Sorry for the sort of idiot question but could you tell me what this line is supposed to be in etc/default/grub please?
GRUB_CMDLINE_LINUX_DEFAULT="quiet loglevel=3 rd.udev.log_leve
(Also where could I look to figure this out myself? Are the current files listed somewhere?)
I must’ve goofed yesterday but thought I just made a few changes to the pacnew version and then made that the main file; however, this line must be missing at least a closing "; and sudo update-grub throws an error about a missing " further down in the file.
Also, somtimes the grub menu is (I guess) themed with the green header and other times it is just like plain CLI. What makes it change its appearance? Is there a line in the grub file that should be changed?
I have this now, if this is the relevant section:
GRUB_THEME="/path/to/gfxtheme"
#GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
Thank you.
