Hello
I’m use tl-wn725n
usb adaptor for connecting to network…
But when I’m update manjaro, driver not work and cannot connect to network
$ ifconfig -a
enp2s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 1c:6f:65:49:08:54 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 8591 bytes 673738 (657.9 KiB)
TX packets 8591 bytes 673738 (657.9 KiB)
wlp0s19f2u1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.193.42 netmask 255.255.255.0 broadcast 192.168.193.255
inet6 fe80::ebc3:ead1:ca4a:5ea prefixlen 64 scopeid 0x20<link>
ether d4:6e:0e:14:b0:16 txqueuelen 1000 (Ethernet)
RX packets 19059 bytes 34835250 (33.2 MiB)
RX errors 0 dropped 1411 overruns 0 frame 0
TX packets 12965 bytes 3535005 (3.3 MiB)
TX errors 0 dropped 13 overruns 0 carrier 0 collisions 0
$ mhwd --listinstalled
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-vesa 2017.03.12 true PCI
video-modesetting 2020.01.13 true PCI
network-r8168 2016.04.20 true PCI
video-nvidia-390xx 2021.12.18 false PCI
inxi -N
driver: r8169
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu
$ dmesg| grep r8169
[ 5.220271] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 5.226530] libphy: r8169: probed
[ 5.227009] r8169 0000:02:00.0 eth0: RTL8168d/8111d, 1c:6f:65:49:08:54, XID 283, IRQ 26
[ 5.227013] r8169 0000:02:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 8.954439] Modules linked in: uas usb_storage nouveau(+) mxm_wmi video i2c_algo_bit firewire_ohci drm_kms_helper syscopyarea ata_generic pata_acpi sysfillrect sysimgblt firewire_core fb_sys_fops crc_itu_t cec r8169 realtek ttm mdio_devres pata_atiixp drm libphy agpgart wmi floppy dm_snapshot dm_bufio dm_mod loop
[ 35.048516] r8169 0000:02:00.0 enp2s0: renamed from eth0
[ 39.646839] RTL8211B Gigabit Ethernet r8169-200:00: attached PHY driver [RTL8211B Gigabit Ethernet] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[ 39.861534] r8169 0000:02:00.0 enp2s0: Link is Down
[ 1031.325571] RTL8211B Gigabit Ethernet r8169-200:00: attached PHY driver [RTL8211B Gigabit Ethernet] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[ 1031.507651] r8169 0000:02:00.0 enp2s0: Link is Down
hint: this log copied form live boot/chroot beacuse I need Internet for copy to manjaro forum…
I search about this issue but can not fix them
Please help me…
