Questions about Dolphin file manager
  1. Is it possible to exclude search terms? Like -word filtering out items that contain “word”.
  2. Is it possible to list every file in the directory and sub-folders? On Windows you can put * (asterisk) in the search bar and it will do that.
I don’t know about excluding, but to get a list of files and directories I would use Kfind there is a button to the right of Dolphins search, under “More options” Also here is some basic hints Quick Tips
Ok I figured out the second one, you just press enter on an empty search bar. However, it only seems to work in folders indexed in File Search settings.
Agreed. Only works with File Search settings indexed.
I found this list of some best file manager for Linux system.
