- I already have TLP installed and configured. Will the new power settings in gnome conflict with TLP or are they meant to be complimentary?
- Where can I find a list of the “selected devices” that support performance mode? (I can’t find it on their gitlab page)
Yes, TLP may conflict. If you want to use TLP, disable and mask the
power-profiles-daemonservice. -
See
Works. Thanks!
doesn’t appear to be on that page.
Basically, if you don’t have a Performance mode available, it’s not technically supported out of the box. However, you can force it to as he explains. There are also some issues there where it’s discussed.
