Hi everyone!
edit: The website has informed me that I’m not allowed to put links in my post. I’ll do my best to make the post coherent without
What I’m trying to do:
I am trying to run a Windows-only game called Raft (steam id: 648800) on Manjaro Linux Xfce. I have enabled steamplay for all titles on Steam, and set Proton to the newest version. According to ProtonDB, this game should work perfectly (Platinum)
What is going wrong:
When I open up the game, I get an error screen with a red exclamation mark. (I have a screenshot with id OudR61A on imgur). The game then shuts off.
I have tried uninstalling and reinstalling my graphics drivers, and adding “WINEDLLOVERRIDES=dxgi=n” to the launch options for Raft in Steam.
I found a Reddit post on r/linux_gaming by u/gn0gs titled " Raft not running on Manjaro OS through Steam." The OP has the same problem as me, and claims that their problem was solved by a Manjaro forum post on this site with “/t/problem-with-vulkan-on-manjaro/95965” in the url. However, I get the message “Oops! That page doesn’t exist or is private.” when I try to visit that page.
My Machine
inxi -Fazy output
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0486070e-8fb3-4cf7-b724-b7862aa620f9 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop System: Dell product: OptiPlex 9020 v: 01 serial: <filter>
Chassis: type: 15 serial: <filter>
Mobo: Dell model: 00V62H v: A00 serial: <filter> UEFI: Dell v: A07
date: 04/25/2014
Info: Quad Core model: Intel Core i7-4790 bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 8 MiB
bogomips: 28747
Speed: 3592 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 3592 2: 3606
3: 3596 4: 3592
Type: l1tf
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, RSB filling
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 305 size: 160x90mm (6.3x3.5")
diag: 184mm (7.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 21.2.3 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 2-1.5:5 chip-ID: b58e:9e84
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: Realtek 802.11ac NIC type: USB driver: N/A bus-ID: 2-1.3:3
chip-ID: 0bda:c811 class-ID: 0000 serial: <filter>
Not an ARRAY reference at /usr/bin/inxi line 16007.
vulkaninfo output
MESA-INTEL: warning: Haswell Vulkan support is incomplete
VULKANINFO
Vulkan Instance Version: 1.2.194
Instance Extensions: count = 19
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Layers: count = 4
VK_LAYER_VALVE_steam_fossilize_32 (Steam Pipeline Caching Layer) Vulkan version 1.2.136, layer version 1:
Layer Extensions: count = 0
Devices: count = 1
GPU id = 0 (Intel(R) HD Graphics 4600 (HSW GT2))
Layer-Device Extensions: count = 0
VK_LAYER_VALVE_steam_fossilize_64 (Steam Pipeline Caching Layer) Vulkan version 1.2.136, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_32 (Steam Overlay Layer) Vulkan version 1.2.136, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_64 (Steam Overlay Layer) Vulkan version 1.2.136, layer version 1:
Devices: count = 1
Presentable Surfaces:
GPU id : 0 (Intel(R) HD Graphics 4600 (HSW GT2)):
Surface types: count = 2
VK_KHR_xcb_surface
VK_KHR_xlib_surface
Formats: count = 2
SurfaceFormat[0]:
format = FORMAT_B8G8R8A8_SRGB
colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
SurfaceFormat[1]:
format = FORMAT_B8G8R8A8_UNORM
Present Modes: count = 4
PRESENT_MODE_IMMEDIATE_KHR
PRESENT_MODE_MAILBOX_KHR
PRESENT_MODE_FIFO_KHR
PRESENT_MODE_FIFO_RELAXED_KHR
VkSurfaceCapabilitiesKHR:
minImageCount = 3
maxImageCount = 0
currentExtent:
width = 256
height = 256MESA-INTEL: warning: Haswell Vulkan support is incomplete
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
maxImageArrayLayers = 1
supportedTransforms: count = 1
SURFACE_TRANSFORM_IDENTITY_BIT_KHR
currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
supportedCompositeAlpha: count = 2
COMPOSITE_ALPHA_OPAQUE_BIT_KHR
COMPOSITE_ALPHA_INHERIT_BIT_KHR
supportedUsageFlags: count = 5
IMAGE_USAGE_TRANSFER_SRC_BIT
IMAGE_USAGE_TRANSFER_DST_BIT
IMAGE_USAGE_SAMPLED_BIT
IMAGE_USAGE_STORAGE_BIT
IMAGE_USAGE_COLOR_ATTACHMENT_BIT
VkSurfaceCapabilities2EXT:
supportedSurfaceCounters:
None
VkSurfaceProtectedCapabilitiesKHR:
supportsProtected = false
Device Groups:
Group 0:
Properties:
physicalDevices: count = 1
Intel(R) HD Graphics 4600 (HSW GT2) (ID: 0)
subsetAllocation = 0
Present Capabilities:
Intel(R) HD Graphics 4600 (HSW GT2) (ID: 0):
Can present images from the following devices: count = 1
Present modes: count = 1
DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
apiVersion = 4202678 (1.2.182)
driverVersion = 88088579 (0x5402003)
vendorID = 0x8086
deviceID = 0x0412
deviceType = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
deviceName = Intel(R) HD Graphics 4600 (HSW GT2)
pipelineCacheUUID = a32f3770-cc34-78cb-ab59-7f43f5cb8a11
VkPhysicalDeviceLimits:
maxImageDimension1D = 16384
maxImageDimension2D = 16384
maxImageDimension3D = 2048
maxImageDimensionCube = 16384
maxImageArrayLayers = 2048
maxTexelBufferElements = 134217728
maxUniformBufferRange = 134217728
maxStorageBufferRange = 1073741824
maxPushConstantsSize = 128
maxMemoryAllocationCount = 4294967295
maxSamplerAllocationCount = 65536
bufferImageGranularity = 0x00000040
sparseAddressSpaceSize = 0x00000000
maxBoundDescriptorSets = 8
maxPerStageDescriptorSamplers = 128
maxPerStageDescriptorUniformBuffers = 64
maxPerStageDescriptorStorageBuffers = 64
maxPerStageDescriptorSampledImages = 128
maxPerStageDescriptorStorageImages = 64
maxPerStageDescriptorInputAttachments = 64
maxPerStageResources = 231
maxDescriptorSetSamplers = 768
maxDescriptorSetUniformBuffers = 384
maxDescriptorSetUniformBuffersDynamic = 8
maxDescriptorSetStorageBuffers = 384
maxDescriptorSetStorageBuffersDynamic = 8
maxDescriptorSetSampledImages = 768
maxDescriptorSetStorageImages = 384
maxDescriptorSetInputAttachments = 256
maxVertexInputAttributes = 28
maxVertexInputBindings = 28
maxVertexInputAttributeOffset = 2047
maxVertexInputBindingStride = 2048
maxVertexOutputComponents = 128
maxTessellationGenerationLevel = 64
maxTessellationPatchSize = 32
maxTessellationControlPerVertexInputComponents = 128
maxTessellationControlPerVertexOutputComponents = 128
maxTessellationControlPerPatchOutputComponents = 128
maxTessellationControlTotalOutputComponents = 2048
maxTessellationEvaluationInputComponents = 128
maxTessellationEvaluationOutputComponents = 128
maxGeometryShaderInvocations = 32
maxGeometryInputComponents = 64
maxGeometryOutputComponents = 128
maxGeometryOutputVertices = 256
maxGeometryTotalOutputComponents = 1024
maxFragmentInputComponents = 116
maxFragmentOutputAttachments = 8
maxFragmentDualSrcAttachments = 1
maxFragmentCombinedOutputResources = 8
maxComputeSharedMemorySize = 65536
maxComputeWorkGroupCount: count = 3
65535
65535
65535
maxComputeWorkGroupInvocations = 2048
maxComputeWorkGroupSize: count = 3
2048
2048
2048
subPixelPrecisionBits = 8
subTexelPrecisionBits = 8
mipmapPrecisionBits = 8
maxDrawIndexedIndexValue = 4294967295
maxDrawIndirectCount = 4294967295
maxSamplerLodBias = 16
maxSamplerAnisotropy = 16
maxViewports = 16
maxViewportDimensions: count = 2
16384
16384
viewportBoundsRange: count = 2
-32768
32767
viewportSubPixelBits = 13
minMemoryMapAlignment = 4096
minTexelBufferOffsetAlignment = 0x00000010
minUniformBufferOffsetAlignment = 0x00000040
minStorageBufferOffsetAlignment = 0x00000004
minTexelOffset = -8
maxTexelOffset = 7
minTexelGatherOffset = -32
maxTexelGatherOffset = 31
minInterpolationOffset = -0.5
maxInterpolationOffset = 0.4375
subPixelInterpolationOffsetBits = 4
maxFramebufferWidth = 16384
maxFramebufferHeight = 16384
maxFramebufferLayers = 2048
framebufferColorSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferDepthSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferStencilSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferNoAttachmentsSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxColorAttachments = 8
sampledImageColorSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageIntegerSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageDepthSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageStencilSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
storageImageSampleCounts: count = 1
SAMPLE_COUNT_1_BIT
maxSampleMaskWords = 1
timestampComputeAndGraphics = true
timestampPeriod = 80
maxClipDistances = 8
maxCullDistances = 8
maxCombinedClipAndCullDistances = 8
discreteQueuePriorities = 2
pointSizeRange: count = 2
0.125
255.875
lineWidthRange: count = 2
0
7.99219
pointSizeGranularity = 0.125
lineWidthGranularity = 0.0078125
strictLines = false
standardSampleLocations = true
optimalBufferCopyOffsetAlignment = 0x00000080
optimalBufferCopyRowPitchAlignment = 0x00000080
nonCoherentAtomSize = 0x00000040
VkPhysicalDeviceSparseProperties:
residencyStandard2DBlockShape = false
residencyStandard2DMultisampleBlockShape = false
residencyStandard3DBlockShape = false
residencyAlignedMipSize = false
residencyNonResidentStrict = false
VkPhysicalDeviceDepthStencilResolveProperties:
supportedDepthResolveModes: count = 4
RESOLVE_MODE_SAMPLE_ZERO_BIT
RESOLVE_MODE_AVERAGE_BIT
RESOLVE_MODE_MIN_BIT
RESOLVE_MODE_MAX_BIT
supportedStencilResolveModes: count = 1
independentResolveNone = true
independentResolve = true
VkPhysicalDeviceDescriptorIndexingProperties:
maxUpdateAfterBindDescriptorsInAllPools = 1048576
shaderUniformBufferArrayNonUniformIndexingNative = false
shaderSampledImageArrayNonUniformIndexingNative = false
shaderStorageBufferArrayNonUniformIndexingNative = true
shaderStorageImageArrayNonUniformIndexingNative = false
shaderInputAttachmentArrayNonUniformIndexingNative = false
robustBufferAccessUpdateAfterBind = true
quadDivergentImplicitLod = false
maxPerStageDescriptorUpdateAfterBindSamplers = 1048576
maxPerStageDescriptorUpdateAfterBindUniformBuffers = 64
maxPerStageDescriptorUpdateAfterBindStorageBuffers = 4294967295
maxPerStageDescriptorUpdateAfterBindSampledImages = 1048576
maxPerStageDescriptorUpdateAfterBindStorageImages = 1048576
maxPerStageDescriptorUpdateAfterBindInputAttachments = 64
maxPerStageUpdateAfterBindResources = 4294967295
maxDescriptorSetUpdateAfterBindSamplers = 1048576
maxDescriptorSetUpdateAfterBindUniformBuffers = 384
maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindStorageBuffers = 4294967295
maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindSampledImages = 1048576
maxDescriptorSetUpdateAfterBindStorageImages = 1048576
maxDescriptorSetUpdateAfterBindInputAttachments = 256
VkPhysicalDeviceDriverProperties:
driverID = DRIVER_ID_INTEL_OPEN_SOURCE_MESA
driverName = Intel open-source Mesa driver
driverInfo = Mesa 21.2.3
conformanceVersion = 1.2.0.0
VkPhysicalDeviceDrmPropertiesEXT:
hasPrimary = true
hasRender = true
primaryMajor = 226
primaryMinor = 0
renderMajor = 226
renderMinor = 128
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
denormBehaviorIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
roundingModeIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_NONE
shaderSignedZeroInfNanPreserveFloat16 = true
shaderSignedZeroInfNanPreserveFloat32 = true
shaderSignedZeroInfNanPreserveFloat64 = true
shaderDenormPreserveFloat16 = false
shaderDenormPreserveFloat32 = true
shaderDenormPreserveFloat64 = true
shaderDenormFlushToZeroFloat16 = false
shaderDenormFlushToZeroFloat32 = true
shaderDenormFlushToZeroFloat64 = true
shaderRoundingModeRTEFloat16 = true
shaderRoundingModeRTEFloat32 = true
shaderRoundingModeRTEFloat64 = true
shaderRoundingModeRTZFloat16 = true
shaderRoundingModeRTZFloat32 = true
shaderRoundingModeRTZFloat64 = true
VkPhysicalDeviceIDProperties:
deviceUUID = 9f423434-0944-1d6b-5a3e-7d8c94abd404
driverUUID = 6c6c446e-46e7-ce0f-b8fb-fa7b002d68cf
deviceNodeMask = 0
deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
maxInlineUniformBlockSize = 4096
maxPerStageDescriptorInlineUniformBlocks = 32
maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 32
maxDescriptorSetInlineUniformBlocks = 32
maxDescriptorSetUpdateAfterBindInlineUniformBlocks = 32
VkPhysicalDeviceLineRasterizationPropertiesEXT:
lineSubPixelPrecisionBits = 4
VkPhysicalDeviceMaintenance3Properties:
maxPerSetDescriptors = 1024
maxMemoryAllocationSize = 0x80000000
VkPhysicalDeviceMultiDrawPropertiesEXT:
maxMultiDrawCount = 2048
VkPhysicalDeviceMultiviewProperties:
maxMultiviewViewCount = 16
maxMultiviewInstanceIndex = 268435455
VkPhysicalDevicePCIBusInfoPropertiesEXT:
pciDomain = 0
pciBus = 0
pciDevice = 2
pciFunction = 0
VkPhysicalDevicePointClippingProperties:
pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
VkPhysicalDeviceProtectedMemoryProperties:
protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
provokingVertexModePerPipeline = true
transformFeedbackPreservesTriangleFanProvokingVertex = false
VkPhysicalDevicePushDescriptorPropertiesKHR:
maxPushDescriptors = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
robustStorageBufferAccessSizeAlignment = 0x00000004
robustUniformBufferAccessSizeAlignment = 0x00000040
VkPhysicalDeviceSampleLocationsPropertiesEXT:
sampleLocationSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxSampleLocationGridSize:
width = 1
height = 1
sampleLocationCoordinateRange: count = 2
0
0.9375
sampleLocationSubPixelBits = 4
variableSampleLocations = true
VkPhysicalDeviceSamplerFilterMinmaxProperties:
filterMinmaxSingleComponentFormats = false
filterMinmaxImageComponentMapping = false
VkPhysicalDeviceSubgroupProperties:
subgroupSize = 32
supportedStages: count = 12
SHADER_STAGE_FRAGMENT_BIT
SHADER_STAGE_COMPUTE_BIT
SHADER_STAGE_ALL_GRAPHICS
SHADER_STAGE_ALL
SHADER_STAGE_RAYGEN_BIT_KHR
SHADER_STAGE_ANY_HIT_BIT_KHR
SHADER_STAGE_CLOSEST_HIT_BIT_KHR
SHADER_STAGE_MISS_BIT_KHR
SHADER_STAGE_INTERSECTION_BIT_KHR
SHADER_STAGE_CALLABLE_BIT_KHR
SHADER_STAGE_TASK_BIT_NV
SHADER_STAGE_MESH_BIT_NV
supportedOperations: count = 6
SUBGROUP_FEATURE_BASIC_BIT
SUBGROUP_FEATURE_VOTE_BIT
SUBGROUP_FEATURE_BALLOT_BIT
SUBGROUP_FEATURE_SHUFFLE_BIT
SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
SUBGROUP_FEATURE_QUAD_BIT
quadOperationsInAllStages = false
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
minSubgroupSize = 8
maxSubgroupSize = 32
maxComputeWorkgroupSubgroups = 64
requiredSubgroupSizeStages: count = 2
SHADER_STAGE_ALL
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
storageTexelBufferOffsetAlignmentBytes = 0x00000010
storageTexelBufferOffsetSingleTexelAlignment = true
uniformTexelBufferOffsetAlignmentBytes = 0x00000001
uniformTexelBufferOffsetSingleTexelAlignment = false
VkPhysicalDeviceTimelineSemaphoreProperties:
maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
maxTransformFeedbackStreams = 4
maxTransformFeedbackBuffers = 4
maxTransformFeedbackBufferSize = 0x100000000
maxTransformFeedbackStreamDataSize = 512
maxTransformFeedbackBufferDataSize = 512
maxTransformFeedbackBufferDataStride = 2048
transformFeedbackQueries = true
transformFeedbackStreamsLinesTriangles = false
transformFeedbackRasterizationStreamSelect = false
transformFeedbackDraw = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
maxVertexAttribDivisor = 268435455
VkPhysicalDeviceVulkan11Properties:
deviceNodeMask = 0
subgroupSize = 32
subgroupSupportedStages: count = 12
SHADER_STAGE_ALL
subgroupSupportedOperations: count = 6
subgroupQuadOperationsInAllStages = false
VkPhysicalDeviceVulkan12Properties:
framebufferIntegerColorSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
Device Extensions: count = 88
VK_EXT_4444_formats : extension revision 1
VK_EXT_calibrated_timestamps : extension revision 2
VK_EXT_color_write_enable : extension revision 1
VK_EXT_conditional_rendering : extension revision 2
VK_EXT_depth_clip_enable : extension revision 1
VK_EXT_display_control : extension revision 1
VK_EXT_extended_dynamic_state : extension revision 1
VK_EXT_extended_dynamic_state2 : extension revision 1
VK_EXT_external_memory_dma_buf : extension revision 1
VK_EXT_external_memory_host : extension revision 1
VK_EXT_host_query_reset : extension revision 1
VK_EXT_image_drm_format_modifier : extension revision 1
VK_EXT_image_robustness : extension revision 1
VK_EXT_index_type_uint8 : extension revision 1
VK_EXT_inline_uniform_block : extension revision 1
VK_EXT_line_rasterization : extension revision 1
VK_EXT_memory_budget : extension revision 1
VK_EXT_multi_draw : extension revision 1
VK_EXT_pci_bus_info : extension revision 2
VK_EXT_physical_device_drm : extension revision 1
VK_EXT_pipeline_creation_cache_control : extension revision 3
VK_EXT_pipeline_creation_feedback : extension revision 1
VK_EXT_private_data : extension revision 1
VK_EXT_provoking_vertex : extension revision 1
VK_EXT_queue_family_foreign : extension revision 1
VK_EXT_robustness2 : extension revision 1
VK_EXT_sample_locations : extension revision 1
VK_EXT_scalar_block_layout : extension revision 1
VK_EXT_separate_stencil_usage : extension revision 1
VK_EXT_shader_atomic_float : extension revision 1
VK_EXT_shader_demote_to_helper_invocation : extension revision 1
VK_EXT_shader_subgroup_ballot : extension revision 1
VK_EXT_shader_subgroup_vote : extension revision 1
VK_EXT_shader_viewport_index_layer : extension revision 1
VK_EXT_subgroup_size_control : extension revision 2
VK_EXT_texel_buffer_alignment : extension revision 1
VK_EXT_transform_feedback : extension revision 1
VK_EXT_vertex_attribute_divisor : extension revision 3
VK_EXT_ycbcr_image_arrays : extension revision 1
VK_GOOGLE_decorate_string : extension revision 1
VK_GOOGLE_hlsl_functionality1 : extension revision 1
VK_GOOGLE_user_type : extension revision 1
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_copy_commands2 : extension revision 1
VK_KHR_create_renderpass2 : extension revision 1
VK_KHR_dedicated_allocation : extension revision 3
VK_KHR_deferred_host_operations : extension revision 4
VK_KHR_depth_stencil_resolve : extension revision 1
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_device_group : extension revision 4
VK_KHR_draw_indirect_count : extension revision 1
VK_KHR_driver_properties : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_imageless_framebuffer : extension revision 1
VK_KHR_incremental_present : extension revision 2
VK_KHR_maintenance1 : extension revision 2
VK_KHR_maintenance2 : extension revision 1
VK_KHR_maintenance3 : extension revision 1
VK_KHR_multiview : extension revision 1
VK_KHR_pipeline_executable_properties : extension revision 1
VK_KHR_push_descriptor : extension revision 2
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 3
VK_KHR_sampler_ycbcr_conversion : extension revision 14
VK_KHR_separate_depth_stencil_layouts : extension revision 1
VK_KHR_shader_clock : extension revision 1
VK_KHR_shader_draw_parameters : extension revision 1
VK_KHR_shader_non_semantic_info : extension revision 1
VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
VK_KHR_shader_terminate_invocation : extension revision 1
VK_KHR_spirv_1_4 : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_swapchain : extension revision 70
VK_KHR_swapchain_mutable_format : extension revision 1
VK_KHR_timeline_semaphore : extension revision 2
VK_KHR_uniform_buffer_standard_layout : extension revision 1
VK_KHR_variable_pointers : extension revision 1
VK_KHR_vulkan_memory_model : extension revision 3
VK_KHR_workgroup_memory_explicit_layout : extension revision 1
VK_KHR_zero_initialize_workgroup_memory : extension revision 1
VK_NV_compute_shader_derivatives : extension revision 1
VkQueueFamilyProperties:
queueProperties[0]:
minImageTransferGranularity = (1,1,1)
queueCount = 1
queueFlags = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER
timestampValidBits = 36
present support = true
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 1
memoryHeaps[0]:
size = 1610612736 (0x60000000) (1.50 GiB)
budget = 1610612736 (0x60000000) (1.50 GiB)
usage = 0 (0x00000000) (0.00 B)
flags: count = 1
MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryTypes: count = 1
memoryTypes[0]:
heapIndex = 0
propertyFlags = 0x000f: count = 4
MEMORY_PROPERTY_DEVICE_LOCAL_BIT
MEMORY_PROPERTY_HOST_VISIBLE_BIT
MEMORY_PROPERTY_HOST_COHERENT_BIT
MEMORY_PROPERTY_HOST_CACHED_BIT
usable for:
IMAGE_TILING_OPTIMAL:
color images
FORMAT_D16_UNORM
FORMAT_X8_D24_UNORM_PACK32
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
FORMAT_D24_UNORM_S8_UINT
FORMAT_D32_SFLOAT_S8_UINT
(non-sparse)
IMAGE_TILING_LINEAR:
color images
(non-sparse)
VkPhysicalDeviceFeatures:
robustBufferAccess = true
fullDrawIndexUint32 = true
imageCubeArray = true
independentBlend = true
geometryShader = true
tessellationShader = true
sampleRateShading = true
dualSrcBlend = true
logicOp = true
multiDrawIndirect = true
drawIndirectFirstInstance = true
depthClamp = true
depthBiasClamp = true
fillModeNonSolid = true
depthBounds = false
wideLines = true
largePoints = true
alphaToOne = true
multiViewport = true
samplerAnisotropy = true
textureCompressionETC2 = false
textureCompressionASTC_LDR = false
textureCompressionBC = true
occlusionQueryPrecise = true
pipelineStatisticsQuery = true
vertexPipelineStoresAndAtomics = false
fragmentStoresAndAtomics = true
shaderTessellationAndGeometryPointSize = true
shaderImageGatherExtended = true
shaderStorageImageExtendedFormats = true
shaderStorageImageMultisample = false
shaderStorageImageReadWithoutFormat = false
shaderStorageImageWriteWithoutFormat = true
shaderUniformBufferArrayDynamicIndexing = true
shaderSampledImageArrayDynamicIndexing = true
shaderStorageBufferArrayDynamicIndexing = true
shaderStorageImageArrayDynamicIndexing = true
shaderClipDistance = true
shaderCullDistance = true
shaderFloat64 = false
shaderInt64 = false
shaderInt16 = false
shaderResourceResidency = false
shaderResourceMinLod = false
sparseBinding = false
sparseResidencyBuffer = false
sparseResidencyImage2D = false
sparseResidencyImage3D = false
sparseResidency2Samples = false
sparseResidency4Samples = false
sparseResidency8Samples = false
sparseResidency16Samples = false
sparseResidencyAliased = false
variableMultisampleRate = true
inheritedQueries = true
VkPhysicalDevice16BitStorageFeatures:
storageBuffer16BitAccess = false
uniformAndStorageBuffer16BitAccess = false
storagePushConstant16 = false
storageInputOutput16 = false
VkPhysicalDevice4444FormatsFeaturesEXT:
formatA4R4G4B4 = true
formatA4B4G4R4 = false
VkPhysicalDevice8BitStorageFeatures:
storageBuffer8BitAccess = false
uniformAndStorageBuffer8BitAccess = false
storagePushConstant8 = false
VkPhysicalDeviceBufferDeviceAddressFeatures:
bufferDeviceAddress = false
bufferDeviceAddressCaptureReplay = false
bufferDeviceAddressMultiDevice = false
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
colorWriteEnable = true
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
conditionalRendering = true
inheritedConditionalRendering = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
shaderInputAttachmentArrayDynamicIndexing = false
shaderUniformTexelBufferArrayDynamicIndexing = false
shaderStorageTexelBufferArrayDynamicIndexing = false
shaderUniformBufferArrayNonUniformIndexing = false
shaderSampledImageArrayNonUniformIndexing = false
shaderStorageBufferArrayNonUniformIndexing = false
shaderStorageImageArrayNonUniformIndexing = false
shaderInputAttachmentArrayNonUniformIndexing = false
shaderUniformTexelBufferArrayNonUniformIndexing = false
shaderStorageTexelBufferArrayNonUniformIndexing = false
descriptorBindingUniformBufferUpdateAfterBind = false
descriptorBindingSampledImageUpdateAfterBind = false
descriptorBindingStorageImageUpdateAfterBind = false
descriptorBindingStorageBufferUpdateAfterBind = false
descriptorBindingUniformTexelBufferUpdateAfterBind = false
descriptorBindingStorageTexelBufferUpdateAfterBind = false
descriptorBindingUpdateUnusedWhilePending = false
descriptorBindingPartiallyBound = false
descriptorBindingVariableDescriptorCount = false
runtimeDescriptorArray = false
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
extendedDynamicState2 = true
extendedDynamicState2LogicOp = true
extendedDynamicState2PatchControlPoints = false
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
extendedDynamicState = true
VkPhysicalDeviceHostQueryResetFeatures:
hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeaturesEXT:
robustImageAccess = true
VkPhysicalDeviceImagelessFramebufferFeatures:
imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
inlineUniformBlock = true
descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
rectangularLines = true
bresenhamLines = true
smoothLines = true
stippledRectangularLines = false
stippledBresenhamLines = true
stippledSmoothLines = false
VkPhysicalDeviceMultiDrawFeaturesEXT:
multiDraw = true
VkPhysicalDeviceMultiviewFeatures:
multiview = true
multiviewGeometryShader = true
multiviewTessellationShader = true
VkPhysicalDevicePipelineCreationCacheControlFeaturesEXT:
pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
pipelineExecutableInfo = true
VkPhysicalDevicePrivateDataFeaturesEXT:
privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
provokingVertexLast = true
transformFeedbackPreservesProvokingVertex = true
VkPhysicalDeviceRobustness2FeaturesEXT:
robustBufferAccess2 = true
robustImageAccess2 = true
nullDescriptor = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
shaderBufferFloat32Atomics = true
shaderBufferFloat32AtomicAdd = false
shaderBufferFloat64Atomics = false
shaderBufferFloat64AtomicAdd = false
shaderSharedFloat32Atomics = true
shaderSharedFloat32AtomicAdd = false
shaderSharedFloat64Atomics = false
shaderSharedFloat64AtomicAdd = false
shaderImageFloat32Atomics = true
shaderImageFloat32AtomicAdd = false
sparseImageFloat32Atomics = false
sparseImageFloat32AtomicAdd = false
VkPhysicalDeviceShaderAtomicInt64Features:
shaderBufferInt64Atomics = false
shaderSharedInt64Atomics = false
VkPhysicalDeviceShaderClockFeaturesKHR:
shaderSubgroupClock = true
shaderDeviceClock = false
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
shaderFloat16 = false
shaderInt8 = false
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderSubgroupUniformControlFlowFeaturesKHR:
shaderSubgroupUniformControlFlow = true
VkPhysicalDeviceShaderTerminateInvocationFeaturesKHR:
shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
subgroupSizeControl = true
computeFullSubgroups = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeatures:
timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
transformFeedback = true
geometryStreams = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
variablePointersStorageBuffer = true
variablePointers = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
vertexAttributeInstanceRateDivisor = true
vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkan11Features:
multiview = true
VkPhysicalDeviceVulkan12Features:
samplerMirrorClampToEdge = true
drawIndirectCount = true
shaderInt8 = false
descriptorIndexing = false
samplerFilterMinmax = false
vulkanMemoryModel = true
vulkanMemoryModelDeviceScope = true
vulkanMemoryModelAvailabilityVisibilityChains = true
shaderOutputViewportIndex = true
shaderOutputLayer = true
subgroupBroadcastDynamicId = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
workgroupMemoryExplicitLayout = true
workgroupMemoryExplicitLayoutScalarBlockLayout = true
workgroupMemoryExplicitLayout8BitAccess = true
workgroupMemoryExplicitLayout16BitAccess = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
ycbcrImageArrays = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeaturesKHR:
shaderZeroInitializeWorkgroupMemory = true
I suspect that the line “MESA-INTEL: warning: Haswell Vulkan support is incomplete” in vulkaninfo has to do with the source of the problem, but my web searches are bringing nothing.
Can anybody point me in the right direction to fix this problem? Thank you very much for taking the time to read this post
