) Initializing extension XTEST
[    69.592] (II) Initializing extension BIG-REQUESTS
[    69.592] (II) Initializing extension SYNC
[    69.592] (II) Initializing extension XKEYBOARD
[    69.592] (II) Initializing extension XC-MISC
[    69.592] (II) Initializing extension SECURITY
[    69.592] (II) Initializing extension XFIXES
[    69.592] (II) Initializing extension RENDER
[    69.592] (II) Initializing extension RANDR
[    69.592] (II) Initializing extension COMPOSITE
[    69.592] (II) Initializing extension DAMAGE
[    69.592] (II) Initializing extension MIT-SCREEN-SAVER
[    69.592] (II) Initializing extension DOUBLE-BUFFER
[    69.592] (II) Initializing extension RECORD
[    69.592] (II) Initializing extension DPMS
[    69.592] (II) Initializing extension Present
[    69.592] (II) Initializing extension DRI3
[    69.592] (II) Initializing extension X-Resource
[    69.592] (II) Initializing extension XVideo
[    69.592] (II) Initializing extension XVideo-MotionCompensation
[    69.592] (II) Initializing extension GLX
[    69.597] (II) AIGLX: Loaded and initialized i965
[    69.597] (II) GLX: Initialized DRI2 GL provider for screen 0
[    69.597] (II) Initializing extension XFree86-VidModeExtension
[    69.597] (II) Initializing extension XFree86-DGA
[    69.597] (II) Initializing extension XFree86-DRI
[    69.597] (II) Initializing extension DRI2
[    69.597] (II) modeset(G0): Damage tracking initialized
[    69.605] (II) intel(0): switch to mode 3840x2160@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[    69.612] (II) intel(0): Setting screen physical size to 1016 x 571
[    69.636] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    69.636] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    69.636] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    69.636] (**) Power Button: Applying InputClass "system-keyboard"
[    69.636] (II) LoadModule: "libinput"
[    69.636] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    69.637] (II) Module libinput: vendor="X.Org Foundation"
[    69.637] 	compiled for 1.20.11, module version = 1.1.0
[    69.637] 	Module class: X.Org XInput Driver
[    69.637] 	ABI class: X.Org XInput driver, version 24.1
[    69.637] (II) Using input driver 'libinput' for 'Power Button'
[    69.637] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 26 paused 0
[    69.637] (**) Power Button: always reports core events
[    69.637] (**) Option "Device" "/dev/input/event2"
[    69.637] (**) Option "_source" "server/udev"
[    69.638] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    69.638] (II) event2  - Power Button: device is a keyboard
[    69.638] (II) event2  - Power Button: device removed
[    69.638] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[    69.638] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    69.638] (**) Option "xkb_layout" "us"
[    69.639] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    69.639] (II) event2  - Power Button: device is a keyboard
[    69.639] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[    69.639] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    69.639] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    69.639] (**) Video Bus: Applying InputClass "system-keyboard"
[    69.639] (II) Using input driver 'libinput' for 'Video Bus'
[    69.639] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 29 paused 0
[    69.639] (**) Video Bus: always reports core events
[    69.639] (**) Option "Device" "/dev/input/event11"
[    69.639] (**) Option "_source" "server/udev"
[    69.640] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[    69.640] (II) event11 - Video Bus: device is a keyboard
[    69.640] (II) event11 - Video Bus: device removed
[    69.640] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input15/event11"
[    69.640] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    69.640] (**) Option "xkb_layout" "us"
[    69.641] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[    69.641] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    69.641] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    69.641] (**) Video Bus: Applying InputClass "system-keyboard"
[    69.641] (II) Using input driver 'libinput' for 'Video Bus'
[    69.641] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 30 paused 0
[    69.641] (**) Video Bus: always reports core events
[    69.641] (**) Option "Device" "/dev/input/event10"
[    69.641] (**) Option "_source" "server/udev"
[    69.642] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[    69.642] (II) event10 - Video Bus: device is a keyboard
[    69.642] (II) event10 - Video Bus: device removed
[    69.642] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input14/event10"
[    69.642] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    69.642] (**) Option "xkb_layout" "us"
[    69.643] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    69.643] (II) No input driver specified, ignoring this device.
[    69.643] (II) This device may have been added with another device file.
[    69.643] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    69.643] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    69.643] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    69.643] (**) Power Button: Applying InputClass "system-keyboard"
[    69.643] (II) Using input driver 'libinput' for 'Power Button'
[    69.643] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 31 paused 0
[    69.643] (**) Power Button: always reports core events
[    69.643] (**) Option "Device" "/dev/input/event1"
[    69.643] (**) Option "_source" "server/udev"
[    69.644] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    69.644] (II) event1  - Power Button: device is a keyboard
[    69.644] (II) event1  - Power Button: device removed
[    69.644] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[    69.644] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[    69.644] (**) Option "xkb_layout" "us"
[    69.645] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event12)
[    69.645] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[    69.645] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[    69.645] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[    69.645] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[    69.646] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 32 paused 0
[    69.646] (**) Integrated Camera: Integrated C: always reports core events
[    69.646] (**) Option "Device" "/dev/input/event12"
[    69.646] (**) Option "_source" "server/udev"
[    69.646] (II) event12 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[    69.646] (II) event12 - Integrated Camera: Integrated C: device is a keyboard
[    69.646] (II) event12 - Integrated Camera: Integrated C: device removed
[    69.646] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/input/input16/event12"
[    69.646] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 10)
[    69.646] (**) Option "xkb_layout" "us"
[    69.647] (II) event12 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[    69.647] (II) event12 - Integrated Camera: Integrated C: device is a keyboard
[    69.647] (II) config/udev: Adding input device MSFT0001:02 06CB:CD3E Mouse (/dev/input/event8)
[    69.647] (**) MSFT0001:02 06CB:CD3E Mouse: Applying InputClass "evdev pointer catchall"
[    69.647] (**) MSFT0001:02 06CB:CD3E Mouse: Applying InputClass "libinput pointer catchall"
[    69.647] (II) Using input driver 'libinput' for 'MSFT0001:02 06CB:CD3E Mouse'
[    69.648] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 33 paused 0
[    69.648] (**) MSFT0001:02 06CB:CD3E Mouse: always reports core events
[    69.648] (**) Option "Device" "/dev/input/event8"
[    69.648] (**) Option "_source" "server/udev"
[    69.648] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: is tagged by udev as: Mouse Pointingstick
[    69.649] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: device is a pointer
[    69.649] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: device removed
[    69.649] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:02/0018:06CB:CD3E.0001/input/input11/event8"
[    69.649] (II) XINPUT: Adding extended input device "MSFT0001:02 06CB:CD3E Mouse" (type: MOUSE, id 11)
[    69.649] (**) Option "AccelerationScheme" "none"
[    69.649] (**) MSFT0001:02 06CB:CD3E Mouse: (accel) selected scheme none/0
[    69.649] (**) MSFT0001:02 06CB:CD3E Mouse: (accel) acceleration factor: 2.000
[    69.649] (**) MSFT0001:02 06CB:CD3E Mouse: (accel) acceleration threshold: 4
[    69.650] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: is tagged by udev as: Mouse Pointingstick
[    69.650] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: device is a pointer
[    69.651] (II) config/udev: Adding input device MSFT0001:02 06CB:CD3E Mouse (/dev/input/mouse0)
[    69.651] (II) No input driver specified, ignoring this device.
[    69.651] (II) This device may have been added with another device file.
[    69.651] (II) config/udev: Adding input device MSFT0001:02 06CB:CD3E Touchpad (/dev/input/event9)
[    69.651] (**) MSFT0001:02 06CB:CD3E Touchpad: Applying InputClass "evdev touchpad catchall"
[    69.651] (**) MSFT0001:02 06CB:CD3E Touchpad: Applying InputClass "libinput touchpad catchall"
[    69.651] (II) Using input driver 'libinput' for 'MSFT0001:02 06CB:CD3E Touchpad'
[    69.651] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 34 paused 0
[    69.651] (**) MSFT0001:02 06CB:CD3E Touchpad: always reports core events
[    69.651] (**) Option "Device" "/dev/input/event9"
[    69.651] (**) Option "_source" "server/udev"
[    69.652] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: is tagged by udev as: Touchpad
[    69.653] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: device is a touchpad
[    69.653] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: device removed
[    69.653] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:02/0018:06CB:CD3E.0001/input/input12/event9"
[    69.653] (II) XINPUT: Adding extended input device "MSFT0001:02 06CB:CD3E Touchpad" (type: TOUCHPAD, id 12)
[    69.654] (**) Option "AccelerationScheme" "none"
[    69.654] (**) MSFT0001:02 06CB:CD3E Touchpad: (accel) selected scheme none/0
[    69.654] (**) MSFT0001:02 06CB:CD3E Touchpad: (accel) acceleration factor: 2.000
[    69.654] (**) MSFT0001:02 06CB:CD3E Touchpad: (accel) acceleration threshold: 4
[    69.655] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: is tagged by udev as: Touchpad
[    69.656] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: device is a touchpad
[    69.656] (II) config/udev: Adding input device MSFT0001:02 06CB:CD3E Touchpad (/dev/input/mouse1)
[    69.656] (II) No input driver specified, ignoring this device.
[    69.656] (II) This device may have been added with another device file.
[    69.656] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event7)
[    69.656] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[    69.656] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[    69.656] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[    69.656] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[    69.657] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 35 paused 0
[    69.657] (**) Ideapad extra buttons: always reports core events
[    69.657] (**) Option "Device" "/dev/input/event7"
[    69.657] (**) Option "_source" "server/udev"
[    69.657] (II) event7  - Ideapad extra buttons: is tagged by udev as: Keyboard
[    69.657] (II) event7  - Ideapad extra buttons: device is a keyboard
[    69.658] (II) event7  - Ideapad extra buttons: device removed
[    69.658] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input7/event7"
[    69.658] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 13)
[    69.658] (**) Option "xkb_layout" "us"
[    69.658] (II) event7  - Ideapad extra buttons: is tagged by udev as: Keyboard
[    69.658] (II) event7  - Ideapad extra buttons: device is a keyboard
[    69.659] (II) config/udev: Adding input device sof-hda-dsp Mic (/dev/input/event13)
[    69.659] (II) No input driver specified, ignoring this device.
[    69.659] (II) This device may have been added with another device file.
[    69.659] (II) config/udev: Adding input device sof-hda-dsp Headphone (/dev/input/event14)
[    69.659] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=3 (/dev/input/event15)
[    69.659] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=4 (/dev/input/event16)
[    69.659] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=5 (/dev/input/event17)
[    69.660] (II) No input driver specified, ignoring this device.
[    69.660] (II) This device may have been added with another device file.
[    69.660] (II) config/udev: Adding input device Intel HID events (/dev/input/event4)
[    69.660] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[    69.660] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[    69.660] (**) Intel HID events: Applying InputClass "system-keyboard"
[    69.660] (II) Using input driver 'libinput' for 'Intel HID events'
[    69.660] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 36 paused 0
[    69.660] (**) Intel HID events: always reports core events
[    69.660] (**) Option "Device" "/dev/input/event4"
[    69.660] (**) Option "_source" "server/udev"
[    69.661] (II) event4  - Intel HID events: is tagged by udev as: Keyboard
[    69.661] (II) event4  - Intel HID events: device is a keyboard
[    69.661] (II) event4  - Intel HID events: device removed
[    69.661] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input4/event4"
[    69.661] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 14)
[    69.661] (**) Option "xkb_layout" "us"
[    69.662] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event5)
[    69.662] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[    69.662] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[    69.662] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[    69.662] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[    69.662] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 37 paused 0
[    69.662] (**) Intel HID 5 button array: always reports core events
[    69.662] (**) Option "Device" "/dev/input/event5"
[    69.662] (**) Option "_source" "server/udev"
[    69.663] (II) event5  - Intel HID 5 button array: is tagged by udev as: Keyboard
[    69.663] (II) event5  - Intel HID 5 button array: device is a keyboard
[    69.663] (II) event5  - Intel HID 5 button array: device removed
[    69.663] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input5/event5"
[    69.663] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 15)
[    69.663] (**) Option "xkb_layout" "us"
[    69.664] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[    69.664] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    69.664] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    69.664] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    69.664] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    69.664] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 38 paused 0
[    69.664] (**) AT Translated Set 2 keyboard: always reports core events
[    69.664] (**) Option "Device" "/dev/input/event3"
[    69.664] (**) Option "_source" "server/udev"
[    69.665] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    69.665] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[    69.666] (II) event3  - AT Translated Set 2 keyboard: device removed
[    69.666] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[    69.666] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[    69.666] (**) Option "xkb_layout" "us"
[    69.666] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    69.666] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[    69.667] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[    69.667] (II) No input driver specified, ignoring this device.
[    69.667] (II) This device may have been added with another device file.
[    70.341] (II) intel(0): EDID vendor "LGD", prod id 1589
[    70.341] (II) intel(0): Printing DDC gathered Modelines:
[    70.341] (II) intel(0): Modeline "3840x2160"x0.0  533.28  3840 3888 3920 4000  2160 2163 2168 2222 +hsync -vsync (133.3 kHz eP)
[   306.001] (**) Option "fd" "26"
[   306.001] (II) event2  - Power Button: device removed
[   306.001] (**) Option "fd" "29"
[   306.001] (II) event11 - Video Bus: device removed
[   306.001] (**) Option "fd" "30"
[   306.001] (II) event10 - Video Bus: device removed
[   306.002] (**) Option "fd" "31"
[   306.002] (II) event1  - Power Button: device removed
[   306.002] (**) Option "fd" "32"
[   306.002] (II) event12 - Integrated Camera: Integrated C: device removed
[   306.002] (**) Option "fd" "33"
[   306.002] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: device removed
[   306.002] (**) Option "fd" "34"
[   306.002] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: device removed
[   306.002] (**) Option "fd" "35"
[   306.002] (II) event7  - Ideapad extra buttons: device removed
[   306.003] (**) Option "fd" "36"
[   306.003] (II) event4  - Intel HID events: device removed
[   306.003] (**) Option "fd" "37"
[   306.003] (II) event5  - Intel HID 5 button array: device removed
[   306.003] (**) Option "fd" "38"
[   306.003] (II) event3  - AT Translated Set 2 keyboard: device removed
[   306.004] (II) UnloadModule: "libinput"
[   306.004] (II) systemd-logind: releasing fd for 13:67
[   306.098] (II) UnloadModule: "libinput"
[   306.098] (II) systemd-logind: releasing fd for 13:69
[   306.135] (II) UnloadModule: "libinput"
[   306.135] (II) systemd-logind: releasing fd for 13:68
[   306.183] (II) UnloadModule: "libinput"
[   306.183] (II) systemd-logind: releasing fd for 13:71
[   306.244] (II) UnloadModule: "libinput"
[   306.244] (II) systemd-logind: releasing fd for 13:73
[   306.328] (II) UnloadModule: "libinput"
[   306.328] (II) systemd-logind: releasing fd for 13:72
[   306.421] (II) UnloadModule: "libinput"
[   306.421] (II) systemd-logind: releasing fd for 13:76
[   306.501] (II) UnloadModule: "libinput"
[   306.501] (II) systemd-logind: releasing fd for 13:65
[   306.541] (II) UnloadModule: "libinput"
[   306.541] (II) systemd-logind: releasing fd for 13:74
[   306.608] (II) UnloadModule: "libinput"
[   306.608] (II) systemd-logind: releasing fd for 13:75
[   306.662] (II) UnloadModule: "libinput"
[   306.662] (II) systemd-logind: releasing fd for 13:66
[   307.419] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[   307.419] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[   307.420] (II) Server terminated successfully (0). Closing log file.
cat /var/log/Xorg.0.log.old
[   228.565] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[   228.565] _XSERVTransMakeAllCOTSServerListeners: server already running
[   228.565] (--) Log file renamed from "/var/log/Xorg.pid-1698.log" to "/var/log/Xorg.1.log"
[   228.565] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[   228.565]
[   228.565] Build Operating System: Linux Manjaro Linux
[   228.565] Current Operating System: Linux ameen-81nw 5.10.56-1-MANJARO #1 SMP PREEMPT Thu Aug 5 10:51:27 UTC 2021 x86_64
[   228.565] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a78a2b34-6b4a-4b3f-b902-6a2989c51e5e rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[   228.565] Build Date: 29 July 2021  08:07:46PM
[   228.565]
[   228.565] Current version of pixman: 0.40.0
[   228.565] 	Before reporting problems, check http://wiki.x.org
[   228.565] Markers: (--) probed, (**) from config file, (==) default setting,
[   228.565] (==) Log file: "/var/log/Xorg.1.log", Time: Mon Aug  9 22:09:49 2021
[   228.565] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   228.565] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   228.565] (==) No Layout section.  Using the first Screen section.
[   228.565] (==) No screen section available. Using defaults.
[   228.565] (**) |-->Screen "Default Screen Section" (0)
[   228.565] (**) |   |-->Monitor "<default monitor>"
[   228.566] (==) No monitor specified for screen "Default Screen Section".
[   228.566] (==) Automatically adding devices
[   228.566] (==) Automatically enabling devices
[   228.566] (==) Automatically adding GPU devices
[   228.566] (==) Automatically binding GPU devices
[   228.566] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   228.566] (WW) The directory "/usr/share/fonts/misc" does not exist.
[   228.566] 	Entry deleted from font path.
[   228.566] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[   228.566] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   228.566] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[   228.566] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[   228.566] (==) FontPath set to:
[   228.566] (==) ModulePath set to "/usr/lib/xorg/modules"
[   228.566] (II) The server relies on udev to provide the list of input devices.
[   228.566] (II) Module ABI versions:
[   228.566] 	X.Org ANSI C Emulation: 0.4
[   228.566] 	X.Org Video Driver: 24.1
[   228.566] 	X.Org XInput driver : 24.1
[   228.566] 	X.Org Server Extension : 10.0
[   228.566] (++) using VT number 3
[   228.568] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_37
[   228.568] (II) xfree86: Adding drm device (/dev/dri/card1)
[   228.568] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[   228.568] (II) xfree86: Adding drm device (/dev/dri/card0)
[   228.569] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[   228.570] (--) PCI:*(0@0:2:0) 8086:3e9b:17aa:3f1a rev 2, Mem @ 0x604a000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[   228.570] (--) PCI: (1@0:0:0) 10de:1f91:17aa:3f1a rev 161, Mem @ 0x62000000/16777216, 0x50000000/268435456, 0x60000000/33554432, I/O @ 0x00003000/128
[   228.570] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   228.570] (II) LoadModule: "glx"
[   228.571] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   228.571] (II) Module glx: vendor="X.Org Foundation"
[   228.571] 	compiled for 1.20.13, module version = 1.0.0
[   228.571] 	ABI class: X.Org Server Extension, version 10.0
[   228.571] (==) Matched intel as autoconfigured driver 0
[   228.571] (==) Matched nouveau as autoconfigured driver 1
[   228.571] (==) Matched nv as autoconfigured driver 2
[   228.571] (==) Matched modesetting as autoconfigured driver 3
[   228.571] (==) Matched fbdev as autoconfigured driver 4
[   228.571] (==) Matched vesa as autoconfigured driver 5
[   228.571] (==) Assigned the driver to the xf86ConfigLayout
[   228.571] (II) LoadModule: "intel"
[   228.571] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[   228.571] (II) Module intel: vendor="X.Org Foundation"
[   228.571] 	compiled for 1.20.10, module version = 2.99.917
[   228.572] 	Module class: X.Org Video Driver
[   228.572] 	ABI class: X.Org Video Driver, version 24.1
[   228.572] (II) LoadModule: "nouveau"
[   228.572] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[   228.572] (II) Module nouveau: vendor="X.Org Foundation"
[   228.572] 	compiled for 1.20.10, module version = 1.0.17
[   228.572] (II) LoadModule: "nv"
[   228.572] (WW) Warning, couldn't open module nv
[   228.572] (EE) Failed to load module "nv" (module does not exist, 0)
[   228.572] (II) LoadModule: "modesetting"
[   228.572] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[   228.572] (II) Module modesetting: vendor="X.Org Foundation"
[   228.572] 	compiled for 1.20.13, module version = 1.20.13
[   228.572] (II) LoadModule: "fbdev"
[   228.572] (WW) Warning, couldn't open module fbdev
[   228.572] (EE) Failed to load module "fbdev" (module does not exist, 0)
[   228.572] (II) LoadModule: "vesa"
[   228.572] (WW) Warning, couldn't open module vesa
[   228.572] (EE) Failed to load module "vesa" (module does not exist, 0)
[   228.572] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[   228.572] (II) intel: Driver for Intel(R) HD Graphics
[   228.572] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[   228.572] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[   228.572] (II) NOUVEAU driver
[   228.572] (II) NOUVEAU driver for NVIDIA chipset families :
[   228.572] 	RIVA TNT            (NV04)
[   228.572] 	RIVA TNT2           (NV05)
[   228.573] 	GeForce 256         (NV10)
[   228.573] 	GeForce 2           (NV11, NV15)
[   228.573] 	GeForce 4MX         (NV17, NV18)
[   228.573] 	GeForce 3           (NV20)
[   228.573] 	GeForce 4Ti         (NV25, NV28)
[   228.573] 	GeForce FX          (NV3x)
[   228.573] 	GeForce 6           (NV4x)
[   228.573] 	GeForce 7           (G7x)
[   228.573] 	GeForce 8           (G8x)
[   228.573] 	GeForce 9           (G9x)
[   228.573] 	GeForce GTX 2xx/3xx (GT2xx)
[   228.573] 	GeForce GTX 4xx/5xx (GFxxx)
[   228.573] 	GeForce GTX 6xx/7xx (GKxxx)
[   228.573] 	GeForce GTX 9xx     (GMxxx)
[   228.573] 	GeForce GTX 10xx    (GPxxx)
[   228.573] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   228.573] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200917
[   228.573] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[   228.588] (WW) Falling back to old probe method for modesetting
[   228.588] (II) [drm] nouveau interface version: 1.3.1
[   228.588] (EE) Unknown chipset: NV167
[   228.588] (II) modeset(G0): using drv /dev/dri/card1
[   228.589] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[   228.589] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 8 threads
[   228.589] (II) intel(0): Creating default Display subsection in Screen section
[   228.589] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[   228.589] (==) intel(0): RGB weight 888
[   228.589] (==) intel(0): Default visual is TrueColor
[   228.589] (II) intel(0): Output eDP1 has no monitor section
[   228.589] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[   228.589] (II) intel(0): Enabled output eDP1
[   228.589] (II) intel(0): Output DP1 has no monitor section
[   228.589] (II) intel(0): Enabled output DP1
[   228.589] (II) intel(0): Output HDMI1 has no monitor section
[   228.589] (II) intel(0): Enabled output HDMI1
[   228.589] (II) intel(0): Output DP2 has no monitor section
[   228.589] (II) intel(0): Enabled output DP2
[   228.589] (II) intel(0): Output HDMI2 has no monitor section
[   228.589] (II) intel(0): Enabled output HDMI2
[   228.589] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[   228.589] (II) intel(0): Output VIRTUAL1 has no monitor section
[   228.589] (II) intel(0): Enabled output VIRTUAL1
[   228.589] (--) intel(0): Output eDP1 using initial mode 3840x2160 on pipe 0
[   228.589] (==) intel(0): TearFree enabled
[   228.589] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[   228.589] (==) intel(0): DPI set to (96, 96)
[   228.589] (II) Loading sub module "dri3"
[   228.589] (II) LoadModule: "dri3"
[   228.590] (II) Module "dri3" already built-in
[   228.590] (II) Loading sub module "dri2"
[   228.590] (II) LoadModule: "dri2"
[   228.590] (II) Module "dri2" already built-in
[   228.590] (II) Loading sub module "present"
[   228.590] (II) LoadModule: "present"
[   228.590] (II) Module "present" already built-in
[   228.590] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[   228.590] (==) modeset(G0): RGB weight 888
[   228.590] (==) modeset(G0): Default visual is TrueColor
[   228.590] (II) Loading sub module "glamoregl"
[   228.590] (II) LoadModule: "glamoregl"
[   228.590] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[   228.592] (II) Module glamoregl: vendor="X.Org Foundation"
[   228.592] 	compiled for 1.20.13, module version = 1.0.1
[   228.592] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   228.628] (II) modeset(G0): glamor X acceleration enabled on NV167
[   228.628] (II) modeset(G0): glamor initialized
[   228.628] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[   228.628] (==) modeset(G0): DPI set to (96, 96)
[   228.628] (II) Loading sub module "fb"
[   228.628] (II) LoadModule: "fb"
[   228.628] (II) Loading /usr/lib/xorg/modules/libfb.so
[   228.628] (II) Module fb: vendor="X.Org Foundation"
[   228.628] 	compiled for 1.20.13, module version = 1.0.0
[   228.628] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   228.628] (II) intel(0): SNA initialized with Coffeelake (gen9) backend
[   228.628] (==) intel(0): Backing store enabled
[   228.628] (==) intel(0): Silken mouse disabled
[   228.628] (II) intel(0): HW Cursor enabled
[   228.628] (==) intel(0): DPMS enabled
[   228.629] (==) intel(0): Display hotplug detection enabled
[   228.629] (II) intel(0): [DRI2] Setup complete
[   228.629] (II) intel(0): [DRI2]   DRI driver: i965
[   228.629] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[   228.629] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[   228.629] (II) intel(0): hardware support for Present enabled
[   228.683] (==) modeset(G0): Backing store enabled
[   228.683] (==) modeset(G0): Silken mouse disabled
[   228.683] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[   228.683] (==) modeset(G0): DPMS enabled
[   228.683] (II) modeset(G0): [DRI2] Setup complete
[   228.683] (II) modeset(G0): [DRI2]   DRI driver: nouveau
[   228.683] (II) modeset(G0): [DRI2]   VDPAU driver: nouveau
[   228.684] (II) Initializing extension Generic Event Extension
[   228.684] (II) Initializing extension SHAPE
[   228.684] (II) Initializing extension MIT-SHM
[   228.684] (II) Initializing extension XInputExtension
[   228.684] (II) Initializing extension XTEST
[   228.684] (II) Initializing extension BIG-REQUESTS
[   228.684] (II) Initializing extension SYNC
[   228.684] (II) Initializing extension XKEYBOARD
[   228.684] (II) Initializing extension XC-MISC
[   228.684] (II) Initializing extension SECURITY
[   228.684] (II) Initializing extension XFIXES
[   228.684] (II) Initializing extension RENDER
[   228.684] (II) Initializing extension RANDR
[   228.684] (II) Initializing extension COMPOSITE
[   228.684] (II) Initializing extension DAMAGE
[   228.684] (II) Initializing extension MIT-SCREEN-SAVER
[   228.684] (II) Initializing extension DOUBLE-BUFFER
[   228.684] (II) Initializing extension RECORD
[   228.684] (II) Initializing extension DPMS
[   228.684] (II) Initializing extension Present
[   228.684] (II) Initializing extension DRI3
[   228.684] (II) Initializing extension X-Resource
[   228.684] (II) Initializing extension XVideo
[   228.684] (II) Initializing extension XVideo-MotionCompensation
[   228.684] (II) Initializing extension GLX
[   228.693] (II) AIGLX: Loaded and initialized i965
[   228.693] (II) GLX: Initialized DRI2 GL provider for screen 0
[   228.693] (II) Initializing extension XFree86-VidModeExtension
[   228.693] (II) Initializing extension XFree86-DGA
[   228.693] (II) Initializing extension XFree86-DRI
[   228.693] (II) Initializing extension DRI2
[   228.693] (II) modeset(G0): Damage tracking initialized
[   228.708] (II) intel(0): switch to mode 3840x2160@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[   228.722] (II) intel(0): Setting screen physical size to 1016 x 571
[   228.751] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[   228.751] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   228.751] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   228.751] (**) Power Button: Applying InputClass "system-keyboard"
[   228.751] (II) LoadModule: "libinput"
[   228.751] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   228.752] (II) Module libinput: vendor="X.Org Foundation"
[   228.752] 	compiled for 1.20.11, module version = 1.1.0
[   228.752] 	Module class: X.Org XInput Driver
[   228.752] 	ABI class: X.Org XInput driver, version 24.1
[   228.752] (II) Using input driver 'libinput' for 'Power Button'
[   228.753] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 26 paused 0
[   228.753] (**) Power Button: always reports core events
[   228.753] (**) Option "Device" "/dev/input/event2"
[   228.753] (**) Option "_source" "server/udev"
[   228.754] (II) event2  - Power Button: is tagged by udev as: Keyboard
[   228.754] (II) event2  - Power Button: device is a keyboard
[   228.754] (II) event2  - Power Button: device removed
[   228.754] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[   228.754] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   228.754] (**) Option "xkb_layout" "us"
[   228.755] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[   228.755] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   228.755] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   228.755] (**) Video Bus: Applying InputClass "system-keyboard"
[   228.755] (II) Using input driver 'libinput' for 'Video Bus'
[   228.755] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 29 paused 0
[   228.755] (**) Video Bus: always reports core events
[   228.755] (**) Option "Device" "/dev/input/event12"
[   228.755] (**) Option "_source" "server/udev"
[   228.756] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[   228.756] (II) event12 - Video Bus: device is a keyboard
[   228.756] (II) event12 - Video Bus: device removed
[   228.756] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input16/event12"
[   228.756] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[   228.756] (**) Option "xkb_layout" "us"
[   228.757] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[   228.757] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   228.757] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   228.757] (**) Video Bus: Applying InputClass "system-keyboard"
[   228.757] (II) Using input driver 'libinput' for 'Video Bus'
[   228.757] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 30 paused 0
[   228.757] (**) Video Bus: always reports core events
[   228.757] (**) Option "Device" "/dev/input/event11"
[   228.757] (**) Option "_source" "server/udev"
[   228.758] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[   228.758] (II) event11 - Video Bus: device is a keyboard
[   228.758] (II) event11 - Video Bus: device removed
[   228.758] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input15/event11"
[   228.758] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[   228.758] (**) Option "xkb_layout" "us"
[   228.759] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[   228.759] (II) No input driver specified, ignoring this device.
[   228.759] (II) This device may have been added with another device file.
[   228.759] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[   228.759] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   228.759] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   228.759] (**) Power Button: Applying InputClass "system-keyboard"
[   228.759] (II) Using input driver 'libinput' for 'Power Button'
[   228.759] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 31 paused 0
[   228.759] (**) Power Button: always reports core events
[   228.759] (**) Option "Device" "/dev/input/event1"
[   228.759] (**) Option "_source" "server/udev"
[   228.760] (II) event1  - Power Button: is tagged by udev as: Keyboard
[   228.760] (II) event1  - Power Button: device is a keyboard
[   228.760] (II) event1  - Power Button: device removed
[   228.760] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[   228.760] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[   228.760] (**) Option "xkb_layout" "us"
[   228.761] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event10)
[   228.761] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[   228.761] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[   228.761] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[   228.761] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[   228.762] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 32 paused 0
[   228.762] (**) Integrated Camera: Integrated C: always reports core events
[   228.762] (**) Option "Device" "/dev/input/event10"
[   228.762] (**) Option "_source" "server/udev"
[   228.762] (II) event10 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[   228.762] (II) event10 - Integrated Camera: Integrated C: device is a keyboard
[   228.762] (II) event10 - Integrated Camera: Integrated C: device removed
[   228.762] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/input/input14/event10"
[   228.762] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 10)
[   228.762] (**) Option "xkb_layout" "us"
[   228.763] (II) event10 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[   228.763] (II) event10 - Integrated Camera: Integrated C: device is a keyboard
[   228.763] (II) config/udev: Adding input device MSFT0001:02 06CB:CD3E Mouse (/dev/input/event8)
[   228.763] (**) MSFT0001:02 06CB:CD3E Mouse: Applying InputClass "evdev pointer catchall"
[   228.763] (**) MSFT0001:02 06CB:CD3E Mouse: Applying InputClass "libinput pointer catchall"
[   228.763] (II) Using input driver 'libinput' for 'MSFT0001:02 06CB:CD3E Mouse'
[   228.764] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 33 paused 0
[   228.764] (**) MSFT0001:02 06CB:CD3E Mouse: always reports core events
[   228.764] (**) Option "Device" "/dev/input/event8"
[   228.764] (**) Option "_source" "server/udev"
[   228.764] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: is tagged by udev as: Mouse Pointingstick
[   228.765] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: device is a pointer
[   228.765] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: device removed
[   228.765] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:02/0018:06CB:CD3E.0001/input/input11/event8"
[   228.765] (II) XINPUT: Adding extended input device "MSFT0001:02 06CB:CD3E Mouse" (type: MOUSE, id 11)
[   228.765] (**) Option "AccelerationScheme" "none"
[   228.765] (**) MSFT0001:02 06CB:CD3E Mouse: (accel) selected scheme none/0
[   228.765] (**) MSFT0001:02 06CB:CD3E Mouse: (accel) acceleration factor: 2.000
[   228.765] (**) MSFT0001:02 06CB:CD3E Mouse: (accel) acceleration threshold: 4
[   228.766] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: is tagged by udev as: Mouse Pointingstick
[   228.766] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: device is a pointer
[   228.766] (II) config/udev: Adding input device MSFT0001:02 06CB:CD3E Mouse (/dev/input/mouse0)
[   228.766] (II) No input driver specified, ignoring this device.
[   228.766] (II) This device may have been added with another device file.
[   228.767] (II) config/udev: Adding input device MSFT0001:02 06CB:CD3E Touchpad (/dev/input/event9)
[   228.767] (**) MSFT0001:02 06CB:CD3E Touchpad: Applying InputClass "evdev touchpad catchall"
[   228.767] (**) MSFT0001:02 06CB:CD3E Touchpad: Applying InputClass "libinput touchpad catchall"
[   228.767] (II) Using input driver 'libinput' for 'MSFT0001:02 06CB:CD3E Touchpad'
[   228.767] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 34 paused 0
[   228.767] (**) MSFT0001:02 06CB:CD3E Touchpad: always reports core events
[   228.767] (**) Option "Device" "/dev/input/event9"
[   228.767] (**) Option "_source" "server/udev"
[   228.768] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: is tagged by udev as: Touchpad
[   228.769] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: device is a touchpad
[   228.769] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: device removed
[   228.769] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-MSFT0001:02/0018:06CB:CD3E.0001/input/input12/event9"
[   228.769] (II) XINPUT: Adding extended input device "MSFT0001:02 06CB:CD3E Touchpad" (type: TOUCHPAD, id 12)
[   228.770] (**) Option "AccelerationScheme" "none"
[   228.770] (**) MSFT0001:02 06CB:CD3E Touchpad: (accel) selected scheme none/0
[   228.770] (**) MSFT0001:02 06CB:CD3E Touchpad: (accel) acceleration factor: 2.000
[   228.770] (**) MSFT0001:02 06CB:CD3E Touchpad: (accel) acceleration threshold: 4
[   228.770] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: is tagged by udev as: Touchpad
[   228.771] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: device is a touchpad
[   228.772] (II) config/udev: Adding input device MSFT0001:02 06CB:CD3E Touchpad (/dev/input/mouse1)
[   228.772] (II) No input driver specified, ignoring this device.
[   228.772] (II) This device may have been added with another device file.
[   228.772] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event6)
[   228.772] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[   228.772] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[   228.772] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[   228.772] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[   228.772] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 35 paused 0
[   228.772] (**) Ideapad extra buttons: always reports core events
[   228.772] (**) Option "Device" "/dev/input/event6"
[   228.772] (**) Option "_source" "server/udev"
[   228.773] (II) event6  - Ideapad extra buttons: is tagged by udev as: Keyboard
[   228.773] (II) event6  - Ideapad extra buttons: device is a keyboard
[   228.773] (II) event6  - Ideapad extra buttons: device removed
[   228.773] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input6/event6"
[   228.773] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 13)
[   228.773] (**) Option "xkb_layout" "us"
[   228.774] (II) event6  - Ideapad extra buttons: is tagged by udev as: Keyboard
[   228.774] (II) event6  - Ideapad extra buttons: device is a keyboard
[   228.774] (II) config/udev: Adding input device sof-hda-dsp Mic (/dev/input/event13)
[   228.774] (II) No input driver specified, ignoring this device.
[   228.774] (II) This device may have been added with another device file.
[   228.774] (II) config/udev: Adding input device sof-hda-dsp Headphone (/dev/input/event14)
[   228.774] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=3 (/dev/input/event15)
[   228.774] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=4 (/dev/input/event16)
[   228.775] (II) No input driver specified, ignoring this device.
[   228.775] (II) This device may have been added with another device file.
[   228.775] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=5 (/dev/input/event17)
[   228.775] (II) config/udev: Adding input device Intel HID events (/dev/input/event4)
[   228.775] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[   228.775] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[   228.775] (**) Intel HID events: Applying InputClass "system-keyboard"
[   228.775] (II) Using input driver 'libinput' for 'Intel HID events'
[   228.775] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 36 paused 0
[   228.775] (**) Intel HID events: always reports core events
[   228.775] (**) Option "Device" "/dev/input/event4"
[   228.775] (**) Option "_source" "server/udev"
[   228.776] (II) event4  - Intel HID events: is tagged by udev as: Keyboard
[   228.776] (II) event4  - Intel HID events: device is a keyboard
[   228.776] (II) event4  - Intel HID events: device removed
[   228.776] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input4/event4"
[   228.776] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 14)
[   228.776] (**) Option "xkb_layout" "us"
[   228.777] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event5)
[   228.777] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[   228.777] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[   228.777] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[   228.777] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[   228.777] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 37 paused 0
[   228.777] (**) Intel HID 5 button array: always reports core events
[   228.777] (**) Option "Device" "/dev/input/event5"
[   228.777] (**) Option "_source" "server/udev"
[   228.778] (II) event5  - Intel HID 5 button array: is tagged by udev as: Keyboard
[   228.778] (II) event5  - Intel HID 5 button array: device is a keyboard
[   228.778] (II) event5  - Intel HID 5 button array: device removed
[   228.778] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input5/event5"
[   228.778] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 15)
[   228.778] (**) Option "xkb_layout" "us"
[   228.779] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[   228.779] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[   228.779] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[   228.779] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[   228.779] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[   228.779] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 38 paused 0
[   228.779] (**) AT Translated Set 2 keyboard: always reports core events
[   228.779] (**) Option "Device" "/dev/input/event3"
[   228.779] (**) Option "_source" "server/udev"
[   228.779] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   228.780] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[   228.780] (II) event3  - AT Translated Set 2 keyboard: device removed
[   228.780] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[   228.780] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[   228.780] (**) Option "xkb_layout" "us"
[   228.781] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   228.781] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[   228.781] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[   228.781] (II) No input driver specified, ignoring this device.
[   228.782] (II) This device may have been added with another device file.
[   229.299] (II) intel(0): EDID vendor "LGD", prod id 1589
[   229.299] (II) intel(0): Printing DDC gathered Modelines:
[   229.299] (II) intel(0): Modeline "3840x2160"x0.0  533.28  3840 3888 3920 4000  2160 2163 2168 2222 +hsync -vsync (133.3 kHz eP)
[   426.125] (**) Option "fd" "26"
[   426.125] (II) event2  - Power Button: device removed
[   426.125] (**) Option "fd" "29"
[   426.125] (II) event12 - Video Bus: device removed
[   426.125] (**) Option "fd" "30"
[   426.125] (II) event11 - Video Bus: device removed
[   426.125] (**) Option "fd" "31"
[   426.125] (II) event1  - Power Button: device removed
[   426.125] (**) Option "fd" "32"
[   426.125] (II) event10 - Integrated Camera: Integrated C: device removed
[   426.125] (**) Option "fd" "33"
[   426.125] (II) event8  - MSFT0001:02 06CB:CD3E Mouse: device removed
[   426.126] (**) Option "fd" "34"
[   426.126] (II) event9  - MSFT0001:02 06CB:CD3E Touchpad: device removed
[   426.126] (**) Option "fd" "35"
[   426.126] (II) event6  - Ideapad extra buttons: device removed
[   426.126] (**) Option "fd" "36"
[   426.126] (II) event4  - Intel HID events: device removed
[   426.126] (**) Option "fd" "37"
[   426.126] (II) event5  - Intel HID 5 button array: device removed
[   426.126] (**) Option "fd" "38"
[   426.126] (II) event3  - AT Translated Set 2 keyboard: device removed
[   426.127] (II) UnloadModule: "libinput"
[   426.127] (II) systemd-logind: releasing fd for 13:67
[   426.208] (II) UnloadModule: "libinput"
[   426.208] (II) systemd-logind: releasing fd for 13:69
[   426.317] (II) UnloadModule: "libinput"
[   426.317] (II) systemd-logind: releasing fd for 13:68
[   426.346] (II) UnloadModule: "libinput"
[   426.346] (II) systemd-logind: releasing fd for 13:70
[   426.404] (II) UnloadModule: "libinput"
[   426.404] (II) systemd-logind: releasing fd for 13:73
[   426.458] (II) UnloadModule: "libinput"
[   426.458] (II) systemd-logind: releasing fd for 13:72
[   426.530] (II) UnloadModule: "libinput"
[   426.530] (II) systemd-logind: releasing fd for 13:74
[   426.604] (II) UnloadModule: "libinput"
[   426.604] (II) systemd-logind: releasing fd for 13:65
[   426.658] (II) UnloadModule: "libinput"
[   426.658] (II) systemd-logind: releasing fd for 13:75
[   426.711] (II) UnloadModule: "libinput"
[   426.711] (II) systemd-logind: releasing fd for 13:76
[   426.765] (II) UnloadModule: "libinput"
[   426.765] (II) systemd-logind: releasing fd for 13:66
[   427.568] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[   427.568] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[   427.661] (II) Server terminated successfully (0). Closing log file.
Usually crashes happen without any warning because there is no utility that will notify users:
hey, your system is about to crash!
:sweat_smile:
Use proprietary drivers and look into Optimus-Manager.
LOL fair. Bad wording on my part. I meant there are no freezes or any other signs of impending doom.
Thanks I will try wih proprietary drivers.
  1. Please read this: Swap - Manjaro
  2. How do you reboot? REISUB?
  3. Can you try to disable as many hardware devices in your EUFI firmware as possible and see if that helps? (I’m suspecting a hardware failure somewhere and the kernel not being very good at catching it)
:thinking:
The reboot button on the gnome toolbar. Nothing fancy. The system doesn’t freeze, it powers off directly so don’t have an opportunity to use REISUB.
I will check out SWAP and disabling hardware. I suspect hardware failure as well. I will run memtest and report back. I’m thinking of running windows for a few days as well to narrow down if its hardware.
I noticed that in
there are
at the start/boot of the PC (some time ago I also had that msgs, but Linux kernel update fixes or hides them)
but then suddenly right before crash
I do not remember that on my PC after PC was booted up, but I saw them for about half of a year on my PC: they are always was only at boot time. So, something triggers a… kernel reboot(?) while OS is running? May be kernel bug.
Try newer kernel version:
pacman -Si linux513
Repository      : core
Version         : 5.13.12-1
and
pacman -Si linux514
Repository      : core
Version         : 5.14.rc6.d0815.g7c60610-1
These are currently in unstable branch.
and 5.10 LTS also:
pacman -Si linux510
Repository      : core
Version         : 5.10.60-1
So, 3 kernel versions (Manjaro - Branch Compare).
It is also a way but if you will read all Event logs in that OS journals also.
Comparing to try to use other Linux kernel versions it will take as you noted:
To try other kernels could be a faster way to check.
Do you need a suggestion how to get them as latest avail. versions on Manjaro?
to update current 5.13 kernel family to newest avail. version:
sudo pacman-mirrors -a -B unstable -c Germany,Austria -P https (substitute to your country(-ies list))
sudo pacman -Syy
sudo pacman -S linux513
Pamac will suggest to update other packages: do not update any other package except available update for the linux-firmware package.
And then revert back all DBs state to your stable branch:
sudo pacman-mirrors -a -B stable -c Germany,Austria -P https
sudo pacman -Syy
Do with Pamac also: open the GUI app, Menu → Refresh databases.
Reboot and check the situation with that newest kernel version.
To get back the version from your branch (and after “revert back all DBs state to your stable branch” actions above) use:
sudo pacman -S linux513 linux-firmware
it will show you downgrade to current stable branch.
or
for all packages to be only from your currently selected stable branch:
sudo pacman -Syyuu
Do the same with 5.14 and 5.10 kernel family or try to use the version which existed in stable branch (you need to select 5.14, or 5.10 version to load them in GRUB’s boot menu).
These actions of gathering newest kernel version are not recommended actions for everyday usage (to get packages from other branches) but it is workable workaround to test newer kernel versions which currently did not reach you update branch yet.
Please do not do it while you do not understand what for every suggested step is: you can damage your system and get problems to get it back workable.
EDIT:
Fixed
pacman-mirrors ... - P ...
to correct
pacman-mirrors ... -P ...
Thanks for all the suggestions. I will give it a try. My laptop also got a BIOS update today so there is a slim chance that might fix it as well.
Tried everything suggested here but the crashes remained :confused:. I ended up switching to Ubuntu and the crashes have stopped. Seems like something was not playing nice after the Gnome 40 update on my laptop. I already miss the AUR though, I’ll be back one day.
Too bad: do you still have Manjaro installed in dual boot with Ubuntu?
If yes, you never tried another kernel and 5.10 LTS would have been very high on my list…
:crossed_fingers:
I did try 5.10 to no avail.
