I’ve been gaming on Manjaro for nearly 2 months, it’s been great so far, most of my games run out of the box without glitches or performance issues, but a few of my games don’t launch at all or don’t work as expected.
Resident Evil 4 Ultimate HD Edition crashes before the Capcom logo shows up.
Need for Speed Hot Pursuit gets stuck in a black screen after the first screen with the car brand logos.
Hades gets stuck in a frame but the game keeps running.
Steam has many options and i wonder what would be best for compatibility, steam-manjaro or steam-native? Should i enable or disable the native runtime in Steam Linux runtime?
Also a few specific versions of Proton fails to launch: Proton 3.7, 3.16, 4.11, 5.0, Proton Experimental, and Steam Linux Runtime.
To attract some helpers it would be usful if you could provide some info about your system by posting output of
inxi -Fxxxza --no-host
mhwd -l
Also, post major steam and proton packages you are using. (Hint: pacman --help -Q)
Wollie:
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc
v: 10.2.0
root=UUID=88532919-1343-473d-b089-c8447abb7dab rw quiet
apparmor=1 security=apparmor
resume=UUID=a89900f1-77d3-460f-b07d-4aca199c2cf2
udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: SAMSUNG product: 550XBE/350XBE v: P10REU
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: SAMSUNG model: NP350XBE-KD1BR
v: SGL9970A0B-C01-G001-S0001+10.0.17763 serial: <filter>
UEFI: American Megatrends v: P10REU.088.200306.JJ
date: 03/06/2020
ID-1: BAT1 charge: 26.9 Wh condition: 35.3/43.1 Wh (82%)
volts: 11.8/11.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: Discharging cycles: 921
Info: Quad Core model: Intel Core i5-8265U bits: 64
type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: C (12) microcode: DE
L2 cache: 6 MiB
bogomips: 28808
Speed: 1600 MHz max: 1600 MHz Core speeds (MHz): 1: 1600
2: 1600 3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 1600
Type: spec_store_bypass mitigation: Speculative Store Bypass
disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and
__user pointer sanitization
Type: spectre_v2
mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: Samsung Co
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
Device-2: Silicon Motion Web Camera type: USB driver: uvcvideo
bus ID: 1-6:3 chip ID: 2232:1080 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: intel display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96
s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
v: 4.6 Mesa 20.3.1 direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Samsung Co driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:9dc8
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network
Adapter
vendor: Samsung Co driver: ath10k_pci v: kernel port: efa0
bus ID: 01:00.0 chip ID: 168c:0042
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Samsung Co driver: r8169 v: kernel port: 3000
bus ID: 02:00.0 chip ID: 10ec:8136
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-3: Qualcomm Atheros type: USB driver: btusb
bus ID: 1-7:4 chip ID: 0cf3:e500
IF-ID-1: vboxnet0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 447.24 GiB (48.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10SPZX-35Z10T0 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1A04
ID-1: / raw size: 922.42 GiB size: 906.94 GiB (98.32%)
used: 447.24 GiB (49.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 10 (default 60)
cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 1.4 MiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 48.0 C mobo: 48.0 C
Processes: 252 Uptime: 2h 09m wakeups: 2 Memory: 7.67 GiB
used: 3.48 GiB (45.4%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.0 Packages: 1731 pacman: 1721 lib: 525
flatpak: 4 snap: 6 Shell: Bash v: 5.1.0 running in: konsole
inxi: 3.2.01
Wollie:
mhwd -l
0000:00:02.0 (0300:8086:3ea0) Display controller Intel Corporation:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Wollie:
pacman --help -Q
libdbusmenu-qt5 0.9.3+16.04.20160218-5
libdc1394 2.2.6-2
libdca 0.0.7-1
libde265 1.0.8-1
libdmtx 0.7.5-2
libdrm 2.4.103-2
libdv 1.0.0-9
libdvbpsi 1:1.3.3-2
libdvdcss 1.4.2-2
libdvdnav 6.1.0-2
libdvdread 6.1.1-1
libe-book 0.1.3-7
libebml 1.4.0-1
libebur128 1.2.4-3
libedit 20191231_3.1-2
libelf 0.181-1
libepoxy 1.5.4-2
libepubgen 0.1.1-2
libetonyek 0.1.9-2
libevdev 1.10.0-1
libevent 2.1.12-1
libexif 0.6.22-1
libexttextcat 3.4.5-2
libfakekey 0.3-2
libfdk-aac 2.0.1-2
libffi 3.3-4
libfontenc 1.1.4-3
libfreehand 0.1.2-3
libftdi 1.5-1
libgcrypt 1.8.7-1
libgcrypt15 1.5.6-4
libgee 0.20.3-2
libgexiv2 0.12.1-3
libgit2 1:1.1.0-1
libglade 2.6.4-7
libglvnd 1.3.2-1
libgme 0.6.3-1
libgnomekbd 3.26.1+2+g8d02ebd-2
libgpg-error 1.39-1
libgphoto2 2.5.26-1
libgpod 0.8.3-11
libgrss 0.7.0+16+g971c421-3
libgsf 1.14.47-1
libgudev 234-1
libgusb 0.3.5-1
libgweather 3.36.1-1
libgxps 0.3.1-2
libheif 1.10.0-1
libibus 1.5.23+3+gaa558de8-1
libical 3.0.8-2
libice 1.0.10-3
libid3tag 0.15.1b-11
libidn 1.36-1
libidn11 1.33-2
libidn2 2.3.0-1
libiec61883 1.2.0-6
libieee1284 0.2.11-11
libimagequant 2.13.1-1
libimobiledevice 1.3.0-3
libindicator-gtk2 12.10.1-9
libindicator-gtk3 12.10.1-9
libinih 52-1
libinput 1.16.4-1
libinstpatch 1.1.5-1
libiptcdata 1.0.4-5
libixion 0.16.1-5
libjcat 0.1.4-1
libjpeg-turbo 2.0.6-1
libjpeg6-turbo 1.5.3-2
libkate 0.4.1-7
libkcddb 20.12.0-1
libkdcraw 20.12.0-1
libkdegames 20.12.0-1
libkexiv2 20.12.0-1
libkipi 20.12.0-1
libksane 20.12.0-1
libksba 1.4.0-2
libkscreen 5.20.4-1
libksysguard 5.20.4-1
libktorrent 20.12.0-1
liblangtag 0.6.3-2
liblastfm-qt5 1.0.9-5
libldac 2.0.2.3-1
libldap 2.4.56-1
liblouis 3.16.0-1
liblqr 0.4.2-3
liblrdf 0.6.1-4
libmad 0.15.1b-9
libmagick6 6.9.11.52-1
libmatroska 1.6.2-1
libmbim 1.24.4-1
libmfx 20.5.0-1
libmicrodns 0.2.0-1
libmicrohttpd 0.9.71-1
libmikmod 3.3.11.1-4
libmm-glib 1.14.8-1
libmms 0.6.4-3
libmng 2.0.3-3
libmnl 1.0.4-3
libmodplug 0.8.9.0-3
libmpc 1.1.0-2
libmpcdec 1:0.1+r475-3
libmpdclient 2.19-3
libmpeg2 0.5.1-7
libmspack 1:0.10.1alpha-3
libmspub 0.1.4-8
libmtp 1.1.18-1
libmusicbrainz5 5.1.0-4
libmwaw 0.3.17-1
libmygpo-qt5 1.1.0-3
libmypaint 1.5.1-2
libmythes 1:1.2.4-4
libnatpmp 20150609-3
libnautilus-extension 3.38.2-1
libndp 1.7-2
libnet 1:1.1.6-1
libnetfilter_conntrack 1.0.8-1
libnewt 0.52.21-5
libnfnetlink 1.0.1-4
libnfs 4.0.0-4
libnftnl 1.1.8-1
libnghttp2 1.41.0-1
libnice 0.1.18-1
libnl 3.5.0-2
libnm 1.26.4-1
libnm-glib 1.18.5dev+12+ga8746f48ca-1
libnotify 0.7.9-1
libnsl 1.3.0-1
libnumbertext 1.0.6-1
libodfgen 0.1.7-2
libofa 0.9.3-9
libogg 1.3.4-2
libomxil-bellagio 0.9.3-3
libopenaptx 0.2.0-1
liborcus 0.16.1-5
libosinfo 1.8.0-1
libp11-kit 0.23.22-1
libpackagekit-glib 1.1.13-1
libpagemaker 0.0.4-2
libpaper 1.1.28-1
libpcap 1.9.1-4
libpciaccess 0.16-2
libpgm 5.3.128-1
libpipeline 1.5.3-1
libpipewire02 0.2.7-1
libplacebo 2.72.2-1
libplist 2.2.0-3
libpng 1.6.37-3
libpng12 1.2.59-2
libproxy 0.4.16-1
libpsl 0.21.1-1
libpulse 14.0-1
libpwquality 1.4.4-3
libqaccessibilityclient 0.4.1-2
libqalculate 3.15.0-1
libqmi 1.26.6-1
libquvi 0.9.4-6
libquvi-scripts 0.9.20131130-5
libqxp 0.0.2-4
libraqm 0.7.1-1
libraw 0.20.2-1
libraw1394 2.1.2-3
libreoffice-still 6.4.7-7
libretro-bsnes 1:1201-1
libretro-core-info 1.9.0-1
libretro-genesis-plus-gx 1580-1
libretro-mesen 2903-1
libretro-overlays 174-1
libretro-shaders-slang 770-1
libretro-snes9x 1797-1
librevenge 0.0.4-3
librsvg 2:2.50.2-1
librtmp0 2.4-5
libsamplerate 0.1.9-3
libsasl 2.1.27-3
libseccomp 2.5.1-2
libsecret 0.20.4-1
libshout 1:2.4.4-1
libsidplay 1.36.59-10
libsidplayfp 2.0.2-1
libsigc++ 2.10.6-1
libslirp 4.4.0-1
libsm 1.2.3-2
libsmbios 2.4.3-3
libsndfile 1.0.28-3
libsodium 1.0.18-2
libsoup 2.72.0+5+g0b094bff-3
libsoxr 0.1.3-2
libspectre 0.2.9-2
libspeechd 0.10.2-1
libspiro 1:20200505-2
libsrtp 1:2.3.0-1
libssh 0.9.5-1
libssh2 1.9.0-2
libstaroffice 0.0.7-1
libstemmer 0+713-2
libtar 1.2.20-5
libtasn1 4.16.0-1
libteam 1.31-2
libthai 0.1.28-2
libtheora 1.1.1-5
libtiff 4.1.0-2
libtiff4 3.9.7-5
libtirpc 1.3.1-1
libtommath 1.2.0-3
libtool 2.4.6+42+gb88cebd5-14
libtorrent 0.13.8-2
libtorrent-rasterbar 1:1.2.10-7
libudev0-shim 1-4
libuninameslist 20200413-2
libunistring 0.9.10-3
libunwind 1.3.1-2
libupnp 1.14.0-1
liburing 0.7-2
libusb 1.0.23-3
libusb-compat 0.1.7-1
libusbmuxd 2.0.2-1
libutempter 1.2.1-1
libutf8proc 2.6.1-1
libuv 1.40.0-1
libva 2.10.0-1
libva-intel-driver 2.4.1-1
libva-mesa-driver 20.3.1-1
libva-vdpau-driver 0.7.4-5
libvdpau 1.4-1
libvirt 1:6.5.0-3
libvirt-glib 3.0.0-2
libvirt-python 1:6.4.0-3
libvisio 0.1.7-3
libvisual 0.4.0-8
libvorbis 1.3.7-2
libvpx 1.9.0-1
libvpx1.3 1.3.0-3
libwacom 1.7-1
libwebp 1.1.0-1
libwmf 0.2.12-2
libwpd 0.10.3-2
libwpe 1.8.0-1
libwpg 0.3.3-2
libwps 0.4.12-1
libwrap 7.6.28-2
libx11 1.7.0-2
libx86emu 3.1-1
libxau 1.0.9-3
libxaw 1.0.13-3
libxcb 1.14-1
libxcomposite 0.4.5-3
libxcrypt 4.4.17-1
libxcursor 1.2.0-2
libxdamage 1.1.5-3
libxdmcp 1.1.3-3
libxext 1.3.4-3
libxfce4ui 4.14.1-3.1
libxfce4util 4.14.0-2
libxfixes 5.0.3-4
libxfont2 2.0.4-3
libxft 2.3.3-2
libxi 1.7.10-3
libxinerama 1.1.4-3
libxkbcommon 1.0.3-1
libxkbcommon-x11 1.0.3-1
libxkbfile 1.1.0-2
libxklavier 5.4-3
libxml2 2.9.10-7
libxmlb 0.2.1-1
libxmu 1.1.3-2
libxnvctrl 455.45.01-1
libxpm 3.5.13-2
libxrandr 1.5.2-3
libxrender 0.9.10-4
libxres 1.2.0-2
libxshmfence 1.3-2
libxslt 1.1.34-5
libxss 1.2.3-3
libxt 1.2.0-2
libxtst 1.2.3-4
libxv 1.0.11-4
libxvmc 1.0.12-3
libxxf86vm 1.1.4-4
libyaml 0.2.5-1
libzip 1.7.3-1
libzmf 0.0.2-8
licenses 20200427-1
lilv 0.24.10-3
linux-api-headers 5.8-1
linux-firmware 20201218.r1803.646f159-1
linux-latest 5.10-1
linux-latest-acpi_call 5.10-1
linux-latest-virtualbox-host-modules 5.10-1
linux-steam-integration 0.7.3-5
linux510 5.10.2-2
linux510-acpi_call 1.1.0-8
linux510-virtualbox-host-modules 6.1.16-8
linux59 5.9.16-1
linux59-acpi_call 1.1.0-15
linux59-virtualbox-host-modules 6.1.16-14
lirc 1:0.10.1-8
lld 11.0.0-1
llvm-libs 11.0.0-4
lm_sensors 3.6.0-2
lmdb 0.9.27-1
logrotate 3.17.0-1
lpsolve 5.5.2.5-4
lsb-release 1.4-13
lsof 4.94.0-1
lsp-plugins 1.1.28-1
lua52 5.2.4-5
lua52-bitop 1.0.2-9
lua52-expat 1.3.0-5
lua52-lpeg 1.0.2-3
lua52-luajson 1.3.4-3
lua52-socket 20200329-1
luajit 2.0.5-3
luit 20201003-1
lutris 0.5.8.1-1
lvm2 2.02.187-3
lz4 1:1.9.3-1
lzo 2.10-3
m4 1.4.18-3
mailcap 2.1.49-1
make 4.3-3
man-db 2.9.3-1
man-pages 5.09-2
mangohud 0.6.1-2
mangohud-common 0.6.1-2
manjaro-alsa 20200126-1
manjaro-application-utility 1.3.3-4.1
manjaro-base-skel 20171029-3
manjaro-browser-settings 20201114-1
manjaro-documentation-en 20181009-1
manjaro-firmware 20160419-1
manjaro-hello 0.6.6-4
manjaro-hotfixes 2018.08-6
manjaro-icons 20191015-1
manjaro-kde-settings 20200804-1
manjaro-keyring 20201216-1
manjaro-pulse 20200126-1
manjaro-release 20.2-1
manjaro-settings-manager 0.5.6-10
manjaro-settings-manager-kcm 0.5.6-10
manjaro-settings-manager-knotifier 0.5.6-10
manjaro-system 20210101-3
manjaro-wallpapers-18.0 1.4-3
manjaro-zsh-config 0.18-1
mariadb-libs 10.5.8-1
mbedtls 2.16.7-1
md4c 0.4.6-1
mdadm 4.1-2
media-player-info 24-2
memtest86+ 5.01-4
mesa 20.3.1-1
mesa-demos 8.4.0-4
mesa-vdpau 20.3.1-1
meson 0.56.0-3
metis 5.1.0.p10-1
mhwd 0.6.5-2
mhwd-amdgpu 19.1.0-1
mhwd-ati 19.1.0-1
mhwd-db 0.6.5-7
mhwd-nvidia 455.45.01-3
mhwd-nvidia-340xx 340.108-1
mhwd-nvidia-390xx 390.138-1
milou 5.20.4-1
mingw-w64-binutils 2.35.1-1
mingw-w64-crt 8.0.0-1
mingw-w64-gcc 10.2.0-2
mingw-w64-headers 8.0.0-1
mingw-w64-winpthreads 8.0.0-1
miniupnpc 2.1.20191224-3
minizip 1:1.2.11-4
mjpegtools 2.1.0-5
mkinitcpio 29-1.0
mkinitcpio-busybox 1.31.1-2
mkinitcpio-openswap 0.1.0-3
mobile-broadband-provider-info 20190618-2
modemmanager 1.14.8-1
modemmanager-qt 5.77.0-1
mpd 0.22.3-1
mpfr 4.1.0-1
mpg123 1.26.3-2
mplayer 38157-3
mtdev 1.1.6-1
mtpfs 1.1-4
mypaint-brushes1 1.3.1-1
mythes-en 20060306-5
nano 5.4-1
nasm 2.15.05-1
nautilus 3.38.2-1
ncurses 6.2-1
ndctl 71-1
neon 0.31.2-1
nerd-fonts-noto-sans-mono 2.0.0-1
net-snmp 5.9-3
net-tools 1.60.20181103git-2
netpbm 10.73.33-1
nettle 3.6-1
networkmanager 1.26.4-1
networkmanager-openconnect 1.2.7dev+49+gc512d5a-1
networkmanager-openvpn 1.8.12-1
networkmanager-pptp 1.2.9dev+10+gb41b0d0-2
networkmanager-qt 5.77.0-1
networkmanager-vpnc 1.2.7dev+20+gdca3aea-2
nfs-utils 2.5.2-2
nfsidmap 2.5.2-2
ninja 1.10.2-1
node-gyp 7.1.1-1
nodejs 15.4.0-1
noto-fonts 20201206-1
noto-fonts-cjk 20201206-1
noto-fonts-compat 20151217-1
noto-fonts-emoji 20200916-1
npm 6.14.9-1
npth 1.6-2
nspr 4.29-1
nss 3.60-1
nss-mdns 0.14.1-3
ntfs-3g 2017.3.23-5
ntp 4.2.8.p15-1
numactl 2.0.14-1
numlockx 1.2-5
nvidia-cg-toolkit 3.1-6
oath-toolkit 2.6.4-1
ocl-icd 2.2.13-1
openal 1.21.0-1
openbsd-netcat 1.217_2-1
opencl-headers 2:2020.06.16-1
openconnect 1:8.10-1
opencore-amr 0.1.5-5
openexr 2.5.3-5
openjpeg2 2.3.1-3
openmpi 4.0.5-2
openresolv 3.11.0-1
openssh 8.4p1-2
openssl 1.1.1.i-2
openssl-1.0 1.0.2.u-1
openvpn 2.5.0-3
opus 1.3.1-2
opusfile 0.12-1
orc 0.4.32-1
os-prober 1.77-1
osinfo-db 20201015-1
ostree 2020.8-1
oxygen 5.20.4-1
oxygen-icons 1:5.77.0-1
p11-kit 0.23.22-1
p7zip 16.02-6
p8-platform 2.1.0.1-4
packagekit 1.1.13-1
packagekit-qt5 1.0.2-1
pacman 5.2.2-3
pacman-mirrors 4.19.1-1
pam 1.5.0-2
pamac-cli 10.0.3-4
pamac-common 10.0.3-4
pamac-flatpak-plugin 10.0.3-4
pamac-gtk 10.0.3-4
pamac-snap-plugin 10.0.3-4
pamac-tray-icon-plasma 0.1.2-2
pambase 20200721.1-2
pango 1:1.48.0-1
pangomm 2.42.2-1
parole 1.0.5-1
parted 3.3-2
partitionmanager 20.12.0-1
patch 2.7.6-8
patchutils 0.4.2-1
pavucontrol 1:4.0-2
pciutils 3.7.0-1
pcre 8.44-1
pcre2 10.36-1
pcsclite 1.9.0-1
pcsx2 1.7.0.r686.03445d0b5-1
perl 5.32.0-3
perl-alien-build 2.37-1
perl-alien-libxml2 0.17-1
perl-cairo-gobject 1.004-10
perl-capture-tiny 0.48-4
perl-clone 0.45-2
perl-dbi 1.643-2
perl-encode-locale 1.05-7
perl-error 0.17029-2
perl-ffi-checklib 0.27-2
perl-file-basedir 0.08-5
perl-file-chdir 0.1011-4
perl-file-desktopentry 0.22-7
perl-file-listing 6.11-1
perl-file-mimeinfo 0.30-1
perl-file-which 1.23-4
perl-glib-object-introspection 0.047-5
perl-gtk3 0.037-1
perl-html-parser 3.75-1
perl-html-tagset 3.20-10
perl-http-cookies 6.09-1
perl-http-daemon 6.06-2
perl-http-date 6.05-3
perl-http-message 6.26-1
perl-http-negotiate 6.01-8
perl-io-html 1.004-1
perl-io-socket-ssl 2.067-2
perl-ipc-system-simple 1.30-2
perl-json 2.97001-2
perl-libwww 6.50-1
perl-locale-gettext 1.07-10
perl-lwp-mediatypes 6.02-8
perl-lwp-protocol-https 6.10-1
perl-mailtools 2.21-4
perl-net-http 6.19-4
perl-net-ssleay 1.88-2
perl-parse-yapp 1.21-3
perl-path-tiny 0.114-1
perl-text-csv 1.97-4
perl-timedate 2.33-2
perl-try-tiny 0.30-5
perl-uri 5.05-1
perl-www-robotrules 6.02-8
perl-xml-libxml 2.0206-1
perl-xml-namespacesupport 1.12-4
perl-xml-parser 2.46-2
perl-xml-sax 1.02-1
perl-xml-sax-base 1.09-4
perl-xml-writer 0.625-6
phodav 2.5-1
phonon-qt5 4.11.1-2
phonon-qt5-gstreamer 4.10.0-2
pinentry 1.1.0-5
pipewire 0.3.18-1
pixman 0.40.0-1
pkcs11-helper 1.27.0-1
pkgconf 1.7.3-1
pkgfile 21-2
plasma-browser-integration 5.20.4-1
plasma-desktop 5.20.4-2
plasma-framework 5.77.0-2
plasma-integration 5.20.4-1
plasma-nm 5.20.4-1
plasma-pa 5.20.4-1
plasma-simplemenu 1.0.12-1
plasma-wayland-session 5.20.4-1
plasma-workspace 5.20.4-1
plasma-workspace-wallpapers 5.20.4-1
plasma5-themes-breath2 1.0.10-2
polkit 0.118-1
polkit-kde-agent 5.20.4-1
polkit-qt5 0.113.0-2
poppler 20.12.1-1
poppler-data 0.4.10-1
poppler-glib 20.12.1-1
poppler-qt5 20.12.1-1
popt 1.18-1
portaudio 1:19.6.0-7
potrace 1.16-2
powerdevil 5.20.4-1
powertop 2.13-1
ppp 2.4.7-7
ppsspp 1.10.3-1
pptpclient 1.10.0-2
preload 0.6.4-1
print-manager 20.12.0-1
prison 5.77.0-1
procps-ng 3.3.16-2
projectm 3.1.7-1
properties-cpp 0.0.2-4
protobuf 3.12.4-3
psmisc 23.3-2
pugixml 1.11.3-1
pulseaudio 14.0-1
pulseaudio-alsa 1:1.2.2-2
pulseaudio-ctl 1.67-1
pulseaudio-equalizer 14.0-1
pulseaudio-equalizer-ladspa 3.0.2-4
pulseaudio-jack 14.0-1
pulseaudio-lirc 14.0-1
pulseaudio-qt 1.2-2
pulseaudio-zeroconf 14.0-1
purpose 5.77.0-1
pychess 1.0.2-2
pygtk 2.24.0-14
pyside2 5.15.2-2
python 3.9.1-1
python-anytree 2.8.0-3
python-apipkg 1.5-5
python-appdirs 1.4.4-3
python-argcomplete 1.12.1-1
python-asn1crypto 1.4.0-3
python-attrs 20.3.0-3
python-autobahn 20.12.3-1
python-automat 20.2.0-4
python-beaker 1.11.0-6
python-brotli 1.0.9-4
python-cachecontrol 0.12.6-3
python-cairo 1.20.0-3
python-cffi 1.14.4-1
python-chardet 3.0.4-7
python-click 7.1.2-3
python-colorama 0.4.4-3
python-constantly 15.1.0-8
python-contextlib2 0.6.0.post1-3
python-coverage 5.3.1-1
python-cryptography 3.3.1-1
python-dateutil 2.8.1-5
python-dbus 1.2.16-3
python-dbus-common 1.2.16-3
python-decorator 4.4.2-3
python-distlib 0.3.1-2
python-distro 1.5.0-3
python-docopt 0.6.2-9
python-evdev 1.3.0-3
python-filelock 3.0.12-5
python-fontpens 0.2.4-1
python-fonttools 4.16.1-3
python-fs 2.4.11-3
python-gobject 3.38.0-3
python-html5lib 1.1-5
python-hyperlink 20.0.1-3
python-idna 2.10-3
python-importlib-metadata 3.3.0-1
python-incremental 17.5.0-6
python-iniconfig 1.1.1-1
python-jade-application-kit 3.5.6-3
python-jinja 2.11.2-4
python-keyutils 0.6-6
python-lxml 4.6.2-1
python-mako 1.1.3-3
python-markupsafe 1.1.1-6
python-mock 3.0.5-5
python-more-itertools 8.6.0-3
python-msgpack 1.0.0-3
python-nose 1.3.7-10
python-npyscreen 4.10.5-5
python-ordered-set 4.0.2-3
python-packaging 20.7-1
python-pbr 5.5.1-3
python-pep517 0.9.1-3
python-pexpect 4.8.0-3
python-pillow 8.0.1-3
python-pip 20.2.2-1
python-pipx 0.15.6.0-2
python-pluggy 0.13.1-4
python-ply 3.11-7
python-progress 1.5-5
python-psutil 5.7.3-3
python-ptyprocess 0.6.0-6
python-py 1.9.0-3
python-pycparser 2.20-3
python-pycups 2.0.1-3
python-pycurl 7.43.0.6-4
python-pygments 2.7.3-1
python-pyhamcrest 1.9.0-7
python-pyjwt 1.7.1-6
python-pyopenssl 20.0.1-1
python-pyparsing 2.4.7-3
python-pypubsub 4.0.3-3
python-pyqt5 5.15.2-2
python-pyqt5-sip 12.8.1-3
python-pyqtwebengine 5.15.2-2
python-pysmbc 1.0.23-2
python-pysocks 1.7.1-3
python-pytest 6.1.2-3
python-pytest-runner 5.2-3
python-pytz 2020.4-4
python-pyxdg 0.26-8
python-qtpy 1.9.0-5
python-reportlab 3.5.56-1
python-requests 2.25.1-1
python-resolvelib 0.5.3-1
python-retrying 1.3.3-9
python-setuptools 1:51.0.0-1
python-setuptools-scm 5.0.1-1
python-shiboken2 5.15.2-2
python-sip 4.19.24-4
python-six 1.15.0-3
python-sqlalchemy 1.3.20-3
python-sqlalchemy-migrate 0.13.0-6
python-sqlparse 0.4.1-3
python-tempita 1:0.5.2-3
python-toml 0.10.2-3
python-twisted 20.3.0-3
python-txaio 20.12.1-1
python-unicodedata2 13.0.0.post2-2
python-urllib3 1.25.10-4
python-userpath 1.4.1-3
python-virtualenv 20.2.2-1
python-webencodings 0.5.1-6
python-websockets 8.1-3
python-wheel 0.36.2-1
python-wsaccel 0.6.3-2
python-wxpython 4.0.7.2-5
python-yaml 5.3.1-4
python-zipp 3.4.0-3
python-zope-interface 5.2.0-3
python-zopfli 0.1.7-3
python2 2.7.18-2
python2-appdirs 1.4.4-3
python2-cairo 1.18.2-4
python2-gobject2 2.28.7-6
python2-ordered-set 3.1.1-3
python2-packaging 20.7-1
python2-pillow 6.2.1-3
python2-pybluez 0.22-6
python2-pycryptodomex 3.9.9-1
python2-pyparsing 2.4.7-3
python2-setuptools 2:44.1.1-1
python2-simplejson 3.17.2-3
python2-six 1.15.0-3
python2-xcb-proto 1.14-1
qbittorrent 4.3.1-1
qca 2.3.1-4
qemu 5.2.0-2
qgpgme 1.15.0-2
qpdf 10.0.4-1
qqc2-desktop-style 5.77.0-1
qrencode 4.1.1-1
qt5-base 5.15.2-1
qt5-declarative 5.15.2-1
qt5-graphicaleffects 5.15.2-1
qt5-imageformats 5.15.2-1
qt5-location 5.15.2-1
qt5-multimedia 5.15.2-1
qt5-quickcontrols 5.15.2-1
qt5-quickcontrols2 5.15.2-1
qt5-script 5.15.2-1
qt5-sensors 5.15.2-1
qt5-speech 5.15.2-1
qt5-svg 5.15.2-1
qt5-tools 5.15.2-1
qt5-translations 5.15.2-1
qt5-virtualkeyboard 5.15.2-1
qt5-wayland 5.15.2-1
qt5-webchannel 5.15.2-1
qt5-webengine 5.15.2-2
qt5-webkit 5.212.0alpha4-8
qt5-x11extras 5.15.2-1
qt5-xmlpatterns 5.15.2-1
qt5pas 2.6.r63484-2
quazip 1.1-1
raptor 2.0.15-14
rasqal 1:0.9.33-4
rav1e 0.3.4-1
re2 1:20201101-1
readline 8.1.0-2
recode 3.7.8-1
redland 1:1.0.17-8
reiserfsprogs 3.6.27-3
rest 0.8.1-3
retroarch 1.9.0-1
retroarch-assets-ozone 1:350-1
retroarch-assets-xmb 1:350-1
rhash 1.4.0-1
ripgrep 12.1.1-1
rpcbind 1.2.5-3
rsync 3.2.3-1
rtkit 0.13-1
rtmpdump 1:2.4.r96.fa8646d-6
ruby 2.7.2-1
ruby-irb 1.2.7-1
ruby-reline 0.1.6-1
rubygems 3.1.4-1
run-parts 4.8.6.1-2
s-nail 14.9.19-2
samba 4.13.3-1
sane 1.0.31-3
sbc 1.5-1
schedtool 1.3.0-7
screenfetch 3.9.1-1
sddm 0.19.0-2.3
sddm-breath2-theme 1.0.10-2
sddm-kcm 5.20.4-1
sdl 1.2.15-14
sdl2 2.0.12-3
sdl2_image 2.0.5-2
sdl2_mixer 2.0.4-5
sdl2_ttf 2.0.15-2
sdl_image 1.2.12-7
sdl_mixer 1.2.12-8
sdl_ttf 2.0.11-6
seabios 1.14.0-1
sed 4.8-1
semver 7.3.4-1
serd 0.30.6-1
serf 1.3.9-5
sfml 2.5.1-2
sg3_utils 1.45-1
shaderc 2020.3-1
shadow 4.8.1-4
shared-mime-info 2.0+1+g6bf9e4f-2
signon-kwallet-extension 20.12.0-1
signon-plugin-oauth2 0.25-1
signon-ui 0.17+20171022-2
signond 8.60-3
skanlite 2.2.0-1
slang 2.3.2-2
smartmontools 7.1-4
smbclient 4.13.3-1
smpeg 0.4.5-5
snapd 2.48.2-1
snapd-glib 1.54-1
snappy 1.1.8-2
socat 1.7.3.4-2
software-center-web-jak 1.0.2-1
solid 5.77.0-1
sonnet 5.77.0-1
sord 0.16.6-1
sound-theme-freedesktop 0.8-4
soundtouch 2.2-1
source-highlight 3.1.9-4
spandsp 0.0.6-3
spectacle 20.12.0-1
spectre-meltdown-checker 0.43-1
speex 1.2.0-3
speexdsp 1.2.0-2
spice 0.14.3-3
spice-gtk 0.38-1
spirv-tools 2020.4-1
splix 2.0.0-15
spotify 1:1.1.42.622-2
sqlite 3.34.0-1
squashfs-tools 4.4-2
squashfuse 0.1.103-3
sratom 0.6.6-1
srt 1.4.2-1
sshfs 3.7.1-1
startup-notification 0.12-7
steam-manjaro 1.0.0.68-1
steam-native 1.0.0.62-5
stoken 0.92-4
subversion 1.14.0-4
sudo 1.9.4.p2-2
suitesparse 5.8.1-1
svt-hevc 1.5.0-1
swh-plugins 0.4.17-4
syntax-highlighting 5.77.0-1
sysfsutils 2.1.0-11
system-config-printer 1.5.13-4
systemd 247.2-1
systemd-fsck-silent 239-1
systemd-kcm 1.2.1-5
systemd-libs 247.2-1
systemd-sysvcompat 247.2-1
systemsettings 5.20.4-1
taglib 1.11.1-4
talloc 2.3.1-5
tar 1.32-3
tbb 2020.3-1
tcl 8.6.10-2
tdb 1.4.3-4
teamviewer 15.13.6-1
terminus-font 4.48-3
tevent 1:0.10.2-3
texinfo 6.7-3
thin-provisioning-tools 0.9.0-1
threadweaver 5.77.0-1
timeshift 20.11.1.r3.g08d0e59-2
tinyxml 2.6.2-7
tlp 1.3.1-2
tlpui 1.3.1-2
totem-pl-parser 3.26.5-1
tpm2-tss 3.0.3-1
tracker3 3.0.2-1
tracker3-miners 3.0.3-1
transcode 1.1.7-35
tslib 1.22-1
ttf-bitstream-vera 1.10-14
ttf-droid 20121017-8
ttf-hack 3.003-3
ttf-inconsolata 1:3.000-2
ttf-indic-otf 0.2-11
ttf-liberation 2.1.2-1
twolame 0.4.0-2
tzdata 2020d-1
udiskie 2.2.0-3
udisks2 2.9.1-1
ufw 0.36-5
uget 2.2.3-1
unarchiver 1.10.7-1
unzip 6.0-14
upower 0.99.11-3
usb_modeswitch 2.6.1-1
usbmuxd 1.1.1-1
usbredir 0.8.0-2
usbutils 013-1
util-linux 2.36.1-4
util-linux-libs 2.36.1-4
v4l-utils 1.20.0-1
v86d 0.1.10-5.1
vala 0.50.2-1
vcdimager 2.0.1-4
vde2 2.3.2-16
vi 1:070224-4
vid.stab 1.1-3
virglrenderer 0.8.2-1
virt-install 3.2.0-1
virt-manager 3.2.0-1
virtualbox 6.1.16-3
virtualbox-guest-iso 6.1.16-1
vivaldi 3.5.2115.81-1
vivaldi-ffmpeg-codecs 87.0.4280.88-2
vkd3d 1.2-1
vlc 3.0.11.1-6
vmaf 1.5.3-1
volume_key 0.3.12-5
vpnc 1:0.5.3.r468.r81-2
vte-common 0.62.1-1
vte3 0.62.1-1
vulkan-extra-layers 1.2.154.0-1
vulkan-extra-tools 1.2.154.0-1
vulkan-headers 1:1.2.164-1
vulkan-icd-loader 1.2.162-1
vulkan-intel 20.3.1-1
vulkan-mesa-layers 20.3.1-1
vulkan-radeon 20.3.1-1
vulkan-tools 1.2.162-1
vulkan-validation-layers 1.2.162-1
wallpapers-2018 1.2-1
wallpapers-juhraya 1.1-2
wavpack 5.3.0-1
wayland 1.18.0-2
wayland-protocols 1.20-1
web-installer-url-handler 1.0.2-1
webkit2gtk 2.30.4-1
webrtc-audio-processing 0.3.1-2
wget 1.20.3-3
which 2.21-5
wildmidi 0.4.3-3
wine 5.22-1
wine-gecko 2.47.1-1
wine-gecko-bin 2.47.1-1
wine-mono 5.1.1-1
wine-nine 0.7-1
winetricks 20201206-1
wireless-regdb 2020.04.29-1
wmctrl 1.07-6
woeusb 3.3.1-2
woff2 1.0.2-3
wpa_supplicant 2:2.9-7
wpebackend-fdo 1.8.0-1
wxgtk-common 3.0.5.1-1
wxgtk2 3.0.5.1-1
wxgtk3 3.0.5.1-1
x264 3:0.160.r3011.cde9a93-1
x265 3.4-1
x86_energy_perf_policy 5.10-2
xapian-core 1:1.4.17-2
xapp 2.0.4-1
xbitmaps 1.1.2-2
xcb-proto 1.14.1-3
xcb-util 0.4.0-3
xcb-util-cursor 0.1.3-3
xcb-util-image 0.4.0-3
xcb-util-keysyms 0.4.0-3
xcb-util-renderutil 0.3.9-3
xcb-util-wm 0.4.1-3
xdg-dbus-proxy 0.1.2-2
xdg-desktop-portal 1.8.0-1
xdg-desktop-portal-kde 5.20.4-1
xdg-user-dirs 0.17-3
xdg-utils 1.1.3+19+g9816ebb-1
xf86-input-elographics 1.4.2-2
xf86-input-evdev 2.10.6-2
xf86-input-libinput 0.30.0-1
xf86-input-void 1.4.1-5
xf86-video-amdgpu 19.1.0-2
xf86-video-ati 1:19.1.0-2
xf86-video-intel 1:2.99.917+913+g9236c582-1
xf86-video-nouveau 1.0.16-2
xfconf 4.14.4-1
xfsprogs 5.8.0-1
xkeyboard-config 2.31-1
xmlsec 1.2.31-1
xorg-fonts-encodings 1.0.5-2
xorg-server 1.20.10-3
xorg-server-common 1.20.10-3
xorg-setxkbmap 1.3.2-2
xorg-twm 1.0.11-1
xorg-xauth 1.1-2
xorg-xdpyinfo 1.3.2-4
xorg-xhost 1.0.8-2
xorg-xinit 1.4.1-3
xorg-xkbcomp 1.4.4-1
xorg-xkill 1.0.5-2
xorg-xmessage 1.0.5-2
xorg-xmodmap 1.0.10-2
xorg-xprop 1.2.5-1
xorg-xrandr 1.5.1-2
xorg-xrdb 1.2.0-2
xorg-xset 1.2.4-2
xorg-xsetroot 1.1.2-2
xorg-xwayland 1.20.0.r800.ge4a9f0bb4-1
xorgproto 2020.1-1
xterm 362-1
xvidcore 1.3.7-2
xxhash 0.8.0-1
xz 5.2.5-1
yajl 2.1.0-4
yaml-cpp 0.6.3-2
yelp 3.38.2-1
yelp-xsl 3.38.2-1
zbar 0.23.1-5
zenity 3.32.0+55+gd7bedff-1
zensu 0.3-1
zeromq 4.3.3-2
zip 3.0-9
zita-alsa-pcmi 0.3.2-3
zita-convolver 4.0.3-2
zita-resampler 1.6.2-3
zlib 1:1.2.11-4
zsh 5.8-1
zsh-autosuggestions 0.6.4-1
zsh-completions 0.32.0-1
zsh-history-substring-search 1.0.2-1
zsh-syntax-highlighting 0.7.1-1
zsh-theme-powerlevel10k 1.14.5-1
zstd 1.4.5-1
zvbi 0.2.35-4
zxing-cpp 1.1.1-1
zziplib 0.13.71-1
OK, that’s more than I wanted to see
With pacman --help -Q you should normally see the options for using this command to then limit the output to steam or proton related packages.
pacman -Qs {search term}
where {search term} has to be replaced by steam or proton for example. Anyway, info is given now.
Wollie:
pacman -Qs
local/game-devices-udev 0.10-1
Udev rules for controllers
local/linux-steam-integration 0.7.3-5
Helper for enabling better Steam integration on Linux
local/steam-manjaro 1.0.0.68-1
Valve’s digital software delivery system
local/steam-native 1.0.0.62-5
Native replacement for the Steam runtime
Wollie:
The more info you get the better i guess
OK, now let’s wait for gamers (I am not) but I think you gave now valuable info to help you. Good luck!
I wonder where the gamers went to cuz they haven’t come yet
Im no expert so excuse me if I’m wrong. It looks like you don’t have a dedicated gpu only an intel chip with intergrated graphics? I would have thought graphic intensive games are going to struggle on intergrated graphics. I have a msi stealth pro with i7 and dedicated graphics, if I try and run steam games on the intergrated graphics most of them crash
sawdoctor:
None of my games are too demanding for my hardware, these games used to run perfectly in my Windows 10, my hardware is not the issue because it’s well above the recommended requirements for these games, despite my gpu being integrated it is an 8th gen chip and it can handle my games better than my good old Xbox 360 slim, also Steam Proton requires a gpu with Vulkan support which explains why your integrated gpu crashes while mine doesn’t
Sorry just read its 8th gen so should be able to run vulkan. Have you tried launching the games with lutris see if that helps or launching steam through terminal and seeing if there’s any logs
My hardware is from 2018, and my gpu does support Vulkan, i run all of my games in DXVK without any issues
Just edited my above post sorry. Like I said if you use terminal or lutris you should be able to get a log when the game crashes
Lutris doesn’t work either, and i don’t understand a single line of these logs, also i don’t know how those logs would help, i have already tried multiple Proton and Proton GE versions none of them worked, i’m not sure those logs would bring a solution for these issues
Could you explain how the logs could help? Do they have any kind of vital information that could help troubleshoot these issues?
If you can get a log from when the game/steam crash and upload it im sure someone will understand it. Lutris will give you a real time log while the game is running. I’m not an expert but I always look for error or fatal in logs and see if I can find what caused it
Hanzel
6 January 2021 20:46
18
Not a avid gamer, but do run some games through steam/lutris. When having problems I lookup the game in protondb, check the lutris forums, use the lutris logs and look there for hints to solve the problem.
For resident evil 4 there seems to be a few solutions for your problem have you tried those solutions?
Need for Speed Hot Pursuit all have green thumbs from people running an older kernel
Maybe try an older stable kernel and see if that does anything?
I’m not sure the older kernels would work well, when i used 5.4 LTS my system would freeze randomly, also can you tell me how the kernel version affects the games?
Hanzel
6 January 2021 23:10
20
I’m not sure either if it will work, just trying to give you options to try to pursue to solve your issue and thinking with you.
