QtWebEngineProc terminated abnormally without generating a coredump (no space left)
Nov 22 01:03:02 weingeist-PC kernel: traps: QtWebEngineProc[9952] trap int3 ip:7fa997ab66bd sp:7ffff0294240 error:0 in libQt6WebEngineCore.so.6[5cb66bd,7fa9929b1000+a10a000]
Nov 22 01:03:02 weingeist-PC systemd-coredump[14783]: Process 9952 (QtWebEngineProc) of user 1000 terminated abnormally with signal 5/TRAP, processing...
Nov 22 01:03:02 weingeist-PC systemd[1]: Started Process Core Dump (PID 14783/UID 0).
Nov 22 01:03:17 weingeist-PC systemd-coredump[14784]: Cannot store coredump of 9952 (QtWebEngineProc): No space left on device
Nov 22 01:03:18 weingeist-PC systemd-coredump[14784]: [🡕] Process 9952 (QtWebEngineProc) of user 1000 terminated abnormally without generating a coredump.
Therein lies a clue. :wink:
Are you using BTRFS?
no all ext4
That makes things easier. What’s the result of
df -h /
df -h /
Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
/dev/nvme1n1p5 63G 31G 29G 53% /
Then it has to be a permission issue, but what can prevent systemd to write on the root… does not make sense on first glance.
Did you made some droping config files to limit the core dumps? Do you have other dumps? What does
This say
systemd-analyze cat-config systemd/coredump.conf
And
coredumpctl
I hope it was a /venv-related error. I’ve set everything up from scratch, and for now, there are no errors. It even triggered an MCE error at one point. I’m hoping it was just down to the /venv.
# /etc/systemd/coredump.conf
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it under the
#  terms of the GNU Lesser General Public License as published by the Free
#  Software Foundation; either version 2.1 of the License, or (at your option)
#  any later version.
# Entries in this file show the compile time defaults. Local configuration
# should be created by either modifying this file (or a copy of it placed in
# /etc/ if the original file is shipped in /usr/), or by creating "drop-ins" in
# the /etc/systemd/coredump.conf.d/ directory. The latter is generally
# recommended. Defaults can be restored by simply deleting the main
# configuration file and all drop-ins located in /etc/.
# Use 'systemd-analyze cat-config systemd/coredump.conf' to display the full config.
# See coredump.conf(5) for details.
[Coredump]
#Storage=external
#Compress=yes
# On 32-bit, the default is 1G instead of 32G.
#ProcessSizeMax=32G
#ExternalSizeMax=32G
#JournalSizeMax=767M
#MaxUse=
#KeepFree=
#EnterNamespace=no
❯ coredumpctl
TIME                            PID  UID  GID SIG     COREFILE EXE        SIZE
Mon 2026-07-20 07:13:41 CEST   6164 1000 1001 SIGABRT missing  GameThread        -
Thu 2026-07-30 02:17:50 CEST   5756 1000 1001 SIGSEGV missing  /usr/lib/qt6/bin/linguist        -
Sat 2026-08-08 15:30:05 CEST   1929 1000 1001 SIGSEGV missing  /mnt/GAMES/ai-toolkit/.node/bin/node                                                          -
Sat 2026-08-08 15:30:05 CEST   1918 1000 1001 SIGSEGV missing  /mnt/GAMES/ai-toolkit/.node/bin/node                                                          -
Thu 2026-08-20 19:18:03 CEST  38123 1000 1001 SIGSEGV missing  /usr/bin/python3.14        -
Thu 2026-08-20 19:25:03 CEST  38611 1000 1001 SIGSEGV missing  /usr/bin/python3.14        -
Thu 2026-08-20 19:34:18 CEST  39465 1000 1001 SIGSEGV missing  /usr/bin/python3.14        -
Sat 2026-09-05 00:27:57 CEST  52602 1000 1001 SIGSEGV missing  /home/weingeist/.local/share/Steam/ubuntu12_32/steam                                          -
Thu 2026-09-17 22:07:06 CEST  37424 1000 1001 SIGABRT missing  /home/weingeist/.local/share/torbrowser/tbb/x86_64/tor-browser/Browser/firefox.real           -
Tue 2026-10-06 19:12:17 CEST   3898 1000 1001 SIGSEGV missing  /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Tue 2026-10-06 20:20:52 CEST  12478 1000 1001 SIGABRT missing  /usr/bin/nheko        -
Sat 2026-10-10 03:25:52 CEST 131207 1000 1001 SIGABRT missing  /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Sat 2026-10-10 19:10:02 CEST  34761 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Tue 2026-10-13 19:19:43 CEST   5095 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Tue 2026-10-20 03:18:16 CEST  33186 1000 1001 SIGABRT missing  /home/weingeist/.local/share/torbrowser/tbb/x86_64/tor-browser/Browser/firefox.real           -
Tue 2026-10-20 23:34:10 CEST  53872 1000 1001 SIGABRT missing  /usr/bin/python3.14        -
Thu 2026-10-22 03:13:13 CEST 208503 1000 1001 SIGABRT missing  /home/weingeist/.local/share/torbrowser/tbb/x86_64/tor-browser/Browser/firefox.real           -
Sun 2026-10-25 23:08:37 CET  218087 1000 1001 SIGSEGV missing  /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Wed 2026-10-28 23:52:15 CET   92771 1000 1001 SIGABRT missing  /home/weingeist/.local/share/torbrowser/tbb/x86_64/tor-browser/Browser/firefox.real           -
Sat 2026-10-31 01:54:04 CET   97241 1000 1001 SIGSEGV none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Sat 2026-10-31 01:54:15 CET   98528 1000 1001 SIGSEGV missing  /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Sat 2026-10-31 16:09:57 CET   15172 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Sat 2026-10-31 17:27:16 CET   25039 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Sat 2026-10-31 17:27:36 CET   44815 1000 1001 SIGSEGV missing  /usr/bin/filelight        -
Sat 2026-10-31 18:08:56 CET   44679 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Mon 2026-11-02 08:29:38 CET    4099 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Wed 2026-11-04 09:12:37 CET   20957 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Wed 2026-11-04 09:14:16 CET   25975 1000 1001 SIGABRT missing  /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Wed 2026-11-04 09:16:06 CET   26285 1000 1001 SIGABRT missing  /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Thu 2026-11-12 23:51:11 CET    6133 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Thu 2026-11-12 23:59:38 CET    8974 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Fri 2026-11-13 00:02:38 CET    9585 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Fri 2026-11-13 00:05:53 CET    9986 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Fri 2026-11-13 00:34:10 CET   10357 1000 1001 SIGSEGV none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Fri 2026-11-13 21:41:09 CET   18913 1000 1001 SIGABRT missing  /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Fri 2026-11-13 21:44:59 CET   19865 1000 1001 SIGABRT missing  /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Fri 2026-11-13 21:56:59 CET   22252 1000 1001 SIGABRT missing  /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Fri 2026-11-13 22:08:51 CET   22640 1000 1001 SIGABRT missing  /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Sat 2026-11-14 03:22:30 CET   67555 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Mon 2026-11-16 18:21:33 CET    6371 1000 1001 SIGSEGV none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Mon 2026-11-16 23:25:16 CET   16288 1000 1001 SIGABRT none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Tue 2026-11-17 01:20:43 CET   53316 1000 1001 SIGSEGV none     /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Tue 2026-11-17 13:32:49 CET    2349 1000 1001 SIGABRT missing  /mnt/GAMES/SwarmUI/src/bin/live_release/SwarmUI                                               -
Wed 2026-11-18 06:27:04 CET   90829 1000 1001 SIGSEGV missing  /home/weingeist/.local/share/uv/python/cpython-3.12.13-linux-x86_64-gnu/bin/python3.12        -
Fri 2026-11-20 19:58:23 CET  120423 1000 1001 SIGABRT none     /usr/bin/python3.14        -
Sat 2026-11-21 18:42:18 CET    6125 1000 1001 SIGSEGV missing  /usr/bin/python3.14        -
Sat 2026-11-21 22:42:40 CET    7052 1000 1001 SIGTRAP missing  /mnt/GAMES/Fizgig/venv/lib/python3.14/site-packages/PyQt6/Qt6/libexec/QtWebEngineProcess      -
Sun 2026-11-22 00:32:20 CET    4479 1000 1001 SIGABRT missing  /usr/bin/python3.14        -
Sun 2026-11-22 00:41:58 CET    2016 1000 1001 SIGTRAP none     /mnt/GAMES/Fizgig/venv/lib/python3.14/site-packages/PyQt6/Qt6/libexec/QtWebEngineProcess      -
Sun 2026-11-22 00:44:29 CET    9562 1000 1001 SIGSEGV present  /usr/bin/python3.14        300.1M
Sun 2026-11-22 01:03:18 CET    9952 1000 1001 SIGTRAP none     /mnt/GAMES/Fizgig/venv/lib/python3.14/site-packages/PyQt6/Qt6/libexec/QtWebEngineProcess      -
Sun 2026-11-22 03:17:25 CET    2819 1000 1001 SIGABRT present  /usr/bin/python3.14
There is a bug in the nvidia-open kernel Module
 [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 0
I hope that this also triggered the MCE error and that everything is somehow connected. As a test workaround, the following is recommended: (kernel module parameter)
nvidia_modeset.opportunistic_flip_sync=0
Mod edit:- Posts merged.
Please avoid consecutive posts.
Bitte vermeiden Sie aufeinanderfolgende Beiträge.
I see that in my journal as well:
Nov 20 19:32:30 gazelle kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 0
Nov 20 19:32:33 gazelle kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 1
Nov 20 19:32:33 gazelle kernel: WARNING: nvidia-drm/nvidia-drm-crtc.h:371 at __nv_drm_handle_flip_event+0x1f8/0x210 [nvidia_drm], CPU#6: nvidia-modeset//352
I’ve added the parameter to my /etc/modprobe.d/nvidia.conf, I’ll reboot and see how it goes.
# https://github.com/NVIDIA/open-gpu-kernel-modules/issues/1553
options nvidia_modeset opportunistic_flip_sync=0
hmpf
Nov 24 09:10:25 weingeist-PC kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 0
Nov 24 09:10:25 weingeist-PC kernel: ------------[ cut here ]------------
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031796] (dw_udev_watch                 ) udev event detected
Nov 24 09:10:25 weingeist-PC kernel: nv_flip == NULL
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838] Udev_Event_Detail
Nov 24 09:10:25 weingeist-PC kernel: WARNING: nvidia-drm/nvidia-drm-crtc.h:371 at __nv_drm_handle_flip_event+0x1f8/0x210 [nvidia_drm], CPU#12: nvidia-modeset//973
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838]    prop_subsystem:  drm
Nov 24 09:10:25 weingeist-PC kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq nvidia_uvm(OE) nvidia_drm(OE) nvidia_modeset(OE) qrtr nct6775 nct6775_core hwmon_vid snd_sof_pci_intel_tgl snd_sof_pci_intel_cnl vfat snd_sof_intel_hda_generic fat soundwire_intel snd_sof_intel_hda_sdw_bpt snd_sof_intel_hda_common snd_soc_hdac_hda snd_sof_intel_hda_mlink nvidia(OE) snd_sof_intel_hda intel_rapl_msr soundwire_cadence intel_rapl_common snd_sof_pci intel_uncore_frequency snd_sof_xtensa_dsp intel_uncore_frequency_common intel_tcc_cooling snd_sof x86_pkg_temp_thermal intel_powerclamp snd_sof_utils coretemp snd_soc_acpi_intel_match gcm snd_soc_acpi_intel_sdca_quirks ucsi_acpi soundwire_generic_allocation kvm_intel snd_soc_sdw_utils typec_ucsi tps6598x snd_soc_acpi roles soundwire_bus typec snd_hda_codec_nvhdmi snd_soc_sdca snd_hda_codec_hdmi kvm crc8 snd_soc_avs irqbypass snd_soc_hda_codec aesni_intel snd_hda_intel snd_hda_ext_core spd5118 iTCO_wdt gf128mul snd_hda_codec intel_pmc_bxt rapl asus_armoury drm_ttm_helper snd_soc_core eeepc_wmi
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838]    prop_action:     change
Nov 24 09:10:25 weingeist-PC kernel:  firmware_attributes_class snd_usb_audio mei_pxp intel_pmc_core mei_hdcp igc i2c_i801 snd_hda_core intel_cstate spi_nor ttm snd_compress asus_wmi ptp sparse_keymap i2c_smbus ac97_bus snd_intel_dspcfg drm_display_helper snd_usbmidi_lib pmt_telemetry snd_intel_sdw_acpi asus_ec_sensors intel_uncore mtd rfkill mei_me pps_core wmi_bmof i2c_mux snd_pcm_dmaengine pcspkr snd_ump pmt_discovery snd_hwdep thunderbolt cec mei snd_rawmidi pmt_class serial_multi_instantiate snd_seq_device intel_pmc_ssram_telemetry snd_pcm intel_pmc_pwrm_telemetry acpi_pad pinctrl_alderlake intel_vsec acpi_tad snd_timer mousedev snd joydev mac_hid soundcore mc dm_mod i2c_dev crypto_user nvme spi_intel_pci nvme_core video intel_lpss_pci spi_intel intel_lpss nvme_keyring idma64 wmi nvme_auth
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838]    prop_connector:  778
Nov 24 09:10:25 weingeist-PC kernel: CPU: 12 UID: 0 PID: 973 Comm: nvidia-modeset/ Tainted: G           OE       7.3.5-2-MANJARO #1 PREEMPT(full)  d73d0d9dd03536eefe6606f8a99cfc1702063fb4
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838]    prop_devname:    /dev/dri/card1
Nov 24 09:10:25 weingeist-PC kernel: Tainted: [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838]    prop_devmode:    (null)
Nov 24 09:10:25 weingeist-PC kernel: Hardware name: ASUS System Product Name/ROG MAXIMUS Z790 HERO, BIOS 3301 09/18/2026
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838]    prop_hotplug:    1
Nov 24 09:10:25 weingeist-PC kernel: RIP: 0010:__nv_drm_handle_flip_event+0x1f8/0x210 [nvidia_drm]
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838]    prop_major:      226
Nov 24 09:10:25 weingeist-PC kernel: Code: 80 3d b3 62 33 ff 00 74 92 48 89 ef e8 31 16 cc d1 eb 88 4c 8b 6c 24 30 4c 8b 7c 24 40 e9 98 fe ff ff 4c 89 e7 e8 58 16 26 d2 <0f> 0b e9 81 fe ff ff 48 8d bd b0 00 00 00 e8 05 16 cc d1 e9 27 ff
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838]    prop_minor:      1
Nov 24 09:10:25 weingeist-PC kernel: RSP: 0018:ffffd2c2c3f93dd8 EFLAGS: 00010282
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838]    sysname:         card1
Nov 24 09:10:25 weingeist-PC kernel: RAX: ffff8e5f0f661818 RBX: ffff8e5f0f661818 RCX: ffff8e5f01ab52c0
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838]    syspath:         /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
Nov 24 09:10:25 weingeist-PC kernel: RDX: 0000000000000001 RSI: 0000000000000000 RDI: ffff8e5f0f661840
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838]    attr_name:       (null)
Nov 24 09:10:25 weingeist-PC kernel: RBP: ffff8e5f0f661800 R08: 0000000000000000 R09: ffffffffc170ba9c
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838] prop_connector = 778 -> /dev/i2c-7
Nov 24 09:10:25 weingeist-PC kernel: R10: fffff3b846c5dfc0 R11: ffff8e5f00042700 R12: ffff8e5f0f661840
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031838] prop_connector = 778 -> card1-DP-1
Nov 24 09:10:25 weingeist-PC kernel: R13: ffff8e5f022e8000 R14: ffff8e5f01ab5000 R15: ffffffffc26485c0
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.031860] (dw_pause_retaking_if_suspended) Allowing time for events to coalesce: Sleeping for 100 milliseconds
Nov 24 09:10:25 weingeist-PC kernel: FS:  0000000000000000(0000) GS:ffff8e6ee9a10000(0000) knlGS:0000000000000000
Nov 24 09:10:25 weingeist-PC kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Nov 24 09:10:25 weingeist-PC kernel: CR2: 00007f6a60200000 CR3: 0000000131c22004 CR4: 0000000000f72ef0
Nov 24 09:10:25 weingeist-PC kernel: PKRU: 55555554
Nov 24 09:10:25 weingeist-PC kernel: Call Trace:
Nov 24 09:10:25 weingeist-PC kernel:  <TASK>
Nov 24 09:10:25 weingeist-PC kernel:  ? __pfx__main_loop+0x10/0x10 [nvidia_modeset dfcfa7bf70dca4cee00789923b095ca488f47bfe]
Nov 24 09:10:25 weingeist-PC kernel:  nv_drm_event_callback+0xaa/0xb0 [nvidia_drm 9f0bc8f0885e422c53a0494b88d09f199b435382]
Nov 24 09:10:25 weingeist-PC kernel:  nvKmsKapiHandleEventQueueChange+0xf4/0x150 [nvidia_modeset dfcfa7bf70dca4cee00789923b095ca488f47bfe]
Nov 24 09:10:25 weingeist-PC kernel:  _main_loop+0x111/0x170 [nvidia_modeset dfcfa7bf70dca4cee00789923b095ca488f47bfe]
Nov 24 09:10:25 weingeist-PC kernel:  kthread+0xe6/0x120
Nov 24 09:10:25 weingeist-PC kernel:  ? __pfx_kthread+0x10/0x10
Nov 24 09:10:25 weingeist-PC kernel:  ret_from_fork+0x2a9/0x340
Nov 24 09:10:25 weingeist-PC kernel:  ret_from_fork_asm+0x1a/0x30
Nov 24 09:10:25 weingeist-PC kernel:  </TASK>
Nov 24 09:10:25 weingeist-PC kernel: ---[ end trace 0000000000000000 ]---
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.132099] (dw_udev_drain                 ) Drained 0 additional queued udev event(s)
Nov 24 09:10:25 weingeist-PC org_kde_powerdevil[1197]: [  1393][5144.351951] (dw_udev_drain                 ) Drained 0 additional queued udev event(s)
Yep, the kernel parameter didn’t seem to help.
NVIDIA has acknowledged the issue:
