I migrated from Mint to Manjaro about two months ago, and, admittedly, this issue was already present in Mint. I tried to get help on its forum, but it was of no use. Eventually I just got used to the issue, but now, after switching OSs, I want to fix it.
For about a third of the times I boot or try to shutdown my computer, it crashes. The boot crashes usually happen between when the cursor appears on screen and right after I log in, and the shutdown crashes happen right after I click shutdown
In those crashes, the screen freezes and no commands work. I canât open a TTY, I canât shutdown my computer through a key combination, literally nothing works. The only solution is to press down the power button.
One of the suggestions that appeared on the Mint post I wrote was to switch kernels. I did back then, and it appeared to have solved the issue. But it didnât. No matter what kernel I use, if I stick to it long enough, those crashes start happening.
After the two most recent crashes and searching a bit for answers in this forum, I decided to inspect the output of journalctl
This is the output (the last part of which, at least â I donât know how much of it I should post here) of journaltcl -b -1
on the boot following a crash during startup:
ago 15 11:43:07 kvothe kernel: microcode: microcode updated early to revision 0xf0, date = 2021-11-15
ago 15 11:43:07 kvothe kernel: Linux version 5.19.1-2-MANJARO (builduser@fv-az397-245) (gcc (GCC) 12.1.1 20220730, GNU ld (GNU Binutils) 2.39) #1>
ago 15 11:43:07 kvothe kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64 root=UUID=01070a50-d90a-4393-b111-113423c883d8 rw quiet resume=>
ago 15 11:43:07 kvothe kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
ago 15 11:43:07 kvothe kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
ago 15 11:43:07 kvothe kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
ago 15 11:43:07 kvothe kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
ago 15 11:43:07 kvothe kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
ago 15 11:43:07 kvothe kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
ago 15 11:43:07 kvothe kernel: x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
ago 15 11:43:07 kvothe kernel: x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
ago 15 11:43:07 kvothe kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
ago 15 11:43:07 kvothe kernel: signal: max sigframe size: 2032
ago 15 11:43:07 kvothe kernel: BIOS-provided physical RAM map:
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x0000000000100000-0x000000003fffffff] usable
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x0000000040000000-0x00000000403fffff] reserved
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x0000000040400000-0x000000006c5b2fff] usable
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x000000006c5b3000-0x000000006c5b3fff] ACPI NVS
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x000000006c5b4000-0x000000006c5b4fff] reserved
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x000000006c5b5000-0x000000007732dfff] usable
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x000000007732e000-0x0000000077939fff] reserved
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x000000007793a000-0x00000000779b6fff] ACPI data
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x00000000779b7000-0x0000000077abdfff] ACPI NVS
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x0000000077abe000-0x000000007912ffff] reserved
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x0000000079130000-0x00000000791fdfff] type 20
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x00000000791fe000-0x00000000791fefff] usable
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x00000000791ff000-0x000000007f7fffff] reserved
ago 15 11:43:07 kvothe kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
...skipping...
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension BIG-REQUESTS
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension SYNC
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension XKEYBOARD
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension XC-MISC
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension SECURITY
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension XFIXES
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension RENDER
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension RANDR
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension COMPOSITE
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension DAMAGE
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension MIT-SCREEN-SAVER
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension DOUBLE-BUFFER
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension RECORD
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension DPMS
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension Present
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension DRI3
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension X-Resource
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension XVideo
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension XVideo-MotionCompensation
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension GLX
ago 15 11:43:14 kvothe /usr/lib/gdm-x-session[870]: (II) Indirect GLX disabled.
ago 15 11:43:15 kvothe /usr/lib/gdm-x-session[870]: (II) AIGLX: Loaded and initialized iris
ago 15 11:43:15 kvothe /usr/lib/gdm-x-session[870]: (II) GLX: Initialized DRI2 GL provider for screen 0
ago 15 11:43:15 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension XFree86-VidModeExtension
ago 15 11:43:15 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension XFree86-DGA
ago 15 11:43:15 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension XFree86-DRI
ago 15 11:43:15 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension DRI2
ago 15 11:43:15 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension NV-GLX
ago 15 11:43:15 kvothe /usr/lib/gdm-x-session[870]: (II) Initializing extension NV-CONTROL
ago 15 11:43:15 kvothe /usr/lib/gdm-x-session[870]: (II) modeset(0): Damage tracking initialized
ago 15 11:43:15 kvothe /usr/lib/gdm-x-session[870]: (II) modeset(0): Setting screen physical size to 508 x 285
This is the output of journaltcl -b -1
on a boot following a crash during shutdown:
ago 13 18:36:15 kvothe kernel: microcode: microcode updated early to revision 0xf0, date = 2021-11-15
ago 13 18:36:15 kvothe kernel: Linux version 5.19.1-2-MANJARO (builduser@fv-az397-245) (gcc (GCC) 12.1.1 20220730, GNU ld (GNU Binutils) 2.39) #1>
ago 13 18:36:15 kvothe kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64 root=UUID=01070a50-d90a-4393-b111-113423c883d8 rw quiet resume=>
ago 13 18:36:15 kvothe kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
ago 13 18:36:15 kvothe kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
ago 13 18:36:15 kvothe kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
ago 13 18:36:15 kvothe kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
ago 13 18:36:15 kvothe kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
ago 13 18:36:15 kvothe kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
ago 13 18:36:15 kvothe kernel: x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
ago 13 18:36:15 kvothe kernel: x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
ago 13 18:36:15 kvothe kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
ago 13 18:36:15 kvothe kernel: signal: max sigframe size: 2032
ago 13 18:36:15 kvothe kernel: BIOS-provided physical RAM map:
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x0000000000100000-0x000000003fffffff] usable
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x0000000040000000-0x00000000403fffff] reserved
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x0000000040400000-0x000000006c5b2fff] usable
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x000000006c5b3000-0x000000006c5b3fff] ACPI NVS
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x000000006c5b4000-0x000000006c5b4fff] reserved
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x000000006c5b5000-0x000000007732dfff] usable
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x000000007732e000-0x0000000077939fff] reserved
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x000000007793a000-0x00000000779b6fff] ACPI data
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x00000000779b7000-0x0000000077abdfff] ACPI NVS
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x0000000077abe000-0x000000007912ffff] reserved
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x0000000079130000-0x00000000791fdfff] type 20
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x00000000791fe000-0x00000000791fefff] usable
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x00000000791ff000-0x000000007f7fffff] reserved
ago 13 18:36:15 kvothe kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
...skipping...
ago 13 20:11:34 kvothe kernel: audit: type=1131 audit(1660432294.107:111): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed>
ago 13 20:11:34 kvothe audit: BPF prog-id=0 op=UNLOAD
ago 13 20:11:34 kvothe kernel: audit: type=1334 audit(1660432294.201:112): prog-id=0 op=UNLOAD
ago 13 20:11:34 kvothe kernel: audit: type=1334 audit(1660432294.201:113): prog-id=0 op=UNLOAD
ago 13 20:11:34 kvothe kernel: audit: type=1334 audit(1660432294.201:114): prog-id=0 op=UNLOAD
ago 13 20:11:43 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:12:15 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:12:19 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:12:20 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:12:34 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:12:41 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:12:49 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:13:18 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:13:24 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:13:37 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:14:02 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:14:14 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:14:22 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:14:38 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:14:55 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:14:57 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:15:07 kvothe systemd[1382]: app-gnome-chromium-3378.scope: Consumed 1min 8.579s CPU time.
ago 13 20:15:17 kvothe gnome-shell[1480]: endSessionDialog: No XDG_SESSION_ID, fetched from logind: 3
ago 13 20:15:17 kvothe wpa_supplicant[974]: TDLS: Invalid frame - payloadtype=1 category=240 action=26
ago 13 20:15:19 kvothe gnome-session-binary[1465]: Entering running state
ago 13 20:15:19 kvothe gnome-shell[1480]: Ignored exception from dbus method: Gio.IOErrorEnum: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._g_>
ago 13 20:15:21 kvothe org.gnome.Nautilus[2007]: warning: ... repeated 20 times...
ago 13 20:15:26 kvothe gnome-shell[1480]: endSessionDialog: No XDG_SESSION_ID, fetched from logind: 3
ago 13 20:15:28 kvothe systemd-logind[702]: System is powering down.
Output of
export LANG=C; inxi --admin --verbosity=7 --filter --width
below:
Kernel: 5.19.1-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
resume=UUID=fa2e3f4c-90a0-436e-9ce4-8ebd9d6f88e8 udev.log_priority=3
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Dell product: G3 3590 v: N/A
Mobo: Dell model: 0GDFK2 v: A00 serial: <superuser required> UEFI: Dell
v: 1.11.1 date: 08/19/2020
ID-1: BAT0 charge: 30.7 Wh (79.1%) condition: 38.8/51.0 Wh (76.1%)
volts: 11.3 min: 11.4 model: LGC-LGC4.474 DELL 415CG99 type: Li-ion
serial: <filter> status: discharging
RAM: total: 7.6 GiB used: 2.31 GiB (30.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2212 high: 2400 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 2400 2: 2400 3: 900
4: 2400 5: 2400 6: 2400 7: 2400 8: 2400 bogomips: 38408
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 0c45:671f class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: LG Display 0x05c4 built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:a348 class-ID: 0401
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.19.1-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: no
vendor: Dell driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s port: 3000 bus-ID: 03:00.0
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:3
chip-ID: 0cf3:e009 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 1.03 TiB used: 121.36 GiB (11.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
NVMe WDC 128GB size: 119.24 GiB block-size: physical: 512 B logical: 512 B
speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: 20240012
temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10SPZX-75Z10T2 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A03 scheme: GPT
ID-1: / raw-size: 114.74 GiB size: 112.38 GiB (97.94%) used: 23.74 GiB
(21.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 01070a50-d90a-4393-b111-113423c883d8
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 571C-DE0F
ID-3: /home raw-size: 931.51 GiB size: 915.81 GiB (98.31%) used: 97.63 GiB
(10.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: ade67289-8f81-47fd-9baf-d44c05aeacf8
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: fa2e3f4c-90a0-436e-9ce4-8ebd9d6f88e8
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-5:2 info: Microdia Integrated_Webcam_HD type: Video
Device-2: 1-14:3 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e009
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.0 C pch: 37.0 C mobo: N/A
Processes: 242 Uptime: 14m wakeups: 2588 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: pacman: 910 lib: 272 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.20
