Hi I purchased a nice Firewire 400 drive on ebay. It works great with the USB 2.0 option. But I want to set it up to run it as a Firewire400 drive. It uses a 6 pin cable at the drive housing and a 1394 connector at my laptop. (My Dell M1330 laptop has that port!) I have the cable for it.
For starters: What modprobe command do I use?
Any help would be appreciated.
lspci -m gives me:
03:01.0 “FireWire (IEEE 1394)” “Ricoh Co Ltd” “R5C832 IEEE 1394 Controller” -r05 -p10 “Del
l” “Device 0209”
Hi @deroberts1
While I never used sich a connection, I would say it is this module:
modinfo sbp2
When loading this module:
sudo modprobe -v sbp2
a new drive must be there recognized.
lsblk --fs
dougrrr@dougs-linux ~ $ modinfo sbp2
filename: /lib/modules/5.17.1-1-rt16-MANJARO/kernel/drivers/firewire/firewire-sbp2.ko.xz
alias: sbp2
license: GPL
description: SCSI over IEEE1394
author: Kristian Hoegsberg <krh@bitplanet.net>
srcversion: 252A8F54BEEA287456BA453
alias: ieee1394:ven*mo*sp0000609Ever00010483*
depends: firewire-core
retpoline: Y
intree: Y
vermagic: 5.17.1-1-rt16-MANJARO SMP preempt_rt mod_unload
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 30:8C:9A:8E:6E:BF:33:5C:2C:AE:BB:48:74:C7:AD:91:C1:39:EC:4D
sig_hashalgo: sha512
signature: 90:DE:32:27:EF:41:2D:67:EC:76:5D:03:D2:A4:FF:CF:2A:78:76:AD:
D0:20:A7:89:AB:82:A9:5E:96:80:C4:1E:59:19:59:F1:8C:D6:B8:F8:
4C:57:1A:CF:98:69:C1:75:5D:75:CC:6F:CE:66:00:F3:AF:61:F3:FE:
3F:B3:57:D4:5F:D0:85:1E:22:9C:14:CE:C4:FB:0B:DD:66:E9:2A:FF:
B1:C3:97:70:04:D2:3D:D6:84:DB:AB:E0:69:26:BF:D0:7A:73:F1:FB:
67:B7:00:E8:C7:2E:6B:10:E4:17:CA:5F:59:58:29:27:F9:69:B7:EA:
DC:89:A5:85:6F:33:2A:33:0E:4E:76:99:94:F4:B7:FC:EE:59:2D:DE:
CE:FD:5C:8B:77:0E:38:26:4E:8B:7E:88:30:F5:04:F9:B4:DA:42:6C:
6E:35:A0:8C:DA:2C:19:33:6A:C9:0A:0E:F7:29:1B:F9:50:A9:BC:21:
3C:55:7D:B0:F0:2A:17:0D:C6:64:D8:CD:63:E1:44:47:26:42:7E:8D:
60:F3:1D:CC:B0:3A:0D:C6:EE:2F:E9:12:37:15:B6:D2:25:58:CE:AE:
D6:49:DE:2E:8D:D3:61:FF:AE:E3:9F:F1:3C:85:FF:AE:40:12:80:3F:
B2:34:9D:F1:91:8E:B2:FE:CC:08:4A:EE:23:D7:CE:D5:5E:B8:5E:BF:
98:52:77:B3:95:6C:CC:90:0A:CB:93:D5:AD:A1:DF:60:20:7D:91:AF:
B7:21:C0:66:71:3D:32:82:1F:2A:88:70:75:C4:D9:6F:56:60:48:C6:
61:B0:E9:61:C0:F7:92:A0:67:53:98:34:7A:7C:EF:F6:DA:88:05:64:
2D:DB:9A:41:6E:F6:78:6E:E9:F1:6B:EC:A6:39:DE:38:4E:B2:51:3E:
7D:1B:AB:BD:7F:CB:B8:63:2D:B3:37:A3:91:F8:A0:76:C3:EA:44:01:
E0:37:96:45:16:5F:38:3E:B1:F4:02:F0:F0:F8:9D:56:98:77:8D:E5:
64:50:E6:DF:CA:0B:FD:61:B7:D2:4A:E2:9A:29:B4:F8:8B:31:34:17:
C6:B3:1E:D2:FF:09:8B:5B:EC:16:17:9D:F2:0A:BB:BF:AE:38:B1:AC:
20:98:47:E2:97:DF:C7:82:BC:3C:57:39:C6:3A:86:FE:69:F1:5D:19:
66:13:AA:85:EA:98:52:A3:EC:98:A4:28:8D:8C:C4:9E:3B:E4:38:1C:
BA:B6:48:8B:33:DC:B1:D8:80:74:00:1A:5E:AB:D2:3B:3C:21:E6:9A:
D7:F2:04:91:28:51:CB:49:94:11:9F:F9:A8:83:D3:D2:09:B2:19:80:
D0:FD:D1:07:3C:0A:48:62:4B:AB:65:91
parm: exclusive_login:Exclusive login to sbp2 device (default = Y, use N for concurrent initiators) (bool)
parm: workarounds:Work around device bugs (default = 0, 128kB max transfer = 0x1, 36 byte inquiry = 0x2, skip mode page 8 = 0x4, fix capacity = 0x8, delay inquiry = 0x10, set power condition in start stop unit = 0x20, override internal blacklist = 0x100, or a combination) (int)
Does this drive require a special login?
lsblk --fs
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1
│ ext4 1.0 Current Pics
│ 7e3e4ba4-01ac-4020-b8e7-84d9f3097a48 6.5G 66% /run/media/dougrrr/Current Pics
├─sda2
├─sda5
│ swap 1 8a99da3b-909d-3bfb-ded7-0e23dda7e60d [SWAP]
├─sda6
│ ext4 1.0 3e92a86c-02d3-4713-a91b-25cc8e788b68 50.1G 48% /
├─sda7
│ ext4 1.0 02f13436-7816-4203-b6ff-4d05738d8f10 17.4G 30% /home
└─sda8
ext4 1.0 b88b938d-0ddc-4d9b-8682-c997769cf658 231.3G 11% /run/media/dougrrr/b88b938d-0ddc-4d9b-8682-c997769cf658
sdb
├─sdb1
├─sdb2
├─sdb3
├─sdb4
├─sdb5
├─sdb6
└─sdb10
Are the sdb* references the available mount points for the firewire drive?
When pasting terminal output, add three backticks ` OR 3 tilde ~ above and below the text:
text
I did it this time for you. Please do it like this in the future.
Thank you
Did you load the module?
lsmod | grep sbp2
Check also:
sudo partprobe -s
sudo parted -l
Ok the command
dougrrr@dougs-linux ~ $ lsmod | grep sbp2
firewire_sbp2 28672 0
firewire_core 81920 2 firewire_ohci,firewire_sbp2
So far so good, I think.
BUT these two commands below only show the internal /dev/sda SSD drive.
sudo partprobe -s
sudo parted -l
Then please check the kernel messages:
sudo dmesg | grep -i sbp2
Creates this output:
[ 8.212086] firewire_sbp2 fw1.0: logged in to LUN 0000 (0 retries)
[ 25.302589] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 40.662433] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 56.022471] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 86.230427] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 116.438450] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 146.647452] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 716.095884] firewire_sbp2 fw1.0: released target 5:0:0
[ 728.812530] firewire_sbp2 fw1.0: logged in to LUN 0000 (0 retries)
[ 762.070455] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 777.430452] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 792.790423] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 822.998407] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 853.206453] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 883.414454] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 2693.443571] firewire_sbp2 fw1.0: released target 5:0:0
[ 2706.234070] firewire_sbp2 fw1.0: logged in to LUN 0000 (0 retries)
[ 2723.030452] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 2738.391437] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 2753.752467] firewire_sbp2 fw1.0: sbp2_scsi_abort
I am sorry, no idea what it could be. As said, I never used it. According to my research, it should just work.
New command output:
sudo dmesg | grep -i 1394
[ 7.616542] scsi host5: SBP-2 IEEE-1394
[ 728.171411] scsi host5: SBP-2 IEEE-1394
[ 2705.627491] scsi host5: SBP-2 IEEE-1394
[ 3159.339576] scsi host5: SBP-2 IEEE-1394
[ 3558.292051] scsi host5: SBP-2 IEEE-1394
You can also run it in follow mode:
sudo dmesg -w
I just check the BIOS to see if 1394 is enabled and it is. When I rebooted I ran this command again
[ 8.294072] firewire_sbp2 fw1.0: logged in to LUN 0000 (0 retries)
[ 25.301857] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 40.661881] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 56.021846] firewire_sbp2 fw1.0: sbp2_scsi_abort
[ 86.229892] firewire_sbp2 fw1.0: sbp2_scsi_abort
Different output this time. ???
New command
sudo dmesg | tail
[ 8417.362117] Buffer I/O error on dev sdc10, logical block 12615680, lost sync page write
[ 8417.362119] JBD2: Error -5 detected when updating journal superblock for sdc10-8.
[ 8417.362133] EXT4-fs error (device sdc10): ext4_put_super:1221: comm umount: Couldn't clean up the journal
[ 8417.362136] EXT4-fs (sdc10): Remounting filesystem read-only
[ 8420.796364] firewire_core 0000:03:01.0: phy config: new root=ffc1, gap_count=5
[ 9022.825662] kauditd_printk_skb: 21 callbacks suppressed
[ 9022.825667] audit: type=1100 audit(1651267683.978:297): pid=103525 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acc
t="dougrrr" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 9022.826021] audit: type=1101 audit(1651267683.979:298): pid=103525 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="dougrrr"
[ 9022.827355] audit: type=1110 audit(1651267683.980:299): pid=103525 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root
[ 9022.832422] audit: type=1105 audit(1651267683.985:300): pid=103525 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_p
ermit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
This command at least sees the first partition. (They are not in order.)
I downloaded Linux firewire utilities this one gave me results that tell me at least the drive is being seen:
/usr/bin/lsfirewire -v -v
device fw0:
vendor ID: 0x001f11
model ID: 0x023901
vendor: Linux Firewire
model: Juju
guid: 0x314fc00036eb41e1
ROM header and bus information block
400 04042483 bus_info_length 4, crc_length 4, crc 9347
404 31333934 bus_name "1394"
408 f000a222 irmc 1, cmc 1, isc 1, bmc 1, pmc 0, cyc_clk_acc 0,
max_rec 10 (2048), max_rom 2, gen 2, spd 2 (S400)
40c 314fc000 company_id 314fc0 |
410 36eb41e1 device_id 0036eb41e1 | EUI-64 314fc00036eb41e1
root directory
414 00051b70 directory_length 5, crc 7024
418 0c0083c0 node capabilities per IEEE 1394
41c 03001f11 vendor
420 81000003 --> descriptor leaf at 42c
424 17023901 model
428 81000008 --> descriptor leaf at 448
42c 00064cb7 leaf_length 6, crc 19639
430 00000000 textual descriptor
434 00000000 minimal ASCII
438 4c696e75 "Linu"
43c 78204669 "x Fi"
440 72657769 "rewi"
444 72650000 "re"
448 0003ff1c leaf_length 3, crc 65308
44c 00000000 textual descriptor
450 00000000 minimal ASCII
454 4a756a75 "Juju"
device fw1:
vendor ID: 0x0023a4
hardware version ID: 0x00f934
vendor: OWC Mercury Elite
hardware version: 934SSA
guid: 0x0023a409e01157db
units: 0x00609e:0x010483
unit fw1.0:
model ID: 0x000000
specifier ID: 0x00609e
version: 0x010483
400 040456be bus_info_length 4, crc_length 4, crc 22206
408 00ff5123 irmc 0, cmc 0, isc 0, bmc 0, pmc 0, cyc_clk_acc 255,
max_rec 5 (64), max_rom 1, gen 2, spd 3 (S800)
40c 0023a409 company_id 0023a4 |
410 e01157db device_id 09e01157db | EUI-64 0023a409e01157db
root directory
414 00063c3a directory_length 6, crc 15418
41c 030023a4 vendor
420 81000057 --> descriptor leaf at 57c
424 0400f934 hardware version
428 8100005d --> descriptor leaf at 59c
42c d1000004 --> unit directory at 43c
43c 000d1df4 directory_length 13, crc 7668
440 1200609e specifier id: INCITS
444 13010483 version: SBP-2
448 3c000113 SBP-2 firmware revision 000113
44c 5400c000 --> SBP-2 management agent CSR at fffff0030000
450 3a003c08 SBP-2 unit char.: mgt_ORB_timeout 30s, ORB_size 8 quadlets
454 3800609e SBP-2 command set spec id: INCITS
458 390104d8 SBP-2 command set: SCSI Primary Commands 2 and related standards
45c 3b000000 SBP-2 command set revision
460 3d000003 SBP-2 reconnect timeout: max_reconnect_hold 4s
464 21000001 SBP-2 revision 1 = SBP-3
468 144e0000 SBP-2 logical unit number: ordered 1, type RBC, lun 0000
46c 17000000 model
470 81000001 --> descriptor leaf at 474
474 0003374e leaf_length 3, crc 14158
478 00000000 textual descriptor
47c 00000000 minimal ASCII
480 20000000 " "
57c 000778f5 leaf_length 7, crc 30965
580 00000000 textual descriptor
584 00000000 minimal ASCII
588 4f574320 "OWC "
58c 4d657263 "Merc"
590 75727920 "ury "
594 456c6974 "Elit"
598 65000000 "e"
59c 0004886d leaf_length 4, crc 34925
5a0 00000000 textual descriptor
5a4 00000000 minimal ASCII
5a8 39333453 "934S"
5ac 53410000 "SA"
Update: On a hunch I decided to see if any other Dell M1330 laptop users have my problem. Yes indeed.
Turns out that the firewire controller card is set back too far and the trick to making the drive visible is to shave some of the plastic off of the 1394 connector so it can insert further. Seriously? Ok. Did that. Well knock me over with a feather! The drive is now visible to the lsblk command. See below. Partitions sb2, 3, 4 and 10 are the ones I created and show the correct sizes. Ok? Now what?
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 447.1G 0 disk
├─sda1 8:1 0 23.6G 0 part /run/media/dougrrr/Current Pics
├─sda2 8:2 0 512B 0 part
├─sda5 8:5 0 4.8G 0 part [SWAP]
├─sda6 8:6 0 109.3G 0 part /
├─sda7 8:7 0 27.3G 0 part /home
└─sda8 8:8 0 282.2G 0 part /run/media/dougrrr/b88b938d-0ddc-4d9b-8682-c997769cf658
sdb 8:16 0 465.8G 0 disk
├─sdb1 8:17 0 31.5K 0 part
├─sdb2 8:18 0 68.7G 0 part
├─sdb3 8:19 0 218.3G 0 part
├─sdb4 8:20 0 82.7G 0 part
├─sdb5 8:21 0 2M 0 part
├─sdb6 8:22 0 24K 0 part
└─sdb10 8:26 0 96.1G 0 part
Congratulations!
So at the end it was not a Software Problem
Now you should be able to mount the partitions like any other.
This works on the commandline for example:
sudo mkdir -pv /media/sdb3
sudo mount -v /dev/sdb3 /media/sdb3
Stuck again. All the mkdir commands worked just fine.
But the partitions are not mounting. I get errors “not a valid block device”. Running this command
sudo fdisk -l /dev/sdb
I get:
fdisk: cannot open /dev/sdb: No such device or address
file /dev/sdb* yields:
/dev/sdb: block special (8/16)
/dev/sdb1: block special (8/17)
/dev/sdb10: block special (8/26)
/dev/sdb2: block special (8/18)
/dev/sdb3: block special (8/19)
/dev/sdb4: block special (8/20)
/dev/sdb5: block special (8/21)
/dev/sdb6: block special (8/22)
