Random connection drops with LAN and Wifi
Hi Manjaro community,
I’m experiencing random internet connection dropouts with LAN and WiFi and am not sure where to start troubleshooting.
My laptop has a Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet and a Intel Wi-Fi 6 AX200 network device. Wifi is directly coming from my router Speedport Smart 4 (unfortunately bound to that by my provider). Ethernet is connected to the same router via a powerline adapter. I’m running 6.12.43-1-MANJARO with KDE 6.3.6 on Wayland, with Windows 11 in dual boot.
The random dropouts have been happening since a while now and only on Linux and never on Windows. They happen whether I’m connected to Ethernet only, WiFi only, and both in parallel. I cannot yet identify a pattern when they happen or for how long they happen. During a dropout I see in the network popup that the connection is active however download and upload speeds are 0 B/s.
I’ve found some posts that recommended to blacklist r8169 and only use linux612-r8168 as driver, so I’ve done that. Other than that I don’t really know where to start looking for the issue or start troubleshooting. I’m hoping that this information helps an I’m happy to provide more if necessary.
inxi -zv8
  Kernel: 6.12.43-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=3c6999e1-5677-4220-ae3e-9fca636d1ab9 rw nvidia-drm.modeset=1
    quiet apparmor=1 security=apparmor udev.log_priority=3 ibt=off
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
  Type: Laptop System: SchenkerGmbH product: XMG CORE 15(M20, RTX 2060)
    v: Standard serial: <superuser required>
  Mobo: SchenkerGmbH model: GK5NxxO M20 v: Standard
    serial: <superuser required> part-nu: XCO15M20 uuid: <superuser required>
    UEFI: American Megatrends v: N.1.21.A04 date: 08/30/2021
  ID-1: BAT0 charge: 48.0 Wh (77.0%) condition: 62.3/62.3 Wh (100.0%)
    volts: 16.5 min: 15.2 model: standard type: Li-ion serial: <filter>
    status: charging
  System RAM: total: 16 GiB available: 15.04 GiB used: 5.96 GiB (39.7%)
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Micron Technology part-no: 4ATF1G64HZ-3G2E1 serial: <filter>
  Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x860010D
    desc: 8x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 2900 min/max: 1400/2900 boost: enabled scaling:
    driver: acpi-cpufreq governor: performance cores: 1: 2900 2: 2900 3: 2900
    4: 2900 5: 2900 6: 2900 7: 2900 8: 2900 9: 2900 10: 2900 11: 2900 12: 2900
    13: 2900 14: 2900 15: 2900 16: 2900 bogomips: 92663
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
    ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: AIstone Global
    driver: nvidia v: 575.64.05 alternate: nouveau,nvidia_drm
    non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: DP-1 empty: DP-2,HDMI-A-1 bus-ID: 01:00.0
    chip-ID: 10de:1f15 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] vendor: AIstone Global driver: amdgpu v: kernel
    arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: none bus-ID: 06:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 57.0 C
  Device-3: Trust AUKEY PC-LM1A Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.1.2:9
    chip-ID: 145f:023a class-ID: 0102 serial: <filter>
  Device-4: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 04f2:b642
    class-ID: 0e02
    compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu,nvidia,nvidia-nvswitch d-rect: 4480x1440 display-ID: 0
  Monitor-1: DP-1 pos: right model: LG (GoldStar) ULTRAGEAR serial: <filter>
    built: 2020 res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 109 gamma: 1.2
    chroma: red: x: 0.686 y: 0.310 green: x: 0.263 y: 0.671 blue: x: 0.149
    y: 0.055 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: 2560x1440, 1920x1080, 1680x1050,
    1600x900, 1280x1024, 1280x800, 1152x864, 1280x720, 1024x768, 800x600,
    720x480, 640x480
  Monitor-2: eDP-1 pos: primary,left model: Najing CEC Panda 0x004b
    built: 2019 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2
    chroma: red: x: 0.596 y: 0.361 green: x: 0.345 y: 0.557 blue: x: 0.157
    y: 0.106 white: x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.2
    renoir ACO DRM 3.61 6.12.43-1-MANJARO) device-ID: 1002:1636
    memory: 500 MiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 6 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 2060 driver: nvidia v: 575.64.05
    device-ID: 10de:1f15 surfaces: N/A device: 1 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.2.1-arch1.2
    device-ID: 1002:1636 surfaces: N/A
  Device-1: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: AIstone Global driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-2: Trust AUKEY PC-LM1A Webcam driver: snd-usb-audio,uvcvideo
  Device-3: C-Media USB Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-3:13 chip-ID: 0d8c:0012 class-ID: 0300
  API: ALSA v: k6.12.43-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
    vendor: AIstone Global driver: r8168 v: 8.055.00-NAPI modules: r8169 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:3 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 1.82 TiB used: 1.11 TiB (61.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 30.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Kingston model: SA2000M81000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 31.9 C
    scheme: GPT
  ID-1: / raw-size: 63.48 GiB size: 62.18 GiB (97.96%) used: 42.04 GiB (67.6%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:8 label: N/A
    uuid: 3c6999e1-5677-4220-ae3e-9fca636d1ab9
  ID-2: /backup raw-size: 352.79 GiB size: 346.18 GiB (98.13%)
    used: 328.53 GiB (94.9%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:9
    label: Backup uuid: 819032c7-2efe-4a54-8446-94a0894176c1
  ID-3: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%)
    used: 35.5 MiB (37.0%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 2296-5261
  ID-4: /exchange raw-size: 29.3 GiB size: 29.29 GiB (99.98%)
    used: 19.69 GiB (67.2%) fs: exfat dev: /dev/nvme1n1p2 maj-min: 259:11
    label: EXCHANGE uuid: 6C4C-3D1C
  ID-5: /home raw-size: 902.21 GiB size: 886.98 GiB (98.31%)
    used: 747.31 GiB (84.3%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:10
    label: Home uuid: e956cc31-29d8-428f-b435-251a9a7b36b9
  ID-1: swap-1 type: partition size: 16.6 GiB used: 126.2 MiB (0.7%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:7 label: N/A
    uuid: f387da59-2790-4404-a518-b793810c4c54
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs label: N/A
    uuid: 9618727818725769
  ID-2: /dev/nvme0n1p3 maj-min: 259:4 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p4 maj-min: 259:5 size: 497.19 GiB fs: ntfs
    label: System uuid: 2684C85584C8295F
  ID-4: /dev/nvme0n1p5 maj-min: 259:6 size: 872 MiB fs: ntfs label: N/A
    uuid: B6FA9B47FA9B02B3
  Hub-1: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Hub-2: 3-2:3 info: Genesys Logic Hub ports: 2 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Hub-3: 3-2.1:7 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Device-1: 3-2.1.1:8 info: Logitech G513 RGB MECHANICAL GAMING KEYBOARD
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c33c class-ID: 0300 serial: <filter>
  Device-2: 3-2.1.2:9 info: Trust AUKEY PC-LM1A Webcam type: video,audio
  Device-3: 3-2.1.4:10 info: Logitech G502 SE HERO Gaming Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
  Device-4: 3-3:13 info: C-Media USB Audio Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-5: 3-4:4 info: Chicony HD Webcam type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b642 class-ID: 0e02
  Hub-5: 4-2:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-7: 5-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 5-4:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 82.9 C mobo: N/A gpu: amdgpu temp: 58.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 2131 libs: 489 tools: pamac,yay
    1: https://mirror.23m.com/manjaro/stable/$repo/$arch
    2: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    5: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    6: https://manjaro.kurdy.org/stable/$repo/$arch
Processes:
  CPU top: 5 of 401
  1: cpu: 8.9% command: firefox pid: 7405 mem: 884.5 MiB (5.7%)
  2: cpu: 8.2% command: kwin_wayland pid: 1304 mem: 318.5 MiB (2.0%)
  3: cpu: 4.3% command: firefox pid: 8668 mem: 494.2 MiB (3.2%)
  4: cpu: 2.7% command: konsole pid: 14974 mem: 313.7 MiB (2.0%)
  5: cpu: 2.1% command: firefox pid: 14647 mem: 309.5 MiB (2.0%)
  Memory top: 5 of 401
  1: mem: 1358.3 MiB (8.8%) command: clamd pid: 924 cpu: 0.1%
  2: mem: 884.5 MiB (5.7%) command: firefox pid: 7405 cpu: 8.9%
  3: mem: 647.2 MiB (4.2%) command: baloorunner pid: 10318 cpu: 0.0%
  4: mem: 494.2 MiB (3.2%) command: firefox pid: 8668 cpu: 4.3%
  5: mem: 463.6 MiB (3.0%) command: plasmashell pid: 1616 cpu: 1.4%
  Processes: 401 Power: uptime: 2h 19m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 5.98 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3
    running-in: konsole inxi: 3.3.38
mhwd -li
video-hybrid-amd-nvidia-prime            2025.01.13               false            PCI
           video-linux            2024.05.06                true            PCI
         network-r8168            2023.09.12                true            PCI
Warning: No installed USB configs!```
journalctl -b0 | grep 'r816'
Aug 30 12:41:31 nucleus kernel: r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
Aug 30 12:41:31 nucleus kernel: r8168  Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
Aug 30 12:41:31 nucleus kernel: r8168 0000:02:00.0 enp2s0: renamed from eth0
Aug 30 13:51:32 nucleus kernel: r8168 0000:02:00.0 enp2s0: Device reseting!
Aug 30 13:51:34 nucleus kernel: r8168: enp2s0: link up
Aug 30 13:51:42 nucleus kernel: r8168: enp2s0: link down
Aug 30 13:51:44 nucleus kernel: r8168: enp2s0: link up
Aug 30 14:34:42 nucleus sudo[12355]:  lennart : TTY=pts/1 ; PWD=/home/lennart ; USER=root ; COMMAND=/usr/bin/modprobe r8169```
First disable mac randomization and power save. Lots of times one of them or both cause random network disconnections:
Hi @wunst ,
I wonder whether you could read this post, in order to solve the problem.
[Stable Update] 2025-08-29 - Kernels, Toolchain, Virtualbox, Mesa, Wine, ZFS - #42 by philm
Hope it help,
Regards
Resync your mirrors and update, version 6.12.44-2 from today should solve it. (Still testing but i did not see a disconnect so far)
There was a kernel regression, which got fixed lately in linux617. Also all stable kernels were affected. So far we backported it to all branches of Manjaro.
Thanks for the hints. I’ve updated to kernel version 6.12.44-2-MANJARO, deactivated wifi power safe and mac randomization, and will see if the disconnections are fixed.
In case they occur again, is there a better way to see what’s happening other than journalctl --since "2min ago"?
Do you mean:
I won’t see it with this command if the event is more than 2 minutes ago?
You could have a minimized terminal running all the time, displaying the log messages as they occur:
journalctl -f
Sorry that wasn’t clear enough. I wondered if there are any other commands to specifically check for network issues or filter the logs for relevant content? With options journalctl -b0 -x -u NetworkManager I get a lot of information but wouldn’t know what to look for.
Anyhow I haven’t had network issues since I updated to 6.12.44 and made the other changes, so I consider this solved.
Not really - the messages might come from kernel or another facility - and by filtering for just one
like NetworkManager,
you might miss important stuff.
journalctl -f
on an already running system should not produce too many messages and you’d see issues right away.
