Hello people,
I’ve been having random system freezes for about three months now, and I can’t troubleshoot them for the life of me.
There does not seem to be a pattern : it can happen when the PC is idle, running a game, browsing the net, etc…
When it happens, there is no coming back from it : no restarting X, shifting to another tty or even raising the elephant. The only solution is a hardware shutdown.
I’ve tried looking into dmesg
and Xorg.0.log
but this has been pretty uninformative. If you have advices as to where to look for answers, I’ll gladly take it.
I suspected either a RAM or driver problem. I ran several memtests without errors and tried booting with each of my individual RAM sticks but eventually the freeze came back.
If it is a driver problem, I don’t know where to look or what to do. My kernel is up to date but the freeze happened for the last several minor versions.
Here are some informations about my system :
Output of inxi -Fazy
Kernel: 5.8.9-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=638f9c8a-df45-450b-8de7-6a9cb664f386 rw quiet
resume=UUID=24a88c1a-8092-4d24-8faa-63a09fd7cb17 loglevel=3
rd.udev.log_priority=3 vt.global_cursor_default=0 usbcore.autosuspend=-1
Desktop: i3 4.18.2 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: B85-PRO GAMER v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 2001 date: 06/20/2014
Topology: Quad Core model: Intel Core i5-4460 bits: 64 type: MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 25554
Speed: 3182 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 3193 2: 3193
3: 3193 4: 3193
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ZOTAC driver: nvidia
v: 440.100 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:13c2
Display: x11 server: X.Org 1.20.9 compositor: picom v: git-e553e
driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 101 s-size: 966x272mm (38.0x10.7")
s-diag: 1004mm (39.5")
Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Monitor-2: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
OpenGL: renderer: GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-2: NVIDIA GM204 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fbb
Sound Server: ALSA v: k5.8.9-2-MANJARO
Device-1: Intel Ethernet I217-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k
port: f040 bus ID: 00:19.0 chip ID: 8086:153b
Device-2: Qualcomm Atheros AR2417 Wireless Network Adapter [AR5007G 802.11bg] vendor: Accton driver: ath5k v: kernel port: e000 bus ID: 04:01.0
chip ID: 168c:001d
IF: wlp4s1 state: down mac: <filter>
Local Storage: total: 1.02 TiB used: 523.58 GiB (50.2%)
ID-1: /dev/sda vendor: Corsair model: Force GT size: 111.79 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 5.41
scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-21M2NA0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-1: / raw size: 95.66 GiB size: 93.66 GiB (97.91%) used: 31.82 GiB (34.0%)
fs: ext4 dev: /dev/sda2
ID-2: /home raw size: 781.25 GiB size: 767.99 GiB (98.30%)
used: 491.76 GiB (64.0%) fs: ext4 dev: /dev/dm-0
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 51 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 208 Uptime: 21m Memory: 7.71 GiB used: 2.38 GiB (30.8%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 2085 lib: 524 Shell: Zsh v: 5.8 running in: kitty inxi: 3.1.05
Xorg.0.log.old
after a freeze and reboot
X.Org X Server 1.20.9
[ 115.286] Build Operating System: Linux Manjaro Linux
[ 115.286] Current Operating System: Linux virgile-fixe-maison 5.8.9-2-MANJARO #1 SMP PREEMPT Sun Sep 13 13:36:33 UTC 2020 x86_64
[ 115.286] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=638f9c8a-df45-450b-8de7-6a9cb664f386 rw quiet resume=UUID=24a88c1a-8092-4d24-8faa-63a09fd7cb17 loglevel=3 rd.udev.log_priority=3 vt.global_cursor_default=0 usbcore.autosuspend=-1
[ 115.286] Build Date: 02 September 2020 07:39:17AM
[ 115.286]
[ 115.286] Current version of pixman: 0.40.0
[ 115.286] Before reporting problems, check http://wiki.x.org
[ 115.286] Markers: (--) probed, (**) from config file, (==) default setting,
[ 115.286] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Sep 19 19:06:10 2020
[ 115.287] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 115.287] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 115.290] (==) ServerLayout "layout"
[ 115.290] (**) |-->Screen "Screen0" (0)
[ 115.290] (**) | |-->Monitor "Monitor0"
[ 115.290] (**) | |-->Device "Device0"
[ 115.290] (==) Automatically adding devices
[ 115.290] (==) Automatically enabling devices
[ 115.290] (==) Automatically adding GPU devices
[ 115.290] (==) Automatically binding GPU devices
[ 115.290] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 115.292] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 115.292] Entry deleted from font path.
[ 115.292] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 115.292] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 115.292] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 115.292] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 115.292] (**) Extension "COMPOSITE" is enabled
[ 115.292] (II) The server relies on udev to provide the list of input devices.
[ 115.292] (II) Module ABI versions:
[ 115.292] X.Org ANSI C Emulation: 0.4
[ 115.292] X.Org Video Driver: 24.1
[ 115.292] X.Org XInput driver : 24.1
[ 115.292] X.Org Server Extension : 10.0
[ 115.293] (++) using VT number 7
[ 115.293] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 115.293] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 115.293] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 115.294] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 115.294] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 115.295] (--) PCI:*(1@0:0:0) 10de:13c2:19da:1366 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 115.295] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 115.295] (II) LoadModule: "glx"
[ 115.298] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 115.306] (II) Module glx: vendor="X.Org Foundation"
[ 115.306] compiled for 1.20.9, module version = 1.0.0
[ 115.306] ABI class: X.Org Server Extension, version 10.0
[ 115.306] (II) LoadModule: "nvidia"
[ 115.307] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 115.312] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 115.312] compiled for 1.6.99.901, module version = 1.0.0
[ 115.312] Module class: X.Org Video Driver
[ 115.313] (II) NVIDIA dlloader X Driver 440.100 Fri May 29 08:21:27 UTC 2020
[ 115.313] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 115.316] (II) Loading sub module "fb"
[ 115.316] (II) LoadModule: "fb"
[ 115.316] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 115.316] (II) Module fb: vendor="X.Org Foundation"
[ 115.316] compiled for 1.20.9, module version = 1.0.0
[ 115.316] ABI class: X.Org ANSI C Emulation, version 0.4
[ 115.316] (II) Loading sub module "wfb"
[ 115.316] (II) LoadModule: "wfb"
[ 115.317] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 115.317] (II) Module wfb: vendor="X.Org Foundation"
[ 115.317] compiled for 1.20.9, module version = 1.0.0
[ 115.317] ABI class: X.Org ANSI C Emulation, version 0.4
[ 115.317] (II) Loading sub module "ramdac"
[ 115.317] (II) LoadModule: "ramdac"
[ 115.317] (II) Module "ramdac" already built-in
[ 115.318] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 115.319] (==) NVIDIA(0): RGB weight 888
[ 115.319] (==) NVIDIA(0): Default visual is TrueColor
[ 115.319] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 115.319] (**) Option "AllowNVIDIAGpuScreens"
[ 115.319] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 115.319] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 115.319] (**) NVIDIA(0): Enabling 2D acceleration
[ 115.319] (II) Loading sub module "glxserver_nvidia"
[ 115.319] (II) LoadModule: "glxserver_nvidia"
[ 115.319] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 115.367] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 115.367] compiled for 1.6.99.901, module version = 1.0.0
[ 115.367] Module class: X.Org Server Extension
[ 115.367] (II) NVIDIA GLX Module 440.100 Fri May 29 08:19:01 UTC 2020
[ 115.369] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 116.044] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 116.044] (--) NVIDIA(0): CRT-0
[ 116.044] (--) NVIDIA(0): DFP-0 (boot)
[ 116.044] (--) NVIDIA(0): DFP-1
[ 116.044] (--) NVIDIA(0): DFP-2
[ 116.044] (--) NVIDIA(0): DFP-3
[ 116.044] (--) NVIDIA(0): DFP-4
[ 116.045] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 970 (GM204-A) at PCI:1:0:0 (GPU-0)
[ 116.045] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 116.045] (--) NVIDIA(0): VideoBIOS: 84.04.2f.00.1e
[ 116.045] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 116.061] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 116.061] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 116.092] (--) NVIDIA(GPU-0): Philips 226V4 (DFP-0): connected
[ 116.092] (--) NVIDIA(GPU-0): Philips 226V4 (DFP-0): Internal TMDS
[ 116.092] (--) NVIDIA(GPU-0): Philips 226V4 (DFP-0): 330.0 MHz maximum pixel clock
[ 116.108] (--) NVIDIA(GPU-0): Acer K222HQL (DFP-1): connected
[ 116.108] (--) NVIDIA(GPU-0): Acer K222HQL (DFP-1): Internal TMDS
[ 116.108] (--) NVIDIA(GPU-0): Acer K222HQL (DFP-1): 165.0 MHz maximum pixel clock
[ 116.108] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 116.108] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 116.108] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 116.108] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 116.108] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 116.108] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 116.108] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 116.108] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 116.108] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 116.112] (==) NVIDIA(0):
[ 116.112] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 116.112] (==) NVIDIA(0): will be used as the requested mode.
[ 116.112] (II) NVIDIA(0): Validated MetaModes:
[ 116.112] (II) NVIDIA(0): "DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select"
[ 116.112] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 1080
[ 116.114] (--) NVIDIA(0): DPI set to (101, 101); computed from "UseEdidDpi" X config
[ 116.114] (--) NVIDIA(0): option
[ 116.115] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 116.115] (II) NVIDIA: access.
[ 116.117] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 116.117] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 116.117] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 116.117] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 116.117] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 116.117] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 116.117] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 116.117] (II) NVIDIA(0): Config Options in the README.
[ 116.147] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select"
[ 116.287] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 116.288] (==) NVIDIA(0): Backing store enabled
[ 116.288] (==) NVIDIA(0): Silken mouse disabled
[ 116.288] (**) NVIDIA(0): DPMS enabled
[ 116.288] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 116.288] (II) Loading sub module "dri2"
[ 116.288] (II) LoadModule: "dri2"
[ 116.288] (II) Module "dri2" already built-in
[ 116.288] (II) NVIDIA(0): [DRI2] Setup complete
[ 116.288] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 116.288] (II) Initializing extension Generic Event Extension
[ 116.289] (II) Initializing extension SHAPE
[ 116.289] (II) Initializing extension MIT-SHM
[ 116.289] (II) Initializing extension XInputExtension
[ 116.289] (II) Initializing extension XTEST
[ 116.289] (II) Initializing extension BIG-REQUESTS
[ 116.289] (II) Initializing extension SYNC
[ 116.289] (II) Initializing extension XKEYBOARD
[ 116.289] (II) Initializing extension XC-MISC
[ 116.290] (II) Initializing extension SECURITY
[ 116.290] (II) Initializing extension XFIXES
[ 116.290] (II) Initializing extension RENDER
[ 116.290] (II) Initializing extension RANDR
[ 116.290] (II) Initializing extension COMPOSITE
[ 116.290] (II) Initializing extension DAMAGE
[ 116.290] (II) Initializing extension MIT-SCREEN-SAVER
[ 116.290] (II) Initializing extension DOUBLE-BUFFER
[ 116.290] (II) Initializing extension RECORD
[ 116.290] (II) Initializing extension DPMS
[ 116.290] (II) Initializing extension Present
[ 116.290] (II) Initializing extension DRI3
[ 116.290] (II) Initializing extension X-Resource
[ 116.291] (II) Initializing extension XVideo
[ 116.291] (II) Initializing extension XVideo-MotionCompensation
[ 116.291] (II) Initializing extension GLX
[ 116.291] (II) Indirect GLX disabled.
[ 116.291] (II) GLX: Another vendor is already registered for screen 0
[ 116.291] (II) Initializing extension XFree86-VidModeExtension
[ 116.291] (II) Initializing extension XFree86-DGA
[ 116.291] (II) Initializing extension XFree86-DRI
[ 116.291] (II) Initializing extension DRI2
[ 116.291] (II) Initializing extension NV-GLX
[ 116.291] (II) Initializing extension NV-CONTROL
[ 116.291] (II) Initializing extension XINERAMA
[ 116.347] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 116.347] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 116.347] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 116.347] (**) Power Button: Applying InputClass "system-keyboard"
[ 116.347] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 116.347] (II) LoadModule: "libinput"
[ 116.347] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 116.351] (II) Module libinput: vendor="X.Org Foundation"
[ 116.351] compiled for 1.20.8, module version = 0.30.0
[ 116.351] Module class: X.Org XInput Driver
[ 116.351] ABI class: X.Org XInput driver, version 24.1
[ 116.351] (II) Using input driver 'libinput' for 'Power Button'
[ 116.351] (**) Power Button: always reports core events
[ 116.351] (**) Option "Device" "/dev/input/event1"
[ 116.351] (**) Option "_source" "server/udev"
[ 116.356] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 116.356] (II) event1 - Power Button: device is a keyboard
[ 116.357] (II) event1 - Power Button: device removed
[ 116.371] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 116.371] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 116.371] (**) Option "xkb_model" "pc105"
[ 116.371] (**) Option "xkb_layout" "fr"
[ 116.371] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 116.384] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 116.384] (II) event1 - Power Button: device is a keyboard
[ 116.385] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 116.385] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 116.385] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 116.385] (**) Power Button: Applying InputClass "system-keyboard"
[ 116.385] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 116.385] (II) Using input driver 'libinput' for 'Power Button'
[ 116.385] (**) Power Button: always reports core events
[ 116.385] (**) Option "Device" "/dev/input/event0"
[ 116.385] (**) Option "_source" "server/udev"
[ 116.385] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 116.385] (II) event0 - Power Button: device is a keyboard
[ 116.385] (II) event0 - Power Button: device removed
[ 116.407] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 116.407] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 116.407] (**) Option "xkb_model" "pc105"
[ 116.407] (**) Option "xkb_layout" "fr"
[ 116.407] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 116.408] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 116.408] (II) event0 - Power Button: device is a keyboard
[ 116.409] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event10)
[ 116.409] (II) No input driver specified, ignoring this device.
[ 116.409] (II) This device may have been added with another device file.
[ 116.409] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event4)
[ 116.409] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event5)
[ 116.410] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event6)
[ 116.410] (II) No input driver specified, ignoring this device.
[ 116.410] (II) This device may have been added with another device file.
[ 116.410] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event7)
[ 116.410] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event8)
[ 116.410] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event9)
[ 116.411] (II) config/udev: Adding input device USB-HID Keyboard (/dev/input/event25)
[ 116.411] (**) USB-HID Keyboard: Applying InputClass "evdev keyboard catchall"
[ 116.411] (**) USB-HID Keyboard: Applying InputClass "libinput keyboard catchall"
[ 116.411] (**) USB-HID Keyboard: Applying InputClass "system-keyboard"
[ 116.411] (**) USB-HID Keyboard: Applying InputClass "Keyboard Defaults"
[ 116.411] (II) Using input driver 'libinput' for 'USB-HID Keyboard'
[ 116.411] (**) USB-HID Keyboard: always reports core events
[ 116.411] (**) Option "Device" "/dev/input/event25"
[ 116.411] (**) Option "_source" "server/udev"
[ 116.412] (II) event25 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 116.412] (II) event25 - USB-HID Keyboard: device is a keyboard
[ 116.412] (II) event25 - USB-HID Keyboard: device removed
[ 116.447] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.0/0003:04D9:0201.0004/input/input25/event25"
[ 116.447] (II) XINPUT: Adding extended input device "USB-HID Keyboard" (type: KEYBOARD, id 8)
[ 116.447] (**) Option "xkb_model" "pc105"
[ 116.447] (**) Option "xkb_layout" "fr"
[ 116.447] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 116.449] (II) event25 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 116.449] (II) event25 - USB-HID Keyboard: device is a keyboard
[ 116.450] (II) config/udev: Adding input device USB-HID Keyboard System Control (/dev/input/event26)
[ 116.450] (**) USB-HID Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 116.450] (**) USB-HID Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 116.450] (**) USB-HID Keyboard System Control: Applying InputClass "system-keyboard"
[ 116.450] (**) USB-HID Keyboard System Control: Applying InputClass "Keyboard Defaults"
[ 116.450] (II) Using input driver 'libinput' for 'USB-HID Keyboard System Control'
[ 116.450] (**) USB-HID Keyboard System Control: always reports core events
[ 116.450] (**) Option "Device" "/dev/input/event26"
[ 116.450] (**) Option "_source" "server/udev"
[ 116.451] (II) event26 - USB-HID Keyboard System Control: is tagged by udev as: Keyboard
[ 116.451] (II) event26 - USB-HID Keyboard System Control: device is a keyboard
[ 116.451] (II) event26 - USB-HID Keyboard System Control: device removed
[ 116.474] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.2/0003:04D9:0201.0006/input/input26/event26"
[ 116.474] (II) XINPUT: Adding extended input device "USB-HID Keyboard System Control" (type: KEYBOARD, id 9)
[ 116.474] (**) Option "xkb_model" "pc105"
[ 116.474] (**) Option "xkb_layout" "fr"
[ 116.474] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 116.475] (II) event26 - USB-HID Keyboard System Control: is tagged by udev as: Keyboard
[ 116.475] (II) event26 - USB-HID Keyboard System Control: device is a keyboard
[ 116.476] (II) config/udev: Adding input device USB-HID Keyboard Consumer Control (/dev/input/event27)
[ 116.476] (**) USB-HID Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 116.476] (**) USB-HID Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 116.476] (**) USB-HID Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 116.476] (**) USB-HID Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[ 116.476] (II) Using input driver 'libinput' for 'USB-HID Keyboard Consumer Control'
[ 116.476] (**) USB-HID Keyboard Consumer Control: always reports core events
[ 116.476] (**) Option "Device" "/dev/input/event27"
[ 116.476] (**) Option "_source" "server/udev"
[ 116.477] (II) event27 - USB-HID Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 116.477] (II) event27 - USB-HID Keyboard Consumer Control: device is a keyboard
[ 116.477] (II) event27 - USB-HID Keyboard Consumer Control: device removed
[ 116.561] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.2/0003:04D9:0201.0006/input/input27/event27"
[ 116.561] (II) XINPUT: Adding extended input device "USB-HID Keyboard Consumer Control" (type: KEYBOARD, id 10)
[ 116.561] (**) Option "xkb_model" "pc105"
[ 116.561] (**) Option "xkb_layout" "fr"
[ 116.561] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 116.562] (II) event27 - USB-HID Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 116.562] (II) event27 - USB-HID Keyboard Consumer Control: device is a keyboard
[ 116.563] (II) config/udev: Adding input device USB-HID Keyboard Mouse (/dev/input/event28)
[ 116.563] (**) USB-HID Keyboard Mouse: Applying InputClass "evdev pointer catchall"
[ 116.563] (**) USB-HID Keyboard Mouse: Applying InputClass "libinput pointer catchall"
[ 116.563] (II) Using input driver 'libinput' for 'USB-HID Keyboard Mouse'
[ 116.563] (**) USB-HID Keyboard Mouse: always reports core events
[ 116.563] (**) Option "Device" "/dev/input/event28"
[ 116.563] (**) Option "_source" "server/udev"
[ 116.564] (II) event28 - USB-HID Keyboard Mouse: is tagged by udev as: Mouse
[ 116.564] (II) event28 - USB-HID Keyboard Mouse: device is a pointer
[ 116.564] (II) event28 - USB-HID Keyboard Mouse: device removed
[ 116.602] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.2/0003:04D9:0201.0006/input/input28/event28"
[ 116.602] (II) XINPUT: Adding extended input device "USB-HID Keyboard Mouse" (type: MOUSE, id 11)
[ 116.602] (**) Option "AccelerationScheme" "none"
[ 116.602] (**) USB-HID Keyboard Mouse: (accel) selected scheme none/0
[ 116.602] (**) USB-HID Keyboard Mouse: (accel) acceleration factor: 2.000
[ 116.602] (**) USB-HID Keyboard Mouse: (accel) acceleration threshold: 4
[ 116.603] (II) event28 - USB-HID Keyboard Mouse: is tagged by udev as: Mouse
[ 116.603] (II) event28 - USB-HID Keyboard Mouse: device is a pointer
[ 116.604] (II) config/udev: Adding input device USB-HID Keyboard Mouse (/dev/input/mouse1)
[ 116.604] (II) No input driver specified, ignoring this device.
[ 116.604] (II) This device may have been added with another device file.
[ 116.604] (II) config/udev: Adding input device USB-HID Keyboard (/dev/input/event29)
[ 116.604] (**) USB-HID Keyboard: Applying InputClass "evdev keyboard catchall"
[ 116.604] (**) USB-HID Keyboard: Applying InputClass "libinput keyboard catchall"
[ 116.604] (**) USB-HID Keyboard: Applying InputClass "system-keyboard"
[ 116.604] (**) USB-HID Keyboard: Applying InputClass "Keyboard Defaults"
[ 116.604] (II) Using input driver 'libinput' for 'USB-HID Keyboard'
[ 116.604] (**) USB-HID Keyboard: always reports core events
[ 116.604] (**) Option "Device" "/dev/input/event29"
[ 116.604] (**) Option "_source" "server/udev"
[ 116.605] (II) event29 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 116.605] (II) event29 - USB-HID Keyboard: device is a keyboard
[ 116.605] (II) event29 - USB-HID Keyboard: device removed
[ 116.621] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.2/0003:04D9:0201.0006/input/input29/event29"
[ 116.621] (II) XINPUT: Adding extended input device "USB-HID Keyboard" (type: KEYBOARD, id 12)
[ 116.621] (**) Option "xkb_model" "pc105"
[ 116.621] (**) Option "xkb_layout" "fr"
[ 116.621] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 116.622] (II) event29 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 116.622] (II) event29 - USB-HID Keyboard: device is a keyboard
[ 116.623] (II) config/udev: Adding input device WALTOP International Corp. Graphics Tablet (/dev/input/event20)
[ 116.623] (**) WALTOP International Corp. Graphics Tablet: Applying InputClass "evdev tablet catchall"
[ 116.623] (**) WALTOP International Corp. Graphics Tablet: Applying InputClass "libinput tablet catchall"
[ 116.623] (**) WALTOP International Corp. Graphics Tablet: Applying InputClass "Waltop class"
[ 116.623] (II) LoadModule: "wacom"
[ 116.623] (II) Loading /usr/lib/xorg/modules/input/wacom_drv.so
[ 116.624] (II) Module wacom: vendor="X.Org Foundation"
[ 116.624] compiled for 1.20.8, module version = 0.39.0
[ 116.624] Module class: X.Org XInput Driver
[ 116.624] ABI class: X.Org XInput driver, version 24.1
[ 116.624] (II) Build version: 0.39.0
[ 116.624] (II) wacom: Driver for Wacom graphics tablets: PenPartner, Graphire,
Graphire2 4x5, Graphire2 5x7, Graphire3 4x5, Graphire3 6x8,
Graphire4 4x5, Graphire4 6x8, BambooFun 4x5, BambooFun 6x8,
Bamboo1 Medium, Graphire4 6x8 BlueTooth, CTL-460, CTH-461, CTL-660,
CTL-461/S, Bamboo Touch, CTH-460/K, CTH-461/S, CTH-661/S1, CTH-461/L,
CTH-661/L, Intuos 4x5, Intuos 6x8, Intuos 9x12, Intuos 12x12,
Intuos 12x18, PTU600, PL400, PL500, PL600, PL600SX, PL550, PL800,
PL700, PL510, PL710, DTI520, DTF720, DTF720a, DTF521, DTU1931,
DTU2231, DTU1631, DTH1152, DTH1152, DTK2451, DTH2452, DTH2452,
Intuos2 4x5, Intuos2 6x8, Intuos2 9x12, Intuos2 12x12, Intuos2 12x18,
Intuos2 6x8 , Volito, PenStation, Volito2 4x5, Volito2 2x3,
PenPartner2, Bamboo, Bamboo1, Bamboo1 4x6, Bamboo1 5x8, Intuos3 4x5,
Intuos3 6x8, Intuos3 9x12, Intuos3 12x12, Intuos3 12x19,
Intuos3 6x11, Intuos3 4x6, Intuos4 4x6, Intuos4 6x9, Intuos4 8x13,
Intuos4 12x19, Intuos4 WL USB Endpoint,
Intuos4 WL Bluetooth Endpoint, Intuos5 touch S, Intuos5 touch M,
Intuos5 touch L, Intuos5 S, Intuos5 M, Intuos Pro S, Intuos Pro M,
Intuos Pro L, Cintiq 21UX, Cintiq 20WSX, Cintiq 12WX, Cintiq 21UX2,
Cintiq 24HD, Cintiq 22HD, Cintiq 24HD touch (EMR digitizer),
Cintiq 13HD, DTK2241, DTH2242, Cintiq 22HDT, Cintiq 27QHDT,
Cintiq 27QHDT, Mobilestudio Pro 13, MobileStudio Pro 16,
MobileStudio Pro 13, MobileStudio Pro 16, Cintiq 13 FHD Pro,
Cintiq 16 UHD Pro, Cintiq Pro 24, Cintiq Pro 32, Cintiq 13 FHD Pro,
Cintiq 16 UHD Pro, Cintiq Pro 24, Cintiq Pro 32, Cintiq Pro 24,
Mobilestudio Pro 13, MobileStudio Pro 16, MobileStudio Pro 13,
MobileStudio Pro 16, MobileStudio Pro 16, MobileStudio Pro 16,
TabletPC 0x90, TabletPC 0x93, TabletPC 0x97, TabletPC 0x9A,
CapPlus 0x9F, TabletPC 0xE2, TabletPC 0xE3, TabletPC 0xE5,
TabletPC 0xE6, TabletPC 0xEC, TabletPC 0xED, TabletPC 0xEF,
TabletPC 0x100, TabletPC 0x101, TabletPC 0x10D, TabletPC 0x116,
TabletPC 0x12C, TabletPC 0x4001, TabletPC 0x4004, TabletPC 0x5000,
TabletPC 0x5002, usb:172f:0024, usb:172f:0025, usb:172f:0026,
usb:172f:0027, usb:172f:0028, usb:172f:0030, usb:172f:0031,
usb:172f:0032, usb:172f:0033, usb:172f:0034, usb:172f:0035,
usb:172f:0036, usb:172f:0037, usb:172f:0038, usb:172f:0039,
usb:172f:0051, usb:172f:0052, usb:172f:0053, usb:172f:0054,
usb:172f:0055, usb:172f:0056, usb:172f:0057, usb:172f:0058,
usb:172f:0500, usb:172f:0501, usb:172f:0502, usb:172f:0503,
usb:1b96:0001, usb:17ef:6004
[ 116.625] (II) Using input driver 'wacom' for 'WALTOP International Corp. Graphics Tablet'
[ 116.625] (**) WALTOP International Corp. Graphics Tablet: always reports core events
[ 116.625] (**) Option "Device" "/dev/input/event20"
[ 116.681] (II) WALTOP International Corp. Graphics Tablet: type not specified, assuming 'stylus'.
[ 116.681] (II) WALTOP International Corp. Graphics Tablet: other types will be automatically added.
[ 116.681] (--) WALTOP International Corp. Graphics Tablet stylus: using pressure threshold of 851 for button 1
[ 116.681] (**) WALTOP International Corp. Graphics Tablet stylus: panscroll is 0
[ 116.681] (**) WALTOP International Corp. Graphics Tablet stylus: panscroll modified to 1027
[ 116.681] (--) WALTOP International Corp. Graphics Tablet stylus: maxX=20000 maxY=12500 maxZ=1023 resX=79000 resY=79000 tilt=disabled
[ 116.681] (II) WALTOP International Corp. Graphics Tablet stylus: hotplugging dependent devices.
[ 116.681] (EE) WALTOP International Corp. Graphics Tablet stylus: Invalid type 'eraser' for this device.
[ 116.681] (EE) WALTOP International Corp. Graphics Tablet stylus: Invalid type 'cursor' for this device.
[ 116.681] (EE) WALTOP International Corp. Graphics Tablet stylus: Invalid type 'touch' for this device.
[ 116.681] (EE) WALTOP International Corp. Graphics Tablet stylus: Invalid type 'pad' for this device.
[ 116.681] (II) WALTOP International Corp. Graphics Tablet stylus: hotplugging completed.
[ 116.744] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.0/0003:172F:0034.0001/input/input30/event20"
[ 116.744] (II) XINPUT: Adding extended input device "WALTOP International Corp. Graphics Tablet stylus" (type: STYLUS, id 13)
[ 116.744] (**) WALTOP International Corp. Graphics Tablet stylus: (accel) keeping acceleration scheme 1
[ 116.744] (**) WALTOP International Corp. Graphics Tablet stylus: (accel) acceleration profile 0
[ 116.744] (**) WALTOP International Corp. Graphics Tablet stylus: (accel) acceleration factor: 2.000
[ 116.744] (**) WALTOP International Corp. Graphics Tablet stylus: (accel) acceleration threshold: 4
[ 116.801] (II) config/udev: Adding input device WALTOP International Corp. Graphics Tablet (/dev/input/mouse2)
[ 116.801] (II) No input driver specified, ignoring this device.
[ 116.801] (II) This device may have been added with another device file.
[ 116.802] (II) config/udev: Adding input device Laview Technology Mionix Avior 7000 (/dev/input/event23)
[ 116.802] (**) Laview Technology Mionix Avior 7000: Applying InputClass "evdev pointer catchall"
[ 116.802] (**) Laview Technology Mionix Avior 7000: Applying InputClass "libinput pointer catchall"
[ 116.802] (II) Using input driver 'libinput' for 'Laview Technology Mionix Avior 7000'
[ 116.802] (**) Laview Technology Mionix Avior 7000: always reports core events
[ 116.802] (**) Option "Device" "/dev/input/event23"
[ 116.802] (**) Option "_source" "server/udev"
[ 116.858] (II) event23 - Laview Technology Mionix Avior 7000: is tagged by udev as: Mouse
[ 116.858] (II) event23 - Laview Technology Mionix Avior 7000: device set to 1600 DPI
[ 116.858] (II) event23 - Laview Technology Mionix Avior 7000: device is a pointer
[ 116.859] (II) event23 - Laview Technology Mionix Avior 7000: device removed
[ 116.904] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-9/2-9:1.0/0003:22D4:1308.0002/input/input23/event23"
[ 116.904] (II) XINPUT: Adding extended input device "Laview Technology Mionix Avior 7000" (type: MOUSE, id 14)
[ 116.904] (**) Option "AccelerationScheme" "none"
[ 116.904] (**) Laview Technology Mionix Avior 7000: (accel) selected scheme none/0
[ 116.904] (**) Laview Technology Mionix Avior 7000: (accel) acceleration factor: 2.000
[ 116.904] (**) Laview Technology Mionix Avior 7000: (accel) acceleration threshold: 4
[ 116.962] (II) event23 - Laview Technology Mionix Avior 7000: is tagged by udev as: Mouse
[ 116.962] (II) event23 - Laview Technology Mionix Avior 7000: device set to 1600 DPI
[ 116.962] (II) event23 - Laview Technology Mionix Avior 7000: device is a pointer
[ 116.962] (II) config/udev: Adding input device Laview Technology Mionix Avior 7000 (/dev/input/mouse0)
[ 116.962] (II) No input driver specified, ignoring this device.
[ 116.962] (II) This device may have been added with another device file.
[ 116.963] (II) config/udev: Adding input device Laview Technology Mionix Avior 7000 Keyboard (/dev/input/event24)
[ 116.963] (**) Laview Technology Mionix Avior 7000 Keyboard: Applying InputClass "evdev keyboard catchall"
[ 116.963] (**) Laview Technology Mionix Avior 7000 Keyboard: Applying InputClass "libinput keyboard catchall"
[ 116.963] (**) Laview Technology Mionix Avior 7000 Keyboard: Applying InputClass "system-keyboard"
[ 116.963] (**) Laview Technology Mionix Avior 7000 Keyboard: Applying InputClass "Keyboard Defaults"
[ 116.963] (II) Using input driver 'libinput' for 'Laview Technology Mionix Avior 7000 Keyboard'
[ 116.963] (**) Laview Technology Mionix Avior 7000 Keyboard: always reports core events
[ 116.963] (**) Option "Device" "/dev/input/event24"
[ 116.963] (**) Option "_source" "server/udev"
[ 116.964] (II) event24 - Laview Technology Mionix Avior 7000 Keyboard: is tagged by udev as: Keyboard
[ 116.964] (II) event24 - Laview Technology Mionix Avior 7000 Keyboard: device is a keyboard
[ 116.964] (II) event24 - Laview Technology Mionix Avior 7000 Keyboard: device removed
[ 117.005] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-9/2-9:1.1/0003:22D4:1308.0003/input/input24/event24"
[ 117.006] (II) XINPUT: Adding extended input device "Laview Technology Mionix Avior 7000 Keyboard" (type: KEYBOARD, id 15)
[ 117.006] (**) Option "xkb_model" "pc105"
[ 117.006] (**) Option "xkb_layout" "fr"
[ 117.006] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 117.007] (II) event24 - Laview Technology Mionix Avior 7000 Keyboard: is tagged by udev as: Keyboard
[ 117.007] (II) event24 - Laview Technology Mionix Avior 7000 Keyboard: device is a keyboard
[ 117.007] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event11)
[ 117.007] (II) No input driver specified, ignoring this device.
[ 117.007] (II) This device may have been added with another device file.
[ 117.008] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[ 117.008] (II) No input driver specified, ignoring this device.
[ 117.008] (II) This device may have been added with another device file.
[ 117.008] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event13)
[ 117.008] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event14)
[ 117.008] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event15)
[ 117.009] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event16)
[ 117.009] (II) No input driver specified, ignoring this device.
[ 117.009] (II) This device may have been added with another device file.
[ 117.009] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event17)
[ 117.009] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event18)
[ 117.009] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event19)
[ 117.010] (II) No input driver specified, ignoring this device.
[ 117.010] (II) This device may have been added with another device file.
[ 117.010] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event3)
[ 117.010] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 117.010] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 117.010] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 117.010] (**) Eee PC WMI hotkeys: Applying InputClass "Keyboard Defaults"
[ 117.010] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[ 117.010] (**) Eee PC WMI hotkeys: always reports core events
[ 117.010] (**) Option "Device" "/dev/input/event3"
[ 117.010] (**) Option "_source" "server/udev"
[ 117.010] (II) event3 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 117.011] (II) event3 - Eee PC WMI hotkeys: device is a keyboard
[ 117.011] (II) event3 - Eee PC WMI hotkeys: device removed
[ 117.055] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input3/event3"
[ 117.055] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 16)
[ 117.055] (**) Option "xkb_model" "pc105"
[ 117.055] (**) Option "xkb_layout" "fr"
[ 117.055] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 117.056] (II) event3 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 117.056] (II) event3 - Eee PC WMI hotkeys: device is a keyboard
[ 117.056] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[ 117.056] (II) No input driver specified, ignoring this device.
[ 117.056] (II) This device may have been added with another device file.
[ 280.728] (EE) event23 - Laview Technology Mionix Avior 7000: client bug: event processing lagging behind by 14ms, your system is too slow
[ 394.453] (EE) event23 - Laview Technology Mionix Avior 7000: client bug: event processing lagging behind by 14ms, your system is too slow
[ 954.632] (EE) event25 - USB-HID Keyboard: client bug: event processing lagging behind by 11ms, your system is too slow
[ 997.765] (EE) client bug: timer event23 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[ 1118.788] (EE) event23 - Laview Technology Mionix Avior 7000: client bug: event processing lagging behind by 14ms, your system is too slow
[ 1118.845] (EE) event23 - Laview Technology Mionix Avior 7000: client bug: event processing lagging behind by 15ms, your system is too slow
[ 1158.662] (EE) event23 - Laview Technology Mionix Avior 7000: client bug: event processing lagging behind by 16ms, your system is too slow
[ 1158.726] (EE) event23 - Laview Technology Mionix Avior 7000: client bug: event processing lagging behind by 16ms, your system is too slow
[ 1268.656] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 1268.656] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 1268.688] (--) NVIDIA(GPU-0): Philips 226V4 (DFP-0): connected
[ 1268.688] (--) NVIDIA(GPU-0): Philips 226V4 (DFP-0): Internal TMDS
[ 1268.688] (--) NVIDIA(GPU-0): Philips 226V4 (DFP-0): 330.0 MHz maximum pixel clock
[ 1268.703] (--) NVIDIA(GPU-0): Acer K222HQL (DFP-1): connected
[ 1268.703] (--) NVIDIA(GPU-0): Acer K222HQL (DFP-1): Internal TMDS
[ 1268.703] (--) NVIDIA(GPU-0): Acer K222HQL (DFP-1): 165.0 MHz maximum pixel clock
[ 1268.703] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 1268.703] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 1268.703] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 1268.703] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 1268.703] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 1268.703] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 1268.703] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 1268.703] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 1268.703] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 1309.664] (EE) event23 - Laview Technology Mionix Avior 7000: client bug: event processing lagging behind by 12ms, your system is too slow
[ 3008.534] (EE) event23 - Laview Technology Mionix Avior 7000: client bug: event processing lagging behind by 11ms, your system is too slow
[ 3010.555] (EE) client bug: timer event23 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[ 3021.204] (II) config/udev: Adding input device UE BOOM 2 (AVRCP) (/dev/input/event21)
[ 3021.204] (**) UE BOOM 2 (AVRCP): Applying InputClass "evdev keyboard catchall"
[ 3021.204] (**) UE BOOM 2 (AVRCP): Applying InputClass "libinput keyboard catchall"
[ 3021.204] (**) UE BOOM 2 (AVRCP): Applying InputClass "system-keyboard"
[ 3021.204] (**) UE BOOM 2 (AVRCP): Applying InputClass "Keyboard Defaults"
[ 3021.204] (II) Using input driver 'libinput' for 'UE BOOM 2 (AVRCP)'
[ 3021.204] (**) UE BOOM 2 (AVRCP): always reports core events
[ 3021.204] (**) Option "Device" "/dev/input/event21"
[ 3021.204] (**) Option "_source" "server/udev"
[ 3021.204] (II) event21 - UE BOOM 2 (AVRCP): is tagged by udev as: Keyboard
[ 3021.204] (II) event21 - UE BOOM 2 (AVRCP): device is a keyboard
[ 3021.204] (II) event21 - UE BOOM 2 (AVRCP): device removed
[ 3021.217] (**) Option "config_info" "udev:/sys/devices/virtual/input/input31/event21"
[ 3021.217] (II) XINPUT: Adding extended input device "UE BOOM 2 (AVRCP)" (type: KEYBOARD, id 17)
[ 3021.217] (**) Option "xkb_model" "pc105"
[ 3021.217] (**) Option "xkb_layout" "fr"
[ 3021.217] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 3021.218] (II) event21 - UE BOOM 2 (AVRCP): is tagged by udev as: Keyboard
[ 3021.218] (II) event21 - UE BOOM 2 (AVRCP): device is a keyboard
[ 3055.472] (EE) event25 - USB-HID Keyboard: client bug: event processing lagging behind by 22ms, your system is too slow
Thank you for reading ! I’ll galdly take any tip
