I am using this on a usb drive that I am going to turn into a security and pen testing usb.
I added a repository with ArchStrike packages on it to start with.
I have one question. I am not finding how to change the login screen resolution. On my laptop it is very small text and login box. I would like to change the resolution to something like 1024x768.
What file is that setting in?
Also sound is not setup correctly. It is showing my HDMI but not my main sound.
Thanks
[demo@manjaro-live ~]$ inxi -Fxyzr
Kernel: 5.15.24-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: LXQt 1.0.0 Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required>
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.26 date: 07/09/2021
ID-1: BAT0 charge: 53.1 Wh (79.0%) condition: 67.2/67.2 Wh (100.0%)
volts: 12.3 min: 11.6 model: HP Primary status: N/A
Device-1: hid-0018:04F3:2992.0001-battery model: ELAN2514:00 04F3:2992
charge: N/A status: N/A
Info: quad core model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB L2: 1024 KiB
L3: 8 MiB
Speed (MHz): avg: 799 high: 800 min/max: 400/4900 cores: 1: 800 2: 800
3: 799 4: 800 5: 800 6: 800 7: 800 8: 800 bogomips: 36812
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nouveau v: kernel bus-ID: 3b:00.0
Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2
Display: x11 server: X.org 1.21.1.3 driver: loaded: modesetting
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.15.24-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: no
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
Local Storage: total: 960.81 GiB used: 7.84 GiB (0.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB temp: 36.9 C
ID-2: /dev/sda type: USB vendor: SMI (STMicroelectronics) model: USB
ID-1: / size: 28.38 GiB used: 7.84 GiB (27.6%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/sda1
System Temperatures: cpu: 47.0 C pch: 44.0 C mobo: N/A
Packages: 767
Active pacman repo servers in: /etc/pacman.conf
1: https://mirror.archstrike.org/$arch/$repo
Active pacman repo servers in: /etc/pacman.d/archstrike-mirrorlist
2: http://mirror.keystealth.org/archstrike/$arch/$repo
3: http://mirror.i3d.net/pub/archstrike/$arch/$repo
4: http://www.mirrorservice.org/sites/mirror.archstrike.org/$arch/$repo
5: https://www.mirrorservice.org/sites/mirror.archstrike.org/$arch/$repo
6: https://mirror.umd.edu/archstrike/$arch/$repo
7: http://mirrors.dotsrc.org/archstrike/$arch/$repo
8: http://mirror.layerjet.com/archstrike/$arch/$repo
9: http://ftp.acc.umu.se/mirror/archstrike.org/$arch/$repo
10: https://ftp.acc.umu.se/mirror/archstrike.org/$arch/$repo
11: https://ftp.yzu.edu.tw/Linux/archstrike/$arch/$repo
12: http://mirror.team-cymru.com/archstrike/$arch/$repo
13: https://mirror.aarnet.edu.au/pub/archstrike/archstrike/$arch/$repo
14: http://mirror.stro.nz/archstrike/$arch/$repo
15: https://mirror.cedia.org.ec/archstrike/$arch/$repo
16: https://mirror.uce.edu.ec/archstrike/$arch/$repo
17: https://mirror.epn.edu.ec/archstrike/$arch/$repo
18: http://archstrike.outerworld.org/$arch/$repo
19: https://archstrike.unixpeople.org/$arch/$repo
1: https://mirrors.manjaro.org/repo/unstable/$repo/$arch
2: https://manjaro.moson.eu/unstable/$repo/$arch
3: https://mirror.easyname.at/manjaro/unstable/$repo/$arch
Processes: 222 Uptime: 8h 33m Memory: 15.27 GiB used: 3.2 GiB (20.9%)
Init: systemd Compilers: gcc: 11.2.0 Shell: Bash v: 5.1.16 inxi: 3.3.12
