Hello. I just configured zram in my system. My question is why zramctl reports less swap data than swapon. I used fedora 34 for a while and if I remember correctly it showed the total amount of swap used in the “Data” section in zramctl.
Is this happening because zramctl is only reporting compressible data? here are some captures and my system info:
inxi --full --admin --verbosity=7 --filter --no-host 22 ✘
Kernel: 5.15.8-228-tkg-pds x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux515-tkg-pds
root=UUID=d0cc26bc-d2c9-4c05-b4dd-d7e8620ef6c3 rw rootflags=subvol=@
quiet resume=UUID=288be438-2ace-4b1b-92da-8c8a37131910
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5602
date: 07/14/2020
RAM: total: 5.79 GiB used: 3.02 GiB (52.2%)
RAM Report:
Info: model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1502 high: 2284 min/max: 1400/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1252 2: 2284
3: 1397 4: 1397 5: 1609 6: 1285 7: 1397 8: 1401 bogomips: 59090
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt
pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit
smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm
svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
STIBP: disabled, RSB filling
Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 07:00.0 chip-ID: 1002:15d8 class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 72 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.42.0
5.15.8-228-tkg-pds LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel v: kernel
bus-ID: 07:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK PRIME B450M-A
driver: snd_hda_intel v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.15.8-228-tkg-pds running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.83 TiB used: 736.1 GiB (39.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 023 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD7500BPVX-60JC3T0 size: 698.64 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Kingston
model: DataTraveler 2.0 size: 14.54 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 31.25 GiB size: 31.25 GiB (100.00%)
used: 13.97 GiB (44.7%) fs: btrfs dev: /dev/sdb7 maj-min: 8:23 label: root
uuid: d0cc26bc-d2c9-4c05-b4dd-d7e8620ef6c3
used: 568 KiB (0.1%) fs: vfat dev: /dev/sdb5 maj-min: 8:21 label: BOOT
uuid: 08E6-2E46
ID-3: /home raw-size: 102.66 GiB size: 102.66 GiB (100.00%)
used: 83.44 GiB (81.3%) fs: btrfs dev: /dev/sdb8 maj-min: 8:24 label: home
uuid: 0e609bad-a95f-43fb-a9f0-68d1cda65108
ID-4: /mnt/01D764BB364BACB0 raw-size: 818.88 GiB
size: 818.88 GiB (100.00%) used: 619.66 GiB (75.7%) fs: ntfs dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 01D764BB364BACB0
ID-5: /mnt/2cb67755-7f36-49e4-a090-7a02cf4a6c78 raw-size: 112.63 GiB
size: 112.63 GiB (100.00%) used: 19.03 GiB (16.9%) fs: btrfs dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: 2cb67755-7f36-49e4-a090-7a02cf4a6c78
ID-6: /var/cache raw-size: 31.25 GiB size: 31.25 GiB (100.00%)
ID-7: /var/log raw-size: 31.25 GiB size: 31.25 GiB (100.00%)
Kernel: swappiness: 100 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.98 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb9 maj-min: 8:25 label: N/A
uuid: 288be438-2ace-4b1b-92da-8c8a37131910
ID-2: swap-2 type: zram size: 5.79 GiB used: 738.7 MiB (12.5%)
priority: 100 dev: /dev/zram0
ID-1: /dev/sdb1 maj-min: 8:17 size: 580 MiB fs: ntfs label: Recovery
uuid: 01D59DCC4A40D630
ID-2: /dev/sdb2 maj-min: 8:18 size: 330.6 MiB fs: vfat label: N/A
uuid: 4AFD-6F70
ID-3: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdb4 maj-min: 8:20 size: 88.09 GiB fs: ntfs label: N/A
uuid: 01D74A8D47F4F900
ID-5: /dev/sdb6 maj-min: 8:22 size: 511.2 MiB fs: vfat label: EFI
uuid: 804C-4160
ID-6: /dev/sdc1 maj-min: 8:33 size: 658.33 GiB fs: ntfs label: N/A
uuid: 01D6DD483DFD42C0
ID-7: /dev/sdc2 maj-min: 8:34 size: 40.31 GiB fs: btrfs label: N/A
uuid: f60dd6df-e2bd-40fe-976d-512c2599cbdd
ID-8: /dev/sdd1 maj-min: 8:49 size: 14.54 GiB fs: ntfs label: N/A
uuid: 54AB541B1D57AED5
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-4:2 info: Kingston Digital DataTraveler SE9
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 200mA chip-ID: 0951:1665 class-ID: 0806
serial: <filter>
Device-2: 1-6:3 info: Razer USA Razer DeathAdder V2 Mini
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:008c class-ID: 0300
Device-3: 1-9:4 info: China Resource Semico USB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:4c5e class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 3 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 35.0 C
Processes: 348 Uptime: 1h 30m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1319 lib: 386
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole
inxi: 3.3.11
swapon ✔ 16s
NAME TYPE SIZE USED PRIO
/dev/sdb9 partition 9G 0B -2
/dev/zram0 partition 5.8G 2G 100
zramctl ✔
NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0 zstd 5.8G 50.6M 28.6M 29.3M 8 [SWAP]
