Hi y’all!
Is there any difference in package versions between the repository that pacman-mirrors uses (i.e repo_manjaro_org) and what is listed in archlinux_org/mirrors/status/ I had used a custom mirror list thus far to update. However, that had gone down temporarily and thus I decided to use pacman-mirrors. I noticed that after updating the mirrorlist using pacman-mirrors -f 5 and then running pacman -Syyu I’d get a bunch of warning saying local extra and community packages are newer than remote.
I went onto repo_manjaro_org and found that the mirror on the top of my mirror list was completely up-to-date (green background and all) but found that packages like xorg-server-wayland is still stuck at 1.20.8-4 even though the lastest is 1.20.9-2.
Is there anyway to fix this (i.e not use repo_manjaro_org)?
Thanks and sorry if I posted this in the wrong section of the forum.
PS: Had to replace periods in links with underscores since I’m not allowed to add links to posts.
