I tried 575 and 570 to no avail
17/02/2026 18:53 systemd Finished Create Static Device Nodes in /dev.
17/02/2026 18:53 kernel nvidia-nvlink: Nvlink Core is being initialized, major device number 237
17/02/2026 18:53 systemd Reached target Preparation for Local File Systems.
17/02/2026 18:53 systemd Starting Rule-based Manager for Device Events and Files...
17/02/2026 18:53 kernel nvidia 0000:07:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
17/02/2026 18:53 systemd Started Network Time Synchronization.
17/02/2026 18:53 kernel NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 570.211.01 Release Build (manjarolinux-builder@echo manjarolinux)
17/02/2026 18:53 systemd Reached target System Time Set.
17/02/2026 18:53 kernel nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 570.211.01 Release Build (manjarolinux-builder@echo manjarolinux)
17/02/2026 18:53 systemd-modules-load Inserted module 'nvidia'
17/02/2026 18:53 kernel [drm] [nvidia-drm] [GPU ID 0x00000700] Loading driver
17/02/2026 18:53 systemd Started Rule-based Manager for Device Events and Files.
17/02/2026 18:53 systemd Finished Coldplug All udev Devices.
17/02/2026 18:53 systemd Starting Show Plymouth Boot Screen...
17/02/2026 18:53 systemd Finished Flush Journal to Persistent Storage.
17/02/2026 18:53 systemd Expecting device /dev/tpm0...
17/02/2026 18:53 systemd Found device /dev/tpm0.
17/02/2026 18:53 systemd Reached target Trusted Platform Module.
17/02/2026 18:53 mtp-probe checking bus 3, device 3: "/sys/devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-2"
17/02/2026 18:53 mtp-probe checking bus 3, device 4: "/sys/devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-4"
17/02/2026 18:53 mtp-probe checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-1"
17/02/2026 18:53 mtp-probe bus: 3, device: 4 was not an MTP device
17/02/2026 18:53 mtp-probe bus: 3, device: 2 was not an MTP device
17/02/2026 18:53 mtp-probe checking bus 1, device 2: "/sys/devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-6"
17/02/2026 18:53 mtp-probe bus: 1, device: 2 was not an MTP device
17/02/2026 18:53 mtp-probe bus: 3, device: 3 was not an MTP device
17/02/2026 18:53 systemd Started Show Plymouth Boot Screen.
17/02/2026 18:53 systemd Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
17/02/2026 18:53 systemd Started Forward Password Requests to Plymouth Directory Watch.
17/02/2026 18:53 systemd Reached target Local Encrypted Volumes.
17/02/2026 18:53 kernel input: PC Speaker as /devices/platform/pcspkr/input/input10
17/02/2026 18:53 kernel ccp 0000:09:00.1: enabling device (0000 -> 0002)
17/02/2026 18:53 kernel pps_core: LinuxPPS API ver. 1 registered
17/02/2026 18:53 kernel pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
17/02/2026 18:53 kernel ccp 0000:09:00.1: ccp: unable to access the device: you might be running a broken BIOS.
17/02/2026 18:53 kernel ccp 0000:09:00.1: psp enabled
17/02/2026 18:53 kernel piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
17/02/2026 18:53 kernel piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
17/02/2026 18:53 kernel RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
17/02/2026 18:53 kernel RAPL PMU: hw unit of domain package 2^-16 Joules
17/02/2026 18:53 kernel RAPL PMU: hw unit of domain core 2^-16 Joules
17/02/2026 18:53 kernel i2c i2c-1: Successfully instantiated SPD at 0x52
17/02/2026 18:53 kernel i2c i2c-1: Successfully instantiated SPD at 0x53
17/02/2026 18:53 kernel piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
17/02/2026 18:53 kernel PTP clock support registered
17/02/2026 18:53 kernel i2c i2c-3: Successfully instantiated SPD at 0x50
17/02/2026 18:53 kernel i2c i2c-3: Successfully instantiated SPD at 0x53
17/02/2026 18:53 kernel mc: Linux media interface: v0.10
17/02/2026 18:53 kernel sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
17/02/2026 18:53 kernel Intel(R) 2.5G Ethernet Linux Driver
17/02/2026 18:53 kernel Copyright(c) 2018 Intel Corporation.
17/02/2026 18:53 kernel igc 0000:06:00.0: PCIe PTM not supported by PCIe bus/controller
17/02/2026 18:53 kernel sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
17/02/2026 18:53 kernel asus_wmi: ASUS WMI generic driver loaded
17/02/2026 18:53 kernel sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
17/02/2026 18:53 systemd Found device CT2000P2SSD8 1.
17/02/2026 18:53 systemd Found device ST4000DM004-2U9104 4To.
17/02/2026 18:53 kernel mousedev: PS/2 mouse device common for all mice
17/02/2026 18:53 kernel asus_wmi: failed to register LPS0 sleep handler in asus-wmi
17/02/2026 18:53 kernel asus_wmi: Initialization: 0x0
17/02/2026 18:53 kernel asus_wmi: BIOS WMI version: 0.9
17/02/2026 18:53 kernel asus_wmi: SFUN value: 0x0
17/02/2026 18:53 kernel eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
17/02/2026 18:53 kernel input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input11
17/02/2026 18:53 systemd Found device ST1000DM003-9YN162 1To.
17/02/2026 18:53 systemd Starting File System Check on /dev/disk/by-uuid/3b93e1fd-fa5e-41d0-ac50-5d125f2968be...
17/02/2026 18:53 systemd Starting File System Check on /dev/disk/by-uuid/8A42-4866...
17/02/2026 18:53 systemd Starting File System Check on /dev/disk/by-uuid/90fa3692-cecd-43be-ba24-9ff67234c792...
17/02/2026 18:53 systemd Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
17/02/2026 18:53 systemd systemd-vconsole-setup.service: Deactivated successfully.
17/02/2026 18:53 systemd Stopped Virtual Console Setup.
17/02/2026 18:53 systemd Stopping Virtual Console Setup...
17/02/2026 18:53 kernel ee1004 1-0052: 512 byte EE1004-compliant SPD EEPROM, read-only
17/02/2026 18:53 kernel ee1004 1-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
17/02/2026 18:53 systemd Starting Virtual Console Setup...
17/02/2026 18:53 kernel igc 0000:06:00.0 (unnamed net_device) (uninitialized): PHC added
17/02/2026 18:53 kernel igc 0000:06:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
17/02/2026 18:53 kernel igc 0000:06:00.0 eth0: MAC: 04:42:1a:04:1d:9d
17/02/2026 18:53 systemd-vconsole-setup All allocated virtual consoles are busy, will not configure key mapping and font.
17/02/2026 18:53 systemd Finished Virtual Console Setup.
17/02/2026 18:53 kernel igc 0000:06:00.0 enp6s0: renamed from eth0
17/02/2026 18:53 systemd-fsck fsck.fat 4.2 (2021-01-31)
17/02/2026 18:53 systemd-fsck There are differences between boot sector and its backup.
17/02/2026 18:53 systemd-fsck This is mostly harmless. Differences: (offset:original/backup)
17/02/2026 18:53 systemd-fsck 65:01/00
17/02/2026 18:53 systemd-fsck Not automatically fixing this.
17/02/2026 18:53 systemd-fsck Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
17/02/2026 18:53 systemd-fsck Automatically removing dirty bit.
17/02/2026 18:53 systemd-fsck *** Filesystem was changed ***
17/02/2026 18:53 systemd-fsck Writing changes.
17/02/2026 18:53 systemd-fsck /dev/nvme0n1p1: 5 files, 82/76646 clusters
17/02/2026 18:53 systemd-timesyncd Network configuration changed, trying to establish connection.
17/02/2026 18:53 systemd Finished File System Check on /dev/disk/by-uuid/8A42-4866.
17/02/2026 18:53 kernel intel_rapl_common: Found RAPL domain package
17/02/2026 18:53 kernel intel_rapl_common: Found RAPL domain core
17/02/2026 18:53 kernel snd_hda_intel 0000:07:00.1: enabling device (0000 -> 0002)
17/02/2026 18:53 kernel snd_hda_intel 0000:07:00.1: Disabling MSI
17/02/2026 18:53 kernel snd_hda_intel 0000:07:00.1: Handle vga_switcheroo audio client
17/02/2026 18:53 kernel snd_hda_intel 0000:09:00.4: enabling device (0000 -> 0002)
17/02/2026 18:53 kernel amd_atl: AMD Address Translation Library initialized
17/02/2026 18:53 systemd-fsck 1To : récupération du journal
17/02/2026 18:53 kernel input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card1/input12
17/02/2026 18:53 kernel input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card1/input13
17/02/2026 18:53 kernel input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card1/input14
17/02/2026 18:53 kernel input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card1/input15
17/02/2026 18:53 kernel snd_hda_codec_alc882 hdaudioC2D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
17/02/2026 18:53 kernel snd_hda_codec_alc882 hdaudioC2D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
17/02/2026 18:53 kernel snd_hda_codec_alc882 hdaudioC2D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
17/02/2026 18:53 kernel snd_hda_codec_alc882 hdaudioC2D0: mono: mono_out=0x0
17/02/2026 18:53 kernel snd_hda_codec_alc882 hdaudioC2D0: dig-out=0x1e/0x0
17/02/2026 18:53 kernel snd_hda_codec_alc882 hdaudioC2D0: inputs:
17/02/2026 18:53 kernel snd_hda_codec_alc882 hdaudioC2D0: Rear Mic=0x18
17/02/2026 18:53 kernel snd_hda_codec_alc882 hdaudioC2D0: Front Mic=0x19
17/02/2026 18:53 kernel snd_hda_codec_alc882 hdaudioC2D0: Line=0x1a
17/02/2026 18:53 kernel input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card2/input16
17/02/2026 18:53 kernel input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card2/input17
17/02/2026 18:53 kernel input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card2/input18
17/02/2026 18:53 kernel input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card2/input19
17/02/2026 18:53 kernel input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card2/input20
17/02/2026 18:53 kernel input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card2/input21
17/02/2026 18:53 kernel input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card2/input22
17/02/2026 18:53 systemd-fsck 4To : récupération du journal
17/02/2026 18:53 systemd Load Kernel Module dm_mod was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!dm_mod).
17/02/2026 18:53 systemd Load Kernel Module loop was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!loop).
17/02/2026 18:53 systemd File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
17/02/2026 18:53 systemd Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
17/02/2026 18:53 systemd Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
17/02/2026 18:53 systemd TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
17/02/2026 18:53 systemd Create System Users was skipped because no trigger condition checks were met.
17/02/2026 18:53 systemd Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
17/02/2026 18:53 systemd Repartition Root Disk was skipped because no trigger condition checks were met.
17/02/2026 18:53 systemd TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
17/02/2026 18:53 systemd-fsck 1To : propre, 142724/61054976 fichiers, 85610814/244190208 blocs
17/02/2026 18:53 systemd Finished File System Check on /dev/disk/by-uuid/3b93e1fd-fa5e-41d0-ac50-5d125f2968be.
17/02/2026 18:53 kernel usb 3-2: Focusrite Scarlett Gen 3 Mixer Driver enabled (pid=0x8211); report any issues to https://github.com/geoffreybennett/scarlett-gen2/issues
17/02/2026 18:53 kernel usb 3-2: Firmware version 1605
17/02/2026 18:53 kernel usbcore: registered new interface driver snd-usb-audio
17/02/2026 18:53 systemd Mounting /boot/efi...
17/02/2026 18:53 systemd Mounting /run/media/vince/1To...
17/02/2026 18:53 systemd Mounting /tmp...
17/02/2026 18:53 systemd Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
17/02/2026 18:53 systemd Listening on Disk Image Download Service Socket.
17/02/2026 18:53 systemd-fsck 4To : propre, 189673/244195328 fichiers, 469863969/976754646 blocs
17/02/2026 18:53 systemd Finished File System Check on /dev/disk/by-uuid/90fa3692-cecd-43be-ba24-9ff67234c792.
17/02/2026 18:53 systemd Mounting /run/media/vince/4To...
17/02/2026 18:53 systemd Mounted /tmp.
17/02/2026 18:53 systemd Mounted /boot/efi.
17/02/2026 18:53 kernel EXT4-fs (sdb1): mounted filesystem 3b93e1fd-fa5e-41d0-ac50-5d125f2968be r/w with ordered data mode. Quota mode: none.
17/02/2026 18:53 systemd Mounted /run/media/vince/1To.
17/02/2026 18:53 kernel EXT4-fs (sda): mounted filesystem 90fa3692-cecd-43be-ba24-9ff67234c792 r/w with ordered data mode. Quota mode: none.
17/02/2026 18:53 systemd Mounted /run/media/vince/4To.
17/02/2026 18:53 systemd Reached target Local File Systems.
17/02/2026 18:53 systemd Listening on Boot Entries Service Socket.
17/02/2026 18:53 systemd Listening on System Extension Image Management.
17/02/2026 18:53 systemd Starting Tell Plymouth To Write Out Runtime Data...
17/02/2026 18:53 systemd Starting Set Up Additional Binary Formats...
17/02/2026 18:53 systemd Update Boot Loader Random Seed was skipped because no trigger condition checks were met.
17/02/2026 18:53 systemd Starting Create System Files and Directories...
17/02/2026 18:53 systemd Starting Load JSON user/group Records from Credentials...
17/02/2026 18:53 systemd proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 753 (systemd-binfmt)
17/02/2026 18:53 systemd Mounting Arbitrary Executable File Formats File System...
17/02/2026 18:53 systemd Finished Load JSON user/group Records from Credentials.
17/02/2026 18:53 systemd Mounted Arbitrary Executable File Formats File System.
17/02/2026 18:53 systemd Finished Set Up Additional Binary Formats.
17/02/2026 18:53 systemd Received SIGRTMIN+20 from PID 413 (plymouthd).
17/02/2026 18:53 kernel [drm] Initialized nvidia-drm 0.0.0 for 0000:07:00.0 on minor 1
17/02/2026 18:53 systemd Finished Tell Plymouth To Write Out Runtime Data.
17/02/2026 18:53 systemd Finished Create System Files and Directories.
17/02/2026 18:53 systemd Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
17/02/2026 18:53 systemd First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
17/02/2026 18:53 systemd First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
17/02/2026 18:53 systemd Rebuild Journal Catalog was skipped because of an unmet condition check (ConditionNeedsUpdate=/var).
17/02/2026 18:53 systemd Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
17/02/2026 18:53 systemd Update is Completed was skipped because no trigger condition checks were met.
17/02/2026 18:53 systemd Starting Record System Boot/Shutdown in UTMP...
17/02/2026 18:53 kernel nvidia 0000:07:00.0: vgaarb: deactivate vga console
17/02/2026 18:53 systemd Finished Record System Boot/Shutdown in UTMP.
17/02/2026 18:53 kernel fbcon: nvidia-drmdrmfb (fb0) is primary device
17/02/2026 18:53 kernel fbcon: Deferring console take-over
17/02/2026 18:53 kernel nvidia 0000:07:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
17/02/2026 18:53 systemd-modules-load Inserted module 'nvidia_drm'
17/02/2026 18:53 systemd Finished Load Kernel Modules.
17/02/2026 18:53 systemd Starting Apply Kernel Variables...
17/02/2026 18:53 systemd Finished Apply Kernel Variables.
17/02/2026 18:53 systemd Reached target System Initialization.
17/02/2026 18:53 systemd Started CUPS Scheduler.
17/02/2026 18:53 systemd Started Refresh existing PGP keys of archlinux-keyring regularly.
17/02/2026 18:53 systemd Started Discard unused filesystem blocks once a week.
17/02/2026 18:53 systemd Started Daily rotation of log files.
17/02/2026 18:53 systemd Started Daily man-db regeneration.
17/02/2026 18:53 systemd Started Monthly clean packages cache.
17/02/2026 18:53 systemd Started Generate mirrorlist weekly.
17/02/2026 18:53 systemd Started Daily verification of password and group files.
17/02/2026 18:53 systemd Started Daily Cleanup of Temporary Directories.
17/02/2026 18:53 systemd Reached target Path Units.
17/02/2026 18:53 systemd Reached target Timer Units.
17/02/2026 18:53 systemd Listening on CUPS Scheduler.
17/02/2026 18:53 systemd Listening on D-Bus System Message Bus Socket.
17/02/2026 18:53 systemd Listening on GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
17/02/2026 18:53 systemd Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg.
17/02/2026 18:53 systemd Listening on GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
17/02/2026 18:53 systemd Listening on GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
17/02/2026 18:53 systemd Listening on GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
17/02/2026 18:53 systemd Listening on GnuPG public key management service for /etc/pacman.d/gnupg.
17/02/2026 18:53 systemd Listening on Authorization Manager Agent Helper.
17/02/2026 18:53 systemd Listening on OpenSSH Server Socket (systemd-ssh-generator, AF_UNIX Local).
17/02/2026 18:53 systemd Listening on Hostname Service Socket.
17/02/2026 18:53 systemd Listening on User Login Management Varlink Socket.
17/02/2026 18:53 systemd Listening on Virtual Machine and Container Registration Service Socket.
17/02/2026 18:53 systemd Reached target Socket Units.
17/02/2026 18:53 systemd Starting D-Bus System Message Bus...
17/02/2026 18:53 systemd TPM PCR Barrier (Initialization) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
17/02/2026 18:53 systemd Started D-Bus System Message Bus.
17/02/2026 18:53 systemd Reached target Basic System.
17/02/2026 18:53 dbus-broker-launch Ready
17/02/2026 18:53 systemd Starting Network Manager...
17/02/2026 18:53 systemd Starting Save/Restore Sound Card State...
17/02/2026 18:53 systemd Manage Sound Card State (restore and store) was skipped because of an unmet condition check (ConditionPathExists=/etc/alsa/state-daemon.conf).
17/02/2026 18:53 systemd Starting Apply cpupower configuration...
17/02/2026 18:53 systemd Starting Authorization Manager...
17/02/2026 18:53 systemd Starting User Login Management...
17/02/2026 18:53 systemd TPM PCR Barrier (User) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
17/02/2026 18:53 systemd Started Verify integrity of password and group files.
17/02/2026 18:53 systemd Finished Apply cpupower configuration.
17/02/2026 18:53 systemd Finished Save/Restore Sound Card State.
17/02/2026 18:53 systemd Reached target Sound Card.
17/02/2026 18:53 NetworkManager <info> [1771350786.7928] NetworkManager (version 1.54.3-1) is starting... (boot:7b54cdcb-865a-4450-b427-eac7d8fcc70a)
17/02/2026 18:53 NetworkManager <info> [1771350786.7930] Read config: /etc/NetworkManager/NetworkManager.conf, /usr/lib/NetworkManager/conf.d/20-connectivity.conf
17/02/2026 18:53 systemd-logind New seat seat0.
17/02/2026 18:53 systemd shadow.service: Deactivated successfully.
17/02/2026 18:53 systemd-logind Watching system buttons on /dev/input/event1 (Power Button)
17/02/2026 18:53 systemd-logind Watching system buttons on /dev/input/event0 (Power Button)
17/02/2026 18:53 systemd-logind Watching system buttons on /dev/input/event2 (SEMICO USB Keyboard)
17/02/2026 18:53 systemd-logind Watching system buttons on /dev/input/event3 (SEMICO USB Keyboard Consumer Control)
17/02/2026 18:53 systemd-logind Watching system buttons on /dev/input/event4 (SEMICO USB Keyboard System Control)
17/02/2026 18:53 systemd-logind Watching system buttons on /dev/input/event5 (SEMICO USB Keyboard)
17/02/2026 18:53 systemd-logind Watching system buttons on /dev/input/event7 (Corsair CORSAIR KATAR PRO Gaming Mouse)
17/02/2026 18:53 polkitd Started polkitd version 127
17/02/2026 18:53 NetworkManager <info> [1771350786.8065] manager[0x55a19a0bef50]: monitoring kernel firmware directory '/lib/firmware'.
17/02/2026 18:53 systemd Started User Login Management.
17/02/2026 18:53 systemd Starting Hostname Service...
17/02/2026 18:53 systemd Started Authorization Manager.
17/02/2026 18:53 systemd Starting Modem Manager...
17/02/2026 18:53 systemd Started Hostname Service.
17/02/2026 18:53 ModemManager <msg> ModemManager (version 1.24.2-1) starting in system bus...
17/02/2026 18:53 NetworkManager <info> [1771350786.8681] hostname: hostname: using hostnamed
17/02/2026 18:53 NetworkManager <info> [1771350786.8681] hostname: static hostname changed from (none) to "vince"
17/02/2026 18:53 NetworkManager <info> [1771350786.8685] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
17/02/2026 18:53 NetworkManager <info> [1771350786.8692] manager[0x55a19a0bef50]: rfkill: Wi-Fi hardware radio set enabled
17/02/2026 18:53 NetworkManager <info> [1771350786.8692] manager[0x55a19a0bef50]: rfkill: WWAN hardware radio set enabled
17/02/2026 18:53 NetworkManager <info> [1771350786.8951] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-adsl.so)
17/02/2026 18:53 NetworkManager <info> [1771350786.8973] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-bluetooth.so)
17/02/2026 18:53 NetworkManager <info> [1771350786.8986] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-wifi.so)
17/02/2026 18:53 NetworkManager <info> [1771350786.9010] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-ovs.so)
17/02/2026 18:53 NetworkManager <info> [1771350786.9019] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-wwan.so)
17/02/2026 18:53 kernel NET: Registered PF_QIPCRTR protocol family
17/02/2026 18:53 systemd Started Modem Manager.
17/02/2026 18:53 NetworkManager <info> [1771350786.9327] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-team.so)
17/02/2026 18:53 NetworkManager <info> [1771350786.9333] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
17/02/2026 18:53 NetworkManager <info> [1771350786.9334] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
17/02/2026 18:53 NetworkManager <info> [1771350786.9334] manager: Networking is enabled by state file
17/02/2026 18:53 NetworkManager <info> [1771350786.9336] settings: Loaded settings plugin: keyfile (internal)
17/02/2026 18:53 systemd Starting Network Manager Script Dispatcher Service...
17/02/2026 18:53 NetworkManager <info> [1771350786.9375] dhcp: init: Using DHCP client 'internal'
17/02/2026 18:53 NetworkManager <info> [1771350786.9376] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
17/02/2026 18:53 NetworkManager <info> [1771350786.9408] device (lo): state change: unmanaged -> unavailable (reason 'connection-assumed', managed-type: 'external')
17/02/2026 18:53 NetworkManager <info> [1771350786.9410] device (lo): state change: unavailable -> disconnected (reason 'connection-assumed', managed-type: 'external')
17/02/2026 18:53 NetworkManager <info> [1771350786.9414] device (lo): Activation: starting connection 'lo' (04fb23a5-ff9d-4db5-9618-239f10f2c272)
17/02/2026 18:53 NetworkManager <info> [1771350786.9421] manager: (enp6s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
17/02/2026 18:53 NetworkManager <info> [1771350786.9439] settings: (enp6s0): created default wired connection 'Connexion filaire 1'
17/02/2026 18:53 NetworkManager <info> [1771350786.9439] device (enp6s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
17/02/2026 18:53 systemd Started Network Manager Script Dispatcher Service.
17/02/2026 18:53 systemd Started Network Manager.
17/02/2026 18:53 NetworkManager <info> [1771350786.9847] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
17/02/2026 18:53 systemd Reached target Network.
17/02/2026 18:53 systemd Starting CUPS Scheduler...
17/02/2026 18:53 NetworkManager <info> [1771350786.9857] ovsdb: disconnected from ovsdb
17/02/2026 18:53 NetworkManager <info> [1771350786.9857] device (lo): state change: disconnected -> prepare (reason 'none', managed-type: 'external')
17/02/2026 18:53 NetworkManager <info> [1771350786.9858] device (lo): state change: prepare -> config (reason 'none', managed-type: 'external')
17/02/2026 18:53 NetworkManager <info> [1771350786.9859] device (lo): state change: config -> ip-config (reason 'none', managed-type: 'external')
17/02/2026 18:53 NetworkManager <info> [1771350786.9861] device (lo): state change: ip-config -> ip-check (reason 'none', managed-type: 'external')
17/02/2026 18:53 systemd Starting Permit User Sessions...
17/02/2026 18:53 NetworkManager <info> [1771350786.9865] modem-manager: ModemManager available
17/02/2026 18:53 NetworkManager <info> [1771350786.9869] device (lo): state change: ip-check -> secondaries (reason 'none', managed-type: 'external')
17/02/2026 18:53 NetworkManager <info> [1771350786.9869] device (lo): state change: secondaries -> activated (reason 'none', managed-type: 'external')
17/02/2026 18:53 NetworkManager <info> [1771350786.9871] device (lo): Activation: successful, device activated.
17/02/2026 18:53 systemd Finished Permit User Sessions.
17/02/2026 18:53 systemd Started Command Scheduler.
17/02/2026 18:53 systemd Starting Hold until boot process finishes up...
17/02/2026 18:53 systemd Starting Terminate Plymouth Boot Screen...
17/02/2026 18:53 crond (CRON) STARTUP (1.7.2)
17/02/2026 18:53 crond (CRON) INFO (Syslog will be used instead of sendmail.)
17/02/2026 18:53 crond (CRON) INFO (RANDOM_DELAY will be scaled with factor 95% if used.)
17/02/2026 18:53 crond (CRON) INFO (running with inotify support)
17/02/2026 18:53 NetworkManager <info> [1771350788.5459] device (enp6s0): carrier: link connected
17/02/2026 18:53 kernel igc 0000:06:00.0 enp6s0: NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
17/02/2026 18:53 NetworkManager <info> [1771350788.5467] device (enp6s0): state change: unavailable -> disconnected (reason 'carrier-changed', managed-type: 'full')
17/02/2026 18:53 NetworkManager <info> [1771350788.5470] policy: auto-activating connection 'Connexion filaire 1' (c5637e7d-8a01-32ad-8e3b-6cf57cacfeee)
17/02/2026 18:53 NetworkManager <info> [1771350788.5472] device (enp6s0): Activation: starting connection 'Connexion filaire 1' (c5637e7d-8a01-32ad-8e3b-6cf57cacfeee)
17/02/2026 18:53 NetworkManager <info> [1771350788.5472] device (enp6s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
17/02/2026 18:53 NetworkManager <info> [1771350788.5473] manager: NetworkManager state is now CONNECTING
17/02/2026 18:53 NetworkManager <info> [1771350788.5474] device (enp6s0): state change: prepare -> config (reason 'none', managed-type: 'full')
17/02/2026 18:53 NetworkManager <info> [1771350788.5477] device (enp6s0): state change: config -> ip-config (reason 'none', managed-type: 'full')
17/02/2026 18:53 NetworkManager <info> [1771350788.5481] dhcp4 (enp6s0): activation: beginning transaction (timeout in 45 seconds)
17/02/2026 18:53 NetworkManager <info> [1771350788.5603] dhcp4 (enp6s0): state changed new lease, address=192.168.1.20, acd pending
17/02/2026 18:53 NetworkManager <info> [1771350788.7442] dhcp4 (enp6s0): state changed new lease, address=192.168.1.20
17/02/2026 18:53 NetworkManager <info> [1771350788.7446] policy: set 'Connexion filaire 1' (enp6s0) as default for IPv4 routing and DNS
17/02/2026 18:53 dbus-broker-launch Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
17/02/2026 18:53 NetworkManager <info> [1771350788.7596] device (enp6s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
17/02/2026 18:53 NetworkManager <info> [1771350788.7601] device (enp6s0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
17/02/2026 18:53 NetworkManager <info> [1771350788.7602] device (enp6s0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
17/02/2026 18:53 NetworkManager <info> [1771350788.7603] manager: NetworkManager state is now CONNECTED_SITE
17/02/2026 18:53 NetworkManager <info> [1771350788.7604] device (enp6s0): Activation: successful, device activated.
17/02/2026 18:53 NetworkManager <info> [1771350788.7606] manager: startup complete
17/02/2026 18:53 NetworkManager <info> [1771350788.8786] manager: NetworkManager state is now CONNECTED_GLOBAL
17/02/2026 18:53 NetworkManager <info> [1771350790.2649] dhcp6 (enp6s0): activation: beginning transaction (timeout in 45 seconds)
17/02/2026 18:53 NetworkManager <info> [1771350790.2652] policy: set 'Connexion filaire 1' (enp6s0) as default for IPv6 routing and DNS
17/02/2026 18:53 NetworkManager <info> [1771350790.2861] dhcp6 (enp6s0): state changed new lease
17/02/2026 18:53 systemd Received SIGRTMIN+21 from PID 413 (plymouthd).
17/02/2026 18:53 systemd Finished Hold until boot process finishes up.
17/02/2026 18:53 systemd Finished Terminate Plymouth Boot Screen.
17/02/2026 18:53 systemd Reached target Multi-User System.
17/02/2026 18:53 systemd Started LACT GPU Control Daemon.
17/02/2026 18:53 systemd Started Simple Desktop Display Manager.
17/02/2026 18:53 systemd Reached target Graphical Interface.
17/02/2026 18:53 systemd Startup finished in 21.140s (firmware) + 13.485s (loader) + 4.582s (kernel) + 7.300s (userspace) = 46.507s.
17/02/2026 18:53 sddm Initializing...
17/02/2026 18:53 sddm Starting...
17/02/2026 18:53 sddm Logind interface found
17/02/2026 18:53 sddm Adding new display...
17/02/2026 18:53 sddm Loaded empty theme configuration
17/02/2026 18:53 sddm Xauthority path: "/run/sddm/xauth_uCuCfw"
17/02/2026 18:53 sddm Using VT 2
17/02/2026 18:53 sddm Display server starting...
17/02/2026 18:53 sddm Writing cookie to "/run/sddm/xauth_uCuCfw"
17/02/2026 18:53 sddm Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_uCuCfw -noreset -displayfd 16
17/02/2026 18:53 ModemManager <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:01:00.2/0000:02:09.0/0000:06:00.0': not supported by any plugin
17/02/2026 18:53 lact service started too early, waiting 2.9 seconds
17/02/2026 18:53 sddm Setting default cursor
17/02/2026 18:53 sddm Running display setup script "/usr/share/sddm/scripts/Xsetup"
17/02/2026 18:53 sddm Display server started.
17/02/2026 18:53 sddm Socket server starting...
17/02/2026 18:53 sddm Socket server started.
17/02/2026 18:53 sddm Loading theme configuration from "/usr/share/sddm/themes/Nordic-Plasma-6/theme.conf"
17/02/2026 18:53 sddm Greeter starting...
17/02/2026 18:53 sddm-helper [PAM] Starting...
17/02/2026 18:53 sddm-helper [PAM] Authenticating...
17/02/2026 18:53 sddm-helper [PAM] returning.
17/02/2026 18:53 sddm-helper pam_unix(sddm-greeter:session): session opened for user sddm(uid=959) by (uid=0)
17/02/2026 18:53 systemd-logind New session 'c1' of user 'sddm' with class 'greeter' and type 'x11'.
17/02/2026 18:53 systemd Created slice User Slice of UID 959.
17/02/2026 18:53 systemd Starting User Runtime Directory /run/user/959...
17/02/2026 18:53 systemd Finished User Runtime Directory /run/user/959.
17/02/2026 18:53 systemd Starting User Manager for UID 959...
17/02/2026 18:53 dbus-broker-launch Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
17/02/2026 18:53 (systemd) pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
17/02/2026 18:53 (systemd) pam_unix(systemd-user:session): session opened for user sddm(uid=959) by sddm(uid=0)
17/02/2026 18:53 systemd-logind New session '1' of user 'sddm' with class 'manager-early' and type 'unspecified'.
17/02/2026 18:53 systemd Queued start job for default target Main User Target.
17/02/2026 18:53 systemd Created slice User Application Slice.
17/02/2026 18:53 systemd Reached target Paths.
17/02/2026 18:53 systemd Reached target Timers.
17/02/2026 18:53 systemd Starting D-Bus User Message Bus Socket...
17/02/2026 18:53 systemd Listening on GnuPG network certificate management daemon.
17/02/2026 18:53 systemd Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
17/02/2026 18:53 systemd Listening on GnuPG cryptographic agent and passphrase cache (restricted).
17/02/2026 18:53 systemd Listening on GnuPG cryptographic agent (ssh-agent emulation).
17/02/2026 18:53 systemd Listening on GnuPG cryptographic agent and passphrase cache.
17/02/2026 18:53 systemd Listening on GnuPG public key management service.
17/02/2026 18:53 systemd Listening on p11-kit server.
17/02/2026 18:53 systemd Listening on PipeWire PulseAudio.
17/02/2026 18:53 systemd Listening on PipeWire Multimedia System Sockets.
17/02/2026 18:53 systemd Listening on Query the User Interactively for a Password.
17/02/2026 18:53 systemd Listening on D-Bus User Message Bus Socket.
17/02/2026 18:53 systemd Reached target Sockets.
17/02/2026 18:53 systemd Reached target Main User Target.
17/02/2026 18:53 systemd Startup finished in 159ms.
17/02/2026 18:53 systemd Started User Manager for UID 959.
17/02/2026 18:53 systemd Started Session c1 of User sddm.
17/02/2026 18:53 sddm-helper Writing cookie to "/tmp/xauth_tAdpoK"
17/02/2026 18:53 sddm-helper Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-TFKBhd --theme /usr/share/sddm/themes/Nordic-Plasma-6"
17/02/2026 18:53 sddm Greeter session started successfully
17/02/2026 18:53 sddm-greeter-qt6 High-DPI autoscaling not Enabled
17/02/2026 18:53 sddm-greeter-qt6 Reading from "/usr/share/wayland-sessions/plasma.desktop"
17/02/2026 18:53 sddm-greeter-qt6 Loading theme configuration from "/usr/share/sddm/themes/Nordic-Plasma-6/theme.conf"
17/02/2026 18:53 systemd Created slice User Core Session Slice.
17/02/2026 18:53 systemd Starting D-Bus User Message Bus...
17/02/2026 18:53 dbus-broker-launch Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
17/02/2026 18:53 dbus-broker-launch Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
17/02/2026 18:53 dbus-broker-launch Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
17/02/2026 18:53 dbus-broker-launch Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
17/02/2026 18:53 dbus-broker-launch Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
17/02/2026 18:53 systemd Started D-Bus User Message Bus.
17/02/2026 18:53 sddm-greeter-qt6 Connected to the daemon.
17/02/2026 18:53 sddm Message received from greeter: Connect
17/02/2026 18:53 sddm-greeter-qt6 Loading file:///usr/share/sddm/themes/Nordic-Plasma-6/Main.qml...
17/02/2026 18:53 sddm-greeter-qt6 KeyStatesEngine is deprecated. Use KeyState from org.kde.plasma.private.keyboardindicator instead.
17/02/2026 18:53 sddm-greeter-qt6 file:///usr/share/sddm/themes/Nordic-Plasma-6/Main.qml:366:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
17/02/2026 18:53 sddm-greeter-qt6 file:///usr/share/sddm/themes/Nordic-Plasma-6/Login.qml:298:21: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
17/02/2026 18:53 sddm-greeter-qt6 file:///usr/share/sddm/themes/Nordic-Plasma-6/Login.qml:117: TypeError: Property 'onDataChanged' of object Plasma5Support::DataSource(0x55d1c130a5b0, "DataSource") is not a function
17/02/2026 18:53 sddm-greeter-qt6 file:///usr/share/sddm/themes/Nordic-Plasma-6/components/animation/RejectPasswordPathAnimation.qml:33: TypeError: Cannot read property 'longDuration' of undefined
17/02/2026 18:53 sddm-greeter-qt6 Adding view for "HDMI-0" QRect(3840,0 1920x1080)
17/02/2026 18:53 sddm-greeter-qt6 file:///usr/share/sddm/themes/Nordic-Plasma-6/Login.qml:117: TypeError: Property 'onDataChanged' of object Plasma5Support::DataSource(0x55d1c19cc920, "DataSource") is not a function
17/02/2026 18:53 sddm-greeter-qt6 Adding view for "DP-2" QRect(0,0 3840x2160)
17/02/2026 18:53 lact listening on "/run/lactd.sock"
17/02/2026 18:53 lact TCP listener disabled
17/02/2026 18:53 systemd Starting Power Profiles daemon...
17/02/2026 18:53 sddm-greeter-qt6 Message received from daemon: Capabilities
17/02/2026 18:53 sddm-greeter-qt6 Message received from daemon: HostName
17/02/2026 18:53 systemd Started Power Profiles daemon.
17/02/2026 18:53 power-profiles-daemon Core Failed to activate initial profile: Failed to activate CPU driver 'amd_pstate': Error writing '/sys/devices/system/cpu/cpufreq/policy11/boost': Argument invalide
17/02/2026 18:53 lact is already disabled
17/02/2026 18:53 lact ent library loaded
17/02/2026 18:53 lact NvAPI library loaded
17/02/2026 18:53 lact /card1/device'
17/02/2026 18:53 lact initialized 1 GPUs
17/02/2026 18:53 sddm-greeter-qt6 file:///usr/share/sddm/themes/Nordic-Plasma-6/Login.qml:287:21 Parameter "event" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
17/02/2026 18:53 sddm-greeter-qt6 file:///usr/share/sddm/themes/Nordic-Plasma-6/Main.qml:102:9 Parameter "event" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
17/02/2026 18:53 sddm-greeter-qt6 file:///usr/share/sddm/themes/Nordic-Plasma-6/Main.qml:204:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
17/02/2026 18:53 sddm Message received from greeter: Login
17/02/2026 18:53 sddm Reading from "/usr/share/wayland-sessions/plasma.desktop"
17/02/2026 18:53 sddm Session "/usr/share/wayland-sessions/plasma.desktop" selected, command: "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland" for VT 1
17/02/2026 18:53 sddm-helper [PAM] Preparing to converse...
17/02/2026 18:53 sddm-helper [PAM] Conversation with 1 messages
17/02/2026 18:53 sddm-helper pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
17/02/2026 18:53 sddm Authentication for user "vince" successful
17/02/2026 18:53 sddm-greeter-qt6 Message received from daemon: LoginSucceeded
17/02/2026 18:53 sddm-greeter-qt6 file:///usr/share/sddm/themes/Nordic-Plasma-6/Main.qml:245: ReferenceError: units is not defined
17/02/2026 18:53 sddm-helper pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
17/02/2026 18:53 sddm-greeter-qt6 file:///usr/share/sddm/themes/Nordic-Plasma-6/Main.qml:377: ReferenceError: footer is not defined
17/02/2026 18:53 sddm-helper pam_unix(sddm:session): session opened for user vince(uid=1000) by vince(uid=0)
17/02/2026 18:53 systemd-logind New session '2' of user 'vince' with class 'user' and type 'wayland'.
17/02/2026 18:53 systemd Created slice User Slice of UID 1000.
17/02/2026 18:53 systemd Starting User Runtime Directory /run/user/1000...
17/02/2026 18:53 systemd-user-runtime-dir Successfully configured disk quota for UID 1000 on /dev/shm to 12.4G
17/02/2026 18:53 systemd Finished User Runtime Directory /run/user/1000.
17/02/2026 18:53 systemd Starting User Manager for UID 1000...
17/02/2026 18:53 (systemd) pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[vince] ruser=[<unknown>] rhost=[<unknown>]
17/02/2026 18:53 (systemd) pam_unix(systemd-user:session): session opened for user vince(uid=1000) by vince(uid=0)
17/02/2026 18:53 systemd-logind New session '3' of user 'vince' with class 'manager' and type 'unspecified'.
17/02/2026 18:53 systemd NetworkManager-dispatcher.service: Deactivated successfully.
17/02/2026 18:53 systemd-xdg-autostart-generator Exec binary 'gwe' does not exist: No such file or directory
17/02/2026 18:53 systemd-xdg-autostart-generator /home/vince/.config/autostart/gwe.desktop: not generating unit, executable specified in Exec= does not exist.
17/02/2026 18:53 systemd-journald File /var/log/journal/2a1c08ada1b349bebcb75fa5a14f3fbe/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
17/02/2026 18:53 sddm-helper [PAM] Closing session
17/02/2026 18:53 sddm-helper pam_unix(sddm-greeter:session): session closed for user sddm
17/02/2026 18:53 sddm-helper [PAM] Ended.
17/02/2026 18:53 sddm Auth: sddm-helper exited successfully
17/02/2026 18:53 sddm Greeter stopped. SDDM::Auth::HELPER_SUCCESS
17/02/2026 18:53 systemd session-c1.scope: Deactivated successfully.
17/02/2026 18:53 systemd session-c1.scope: Consumed 895ms CPU time, 383M memory peak.
17/02/2026 18:53 systemd-logind Session c1 logged out. Waiting for processes to exit.
17/02/2026 18:53 systemd-logind Removed session c1.
17/02/2026 18:53 systemd Requested transaction contradicts existing jobs: Transaction for sound.target/start is destructive (sound.target has 'stop' job queued, but 'start' is included in transaction).
17/02/2026 18:53 systemd sys-devices-pci0000:00-0000:00:03.1-0000:07:00.1-sound-card1-controlC1.device: Failed to enqueue SYSTEMD_USER_WANTS job, ignoring: Transaction for sound.target/start is destructive (sound.target has 'stop' job queued, but 'start' is included in transaction).
17/02/2026 18:53 systemd sys-devices-pci0000:00-0000:00:08.1-0000:09:00.4-sound-card2-controlC2.device: Failed to enqueue SYSTEMD_USER_WANTS job, ignoring: Transaction for sound.target/start is destructive (sound.target has 'stop' job queued, but 'start' is included in transaction).
17/02/2026 18:53 systemd sys-devices-pci0000:00-0000:00:08.1-0000:09:00.3-usb3-3\x2d2-3\x2d2:1.0-sound-card0-controlC0.device: Failed to enqueue SYSTEMD_USER_WANTS job, ignoring: Transaction for sound.target/start is destructive (sound.target has 'stop' job queued, but 'start' is included in transaction).
17/02/2026 18:53 systemd Startup finished in 108ms.
17/02/2026 18:53 systemd Started User Manager for UID 1000.
17/02/2026 18:53 systemd Started Session 2 of User vince.
17/02/2026 18:53 sddm-helper pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
17/02/2026 18:53 sddm-helper pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
17/02/2026 18:53 sddm-helper Starting Wayland user session: "/usr/share/sddm/scripts/wayland-session" "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland"
17/02/2026 18:53 sddm-helper Jumping to VT 1
17/02/2026 18:53 sddm-helper VT mode didn't need to be fixed
17/02/2026 18:53 lact event, reloading GPUs
17/02/2026 18:53 lact GPU list reloaded with 1 devices, reapplying configuration
17/02/2026 18:53 lact configuration applied
17/02/2026 18:53 sddm Session started true
17/02/2026 18:53 systemd Starting Locale Service...
17/02/2026 18:53 systemd Started Locale Service.
17/02/2026 18:53 systemd Reload requested from client PID 995 ('startplasma-way')...
17/02/2026 18:53 systemd Reloading...
17/02/2026 18:53 systemd Reloading finished in 85 ms.
17/02/2026 18:53 systemd Created slice Slice /app/dbus-:1.2-org.kde.KSplash.
17/02/2026 18:53 systemd Started dbus-:1.2-org.kde.KSplash@0.service.
17/02/2026 18:53 systemd Created slice User Background Tasks Slice.
17/02/2026 18:53 systemd Starting KDE Global Shortcuts Server...
17/02/2026 18:53 systemd Starting KDE Window Manager...
17/02/2026 18:53 systemd Starting User folders update...
17/02/2026 18:53 systemd Starting Baloo File Indexer Daemon...
17/02/2026 18:53 systemd Finished User folders update.
17/02/2026 18:53 systemd Reached target Session services which should run early before the graphical session is brought up.
17/02/2026 18:53 systemd Started KDE Window Manager.
17/02/2026 18:53 systemd Starting KDE Config Module Initialization...
17/02/2026 18:53 systemd Starting Splash screen shown during boot...
17/02/2026 18:53 systemd Started KDE Global Shortcuts Server.
17/02/2026 18:53 systemd Started Baloo File Indexer Daemon.
17/02/2026 18:53 systemd Starting Portal service...
17/02/2026 18:53 systemd Starting Daemon for power management...
17/02/2026 18:53 systemd Starting sandboxed app permission store...
17/02/2026 18:53 systemd Started sandboxed app permission store.
17/02/2026 18:53 systemd Starting flatpak document portal service...
17/02/2026 18:53 systemd Started flatpak document portal service.
17/02/2026 18:53 /usr/lib/xdg-desktop-portal Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
17/02/2026 18:53 kwin_wayland No backend specified, automatically choosing drm
17/02/2026 18:53 systemd Started Daemon for power management.
17/02/2026 18:53 systemd Starting Disk Manager...
17/02/2026 18:53 kernel nvme nvme0: using unchecked data buffer
17/02/2026 18:53 systemd Started Disk Manager.
17/02/2026 18:53 baloo_file QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.28'
17/02/2026 18:53 systemd Started PipeWire Multimedia Service.
17/02/2026 18:53 systemd Started Multimedia Service Session Manager.
17/02/2026 18:53 kcminit_startup Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_mouse.so"
17/02/2026 18:53 kcminit_startup Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
17/02/2026 18:53 ksplashqml QWaylandGLContext: Failed to create the decorations EGLContext. Decorations will not be drawn.
17/02/2026 18:53 kwin_wayland_wrapper The XKEYBOARD keymap compiler (xkbcomp) reports:
17/02/2026 18:53 kwin_wayland_wrapper > Warning: Unsupported maximum keycode 708, clipping.
17/02/2026 18:53 kwin_wayland_wrapper > X11 cannot support keycodes above 255.
17/02/2026 18:53 kwin_wayland_wrapper > Warning: Virtual modifier Hyper multiply defined
17/02/2026 18:53 kwin_wayland_wrapper > Using 0, ignoring 0
17/02/2026 18:53 kwin_wayland_wrapper > Warning: Virtual modifier ScrollLock multiply defined
17/02/2026 18:53 kwin_wayland_wrapper Errors from xkbcomp are not fatal to the X server
17/02/2026 18:53 systemd Starting Accessibility services bus...
17/02/2026 18:53 kcminit_startup Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_style.so"
17/02/2026 18:53 systemd Started Accessibility services bus.
17/02/2026 18:53 kcminit Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
17/02/2026 18:53 kcminit Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_style.so"
17/02/2026 18:53 systemd Created slice Slice /app/dbus-:1.17-org.a11y.atspi.Registry.
17/02/2026 18:53 systemd Started dbus-:1.17-org.a11y.atspi.Registry@0.service.
17/02/2026 18:53 at-spi2-registryd SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
17/02/2026 18:53 wireplumber spa.bluez5: BlueZ system service is not available
17/02/2026 18:53 wireplumber wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
17/02/2026 18:53 wireplumber s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
17/02/2026 18:53 systemd Started KDE Config Module Initialization.
17/02/2026 18:53 systemd Starting KDE Session Management Server...
17/02/2026 18:53 systemd Started Unlock kwallet from pam credentials.
17/02/2026 18:53 systemd Starting KDE Daemon 6...
17/02/2026 18:53 pam_kwallet_init 2026/02/17 18:53:19 socat[1154] W address is opened in read-write mode but only supports read-only
17/02/2026 18:53 systemd Started KDE Session Management Server.
17/02/2026 18:53 systemd Starting KDE Plasma Workspace...
17/02/2026 18:53 systemd Started KDE Daemon 6.
17/02/2026 18:53 systemd Starting KDE Configuration Module Initialization (Phase 1)...
17/02/2026 18:53 kcminit_startup Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings_qwidgets/kcm_kgamma.so"
17/02/2026 18:53 kcminit_startup Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_touchpad.so"
17/02/2026 18:53 systemd Finished KDE Configuration Module Initialization (Phase 1).
17/02/2026 18:53 kded6 QDBusObjectPath: invalid path "/modules/wpad-detector"
17/02/2026 18:53 kded6 The kded module name "wpad-detector" is invalid!
17/02/2026 18:53 kded6 QDBusObjectPath: invalid path "/modules/oom-notifier"
17/02/2026 18:53 kded6 The kded module name "oom-notifier" is invalid!
17/02/2026 18:53 systemd Starting User preferences database...
17/02/2026 18:53 systemd Started User preferences database.
17/02/2026 18:53 plasmashell QWaylandGLContext: Failed to create the decorations EGLContext. Decorations will not be drawn.
17/02/2026 18:53 systemd Starting KActivityManager Activity manager Service...
17/02/2026 18:53 plasmashell The theme "Nordic-Solid" uses the legacy metadata.desktop. Consider contacting the author and asking them update it to use the newer JSON format.
17/02/2026 18:53 kded6 Failed to connect to Bolt manager DBus interface:
17/02/2026 18:53 kded6 Couldn't connect to Bolt DBus daemon
17/02/2026 18:53 systemd Started KDE Plasma Workspace.
17/02/2026 18:53 systemd Reached target KDE Plasma Workspace Core.
17/02/2026 18:53 systemd Started Proxies GTK DBus menus to a Plasma readable format.
17/02/2026 18:53 systemd Started KAccess.
17/02/2026 18:53 systemd Starting KDE PolicyKit Authentication Agent...
17/02/2026 18:53 systemd Started Handle legacy xembed system tray icons.
17/02/2026 18:53 systemd Started KActivityManager Activity manager Service.
17/02/2026 18:53 kaccess Xlib XKB extension major= 1 minor= 0
17/02/2026 18:53 systemd Started PipeWire PulseAudio.
17/02/2026 18:53 NetworkManager <info> [1771350799.7453] agent-manager: agent[cd29ec6756351f9c,:1.40/org.kde.plasma.networkmanagement/1000]: agent registered
17/02/2026 18:53 kded6 QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
17/02/2026 18:53 kded6 The kded module name "plasma-session-shortcuts" is invalid!
17/02/2026 18:53 kded6 found no RGB LED devices
17/02/2026 18:53 systemd Started KDE PolicyKit Authentication Agent.
17/02/2026 18:53 polkit-kde-authentication-agent-1 New PolkitAgentListener 0x55b365e88c10
17/02/2026 18:53 polkit-kde-authentication-agent-1 Adding new listener PolkitQt1::Agent::Listener(0x55b365e88730) for 0x55b365e88c10
17/02/2026 18:53 polkit-kde-authentication-agent-1 Listener online
17/02/2026 18:53 systemd Reached target KDE Plasma Workspace.
17/02/2026 18:53 systemd Reached target Current graphical user session.
17/02/2026 18:53 systemd Reached target plasma-workspace-wayland.target.
17/02/2026 18:53 systemd Starting AT-SPI D-Bus Bus...
17/02/2026 18:53 kconf_update /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
17/02/2026 18:53 systemd Starting Geoclue Demo agent...
17/02/2026 18:53 kconf_update /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
17/02/2026 18:53 polkit-kde-authentication-agent-1 Authentication agent result: true
17/02/2026 18:53 systemd Starting MSM Notifier...
17/02/2026 18:53 systemd Starting Plasma Session Restore...
17/02/2026 18:53 systemd Starting Update Notifier...
17/02/2026 18:53 systemd Starting Update Notifier Tray Icon...
17/02/2026 18:53 systemd Starting Print Queue Applet...
17/02/2026 18:53 systemd Starting xapp-sn-watcher...
17/02/2026 18:53 systemd Starting KDE Session Restoration...
17/02/2026 18:53 systemd Starting Portal service (GTK/GNOME implementation)...
17/02/2026 18:53 systemd Started MSM Notifier.
17/02/2026 18:53 systemd app-at\x2dspi\x2ddbus\x2dbus@autostart.service: Skipped due to 'exec-condition'.
17/02/2026 18:53 systemd Condition check resulted in AT-SPI D-Bus Bus being skipped.
17/02/2026 18:53 systemd app-pamac\x2dtray@autostart.service: Skipped due to 'exec-condition'.
17/02/2026 18:53 systemd Condition check resulted in Update Notifier being skipped.
17/02/2026 18:53 systemd app-pamac\x2dtray\x2dbudgie@autostart.service: Skipped due to 'exec-condition'.
17/02/2026 18:53 systemd app-print\x2dapplet@autostart.service: Skipped due to 'exec-condition'.
17/02/2026 18:53 systemd Condition check resulted in Print Queue Applet being skipped.
17/02/2026 18:53 systemd Started Plasma Session Restore.
17/02/2026 18:53 systemd Started Geoclue Demo agent.
17/02/2026 18:53 systemd Finished KDE Session Restoration.
17/02/2026 18:53 systemd Started Update Notifier Tray Icon.
17/02/2026 18:53 systemd Started xapp-sn-watcher.
17/02/2026 18:53 systemd Reached target Startup of XDG autostart applications.
17/02/2026 18:53 kaccess X server XKB extension major= 1 minor= 0
17/02/2026 18:53 kded6 xsettingsd: Loaded 16 settings from /home/vince/.config/xsettingsd/xsettingsd.conf
17/02/2026 18:53 kded6 xsettingsd: Created window 0xe00001 on screen 0 with timestamp 20934
17/02/2026 18:53 kded6 xsettingsd: Selection _XSETTINGS_S0 is owned by 0x0
17/02/2026 18:53 kded6 xsettingsd: Took ownership of selection _XSETTINGS_S0
17/02/2026 18:53 dbus-broker-launch Activation request for 'org.bluez' failed: The systemd unit 'dbus-org.bluez.service' could not be found.
17/02/2026 18:53 kded6 PendingCall Error: "The name is not activatable"
17/02/2026 18:53 kded6 PendingCall Error: "Could not activate remote peer 'org.bluez': activation request failed: unknown unit"
17/02/2026 18:53 systemd Started Portal service (GTK/GNOME implementation).
17/02/2026 18:53 systemd Starting RealtimeKit Scheduling Policy Service...
17/02/2026 18:53 systemd Started RealtimeKit Scheduling Policy Service.
17/02/2026 18:53 rtkit-daemon Handling system-suspend using logind.
17/02/2026 18:53 systemd Starting Xdg Desktop Portal For KDE...
17/02/2026 18:53 plasmashell Applet preload policy set to 1
17/02/2026 18:53 kded6 Registering ":1.46/StatusNotifierItem" to system tray
17/02/2026 18:53 user@1000.service updates_checker.vala:59: check updates
17/02/2026 18:53 user@1000.service flatpak_plugin.vala:393: refreshing flathub appstream data
17/02/2026 18:53 kded6 Registering ":1.47/StatusNotifierItem" to system tray
17/02/2026 18:53 systemd Started Xdg Desktop Portal For KDE.
17/02/2026 18:53 systemd Started Portal service.
17/02/2026 18:53 kwin_wayland Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Unable to open /proc/1029/root")
17/02/2026 18:53 ksmserver Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.ksmserver'")
17/02/2026 18:53 kactivitymanagerd Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.ActivityManager'")
17/02/2026 18:53 gmenudbusmenuproxy Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.gmenudbusmenuproxy'")
17/02/2026 18:53 xembedsniproxy Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.xembedsniproxy'")
17/02/2026 18:53 kded6 Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.kded6'")
17/02/2026 18:53 polkit-kde-authentication-agent-1 Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Unable to open /proc/1187/root")
17/02/2026 18:53 xdg-desktop-portal-kde Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
17/02/2026 18:53 ksecretd Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
17/02/2026 18:53 kaccess Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
17/02/2026 18:53 plasmashell Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
17/02/2026 18:53 pamac-tray-plasma Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for ''")
17/02/2026 18:53 ksplashqml Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for ''")
17/02/2026 18:53 systemd Finished Splash screen shown during boot.
17/02/2026 18:53 systemd plasma-ksplash.service: Consumed 383ms CPU time, 170.4M memory peak.
17/02/2026 18:53 plasmashell No QSGTexture provided from updateSampledImage(). This is wrong.
17/02/2026 18:53 plasmashell qrc:/qt/qml/org/kde/plasma/private/clipboard/UrlItemDelegate.qml:49:17: TypeError: Cannot read property 'height' of null
17/02/2026 18:53 pamac-checkupdates libostree pull from 'flathub' for appstream2/x86_64 complete
security: GPG: summary+commit
security: SIGN: disabled http: TLS
non-delta: meta: 7 content: 9
transfer: secs: 2 size: 9.5 MB
17/02/2026 18:53 pamac-checkupdates /var/tmp/flatpak-cache-3WA0K3/repo-8Vonce: Pulled appstream2/x86_64 from flathub
17/02/2026 18:53 systemd Starting flatpak system helper...
17/02/2026 18:53 systemd Started flatpak system helper.
17/02/2026 18:53 flatpak-system-helper system: Pulled appstream2/x86_64 from /var/tmp/flatpak-cache-3WA0K3/repo-8Vonce
17/02/2026 18:53 baloo_file_extractor Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.baloo'")
17/02/2026 18:53 systemd Started Firefox - Navigateur web.
17/02/2026 18:53 systemd Starting Pamac Daemon...
17/02/2026 18:53 systemd Started Pamac Daemon.
17/02/2026 18:53 systemd Starting Time & Date Service...
17/02/2026 18:53 systemd Started Time & Date Service.
17/02/2026 18:53 rtkit-daemon Successfully made thread 1853 of process 1463 owned by '1000' RT at priority 10.
17/02/2026 18:53 kwin_wayland Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
17/02/2026 18:53 systemd Stopping User Manager for UID 959...
17/02/2026 18:53 systemd Activating special unit Exit the Session...
17/02/2026 18:53 systemd Stopped target Main User Target.
17/02/2026 18:53 systemd Stopped target Basic System.
17/02/2026 18:53 systemd Stopped target Paths.
17/02/2026 18:53 systemd Stopped target Sockets.
17/02/2026 18:53 systemd Stopped target Sound Card.
17/02/2026 18:53 systemd Stopped target Timers.
17/02/2026 18:53 systemd Closed GnuPG network certificate management daemon.
17/02/2026 18:53 systemd Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
17/02/2026 18:53 systemd Closed GnuPG cryptographic agent and passphrase cache (restricted).
17/02/2026 18:53 systemd Closed GnuPG cryptographic agent (ssh-agent emulation).
17/02/2026 18:53 systemd Closed GnuPG cryptographic agent and passphrase cache.
17/02/2026 18:53 systemd Closed GnuPG public key management service.
17/02/2026 18:53 systemd Closed p11-kit server.
17/02/2026 18:53 systemd Closed PipeWire PulseAudio.
17/02/2026 18:53 systemd Closed PipeWire Multimedia System Sockets.
17/02/2026 18:53 systemd Closed Query the User Interactively for a Password.
17/02/2026 18:53 dbus-broker Dispatched 366 messages @ 1(±2)μs / message.
17/02/2026 18:53 systemd Stopping D-Bus User Message Bus...
17/02/2026 18:53 systemd Stopped D-Bus User Message Bus.
17/02/2026 18:53 systemd Removed slice User Core Session Slice.
17/02/2026 18:53 systemd Closed D-Bus User Message Bus Socket.
17/02/2026 18:53 systemd Removed slice User Application Slice.
17/02/2026 18:53 systemd Reached target Shutdown.
17/02/2026 18:53 systemd Finished Exit the Session.
17/02/2026 18:53 systemd Reached target Exit the Session.
17/02/2026 18:53 systemd-logind Removed session 1.
17/02/2026 18:53 (sd-pam) pam_unix(systemd-user:session): session closed for user sddm
17/02/2026 18:53 systemd user@959.service: Deactivated successfully.
17/02/2026 18:53 systemd Stopped User Manager for UID 959.
17/02/2026 18:53 systemd Stopping User Runtime Directory /run/user/959...
17/02/2026 18:53 systemd run-user-959.mount: Deactivated successfully.
17/02/2026 18:53 systemd user-runtime-dir@959.service: Deactivated successfully.
17/02/2026 18:53 systemd Stopped User Runtime Directory /run/user/959.
17/02/2026 18:53 systemd Removed slice User Slice of UID 959.
17/02/2026 18:53 systemd user-959.slice: Consumed 1.041s CPU time, 393.9M memory peak.
17/02/2026 18:53 systemd Reached target User and Group Name Lookups.
17/02/2026 18:53 systemd Starting Accounts Service...
17/02/2026 18:53 accounts-daemon started daemon version 23.13.0
17/02/2026 18:53 systemd Started Accounts Service.
17/02/2026 18:53 systemd systemd-hostnamed.service: Deactivated successfully.
17/02/2026 18:53 systemd-timesyncd Contacted time server [2a01:cb00:129e:a803::130]:123 (2.manjaro.pool.ntp.org).
17/02/2026 18:53 systemd-timesyncd Initial clock synchronization to Tue 2026-02-17 18:53:39.376147 CET.
17/02/2026 18:53 systemd pamac-daemon.service: Deactivated successfully.
17/02/2026 18:53 systemd pamac-daemon.service: Consumed 2.542s CPU time, 79.4M memory peak.
17/02/2026 18:53 systemd systemd-timedated.service: Deactivated successfully.
17/02/2026 18:53 systemd systemd-localed.service: Deactivated successfully.
17/02/2026 19:01 CROND (root) CMD (run-parts /etc/cron.hourly)
17/02/2026 19:01 anacron Anacron started on 2026-02-17
17/02/2026 19:01 CROND (root) CMDEND (run-parts /etc/cron.hourly)
17/02/2026 19:01 anacron Will run job `cron.daily' in 42 min.
17/02/2026 19:01 anacron Jobs will be executed sequentially
17/02/2026 19:01 rtkit-daemon Successfully made thread 2683 of process 2434 owned by '1000' RT at priority 10.
17/02/2026 19:02 plasmashell QWaylandGLContext: Failed to create the decorations EGLContext. Decorations will not be drawn.
17/02/2026 19:02 plasmashell Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
17/02/2026 19:02 plasmashell Skipping a nested svg element, because SVG Document must not contain nested svg elements in Svg Tiny 1.2
17/02/2026 19:02 systemd Starting KRunner provider for baloo file indexer...
17/02/2026 19:02 systemd Started KRunner provider for baloo file indexer.
17/02/2026 19:02 baloorunner Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.baloorunner'")
17/02/2026 19:02 systemd Started KSystemLog - Afficheur des journaux du système.
17/02/2026 19:02 kwin_wayland QDBusConnection: couldn't handle call to Teardown, no slot matched
17/02/2026 19:02 kwin_wayland Could not find slot Krunner1Adaptor::Teardown
17/02/2026 19:02 baloorunner QDBusConnection: couldn't handle call to Teardown, no slot matched
17/02/2026 19:02 baloorunner Could not find slot Krunner1Adaptor::Teardown
17/02/2026 19:02 kdesud KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "Copyright (c) 1999,2000 Geert Jansen" msgid_plural: "" msgctxt: ""
17/02/2026 19:02 kdesud KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "Daemon used by kdesu" msgid_plural: "" msgctxt: ""
17/02/2026 19:02 kdesud KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "KDE su daemon" msgid_plural: "" msgctxt: ""
17/02/2026 19:02 kdesud KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "Author" msgid_plural: "" msgctxt: ""
17/02/2026 19:02 kdesud KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "Geert Jansen" msgid_plural: "" msgctxt: ""
17/02/2026 19:02 kdesu Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Unable to open /proc/2901/root")
17/02/2026 19:02 su (to root) vince on pts/2
17/02/2026 19:02 su pam_unix(su:session): session opened for user root(uid=0) by vince(uid=1000)
17/02/2026 19:02 su pam_unix(su:session): session closed for user root
17/02/2026 19:03 systemd flatpak-system-helper.service: Deactivated successfully.
17/02/2026 19:04 systemd Started Adobe Photoshop CS5 (64 Bit).
17/02/2026 19:04 env 002c:fixme:winediag:loader_init wine-staging 9.21 is a testing version containing experimental patches.
17/02/2026 19:04 env 002c:fixme:winediag:loader_init Please mention your exact version when filing bug reports on winehq.org.
17/02/2026 19:04 env 0024:fixme:exec:SHELL_execute flags ignored: 0x00004000
17/02/2026 19:04 systemd app-wine\x2dPrograms\x2dAdobe\x20Photoshop\x20CS5\x20\x2864\x20Bit\x29@be0c8e91e2bd472888b02f90927fa313.service: Main process exited, code=exited, status=3/NOTIMPLEMENTED
17/02/2026 19:04 dbus-broker-launch Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
17/02/2026 19:04 env 0148:fixme:ntdll:NtSetInformationToken unimplemented class 24
17/02/2026 19:04 env 0148:fixme:file:NtLockFile I/O completion on lock not implemented yet
17/02/2026 19:04 env 017c:fixme:ole:CoInitializeSecurity 0000000000000000, -1, 0000000000000000, 0000000000000000, 1, 3, 0000000000000000, 0, 0000000000000000 stub
17/02/2026 19:04 kwin_wayland 0x501: GL_INVALID_VALUE error generated. Size and/or offset out of range.
17/02/2026 19:04 env 0190:fixme:wia:wiadevmgr_QueryInterface interface {00000003-0000-0000-c000-000000000046} not implemented
17/02/2026 19:04 env 0190:fixme:wia:wiadevmgr_QueryInterface interface {00000019-0000-0000-c000-000000000046} not implemented
17/02/2026 19:04 env 0148:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
17/02/2026 19:04 env 0148:fixme:msvcrt:type_info_name_internal_method type_info_node parameter ignored
17/02/2026 19:04 env 0148:fixme:msvcp:locale__Locimp__Makexloc (000000000011E4E0 63 000000000A4AA9B0 0000000000000000) semi-stub
17/02/2026 19:04 env 0148:fixme:msvcp:locale__Locimp__Makewloc (000000000011E4E0 63 000000000A4AA9B0 0000000000000000) semi-stub
17/02/2026 19:04 env 0148:fixme:msvcp:locale__Locimp__Makeushloc (000000000011E4E0 63 000000000A4AA9B0 0000000000000000) semi-stub
17/02/2026 19:04 env 0148:fixme:msvcp:locale_operator_assign (000000000BAC0400 000000000011E610) stub
17/02/2026 19:04 env 0148:fixme:wtsapi:WTSRegisterSessionNotification Stub 0000000000010090 0x00000001
17/02/2026 19:04 env 0148:fixme:win:DisableProcessWindowsGhosting : stub
17/02/2026 19:04 env 0148:fixme:appbar:SHAppBarMessage unknown msg: 4
17/02/2026 19:04 env 0090:fixme:appbar:handle_appbarmessage SHAppBarMessage(ABM_GETSTATE): stub
17/02/2026 19:04 env 0090:fixme:appbar:handle_appbarmessage SHAppBarMessage(ABM_GETTASKBARPOS, hwnd=0000000000000000): stub
17/02/2026 19:04 env 0148:fixme:ole:CoResumeClassObjects stub
17/02/2026 19:04 env 0148:fixme:nls:get_dummy_preferred_ui_language (0x8 0x40c 000000000011C574 0000000000000000 000000000011C570) returning a dummy value (current locale)
17/02/2026 19:04 env 0148:fixme:nls:get_dummy_preferred_ui_language (0x8 0x40c 000000000011C574 0000000009CB5B80 000000000011C570) returning a dummy value (current locale)
17/02/2026 19:04 kded6 Registering ":1.62/StatusNotifierItem" to system tray
17/02/2026 19:04 kded6 Service ":1.62" unregistered
17/02/2026 19:04 kded6 Registering ":1.63/StatusNotifierItem" to system tray
17/02/2026 19:04 kded6 Service ":1.63" unregistered
17/02/2026 19:04 kded6 Registering ":1.64/StatusNotifierItem" to system tray
17/02/2026 19:04 kded6 Service ":1.64" unregistered
17/02/2026 19:04 kded6 Registering ":1.65/StatusNotifierItem" to system tray
17/02/2026 19:04 kded6 Service ":1.65" unregistered
17/02/2026 19:04 kded6 Registering ":1.66/StatusNotifierItem" to system tray
17/02/2026 19:04 kded6 Service ":1.66" unregistered
17/02/2026 19:04 kded6 Registering ":1.67/StatusNotifierItem" to system tray
17/02/2026 19:04 kded6 Service ":1.67" unregistered
17/02/2026 19:04 kded6 Registering ":1.68/StatusNotifierItem" to system tray
17/02/2026 19:04 kded6 Service ":1.68" unregistered
17/02/2026 19:04 env 029c:fixme:ole:CoInitializeSecurity 0000000000000000, -1, 0000000000000000, 0000000000000000, 0, 3, 0000000000000000, 0, 0000000000000000 stub
17/02/2026 19:04 env 029c:fixme:wbemprox:client_security_SetBlanket 00006FFFFB081680, 00000000111BA6C0, 10, 0, (null), 3, 3, 0000000000000000, 0
17/02/2026 19:04 env 029c:fixme:wbemprox:client_security_Release 00006FFFFB081680
17/02/2026 19:04 env 029c:fixme:netapi32:NetWkstaUserGetInfo Level 1 processing is partially implemented
17/02/2026 19:04 env 02a4:fixme:ole:CoInitializeSecurity 0000000000000000, -1, 0000000000000000, 0000000000000000, 6, 3, 0000000000000000, 0, 0000000000000000 stub
17/02/2026 19:04 env 02a4:fixme:taskschd:regtasks_get_Count 00000000111C88B0,000000001466FBDC: stub
17/02/2026 19:04 env 02b8:fixme:ole:CoInitializeSecurity 0000000000000000, -1, 0000000000000000, 0000000000000000, 6, 3, 0000000000000000, 0, 0000000000000000 stub
17/02/2026 19:04 env 02b8:fixme:taskschd:regtasks_get_Count 00000000111D21E0,000000001456FBDC: stub
17/02/2026 19:04 env 02c4:fixme:exec:SHELL_execute flags ignored: 0x00004000
17/02/2026 19:04 env 02cc:fixme:file:NtLockFile I/O completion on lock not implemented yet
17/02/2026 19:04 env 0148:fixme:wbemprox:client_security_SetBlanket 00006FFFFB081680, 000000001119CD70, 10, 0, (null), 3, 3, 0000000000000000, 0
17/02/2026 19:04 env 0148:fixme:wbemprox:client_security_Release 00006FFFFB081680
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (00000001068DC858) stub
17/02/2026 19:04 env 0148:fixme:ole:CoSuspendClassObjects
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (0000000104B2B840) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (00006FFFFC41A648) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (00006FFFFC31C0A8) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (0000000102D9C778) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (00006FFFFC0A7008) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (000000000B842B08) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (000000000BF1EA68) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (000000000BAD6498) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (000000000B8AE928) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (00006FFFFCD1A108) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (00006FFFFD148B00) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (00000001007C5620) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (00006FFFFDBAD1D8) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (00006FFFFDBF8688) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (000000010073E8D8) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (00000001004F2888) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (000000010055D228) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (0000000100522F38) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (0000000100401388) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (0000000180075018) stub
17/02/2026 19:04 env 0148:fixme:msvcrt:__clean_type_info_names_internal (0000000100131DD8) stub
17/02/2026 19:05 systemd Started /usr/lib/libreoffice/program/soffice.bin.
17/02/2026 19:05 soffice.bin This plugin supports grabbing the mouse only for popup windows
17/02/2026 19:05 soffice.bin KFileFilterCombo::setCurrentFilter: Could not find file filter KFileFilter(MIME patterns: QList() File patterns: QList("*.docx") label: "Word 2010–365 Document (.docx)")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier ADELLE Cameron.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier ALAOUI Marwa.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier DEBOVE Robin.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier DESLORIEZ Jade.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier GERMAIN Théo.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier ISLAM Mahira.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier KARATEPE Elanur.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier LUTISI Glody.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier MAFUENE Kennedy.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier MANAI Omar.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier SIBY Sokona.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier TRANQUILLIN Enzo.docx")
17/02/2026 19:05 soffice.bin No node found for item that was just removed: QUrl("file:///home/vince/Bureau/IME/livret 2026/fevrier/Livret Fevrier VIARD Éléonore.docx")
17/02/2026 19:05 baloo_file_extractor Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.baloo'")
17/02/2026 19:05 plasmashell No node found for item that was just removed: QUrl("desktop:/.~lock.caca.docx%23")
17/02/2026 19:05 systemd app-\x2fusr\x2flib\x2flibreoffice\x2fprogram\x2fsoffice.bin@c2cf35a6e032428cb0128f45631ad1d2.service: Consumed 6.438s CPU time, 1.1G memory peak.
17/02/2026 19:05 kwin_wayland 0x501: GL_INVALID_VALUE error generated. Size and/or offset out of range.
17/02/2026 19:06 systemd Started Dolphin - Gestionnaire de fichiers.
17/02/2026 19:06 kioworker "Could not load plugin from /usr/lib/qt6/plugins/kf6/thumbcreator/appimagethumbnail.so: Impossible de charger la bibliothèque /usr/lib/qt6/plugins/kf6/thumbcreator/appimagethumbnail.so : libappimage.so.1.0: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce nom"
17/02/2026 19:07 kwin_wayland 0x501: GL_INVALID_VALUE error generated. Size and/or offset out of range.
