hi recently tried to switch to manjaro from win10,i`m noob, im tryng to run some games but wont run, i dig a bit on the web and maybe i found somethings, since my gpu is a sea island i have to enable in the kernel i read the arch wiki but im a bit confused on how to do it
Set one of the following kernel parameters:
Southern Islands (SI): radeon.si_support=0 amdgpu.si_support=1
Sea Islands (CIK): radeon.cik_support=0 amdgpu.cik_support=1
Set module parameters in modprobe.d
Create the configuration modprobe files in /etc/modprobe.d/, see modprobe.d(5) for syntax details.
For Southern Islands (SI) use option si_support=1, for Sea Islands (CIK) use option cik_support=1, e.g.:
/etc/modprobe.d/amdgpu.conf
options amdgpu si_support=1
options amdgpu cik_support=1
/etc/modprobe.d/radeon.conf
options radeon si_support=0
options radeon cik_support=0
Make sure modconf is in the the HOOKS array in /etc/mkinitcpio.conf and regenerate the initramfs. `````
this is what i think i have to do but i dont know how to do it
