As the title hopefully states clearly, there is no problem to solve other than my understanding.
I wanted to tinker with my installation and install a second OS on my system. In preparation i wanted to locate my bootloader and check the configuration.
I expected to find a partition called /efi
or /boot
or maybe even /grub
on my disk… or any of my disks.
mount -l
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
dev on /dev type devtmpfs (rw,nosuid,relatime,size=16338956k,nr_inodes=4084739,mode=755,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
/dev/nvme0n1p1 on / type ext4 (rw,noatime) [Manjaro HyprKDE]
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=36,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=3885)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,nosuid,nodev,relatime,pagesize=2M)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /tmp type tmpfs (rw,noatime,inode64)
/dev/nvme1n1p1 on /home/sgr/Games type ext4 (rw,noatime) [Games]
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=3273732k,nr_inodes=818433,mode=700,uid=1000,gid=1000,inode64)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
fdisk -l
Disk /dev/sda: 119,24 GiB, 128035676160 bytes, 250069680 sectors
Disk model: SanDisk SD9SB8W-
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0xaaaa501a
Device Boot Start End Sectors Size Id Type
/dev/sda2 231612852 250067789 18454938 8,8G 82 Linux swap / Solaris
/dev/sda3 * 2048 231612415 231610368 110,4G 83 Linux
Partition 2 does not start on physical sector boundary.
Partition table entries are not in disk order.
Disk /dev/sdb: 931,51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: WDC WD10EZEX-60W
Disklabel type: gpt
Disk identifier: AF692F6B-7FED-420F-89BA-917E604C5953
Device Start End Sectors Size Type
/dev/sdb1 2048 1953521663 1953519616 931,5G Microsoft basic data
Disk /dev/nvme1n1: 931,51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: KINGSTON SA2000M81000G
Disklabel type: gpt
Disk identifier: ABC25D73-596F-482E-877C-7D05BA90CDA3
/dev/nvme1n1p1 34 1953124351 1953124318 931,3G Linux filesystem
Disk /dev/nvme0n1: 238,47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: WDC PC SN730 SDBQNTY-256G-1001
Disklabel type: dos
Disk identifier: 0x53ad8093
/dev/nvme0n1p1 * 2048 500103449 500101402 238,5G 83 Linux
It seems I got two partitions marked as bootalble. On SanDisk SD9SB8W
with /dev/sda3
and on WDC PC SN730 SDBQNTY-256G-1001
with /dev/nvme0n1p1
So I’am more familiar with a seperate boot partition with a bootloader, but at least from what i can see this is not how my system is set up.
As far as i can see the booloader is build in in my installation partitions which would be mounted as root
. And which system would get mounted is decided by device priority in the UEFI.
Is this correct?
How would this work if i was to install a grub bootloader? would he call the installation and just ignore the integrated bootloader? or would he call that bootloader and they would just pass in sequence?
