Random crashes, programs not responding
Dear all,
First post here, I hope the problem is clear enough and we’ll find the issue.
I freshly installed Manjaro last week on my computer, with i3wm.
What happens:
It becomes very slow, the applications start to crash. Commands are not answering anymore (Run command, shortcut to start a new terminal etc.)
I can go to another tty but cannot log-in, it does not respond, gets very slow.
If a terminal is still open, no command answers, as the system answer it does not know the commands I type (unfound) even for reboot, journalctl, vim etc.
Overall my only issue is the hard reset.
When does it happen:
A few time while I use the computer, and often, almost always, after letting it on idle for a time, or in sleep, suspend mode.
It also happened a few times when plugging or unplugging the compiuter.
I really suspected the power manager for this reason.
Here is the output for my system info
  Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=1bba5900-5dd8-4aa5-ba6f-165bae5fdfd5 rw quiet apparmor=1
  Desktop: i3 v: 4.21.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: Dell product: XPS 15 9510 v: N/A
  Mobo: Dell model: 01V4T3 v: A00 serial: <superuser required> UEFI: Dell
    v: 1.15.2 date: 10/27/2022
  ID-1: BAT0 charge: 61.0 Wh (90.9%) condition: 67.1/84.3 Wh (79.6%)
    volts: 12.6 min: 11.4 model: BYD DELL M59JH19 type: Li-poly serial: <filter>
    status: N/A
  RAM: total: 62.53 GiB used: 4.12 GiB (6.6%)
  Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
    microcode: 0x42
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 887 high: 1084 min/max: 800/4600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1084 2: 949 3: 781 4: 801
    5: 784 6: 886 7: 934 8: 800 9: 801 10: 991 11: 842 12: 938 13: 801 14: 1062
    15: 964 16: 789 bogomips: 73744
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:9a60
    class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: Dell
    driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2022-12) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0302
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
    bus-ID: 3-11:3 chip-ID: 0c45:6a11 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.6 driver: X: loaded: modesetting,nvidia
    unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 64 s-size: 1016x635mm (40.00x25.00")
    s-diag: 1198mm (47.17")
  Monitor-1: eDP-1 model: Sharp 0x14d0 built: 2020 res: 2560x1600 hz: 60
    dpi: 194 gamma: 1.2 size: 336x210mm (13.23x8.27") diag: 396mm (15.6")
    ratio: 16:10 modes: 3840x2400
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Tiger Lake-H HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
    class-ID: 0403
  Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.63 running: no
  Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-14:4
    chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 3.64 TiB used: 16.28 GiB (0.4%)
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    rev: 2B2QEXM7 temp: 44.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
    rev: 2B2QEXM7 temp: 43.9 C scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 16.28 GiB (0.9%)
    fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7 label: N/A
    uuid: 1bba5900-5dd8-4aa5-ba6f-165bae5fdfd5
    used: 332 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
    label: NO_LABEL uuid: 84FA-BF9D
  ID-1: /dev/nvme0n1p1 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
    uuid: 8419-35D1
  ID-2: /dev/nvme0n1p2 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:4 size: 1.82 TiB fs: ntfs label: N/A
    uuid: 241A1AB31A1A824A
  ID-4: /dev/nvme0n1p4 maj-min: 259:5 size: 829 MiB fs: ntfs label: N/A
    uuid: C442E65342E649AE
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 3-10:2 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
  Device-2: 3-11:3 info: Microdia Integrated_Webcam_HD type: Video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-3: 3-14:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
    class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 20 Gb/s
  System Temperatures: cpu: 44.0 C mobo: N/A
  Processes: 348 Uptime: 19m wakeups: 4329 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: pm: pacman pkgs: 1234 libs: 347 tools: pamac,yay Shell: Zsh v: 5.9
  running-in: terminator inxi: 3.3.24
And this is journalctl -b0 -p4 --no-pager
Jan 10 22:30:00 archline-XPS15 kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
Jan 10 22:30:00 archline-XPS15 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jan 10 22:30:00 archline-XPS15 kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Jan 10 22:30:00 archline-XPS15 kernel: pci 0000:00:07.3: DPC: RP PIO log size 0 is invalid
Jan 10 22:30:00 archline-XPS15 kernel: pnp 00:05: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jan 10 22:30:00 archline-XPS15 kernel: hpet_acpi_add: no address or irqs in _CRS
Jan 10 22:30:00 archline-XPS15 kernel: efifb: Ignoring BGRT: unexpected or invalid BMP data
Jan 10 22:30:00 archline-XPS15 kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 10 22:30:00 archline-XPS15 kernel: nvme nvme1: missing or invalid SUBNQN field.
Jan 10 22:30:00 archline-XPS15 kernel: i8042: Warning: Keylock active
Jan 10 22:30:00 archline-XPS15 kernel: usb: port power management may be unreliable
Jan 10 22:30:00 archline-XPS15 systemd-journald[385]: File /var/log/journal/d9222eef6532463081f9488842c20c49/system.journal corrupted or uncleanly shut down, renaming and replacing.
Jan 10 22:30:00 archline-XPS15 kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jan 10 22:30:00 archline-XPS15 kernel: wmi_bus wmi_bus-PNP0C14:02: WQBC data block query control method not found
Jan 10 22:30:00 archline-XPS15 kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jan 10 22:30:00 archline-XPS15 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jan 10 22:30:00 archline-XPS15 kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jan 10 22:30:00 archline-XPS15 kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jan 10 22:30:00 archline-XPS15 kernel: acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jan 10 22:30:00 archline-XPS15 kernel: acpi PNP0C14:07: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jan 10 22:30:00 archline-XPS15 kernel: ioremap error for 0x63cc3000-0x63cc4000, requested 0x2, got 0x0
Jan 10 22:30:00 archline-XPS15 kernel: ucsi_acpi: probe of USBC000:00 failed with error -12
Jan 10 22:30:00 archline-XPS15 kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcdfff], which spans more than pnp 00:05 [mem 0xfedc0000-0xfedc7fff]
Jan 10 22:30:00 archline-XPS15 kernel: caller tgl_uncore_imc_freerunning_init_box+0xba/0x110 [intel_uncore] mapping multiple BARs
Jan 10 22:30:00 archline-XPS15 kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Jan 10 22:30:00 archline-XPS15 kernel: dell_smm_hwmon: unable to get SMM Dell signature
Jan 10 22:30:01 archline-XPS15 kernel: thermal thermal_zone11: failed to read out thermal zone (-61)
Jan 10 22:30:01 archline-XPS15 kernel: nvidia: loading out-of-tree module taints kernel.
Jan 10 22:30:01 archline-XPS15 kernel: nvidia: module license 'NVIDIA' taints kernel.
Jan 10 22:30:01 archline-XPS15 kernel: Disabling lock debugging due to kernel taint
Jan 10 22:30:01 archline-XPS15 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  525.60.11  Wed Nov 23 23:04:03 UTC 2022
Jan 10 22:30:02 archline-XPS15 kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Jan 10 22:30:02 archline-XPS15 systemd[680]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Jan 10 22:30:02 archline-XPS15 bluetoothd[680]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Jan 10 22:30:02 archline-XPS15 bluetoothd[680]: src/plugin.c:plugin_init() Failed to init vcp plugin
Jan 10 22:30:02 archline-XPS15 bluetoothd[680]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Jan 10 22:30:02 archline-XPS15 bluetoothd[680]: src/plugin.c:plugin_init() Failed to init mcp plugin
Jan 10 22:30:02 archline-XPS15 bluetoothd[680]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Jan 10 22:30:02 archline-XPS15 bluetoothd[680]: src/plugin.c:plugin_init() Failed to init bap plugin
Jan 10 22:30:03 archline-XPS15 kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Jan 10 22:30:03 archline-XPS15 kernel: ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Jan 10 22:30:05 archline-XPS15 kernel: kauditd_printk_skb: 189 callbacks suppressed
Jan 10 22:30:06 archline-XPS15 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Jan 10 22:30:12 archline-XPS15 kernel: kauditd_printk_skb: 32 callbacks suppressed
Jan 10 22:30:20 archline-XPS15 lightdm[939]: gkr-pam: unable to locate daemon control file
Jan 10 22:30:20 archline-XPS15 systemd-journald[385]: File /var/log/journal/d9222eef6532463081f9488842c20c49/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Jan 10 22:30:21 archline-XPS15 pulseaudio[988]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jan 10 22:30:30 archline-XPS15 kernel: kauditd_printk_skb: 35 callbacks suppressed
I suspected something I run at the boot of the computer.
As my terminal (terminator) does not show transparent background, which it should, I run the line “picom -b -c”, which resolves the mentioned problem, but seems to randomly be linked with the cause.
If I remove it, the issue still happens, but way less frequently.
Here is a piece of my current config file:
# i3 config file (v4)
# Please see http://i3wm.org/docs/userguide.html for a complete reference!
#Run boot:
exec --no-startup-id xrandr -s 2560x1600
exec --no-startup-id volumeicon
exec --no-startup-id nitrogen /usr/share/backgrounds/1228050.jpg --set-scaled
exec --no-startup-id xbacklight 1
#exec --no-startup-id picom -b -c
# Lock screen
bindsym $mod+9 exec --no-startup-id blurlock
# Autostart applications
exec --no-startup-id /usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1
#wallpaper at first:  exec --no-startup-id nitrogen --restore; sleep 1; picom -b
exec --no-startup-id manjaro-hello
exec --no-startup-id nm-applet
exec --no-startup-id xfce4-power-manager
exec --no-startup-id pamac-tray
exec --no-startup-id clipit
# exec --no-startup-id blueman-applet
# exec_always --no-startup-id sbxkb
exec --no-startup-id start_conky_maia
# exec --no-startup-id start_conky_green
# exec --no-startup-id xautolock -time 10 -locker blurlock
exec_always --no-startup-id ff-theme-util
exec_always --no-startup-id fix_xcursor
I considered the issue to be linked with the drivers of the graphic cards, particularly as this bug also show weird colors on the screen, like greenish lines. I uninstalled all the pilots and installed back the xf86-vide-intel ones.
I also suspected the power management as it was at first related to the sleeping mode.
I read multiple articles and posts about it but nothing convincing.
Nothing works so far.
Related posts:
=> In my case it does not logs me out
=> Fresh install, tons of space available
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Can you try a more recent kernel: 6.1.
Your computer has a modern CPU.
see this
Hello,
Thank you for tips! I did the upgrade:
mhwd-kernel -li  :heavy_check_mark:
Currently running: 6.1.1-1-MANJARO (linux61)
  • linux515
  • linux61
I could run 6.1.1 thanks to Stephane link to the post with ibt=off, as I had the same issue as the others when booting.
However, my main issue is not resolved.
It bugged again a few minutes ago, after an hour with the new Kernel. I did not unplug the computer, I was using it. It simply started to bug slowly. Steps:
  • I could not write in my brave browser anymore
  • I could not click on the windows.
  • I could first open a terminal, but the commands were not recognized
  • I could not open any more terminal
  • Programs closed by themselves
  • Cannot do anything. I tried changing TTY, no succed, I had to hard reset the computer.
Other element observed:
When switching desktops, or opening a new windows, for a short fraction of time I can see like RGB pixels in the shape of what I am opening, maybe something video related. My pilots are up to date, but since this issue here is not resolve I prefer to mention it if it gives a lead.
I tried to check the journal and got for journalctl -k -b -l the following output at the end:
Jan 12 12:59:33 archline-XPS15 kernel: kauditd_printk_skb: 100 callbacks suppressed
Jan 12 12:59:33 archline-XPS15 kernel: audit: type=1130 audit(1673524773.070:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=wpa_supplicant comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 12:59:33 archline-XPS15 kernel: input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
Jan 12 12:59:33 archline-XPS15 kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input29
Jan 12 12:59:33 archline-XPS15 kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
Jan 12 12:59:33 archline-XPS15 kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
Jan 12 12:59:33 archline-XPS15 kernel: input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input32
Jan 12 12:59:33 archline-XPS15 kernel: audit: type=1130 audit(1673524773.593:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=alsa-restore comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 12:59:33 archline-XPS15 kernel: ACPI Warning: _SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
Jan 12 12:59:33 archline-XPS15 kernel: ACPI Warning: _SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
Jan 12 12:59:35 archline-XPS15 kernel: audit: type=1103 audit(1673524775.823:113): pid=833 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:setcred grantors=pam_env,pam_permit acct=“lightdm” exe=“/usr/bin/lightdm” hostname=? addr=? terminal=:0 res=success’
Jan 12 12:59:35 archline-XPS15 kernel: audit: type=1130 audit(1673524775.933:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=user-runtime-dir@969 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 12:59:35 archline-XPS15 kernel: audit: type=1101 audit(1673524775.940:115): pid=851 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct=“lightdm” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 12:59:35 archline-XPS15 kernel: audit: type=1103 audit(1673524775.940:116): pid=851 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:setcred grantors=? acct=“lightdm” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=failed’
Jan 12 12:59:35 archline-XPS15 kernel: audit: type=1006 audit(1673524775.940:117): pid=851 uid=0 subj=unconfined old-auid=4294967295 auid=969 tty=(none) old-ses=4294967295 ses=1 res=1
Jan 12 12:59:35 archline-XPS15 kernel: audit: type=1300 audit(1673524775.940:117): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffe4d0ba4e0 a2=3 a3=7ffe4d0ba1f5 items=0 ppid=1 pid=851 auid=969 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm=“(systemd)” exe=“/usr/lib/systemd/syste>
Jan 12 12:59:35 archline-XPS15 kernel: audit: type=1327 audit(1673524775.940:117): proctitle=”(systemd)"
Jan 12 12:59:35 archline-XPS15 kernel: audit: type=1105 audit(1673524775.943:118): pid=851 uid=0 auid=969 ses=1 subj=unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct=“lightdm” exe=“/usr/lib/systemd/sys>
Jan 12 12:59:36 archline-XPS15 kernel: wlp0s20f3: authenticate with 24:95:04:f6:89:04
Jan 12 12:59:36 archline-XPS15 kernel: wlp0s20f3: 80 MHz not supported, disabling VHT
Jan 12 12:59:36 archline-XPS15 kernel: wlp0s20f3: send auth to 24:95:04:f6:89:04 (try 1/3)
Jan 12 12:59:37 archline-XPS15 kernel: wlp0s20f3: authenticated
Jan 12 12:59:37 archline-XPS15 kernel: wlp0s20f3: associate with 24:95:04:f6:89:04 (try 1/3)
Jan 12 12:59:37 archline-XPS15 kernel: wlp0s20f3: RX AssocResp from 24:95:04:f6:89:04 (capab=0x411 status=0 aid=4)
Jan 12 12:59:37 archline-XPS15 kernel: wlp0s20f3: associated
Jan 12 12:59:37 archline-XPS15 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Jan 12 12:59:38 archline-XPS15 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
Jan 12 12:59:40 archline-XPS15 kernel: kauditd_printk_skb: 7 callbacks suppressed
Jan 12 12:59:40 archline-XPS15 kernel: audit: type=1100 audit(1673524780.013:126): pid=923 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct=“archline” exe=”/usr/bin/lightdm" hostname=? addr=? terminal=:0 re>
Jan 12 12:59:40 archline-XPS15 kernel: audit: type=1101 audit(1673524780.013:127): pid=923 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct=“archline” exe=“/usr/bin/lightdm” hostname=? addr=? terminal=:0 res=success’
Jan 12 12:59:40 archline-XPS15 kernel: audit: type=1106 audit(1673524780.050:128): pid=833 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:session_close grantors=pam_unix,pam_systemd acct=“lightdm” exe=“/usr/bin/lightdm” hostname=? addr=? terminal=:0 res=success’
Jan 12 12:59:40 archline-XPS15 kernel: audit: type=1104 audit(1673524780.050:129): pid=833 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:setcred grantors=pam_env,pam_permit acct=“lightdm” exe=“/usr/bin/lightdm” hostname=? addr=? terminal=:0 res=success’
Jan 12 12:59:40 archline-XPS15 kernel: audit: type=1103 audit(1673524780.073:130): pid=923 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct=“archline” exe=“/usr/bin/lightdm” hostname=? addr=? terminal=:0 res=succe>
Jan 12 12:59:40 archline-XPS15 kernel: audit: type=1006 audit(1673524780.073:131): pid=923 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Jan 12 12:59:40 archline-XPS15 kernel: audit: type=1300 audit(1673524780.073:131): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffc5db9f4b0 a2=4 a3=7ffc5db9f1c4 items=0 ppid=743 pid=923 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm=“lightdm” exe=“/usr/bin/lightdm” sub>
Jan 12 12:59:40 archline-XPS15 kernel: audit: type=1327 audit(1673524780.073:131): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003133003230
Jan 12 12:59:40 archline-XPS15 kernel: audit: type=1130 audit(1673524780.176:132): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=user-runtime-dir@1000 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 12:59:40 archline-XPS15 kernel: audit: type=1101 audit(1673524780.186:133): pid=964 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct=“archline” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 12:59:40 archline-XPS15 kernel: Bluetooth: RFCOMM TTY layer initialized
Jan 12 12:59:40 archline-XPS15 kernel: Bluetooth: RFCOMM socket layer initialized
Jan 12 12:59:40 archline-XPS15 kernel: Bluetooth: RFCOMM ver 1.11
Jan 12 12:59:48 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 12:59:50 archline-XPS15 kernel: kauditd_printk_skb: 12 callbacks suppressed
Jan 12 12:59:50 archline-XPS15 kernel: audit: type=1131 audit(1673524790.420:144): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=user@969 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 12:59:50 archline-XPS15 kernel: audit: type=1131 audit(1673524790.540:145): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=user-runtime-dir@969 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 13:00:02 archline-XPS15 kernel: audit: type=1131 audit(1673524802.636:146): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 13:00:02 archline-XPS15 kernel: audit: type=1131 audit(1673524802.656:147): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-timedated comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 13:00:02 archline-XPS15 kernel: audit: type=1334 audit(1673524802.680:148): prog-id=0 op=UNLOAD
Jan 12 13:00:02 archline-XPS15 kernel: audit: type=1334 audit(1673524802.680:149): prog-id=0 op=UNLOAD
Jan 12 13:00:02 archline-XPS15 kernel: audit: type=1334 audit(1673524802.680:150): prog-id=0 op=UNLOAD
Jan 12 13:00:02 archline-XPS15 kernel: audit: type=1334 audit(1673524802.726:151): prog-id=0 op=UNLOAD
Jan 12 13:00:02 archline-XPS15 kernel: audit: type=1334 audit(1673524802.726:152): prog-id=0 op=UNLOAD
Jan 12 13:00:02 archline-XPS15 kernel: audit: type=1334 audit(1673524802.726:153): prog-id=0 op=UNLOAD
Jan 12 13:00:34 archline-XPS15 kernel: ACPI Error: Thread 1155278592 cannot release Mutex [ECMX] acquired by thread 1713032704 (20220331/exmutex-378)
Jan 12 13:00:34 archline-XPS15 kernel: ACPI Error: Aborting method _SB.PC00.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20220331/psparse-529)
Jan 12 13:00:34 archline-XPS15 kernel: ACPI Error: Thread 1152820992 cannot release Mutex [ECMX] acquired by thread 1713032704 (20220331/exmutex-378)
Jan 12 13:00:34 archline-XPS15 kernel: ACPI Error: Thread 1099320832 cannot release Mutex [ECMX] acquired by thread 1713032704 (20220331/exmutex-378)
Jan 12 13:00:41 archline-XPS15 kernel: ACPI Error: Thread 1713032704 cannot release Mutex [ECMX] acquired by thread 1155278592 (20220331/exmutex-378)
Jan 12 13:00:41 archline-XPS15 kernel: ACPI Error: Aborting method _SB.PC00.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20220331/psparse-529)
Jan 12 13:03:24 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:03:40 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:04:43 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:04:44 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:04:46 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:04:47 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:04:53 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:04:55 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:07:54 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:08:35 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:09:43 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:09:44 archline-XPS15 kernel: audit: type=1334 audit(1673525384.103:154): prog-id=42 op=LOAD
Jan 12 13:09:44 archline-XPS15 kernel: audit: type=1334 audit(1673525384.103:155): prog-id=43 op=LOAD
Jan 12 13:09:44 archline-XPS15 kernel: audit: type=1334 audit(1673525384.103:156): prog-id=44 op=LOAD
Jan 12 13:09:44 archline-XPS15 kernel: audit: type=1130 audit(1673525384.166:157): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-timedated comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 13:09:54 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:10:14 archline-XPS15 kernel: audit: type=1131 audit(1673525414.243:158): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-timedated comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 13:10:14 archline-XPS15 kernel: audit: type=1334 audit(1673525414.276:159): prog-id=0 op=UNLOAD
Jan 12 13:10:14 archline-XPS15 kernel: audit: type=1334 audit(1673525414.276:160): prog-id=0 op=UNLOAD
Jan 12 13:10:14 archline-XPS15 kernel: audit: type=1334 audit(1673525414.276:161): prog-id=0 op=UNLOAD
Jan 12 13:10:27 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:10:29 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:10:30 archline-XPS15 kernel: audit: type=1100 audit(1673525430.449:162): pid=5349 uid=1000 auid=1000 ses=2 subj=unconfined msg=‘op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct=“archline” exe=“/usr/lib/polkit-1/polkit-agent-helper-1” hostname=? addr=? terminal=? res=success’
Jan 12 13:10:30 archline-XPS15 kernel: audit: type=1101 audit(1673525430.449:163): pid=5349 uid=1000 auid=1000 ses=2 subj=unconfined msg=‘op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct=“archline” exe=“/usr/lib/polkit-1/polkit-agent-helper-1” hostname=? addr=? terminal=? res=success’
Jan 12 13:10:31 archline-XPS15 kernel: st: Version 20160209, fixed bufsize 32768, s/g segs 256
Jan 12 13:10:45 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:11:08 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:11:11 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:11:13 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:11:54 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:13:34 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:13:39 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:14:02 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:14:04 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:14:06 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:14:16 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:14:20 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:14:22 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:14:24 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:14:26 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:14:30 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:14:30 archline-XPS15 kernel: audit: type=1130 audit(1673525670.521:164): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-tmpfiles-clean comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 13:14:30 archline-XPS15 kernel: audit: type=1131 audit(1673525670.521:165): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=‘unit=systemd-tmpfiles-clean comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jan 12 13:14:32 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:14:36 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:15:20 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:15:25 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:15:30 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:15:54 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:17:14 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:17:31 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:17:40 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:17:42 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:18:10 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:19:04 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:20:01 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:20:09 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:22:11 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:22:20 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:22:35 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:22:45 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:23:47 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:24:20 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:26:14 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:27:05 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:27:40 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:28:22 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:28:35 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:28:41 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:28:50 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:29:10 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:29:21 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:29:56 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:30:11 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:30:12 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:31:45 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:31:48 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:31:55 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:32:21 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:32:31 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:32:32 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:32:35 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:32:41 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:33:23 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:33:31 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:33:51 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:34:05 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:34:11 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:34:17 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:34:46 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:35:01 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:35:17 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
Jan 12 13:36:15 archline-XPS15 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
The crash occurred at about 13:36.
I am trying to read out other elements related to it. I could try the kernel 6.0. but since the exact same thing happened with the older version I am not sure it makes much sense.
FYI, I managed to get a screenshot of the graphic bug that appears punctually, it tends to crash after that. The web browser disappears but sometimes appear like this. No error appear though and I cannot find many information so far on the forum. I wonder if it might be related. I re-installed the GPU drivers just in case.
format the logs properly, they are a mess…
but you have some i915 logs there, which are related to igpu…
try adding these parameters:
sudo nano /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT - inside the quotes add these parameters:
i915.edp_vswing=2 i915.enable_psr=0
dont remove anything from there, just add them to the existing parameters, save the file with ctrl+x, update grub with:
sudo update-grub
reboot and test
I suggest you update BIOS to latest version - Dell XPS 15 9510 System BIOS v1.16.0
I tried to make it look more clean. Here we have only the errors and the boots. The boots were following the crash (hard reset always)
It was ok for most of the day then it crashed again.
At the boot I always get the following errors, which I am trying to investigate.
Jan 13 22:41:25 archline-XPS15 lightdm[900]: gkr-pam: unable to locate daemon control file
Jan 13 22:41:18 archline-XPS15 bluetoothd[646]: src/plugin.c:plugin_init() Failed to init bap plugin
Jan 13 22:41:18 archline-XPS15 bluetoothd[646]: src/plugin.c:plugin_init() Failed to init mcp plugin
Jan 13 22:41:18 archline-XPS15 bluetoothd[646]: src/plugin.c:plugin_init() Failed to init vcp plugin
Jan 13 22:41:18 archline-XPS15 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jan 13 22:41:17 archline-XPS15 kernel:
Jan 13 22:41:16 archline-XPS15 kernel: dell_smm_hwmon: unable to get SMM Dell signature
– Boot db70d2324446426ca697cc12033a58df –
Here are the logs at the moment of the crashes
– Boot 76fa7a387a254db982ad9bd8dce730c0 –
22:24:17 kernel: ACPI Error: Aborting method _SB.PC00.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20220331/psparse-529)
22:24:17 kernel: ACPI Error: Thread 112502528 cannot release Mutex [ECMX] acquired by thread 43548672 (20220331/exmutex-378)
22:24:07 kernel: ACPI Error: Aborting method _SB.PC00.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20220331/psparse-529)
22:24:07 kernel: ACPI Error: Thread 189746688 cannot release Mutex [ECMX] acquired by thread 189736704 (20220331/exmutex-378)
22:24:07 kernel: ACPI Error: Thread 22062848 cannot release Mutex [ECMX] acquired by thread 189736704 (20220331/exmutex-378)
22:16:20 kernel: ucsi_acpi USBC000:00: failed to re-enable notifications (-110)
19:10:32 kernel: ACPI Error: Aborting method _SB.PC00.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20220331/psparse-529)
19:10:32 kernel: ACPI Error: Thread 112578048 cannot release Mutex [ECMX] acquired by thread 942024448 (20220331/exmutex-378)
19:10:32 kernel: ACPI Error: Thread 942034432 cannot release Mutex [ECMX] acquired by thread 942024448 (20220331/exmutex-378)
19:10:32 kernel: ACPI Error: Thread 189746688 cannot release Mutex [ECMX] acquired by thread 942024448 (20220331/exmutex-378)
17:31:36 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
17:31:30 kernel: i915 0000:00:02.0: [drm] ERROR Unexpected DE Misc interrupt
17:31:18 lightdm[849]: gkr-pam: unable to locate daemon control file
17:31:01 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
17:31:00 bluetoothd[581]: src/plugin.c:plugin_init() Failed to init bap plugin
17:31:00 bluetoothd[581]: src/plugin.c:plugin_init() Failed to init mcp plugin
17:31:00 bluetoothd[581]: src/plugin.c:plugin_init() Failed to init vcp plugin
17:30:59 kernel:
17:30:59 kernel: dell_smm_hwmon: unable to get SMM Dell signature
17:30:58 kernel: ACPI Error: Aborting method _SB.PC00.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20220331/psparse-529)
17:30:58 kernel: ACPI Error: Thread 112676352 cannot release Mutex [ECMX] acquired by thread 43089920 (20220331/exmutex-378)
– Boot 2428e0dd2518450fbba6f9ac921ce4ba –
17:30:14 kernel: watchdog: watchdog0: watchdog did not stop!
17:24:51 lightdm[904]: gkr-pam: unable to locate daemon control file
17:24:31 bluetoothd[655]: src/plugin.c:plugin_init() Failed to init bap plugin
17:24:31 bluetoothd[655]: src/plugin.c:plugin_init() Failed to init mcp plugin
17:24:31 bluetoothd[655]: src/plugin.c:plugin_init() Failed to init vcp plugin
17:24:31 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
17:24:30 kernel:
17:24:29 kernel: dell_smm_hwmon: unable to get SMM Dell signature
I focused a bit more on the first error called dell_smm_hwmon: unable to get SMM Dell Signature and found couple of posts including:
https://bbs.archlinux.org/viewtopic.php?id=281125
I made sure to remove the intel drivers to keep only the nouveau, and made replacements in the grub files. Still not success.
Overall, this is linked to the fan and I have a few BIOS messages about the fan appearing. I will dismount the computer to check if I do not have a faulty contact tomorrow morning.
EDIT: With the update of the BIOS, the bug still persists.
Hi. I see you have quoted my thread as a similar issue, although there are some differences, and my issue was probably caused by my encrypted drive. In my case either upgrading the kernel, or the solution that involves changing GRUB config worked. (probably latter). I cannot include links yet unfortunately -.- but you can find it on the first related post.
Update here:
I have the latest BIOS vesrions, latest Kernel version, applied the above points for me grub file:
GRUB_CMDLINE_LINUX_DEFAULT=“quiet apparmor=1 security=apparmor udev.log_priority=3 ibt=off i915.edp_vswing=2 i915.enable_psr=0”
I tried many different configuration, also to put the modeset of the drivers to 0. I have less crashes overall, but still the exact same thing happen.
I reviewed again my graphic drivers, not from the manjaro installer but manually and made a clean install (I use the “nouveau” drivers only) as the other ones seem to have some issues with recent Hardware.
Here is the current output for the drivers:
I do not have a particular error in the journalctl.
The computer is like lagging, then none of the shortcuts like open terminal etc. work. I cannot put in sleep more with the start button (permission denied), none of the normal command in the terminal are known (Not found).
The latest errors:
Jan 16 14:01:59 archline-XPS15 kernel: dell_smm_hwmon: unable to get SMM Dell signature
– Boot 5206bd989cde46158503c51184ab846d –
Jan 16 13:57:11 archline-XPS15 lightdm[918]: gkr-pam: unable to locate daemon control file
Jan 16 13:56:55 archline-XPS15 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jan 16 13:56:54 archline-XPS15 bluetoothd[680]: src/plugin.c:plugin_init() Failed to init bap plugin
Jan 16 13:56:54 archline-XPS15 bluetoothd[680]: src/plugin.c:plugin_init() Failed to init mcp plugin
Jan 16 13:56:54 archline-XPS15 bluetoothd[680]: src/plugin.c:plugin_init() Failed to init vcp plugin
Jan 16 13:56:53 archline-XPS15 kernel: dell_smm_hwmon: unable to get SMM Dell signature
– Boot 545e800c9827453dabc0f2b413a35091 –
Jan 16 13:32:11 archline-XPS15 kernel: ucsi_acpi USBC000:00: failed to re-enable notifications (-110)
Jan 16 11:47:09 archline-XPS15 kernel: ucsi_acpi USBC000:00: failed to re-enable notifications (-110)
Jan 16 11:35:04 archline-XPS15 kernel: ucsi_acpi USBC000:00: failed to re-enable notifications (-110)
Jan 16 07:26:46 archline-XPS15 kernel: ucsi_acpi USBC000:00: failed to re-enable notifications (-110)
Jan 15 22:45:08 archline-XPS15 lightdm[927]: gkr-pam: unable to locate daemon control file
Jan 15 22:45:02 archline-XPS15 kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
Jan 15 22:45:02 archline-XPS15 kernel: ucsi_acpi USBC000:00: unknown error 0
Jan 15 22:45:02 archline-XPS15 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jan 15 22:45:00 archline-XPS15 bluetoothd[699]: src/plugin.c:plugin_init() Failed to init bap plugin
Jan 15 22:45:00 archline-XPS15 bluetoothd[699]: src/plugin.c:plugin_init() Failed to init mcp plugin
Jan 15 22:45:00 archline-XPS15 bluetoothd[699]: src/plugin.c:plugin_init() Failed to init vcp plugin
Jan 15 22:44:59 archline-XPS15 kernel: dell_smm_hwmon: unable to get SMM Dell signature
this is probably because you are running on nouveau drivers, instead of the nvidia ones…
and the mhwd output shows, only what drivers are available for install… if you want to check what drivers you have installed run:
mhwd -li
it would be worth a try to run only on nvidia gpu, maybe it will help…
also do you have issues also in the live usb?
it could be also because you are using i3wm?
The issue persisted with the different drivers:
video-linux, video-nvidia, video-hybrid-intel-nvidia-prime.
I am rejecting it as an issue for now.
I will try to run with a live USB and see if it keeps happening, who knows…
The i3wm was the official install by Manjaro. It might be related, or X11? I am not sure how to diagnose these properly.
Have you taken a look through these:
https://wiki.archlinux.org/title/Dell_XPS_15_(9510)
https://wiki.archlinux.org/title/NVIDIA_Optimus#Available_methods
https://wiki.archlinux.org/title/Hybrid_graphics#Fully_power_down_discrete_GPU
The BIOS part yep, no choice otherwise it would not boot.
For the remaining part, I installed Manjaro i3 config directly.
I focused mostly on Manjaro’s forum, even if I am considering making a fresh install with Arch, forgetting about Manjaro. Manjaro was supposed to make it easier to install, but if it goes with some stuff not compatible it is more of a headache to check it all.
I am currently following some of the subtilities in the links you gave me, to see if a parameter is wrong but so far nothing particular.
I would really need to find a way to see what triggers the bug, what error…
Hello,
Here is an update:
  • I tried to check many packages installed but it was very long. I decided to do a fresh install.
  • After a fresh install, the problem occured again multiple times.
  • I decided to go from something “cleaner” and fresh installed archlinux.
The issue occured only after a few days. I made a thread on the arch forum and it seems solved for now.
https://bbs.archlinux.org/viewtopic.php?pid=2080704#p2080704
I modified a kernel parameter with the following input:
nvme_core.default_ps_max_latency_us=0 iommu=soft
Also, I realised the error happened with “volumeicon” multiple times.
=> Everytime I had it in my .xinitrc, my system would boot but startx would fail to a black screen
=> A few times at the moment I would execute it, or slightly after.
In everycases, volumeicon was installed and in use. I had it installed on archlinux a bit before the bug happened, and it comes natively with Manjaro.
I did not try to solve what fails with this package, I just made my own script for the volume.
Thank you all again for your inputs. I hope it helps someone else in a similar situation.
