Hello everyone. I am trying to raise the power limit on my AMD GPU. I’ve tried CoreCtrl, but it didn’t let me raise it as high as I wanted. I also tried to change it like the arch wiki mentions on the manual overclocking section, but it seemingly doesn’t support going higher than 293W? I know that my card can handle close to 340W (that’s around the point I had while I was on Windows).
Any and all help appreciated.
~ screenfetch
██████████████████ ████████ monni@monni-monjaro
██████████████████ ████████ OS: Manjaro 22.1.0 Talos
██████████████████ ████████ Kernel: x86_64 Linux 6.1.25-1-MANJARO
██████████████████ ████████ Uptime: 1h 10m
████████ ████████ Packages: 1520
████████ ████████ ████████ Shell: zsh 5.9
████████ ████████ ████████ Resolution: 6560x2560
████████ ████████ ████████ DE: KDE 5.104.0 / Plasma 5.27.4
████████ ████████ ████████ WM: KWin
████████ ████████ ████████ GTK Theme: Breeze [GTK2/3]
████████ ████████ ████████ Icon Theme: candy-icons
████████ ████████ ████████ Disk: 383G / 924G (44%)
████████ ████████ ████████ CPU: AMD Ryzen 9 3900X 12-Core @ 24x 3.8GHz
████████ ████████ ████████ GPU: AMD Radeon RX 6900 XT (navi21, LLVM 15.0.7, DRM 3.49, 6.1.25-1-MANJARO)
RAM: 4082MiB / 15881MiB
~ inxi -a -G
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Tul /
PowerColor Red Devil driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1 bus-ID: 0c:00.0
chip-ID: 1002:73bf class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 7-2:2 chip-ID: 046d:085c
class-ID: 0102 serial: AA79661F
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 6560x2560 s-dpi: 96 s-size: 1735x677mm (68.31x26.65")
s-diag: 1862mm (73.32")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,bottom-l
model: Samsung LC49G95T serial: H4ZN601010 built: 2020 res: 5120x1440
hz: 120 dpi: 109 gamma: 1.2 size: 1190x340mm (46.85x13.39")
diag: 1239mm (48.8") modes: max: 5120x1440 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: top-right
model: Gigabyte AORUS AD27QD serial: 19120B001035 built: 2019 res: 1440x2560
dpi: 103 gamma: 1.2 size: 355x609mm (13.98x23.98") diag: 705mm (27.8")
ratio: 15:9 modes: max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon RX 6900 XT (navi21
LLVM 15.0.7 DRM 3.49 6.1.25-1-MANJARO) direct-render: Yes
