Qutebrowser again
after update:
[2022-10-23T14:13:11+0200] [PACMAN] Running ‘pacman -Syyuu’
[2022-10-23T14:13:11+0200] [PACMAN] synchronizing package lists
[2022-10-23T19:17:51+0200] [PACMAN] starting full system upgrade
[2022-10-24T17:44:59+0200] [PACMAN] Running ‘pacman -Syyuu’
[2022-10-24T17:44:59+0200] [PACMAN] synchronizing package lists
[2022-10-24T17:45:09+0200] [PACMAN] starting full system upgrade
[2022-10-24T17:46:13+0200] [ALPM] transaction started
[2022-10-24T17:46:13+0200] [ALPM] upgraded harfbuzz (5.3.1-1 → 5.3.1-3)
[2022-10-24T17:46:13+0200] [ALPM] upgraded fontconfig (2:2.14.0-1 → 2:2.14.1-2)
[2022-10-24T17:46:13+0200] [ALPM-SCRIPTLET] Rebuilding fontconfig cache…
[2022-10-24T17:46:18+0200] [ALPM] upgraded icu (71.1-1 → 72.1-1)
[2022-10-24T17:46:19+0200] [ALPM] upgraded flac (1.4.1-2 → 1.4.2-1)
[2022-10-24T17:46:19+0200] [ALPM] upgraded libxml2 (2.10.3-1 → 2.10.3-2)
[2022-10-24T17:46:19+0200] [ALPM] upgraded libxrender (0.9.10-5 → 0.9.11-1)
[2022-10-24T17:46:19+0200] [ALPM] upgraded tracker3 (3.4.0-1 → 3.4.0-2)
[2022-10-24T17:46:35+0200] [ALPM] upgraded chromium (106.0.5249.119-1 → 106.0.5249.119-2)
[2022-10-24T17:46:35+0200] [ALPM] upgraded fuzzel (1.7.0-2 → 1.8.0-1)
[2022-10-24T17:46:35+0200] [ALPM] upgraded j4-dmenu-desktop (2.18-2 → 2.18-4)
[2022-10-24T17:46:41+0200] [ALPM] upgraded mtools (1:4.0.41-1 → 1:4.0.42-1)
[2022-10-24T17:46:41+0200] [ALPM] upgraded python-more-itertools (8.14.0-1 → 9.0.0-1)
[2022-10-24T17:46:41+0200] [ALPM] upgraded python-setuptools (1:63.4.2-1 → 1:63.4.3-1)
[2022-10-24T17:46:47+0200] [ALPM] upgraded qt5-base (5.15.6+kde+r180-1 → 5.15.6+kde+r181-1)
[2022-10-24T17:47:01+0200] [ALPM] upgraded qt5-webengine (5.15.10-3 → 5.15.10-4)
[2022-10-24T17:47:07+0200] [ALPM] upgraded qt6-base (6.4.0-1 → 6.4.0-2)
[2022-10-24T17:47:09+0200] [ALPM] upgraded qt6-5compat (6.4.0-2 → 6.4.0-3)
[2022-10-24T17:47:27+0200] [ALPM] upgraded thunderbird (102.4.0-1 → 102.4.0-2)
[2022-10-24T17:47:28+0200] [ALPM] upgraded xfsprogs (5.19.0-1 → 5.19.0-2)
[2022-10-24T17:47:41+0200] [ALPM] transaction completed
Not sire what your point is.
We don’t maintain qt5-webengine, ALARM does. So if there is an issue with it, you should report it to the Arch Linux ARM guys.
Is it because of the ICU update?
I dont know exactly if is icu or more packages related, when i run qutebrowser i get this:
title window: No backend library found:
  • QtWebKit: libQt5WebKit.so.5: impossibile aprire il file oggetto condiviso: File o directory non esistente
  • QtWebEngine: libQt5WebEngineWidgets.so.5: impossibile aprire il file oggetto condiviso: File o directory non esistente
Looks like the qt5-webengine package is missing lots of files again. Did the previous package have them all?
-rw-r–r-- 1 root root 42M 22 ago 16.30 qt5-webengine-5.15.10-2.1-aarch64.pkg.tar.xz
-rw-r–r-- 1 root root 566 22 ago 16.30 qt5-webengine-5.15.10-2.1-aarch64.pkg.tar.xz.sig
-rw-r–r-- 1 root root 42M 10 set 08.19 qt5-webengine-5.15.10-3-aarch64.pkg.tar.xz
-rw-r–r-- 1 root root 566 10 set 08.19 qt5-webengine-5.15.10-3-aarch64.pkg.tar.xz.sig
-rw-r–r-- 1 root root 1,5M 24 ott 16.20 qt5-webengine-5.15.10-4-aarch64.pkg.tar.xz
-rw-r–r-- 1 root root 566 24 ott 16.20 qt5-webengine-5.15.10-4-aarch64.pkg.tar.xz.sig
pkg]$ sudo pacman -U qt5-webengine-5.15.10-2.1-aarch64.pkg.tar.xz
[sudo] password di alarm:
caricamento dei pacchetti in corso…
attenzione: installazione in corso di una versione meno recente del pacchetto qt5-webengine (5.15.10-4 => 5.15.10-2.1)
risoluzione delle dipendenze in corso…
ricerca dei pacchetti in conflitto in corso…
Pacchetti (1) qt5-webengine-5.15.10-2.1
Dimensione totale dei pacchetti da installare: 145,36 MiB
Dimensione netta dell’aggiornamento: 141,94 MiB
Also seems like the -3 has all the files.
Someone has posted on the ALARM forum about it too:
https://archlinuxarm.org/forum/viewtopic.php?f=15&t=16217
So lets hope they get it fixed at some point. Looks like qt6-webengine has the same issue.
qt5-webengine-5.15.11-1-aarch64 is the solution
