Hello Manjaro Community! Bear with me, I’m pretty new to the forum and to debugging upgrade issues (I’m trying to get better).
I primarily do upgrades through the “Add/Remove Software” program and have enabled AUR packages there as well. I’m on the unstable branch (Wanted Nvidia 555 and explicit-sync) which I managed to get working and haven’t had too many problems. I used the nvidia-all project to upgrade drivers.
After my most recent upgrade attempt, I’m unable to log in to a desktop session with either wayland or x11. I’m attaching my inxi and journalctl logs. I’m seeing a lot of:
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Kernel: 6.6.37-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: root=UUID=f9b3f625-a52c-46fd-9535-6642ddfc12c9 rw
rootflags=subvol=@ nvidia_drm.modeset=1 quiet splash udev.log_priority=3
initrd=@\boot\initramfs-.img
Console: tty 3 DM: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop System: Gigabyte product: Z390 AORUS ULTRA v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z390 AORUS ULTRA-CF v: x.x
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: F9 date: 10/15/2019
System RAM: total: 16 GiB available: 15.55 GiB used: 1.2 GiB (7.7%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: no module installed
Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Corsair part-no: CMW16GX4M2C3200C16
serial: N/A
Device-3: ChannelB-DIMM0 type: no module installed
Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
serial: N/A
Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xB8
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 57616
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: gather_data_sampling status: Vulnerable: No microcode
Type: mmio_stale_data status: Vulnerable: Clear CPU buffers attempted, no
microcode; SMT disabled
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Type: srbds status: Vulnerable: No microcode
Type: tsx_async_abort status: Vulnerable: Clear CPU buffers attempted, no
Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor: eVga.com.
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: DP-3,HDMI-A-1 empty: DP-1,DP-2,Unknown-1 bus-ID: 01:00.0
chip-ID: 10de:1e87 class-ID: 0300
Display: unspecified server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch tty: 128x48
Monitor-1: DP-3 model: Dell S2716DG serial: <filter> built: 2018
res: 2560x1440 dpi: 109 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-2: HDMI-A-1 model: E291-A1 serial: <filter> built: 2012
res: 1360x768 dpi: 55 gamma: 1.2 size: 631x354mm (24.84x13.94")
diag: 724mm (28.5") ratio: 16:9 modes: max: 1360x768 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia
inactive: wayland,x11,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.1.3-manjaro1.1
note: console (EGL sourced) renderer: NVIDIA GeForce RTX 2080/PCIe/SSE2,
llvmpipe (LLVM 18.1.8 256 bits)
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2080 driver: nvidia v: 555.58.02
device-ID: 10de:1e87 surfaces: N/A
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
Device-2: NVIDIA TU104 HD Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f8 class-ID: 0403
Device-3: Corsair HS60 Surround Adapter
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 1b1c:0a3b class-ID: 0300
serial: <filter>
API: ALSA v: k6.6.37-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
status: off 2: wireplumber status: active 3: pipewire-alsa type: plugin
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:11
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 4020
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 2.73 TiB used: 1.5 TiB (55.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR010 temp: 35.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WDBA3V0010BNC-WRSN size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211070WD temp: 40.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10S21X-24R1BT0-SSHD-8GB size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400
serial: <filter> fw-rev: 1A02 scheme: GPT
ID-1: / raw-size: 431.02 GiB size: 431.02 GiB (100.00%)
used: 226.31 GiB (52.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: Manjaro uuid: f9b3f625-a52c-46fd-9535-6642ddfc12c9
ID-2: /boot/efi raw-size: 500 MiB size: 498 MiB (99.61%)
used: 30.6 MiB (6.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
uuid: 5F55-4C80
ID-3: /home raw-size: 431.02 GiB size: 431.02 GiB (100.00%)
ID-4: /home/<filter>/Drive raw-size: N/A size: 100 GiB
used: 52.7 GiB (52.7%) fs: fuse.rclone remote: Drive:
ID-5: /mnt/sata1_data raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 202.71 GiB (21.8%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 01D6BA11BB090830
ID-6: /mnt/ssd2_data raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 726.11 GiB (77.9%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:5
label: SSD2 Data uuid: cc12dc7c-cc23-4ff6-8cbb-7b71c93da42d
ID-7: /mnt/windows11 raw-size: 500 GiB size: 500 GiB (100.00%)
used: 384.02 GiB (76.8%) fs: ntfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 01DA7B405EFE52E0
ID-8: /var/cache raw-size: 431.02 GiB size: 431.02 GiB (100.00%)
ID-9: /var/log raw-size: 431.02 GiB size: 431.02 GiB (100.00%)
Device-1: 1-4:2 info: Razer USA BlackWidow Chroma type: keyboard,mouse
driver: razerkbd,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0203 class-ID: 0300
Device-2: 1-5:3 info: Corsair HS60 Surround Adapter type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
chip-ID: 1b1c:0a3b class-ID: 0300 serial: <filter>
Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-7.4:6 info: Razer USA Base Station Chroma type: mouse,keyboard
driver: razeraccessory,usbhid interfaces: 3 rev: 2.0
chip-ID: 1532:0f08 class-ID: 0300
Hub-3: 1-11:5 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-11.3:14 info: Razer USA Naga Trinity type: mouse,keyboard
driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0067 class-ID: 0300
serial: <filter>
Hub-4: 1-11.4:15 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8142
Device-1: 1-12:7 info: Integrated Express IT8297 RGB LED Controller
type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
chip-ID: 048d:8297 class-ID: 0301
Hub-5: 1-13:10 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-14:11 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-6: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
Hub-7: 2-7:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
Hub-8: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-9: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 36.0 C pch: 55.0 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (rpm): cpu: 838 fan-2: 0 fan-3: 1250
Power: 12v: N/A 5v: N/A 3.3v: 3.40 vbat: 3.18
Processes: 242 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB
services: power-profiles-daemon,upowerd Init: systemd v: 256
Packages: pm: pacman pkgs: 1616 libs: 487 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Bash (login) v: 5.2.26
running-in: tty 3 inxi: 3.3.35
Jul 08 13:50:30 BambiPC kernel: x86/cpu: SGX disabled by BIOS.
Jul 08 13:50:34 BambiPC kernel: usb 1-11-port1: unable to enumerate USB device
Jul 08 13:50:35 BambiPC bluetoothd[742]: Failed to set mode: Failed (0x03)
Jul 08 13:50:48 BambiPC kcminit_startup[956]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vkkhrdisplay, vnc, xcb, wayland-egl, wayland.
Jul 08 13:50:48 BambiPC ksplashqml[955]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:48 BambiPC systemd-coredump[1007]: Process 956 (kcminit_startup) of user 1000 dumped core.
Stack trace of thread 956:
#0 0x00007fb0e8ea8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fb0e8e50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fb0e8e384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fb0e888c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007fb0e888cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007fb0e90daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007fb0e917b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007fb0e8948c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007fb0e917b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007fb0e9173cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x000056064ad7f198 n/a (kcminit + 0x3198)
#11 0x00007fb0e8e39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007fb0e8e39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000056064ad80675 n/a (kcminit + 0x4675)
Stack trace of thread 959:
#0 0x00007fb0e8f1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007fb0e81918fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fb0e812ef95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fb0e8ba2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007fb0e894f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007fb0e8a3a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007fb0e9888e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007fb0e8ac9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007fb0e8ea6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007fb0e8f2a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 956 (kcminit_startup) dumped core
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Process 956 (kcminit_startup) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Jul 08 13:50:48 BambiPC systemd-coredump[1008]: Process 955 (ksplashqml) of user 1000 dumped core.
Stack trace of thread 955:
#0 0x00007f74bd6a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f74bd650a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f74bd6384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f74bd08c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f74bd08cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f74bd8daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f74bd97b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f74bd148c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f74bd97b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f74bd973cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x0000562b10171668 n/a (ksplashqml + 0x5668)
#11 0x00007f74bd639c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f74bd639d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x0000562b10172325 n/a (ksplashqml + 0x6325)
Stack trace of thread 961:
#0 0x00007f74bd71c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f74bb8e88fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f74bb885f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f74bd3a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f74bd14f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f74bd23a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f74beefee4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f74bd2c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f74bd6a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f74bd72a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 955 (ksplashqml) dumped core
░░ Process 955 (ksplashqml) crashed and dumped core.
Jul 08 13:50:48 BambiPC systemd[910]: Failed to start Splash screen shown during boot.
░░ Subject: A start job for unit UNIT has failed
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 109 and the job result is failed.
Jul 08 13:50:48 BambiPC kded6[1021]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:48 BambiPC systemd-coredump[1040]: Process 1021 (kded6) of user 1000 dumped core.
Stack trace of thread 1021:
#0 0x00007f166f8a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f166f850a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f166f8384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f166f28c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f166f28cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f166fadaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f166fb7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f166f348c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f166fb7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f16704f70b6 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf70b6)
#10 0x00005567c966fe73 n/a (kded6 + 0x5e73)
#11 0x00007f166f839c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f166f839d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x00005567c966fed5 n/a (kded6 + 0x5ed5)
Stack trace of thread 1034:
#0 0x00007f166f91c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f166ebe28fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f166eb7ff95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f166f5a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f166f34f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f166f43a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f1670b38e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f166f4c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f166f8a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f166f92a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1021 (kded6) dumped core
░░ Process 1021 (kded6) crashed and dumped core.
Jul 08 13:50:48 BambiPC systemd[910]: Failed to start KDE Daemon 6.
░░ The job identifier is 83 and the job result is failed.
Jul 08 13:50:48 BambiPC ksmserver[1019]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:48 BambiPC systemd[910]: Failed to start KDE Configuration Module Initialization (Phase 1).
░░ The job identifier is 84 and the job result is failed.
Jul 08 13:50:48 BambiPC systemd-coredump[1060]: Process 1019 (ksmserver) of user 1000 dumped core.
Stack trace of thread 1019:
#0 0x00007f0f7c0a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f0f7c050a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f0f7c0384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f0f7c68c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f0f7c68cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f0f7cedaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f0f7cf7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f0f7c748c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f0f7cf7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f0f7cf73cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x000055c6b69744bd n/a (ksmserver + 0x94bd)
#11 0x00007f0f7c039c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f0f7c039d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000055c6b6976d05 n/a (ksmserver + 0xbd05)
Stack trace of thread 1051:
#0 0x00007f0f7c11c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f0f7bba48fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f0f7bb41f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f0f7c9a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f0f7c74f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f0f7c83a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f0f7cd75e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f0f7c8c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f0f7c0a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f0f7c12a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1019 (ksmserver) dumped core
░░ Process 1019 (ksmserver) crashed and dumped core.
Jul 08 13:50:48 BambiPC systemd[910]: Failed to start KDE Session Management Server.
░░ The job identifier is 79 and the job result is failed.
Jul 08 13:50:48 BambiPC gmenudbusmenuproxy[1080]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:48 BambiPC kdeconnectd[1070]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:48 BambiPC xembedsniproxy[1100]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:48 BambiPC polkit-kde-authentication-agent-1[1093]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:48 BambiPC systemd[910]: Failed to start KDE PolicyKit Authentication Agent.
░░ The job identifier is 106 and the job result is failed.
Jul 08 13:50:48 BambiPC plasmashell[1092]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:48 BambiPC msm_kde_notifier[1069]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Jul 08 13:50:48 BambiPC org_kde_powerdevil[1096]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC xdg-desktop-portal-kde[1098]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC systemd-coredump[1108]: Process 1080 (gmenudbusmenupr) of user 1000 dumped core.
Stack trace of thread 1080:
#0 0x00007fbf266a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fbf26650a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fbf266384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fbf2608c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007fbf2608cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007fbf268daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007fbf2697b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007fbf26148c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007fbf2697b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007fbf26973cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x00005605d99cbc6e n/a (gmenudbusmenuproxy + 0x9c6e)
#11 0x00007fbf26639c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007fbf26639d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x00005605d99cbf45 n/a (gmenudbusmenuproxy + 0x9f45)
Stack trace of thread 1099:
#0 0x00007fbf2671c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007fbf25acf8fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fbf25a6cf95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fbf263a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007fbf2614f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007fbf2623a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007fbf27235e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007fbf262c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007fbf266a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007fbf2672a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1080 (gmenudbusmenupr) dumped core
░░ Process 1080 (gmenudbusmenupr) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd-coredump[1121]: Process 1100 (xembedsniproxy) of user 1000 dumped core.
Stack trace of thread 1100:
#0 0x00007fef93ea8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fef93e50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fef93e384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fef9388c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007fef9388cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007fef940daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007fef9417b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007fef93948c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007fef9417b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007fef94173cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x0000556f79a76265 n/a (xembedsniproxy + 0x6265)
#11 0x00007fef93e39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007fef93e39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x0000556f79a76665 n/a (xembedsniproxy + 0x6665)
Stack trace of thread 1116:
#0 0x00007fef93f1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007fef933208fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fef932bdf95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fef93ba2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007fef9394f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007fef93a3a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007fef94a30e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007fef93ac9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007fef93ea6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007fef93f2a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1100 (xembedsniproxy) dumped core
░░ Process 1100 (xembedsniproxy) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd-coredump[1112]: Process 1070 (kdeconnectd) of user 1000 dumped core.
Stack trace of thread 1070:
#0 0x00007f70b24a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f70b2450a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f70b24384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f70b1e8c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f70b1e8cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f70b26daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f70b277b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f70b1f48c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f70b277b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f70b30f70b6 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf70b6)
#10 0x000056210683e411 n/a (kdeconnectd + 0x3411)
#11 0x00007f70b2439c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f70b2439d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000056210683eb85 n/a (kdeconnectd + 0x3b85)
Stack trace of thread 1105:
#0 0x00007f70b251c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f70b106f8fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f70b100cf95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f70b21a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f70b1f4f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f70b203a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f70b37ebe4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f70b20c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f70b24a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f70b252a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1070 (kdeconnectd) dumped core
░░ Process 1070 (kdeconnectd) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd-coredump[1151]: Process 1069 (msm_kde_notifie) of user 1000 dumped core.
Stack trace of thread 1069:
#0 0x00007f27c02a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f27c0250a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f27c02384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f27c0898143 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x98143)
#4 0x00007f27c0f32da7 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x132da7)
#5 0x00007f27c0f33451 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x133451)
#6 0x00007f27c0ab337d _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x2b337d)
#7 0x00007f27c0f33507 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x133507)
#8 0x00007f27c1753586 _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x153586)
#9 0x000055e653fe752c n/a (msm_kde_notifier + 0xa52c)
#10 0x00007f27c0239c88 n/a (libc.so.6 + 0x25c88)
#11 0x00007f27c0239d4c __libc_start_main (libc.so.6 + 0x25d4c)
#12 0x000055e653fe7e95 _start (msm_kde_notifier + 0xae95)
Stack trace of thread 1130:
#0 0x00007f27c031c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f27bf6058fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f27bf5a2f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f27c0afa37f _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2fa37f)
#4 0x00007f27c0aa382c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2a382c)
#5 0x00007f27c08f277d _ZN7QThread4execEv (libQt5Core.so.5 + 0xf277d)
#6 0x00007f27c0d6fb23 n/a (libQt5DBus.so.5 + 0x17b23)
#7 0x00007f27c08f261b n/a (libQt5Core.so.5 + 0xf261b)
#8 0x00007f27c02a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f27c032a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1069 (msm_kde_notifie) dumped core
░░ Process 1069 (msm_kde_notifie) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd-coredump[1136]: Process 1092 (plasmashell) of user 1000 dumped core.
Stack trace of thread 1092:
#0 0x00007f14258a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f1425850a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f14258384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f142528c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f142528cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f1425adaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f1425b7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f1425348c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f1425b7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f14274f70b6 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf70b6)
#10 0x000055e1fb2e5ed8 n/a (plasmashell + 0x23ed8)
#11 0x00007f1425839c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f1425839d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000055e1fb2e9255 n/a (plasmashell + 0x27255)
Stack trace of thread 1131:
#0 0x00007f142591c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f142408a8fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f1424027f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f14255a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f142534f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f142543a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f1426975e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f14254c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f14258a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f142592a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1092 (plasmashell) dumped core
░░ Process 1092 (plasmashell) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd[910]: Failed to start KDE Plasma Workspace.
░░ The job identifier is 82 and the job result is failed.
Jul 08 13:50:49 BambiPC polkit-kde-authentication-agent-1[1192]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC systemd[910]: Failed to start KDE PolicyKit Authentication Agent.
░░ The job identifier is 262 and the job result is failed.
Jul 08 13:50:49 BambiPC systemd-coredump[1184]: Process 1096 (org_kde_powerde) of user 1000 dumped core.
Stack trace of thread 1096:
#0 0x00007fea59ca8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fea59c50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fea59c384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fea5968c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007fea5968cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007fea59edaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007fea59f7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007fea59748c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007fea59f7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007fea59f73cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x0000564174fce0ac n/a (org_kde_powerdevil + 0x70ac)
#11 0x00007fea59c39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007fea59c39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x0000564174fce995 n/a (org_kde_powerdevil + 0x7995)
Stack trace of thread 1137:
#0 0x00007fea59d1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007fea57d708fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fea57d0df95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fea599a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007fea5974f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007fea5983a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007fea5a6e2e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007fea598c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007fea59ca6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007fea59d2a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1096 (org_kde_powerde) dumped core
░░ Process 1096 (org_kde_powerde) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd[910]: Failed to start Powerdevil.
░░ The job identifier is 91 and the job result is failed.
Jul 08 13:50:49 BambiPC systemd-coredump[1185]: Process 1098 (xdg-desktop-por) of user 1000 dumped core.
Stack trace of thread 1098:
#0 0x00007f16e6ca8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f16e6c50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f16e6c384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f16e668c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f16e668cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f16e6edaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f16e6f7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f16e6748c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f16e6f7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f16e78f70b6 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf70b6)
#10 0x000055855d9073a0 n/a (xdg-desktop-portal-kde + 0x273a0)
#11 0x00007f16e6c39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f16e6c39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000055855d9078d5 n/a (xdg-desktop-portal-kde + 0x278d5)
Stack trace of thread 1139:
#0 0x00007f16e6d1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f16e443a8fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f16e43d7f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f16e69a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f16e674f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f16e683a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f16e803de4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f16e68c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f16e6ca6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f16e6d2a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1098 (xdg-desktop-por) dumped core
░░ Process 1098 (xdg-desktop-por) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd[910]: Failed to start Xdg Desktop Portal For KDE.
░░ The job identifier is 191 and the job result is failed.
Jul 08 13:50:49 BambiPC gmenudbusmenuproxy[1207]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC xembedsniproxy[1213]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC xdg-desktop-portal-kde[1214]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC systemd-coredump[1230]: Process 1207 (gmenudbusmenupr) of user 1000 dumped core.
Stack trace of thread 1207:
#0 0x00007f5f176e9e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f5f17691a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f5f176794c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f5f1668c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f5f1668cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f5f16edaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f5f16f7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f5f16748c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f5f16f7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f5f16f73cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x0000564985f75c6e n/a (gmenudbusmenuproxy + 0x9c6e)
#11 0x00007f5f1767ac88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f5f1767ad4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x0000564985f75f45 n/a (gmenudbusmenuproxy + 0x9f45)
Stack trace of thread 1215:
#0 0x00007f5f1775d39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f5f161208fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f5f160bdf95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f5f169a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f5f1674f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f5f1683a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f5f17870e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f5f168c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f5f176e7ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f5f1776b0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1207 (gmenudbusmenupr) dumped core
░░ Process 1207 (gmenudbusmenupr) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd-coredump[1231]: Process 1213 (xembedsniproxy) of user 1000 dumped core.
Stack trace of thread 1213:
#0 0x00007f7a210a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f7a21050a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f7a210384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f7a20a8c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f7a20a8cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f7a212daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f7a2137b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f7a20b48c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f7a2137b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f7a21373cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x000055e4f1053265 n/a (xembedsniproxy + 0x6265)
#11 0x00007f7a21039c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f7a21039d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000055e4f1053665 n/a (xembedsniproxy + 0x6665)
Stack trace of thread 1219:
#0 0x00007f7a2111c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f7a205208fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f7a204bdf95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f7a20da2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f7a20b4f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f7a20c3a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f7a21bc4e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f7a20cc9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f7a210a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f7a2112a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1213 (xembedsniproxy) dumped core
░░ Process 1213 (xembedsniproxy) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd-coredump[1236]: Process 1214 (xdg-desktop-por) of user 1000 dumped core.
Stack trace of thread 1214:
#0 0x00007fefe98a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fefe9850a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fefe98384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fefe928c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007fefe928cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007fefe9adaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007fefe9b7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007fefe9348c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007fefe9b7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007fefea4f70b6 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf70b6)
#10 0x00005631d86243a0 n/a (xdg-desktop-portal-kde + 0x273a0)
#11 0x00007fefe9839c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007fefe9839d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x00005631d86248d5 n/a (xdg-desktop-portal-kde + 0x278d5)
Stack trace of thread 1232:
#0 0x00007fefe991c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007fefe6fc78fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fefe6f64f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fefe95a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007fefe934f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007fefe943a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007fefeac23e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007fefe94c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007fefe98a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007fefe992a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1214 (xdg-desktop-por) dumped core
░░ Process 1214 (xdg-desktop-por) crashed and dumped core.
░░ The job identifier is 322 and the job result is failed.
Jul 08 13:50:49 BambiPC polkit-kde-authentication-agent-1[1245]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
░░ The job identifier is 362 and the job result is failed.
Jul 08 13:50:49 BambiPC org_kde_powerdevil[1246]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC plasmashell[1242]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC xdg-desktop-portal-kde[1255]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC xembedsniproxy[1278]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC gmenudbusmenuproxy[1276]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC polkit-kde-authentication-agent-1[1277]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
░░ The job identifier is 442 and the job result is failed.
Jul 08 13:50:49 BambiPC systemd-coredump[1302]: Process 1278 (xembedsniproxy) of user 1000 dumped core.
Stack trace of thread 1278:
#0 0x00007f4f39ca8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f4f39c50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f4f39c384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f4f3968c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f4f3968cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f4f39edaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f4f39f7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f4f39748c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f4f39f7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f4f39f73cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x000056028d2c2265 n/a (xembedsniproxy + 0x6265)
#11 0x00007f4f39c39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f4f39c39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000056028d2c2665 n/a (xembedsniproxy + 0x6665)
Stack trace of thread 1292:
#0 0x00007f4f39d1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f4f38fe48fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f4f38f81f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f4f399a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f4f3974f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f4f3983a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f4f3a6e1e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f4f398c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f4f39ca6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f4f39d2a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1278 (xembedsniproxy) dumped core
░░ Process 1278 (xembedsniproxy) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd-coredump[1303]: Process 1276 (gmenudbusmenupr) of user 1000 dumped core.
Stack trace of thread 1276:
#0 0x00007fb4afca8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fb4afc50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fb4afc384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fb4af68c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007fb4af68cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007fb4afedaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007fb4aff7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007fb4af748c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007fb4aff7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007fb4aff73cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x00005595a58ccc6e n/a (gmenudbusmenuproxy + 0x9c6e)
#11 0x00007fb4afc39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007fb4afc39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x00005595a58ccf45 n/a (gmenudbusmenuproxy + 0x9f45)
Stack trace of thread 1294:
#0 0x00007fb4afd1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007fb4af0328fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fb4aefcff95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fb4af9a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007fb4af74f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007fb4af83a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007fb4b0775e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007fb4af8c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007fb4afca6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007fb4afd2a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1276 (gmenudbusmenupr) dumped core
░░ Process 1276 (gmenudbusmenupr) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd-coredump[1293]: Process 1246 (org_kde_powerde) of user 1000 dumped core.
Stack trace of thread 1246:
#0 0x00007f1cf0ea8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f1cf0e50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f1cf0e384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f1cf088c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f1cf088cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f1cf10daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f1cf117b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f1cf0948c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f1cf117b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f1cf1173cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x0000561cacd660ac n/a (org_kde_powerdevil + 0x70ac)
#11 0x00007f1cf0e39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f1cf0e39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x0000561cacd66995 n/a (org_kde_powerdevil + 0x7995)
Stack trace of thread 1257:
#0 0x00007f1cf0f1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f1cef1708fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f1cef10df95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f1cf0ba2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f1cf094f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f1cf0a3a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f1cf19f2e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f1cf0ac9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f1cf0ea6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f1cf0f2a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1246 (org_kde_powerde) dumped core
░░ Process 1246 (org_kde_powerde) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd-coredump[1300]: Process 1242 (plasmashell) of user 1000 dumped core.
Stack trace of thread 1242:
#0 0x00007fdf908a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fdf90850a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fdf908384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fdf9028c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007fdf9028cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007fdf90adaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007fdf90b7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007fdf90348c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007fdf90b7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007fdf924f70b6 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf70b6)
#10 0x000055dc1328aed8 n/a (plasmashell + 0x23ed8)
#11 0x00007fdf90839c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007fdf90839d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000055dc1328e255 n/a (plasmashell + 0x27255)
Stack trace of thread 1260:
#0 0x00007fdf9091c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007fdf8f1d28fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fdf8f16ff95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fdf905a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007fdf9034f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007fdf9043a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007fdf921c1e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007fdf904c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007fdf908a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007fdf9092a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1242 (plasmashell) dumped core
░░ Process 1242 (plasmashell) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd-coredump[1301]: Process 1255 (xdg-desktop-por) of user 1000 dumped core.
Stack trace of thread 1255:
#0 0x00007fc20c2a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fc20c250a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fc20c2384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fc20bc8c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007fc20bc8cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007fc20c4daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007fc20c57b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007fc20bd48c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007fc20c57b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007fc20cef70b6 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf70b6)
#10 0x0000561e57daa3a0 n/a (xdg-desktop-portal-kde + 0x273a0)
#11 0x00007fc20c239c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007fc20c239d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x0000561e57daa8d5 n/a (xdg-desktop-portal-kde + 0x278d5)
Stack trace of thread 1266:
#0 0x00007fc20c31c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007fc2099258fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fc2098c2f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fc20bfa2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007fc20bd4f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007fc20be3a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007fc20d5b9e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007fc20bec9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007fc20c2a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007fc20c32a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1255 (xdg-desktop-por) dumped core
░░ Process 1255 (xdg-desktop-por) crashed and dumped core.
░░ The job identifier is 382 and the job result is failed.
░░ The job identifier is 342 and the job result is failed.
░░ The job identifier is 402 and the job result is failed.
Jul 08 13:50:49 BambiPC polkit-kde-authentication-agent-1[1324]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
░░ The job identifier is 502 and the job result is failed.
Jul 08 13:50:49 BambiPC xdg-desktop-portal-kde[1319]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC gmenudbusmenuproxy[1338]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC xembedsniproxy[1339]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC plasmashell[1343]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC org_kde_powerdevil[1344]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC systemd-coredump[1366]: Process 1339 (xembedsniproxy) of user 1000 dumped core.
Stack trace of thread 1339:
#0 0x00007f2807aa8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f2807a50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f2807a384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f280748c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f280748cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f2807cdaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f2807d7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f2807548c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f2807d7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f2807d73cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x000056483e3ec265 n/a (xembedsniproxy + 0x6265)
#11 0x00007f2807a39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f2807a39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000056483e3ec665 n/a (xembedsniproxy + 0x6665)
Stack trace of thread 1345:
#0 0x00007f2807b1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f2806de48fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f2806d81f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f28077a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f280754f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f280763a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f2808500e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f28076c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f2807aa6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f2807b2a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1339 (xembedsniproxy) dumped core
░░ Process 1339 (xembedsniproxy) crashed and dumped core.
░░ The job identifier is 602 and the job result is failed.
Jul 08 13:50:49 BambiPC systemd-coredump[1368]: Process 1338 (gmenudbusmenupr) of user 1000 dumped core.
Stack trace of thread 1338:
#0 0x00007fdece2a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fdece250a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fdece2384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fdecdc8c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007fdecdc8cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007fdece4daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007fdece57b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007fdecdd48c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007fdece57b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007fdece573cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x0000558e1690dc6e n/a (gmenudbusmenuproxy + 0x9c6e)
#11 0x00007fdece239c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007fdece239d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x0000558e1690df45 n/a (gmenudbusmenuproxy + 0x9f45)
Stack trace of thread 1346:
#0 0x00007fdece31c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007fdecd6328fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fdecd5cff95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fdecdfa2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007fdecdd4f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007fdecde3a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007fdeced6ce4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007fdecdec9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007fdece2a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007fdece32a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1338 (gmenudbusmenupr) dumped core
░░ Process 1338 (gmenudbusmenupr) crashed and dumped core.
Jul 08 13:50:49 BambiPC systemd-coredump[1365]: Process 1319 (xdg-desktop-por) of user 1000 dumped core.
Stack trace of thread 1319:
#0 0x00007f9a850a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f9a85050a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f9a850384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f9a84a8c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f9a84a8cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f9a852daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f9a8537b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f9a84b48c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f9a8537b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f9a85cf70b6 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf70b6)
#10 0x000056237f7c03a0 n/a (xdg-desktop-portal-kde + 0x273a0)
#11 0x00007f9a85039c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f9a85039d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000056237f7c08d5 n/a (xdg-desktop-portal-kde + 0x278d5)
Stack trace of thread 1331:
#0 0x00007f9a8511c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f9a828898fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f9a82826f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f9a84da2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f9a84b4f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f9a84c3a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f9a864a7e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f9a84cc9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f9a850a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f9a8512a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1319 (xdg-desktop-por) dumped core
░░ Process 1319 (xdg-desktop-por) crashed and dumped core.
░░ The job identifier is 482 and the job result is failed.
Jul 08 13:50:49 BambiPC systemd-coredump[1379]: Process 1343 (plasmashell) of user 1000 dumped core.
Stack trace of thread 1343:
#0 0x00007f83ba6a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f83ba650a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f83ba6384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f83ba08c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f83ba08cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f83ba8daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f83ba97b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f83ba148c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f83ba97b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f83bc2f70b6 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf70b6)
#10 0x000055cf7b55ced8 n/a (plasmashell + 0x23ed8)
#11 0x00007f83ba639c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f83ba639d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000055cf7b560255 n/a (plasmashell + 0x27255)
Stack trace of thread 1372:
#0 0x00007f83ba71c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f83b8f968fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f83b8f33f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f83ba3a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f83ba14f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f83ba23a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f83bbf74e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f83ba2c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f83ba6a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f83ba72a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1343 (plasmashell) dumped core
░░ Process 1343 (plasmashell) crashed and dumped core.
░░ The job identifier is 562 and the job result is failed.
Jul 08 13:50:49 BambiPC systemd-coredump[1380]: Process 1344 (org_kde_powerde) of user 1000 dumped core.
Stack trace of thread 1344:
#0 0x00007f1fe8aa8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f1fe8a50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f1fe8a384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f1fe848c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f1fe848cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f1fe8cdaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f1fe8d7b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f1fe8548c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f1fe8d7b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f1fe8d73cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x000055567714f0ac n/a (org_kde_powerdevil + 0x70ac)
#11 0x00007f1fe8a39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f1fe8a39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000055567714f995 n/a (org_kde_powerdevil + 0x7995)
Stack trace of thread 1374:
#0 0x00007f1fe8b1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f1fe6b708fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f1fe6b0df95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f1fe87a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f1fe854f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f1fe863a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f1fe9504e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f1fe86c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f1fe8aa6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f1fe8b2a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1344 (org_kde_powerde) dumped core
░░ Process 1344 (org_kde_powerde) crashed and dumped core.
░░ The job identifier is 582 and the job result is failed.
Jul 08 13:50:49 BambiPC xdg-desktop-portal-kde[1393]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC gmenudbusmenuproxy[1413]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC xembedsniproxy[1414]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:49 BambiPC systemd-coredump[1412]: Process 1393 (xdg-desktop-por) of user 1000 dumped core.
Stack trace of thread 1393:
#0 0x00007ff1864a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007ff186450a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007ff1864384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007ff185e8c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007ff185e8cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007ff1866daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007ff18677b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007ff185f48c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007ff18677b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007ff1870f70b6 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf70b6)
#10 0x00005623e57873a0 n/a (xdg-desktop-portal-kde + 0x273a0)
#11 0x00007ff186439c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007ff186439d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x00005623e57878d5 n/a (xdg-desktop-portal-kde + 0x278d5)
Stack trace of thread 1408:
#0 0x00007ff18651c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007ff183d208fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007ff183cbdf95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007ff1861a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007ff185f4f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007ff18603a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007ff188175e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007ff1860c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007ff1864a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007ff18652a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1393 (xdg-desktop-por) dumped core
░░ Process 1393 (xdg-desktop-por) crashed and dumped core.
░░ The job identifier is 622 and the job result is failed.
░░ The job identifier is 702 and the job result is failed.
░░ The job identifier is 722 and the job result is failed.
░░ The job identifier is 742 and the job result is failed.
░░ The job identifier is 762 and the job result is failed.
Jul 08 13:50:50 BambiPC systemd[910]: Failed to start Xdg Desktop Portal For KDE.
░░ The job identifier is 804 and the job result is failed.
░░ The job identifier is 824 and the job result is failed.
░░ The job identifier is 844 and the job result is failed.
░░ The job identifier is 864 and the job result is failed.
░░ The job identifier is 884 and the job result is failed.
░░ The job identifier is 904 and the job result is failed.
░░ The job identifier is 924 and the job result is failed.
░░ The job identifier is 944 and the job result is failed.
░░ The job identifier is 964 and the job result is failed.
░░ The job identifier is 984 and the job result is failed.
░░ The job identifier is 1004 and the job result is failed.
Jul 08 13:50:50 BambiPC org_kde_powerdevil[1433]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jul 08 13:50:50 BambiPC systemd-coredump[1477]: Process 1414 (xembedsniproxy) of user 1000 dumped core.
Stack trace of thread 1414:
#0 0x00007f54a4ea8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f54a4e50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f54a4e384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f54a488c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f54a488cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f54a50daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f54a517b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f54a4948c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f54a517b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f54a5173cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x000055bf15dca265 n/a (xembedsniproxy + 0x6265)
#11 0x00007f54a4e39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f54a4e39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000055bf15dca665 n/a (xembedsniproxy + 0x6665)
Stack trace of thread 1416:
#0 0x00007f54a4f1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f54a43708fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f54a430df95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f54a4ba2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f54a494f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f54a4a3a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f54a5a60e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f54a4ac9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f54a4ea6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f54a4f2a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1414 (xembedsniproxy) dumped core
░░ Process 1414 (xembedsniproxy) crashed and dumped core.
Jul 08 13:50:50 BambiPC systemd-coredump[1478]: Process 1413 (gmenudbusmenupr) of user 1000 dumped core.
Stack trace of thread 1413:
#0 0x00007f702f0ede44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f702f095a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f702f07d4c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f702e08c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f702e08cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f702e8daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f702e97b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f702e148c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f702e97b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f702e973cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x00005586c5b5ac6e n/a (gmenudbusmenuproxy + 0x9c6e)
#11 0x00007f702f07ec88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f702f07ed4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x00005586c5b5af45 n/a (gmenudbusmenuproxy + 0x9f45)
Stack trace of thread 1415:
#0 0x00007f702f16139d __poll (libc.so.6 + 0x10839d)
#1 0x00007f702db208fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f702dabdf95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f702e3a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f702e14f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f702e23a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f702f274e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f702e2c9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f702f0ebded n/a (libc.so.6 + 0x92ded)
#9 0x00007f702f16f0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1413 (gmenudbusmenupr) dumped core
░░ Process 1413 (gmenudbusmenupr) crashed and dumped core.
Jul 08 13:50:50 BambiPC systemd-coredump[1479]: Process 1433 (org_kde_powerde) of user 1000 dumped core.
Stack trace of thread 1433:
#0 0x00007f3d682a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f3d68250a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f3d682384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f3d67c8c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007f3d67c8cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007f3d684daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f3d6857b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007f3d67d48c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007f3d6857b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007f3d68573cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x0000555a735340ac n/a (org_kde_powerdevil + 0x70ac)
#11 0x00007f3d68239c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f3d68239d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x0000555a73534995 n/a (org_kde_powerdevil + 0x7995)
Stack trace of thread 1462:
#0 0x00007f3d6831c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f3d663708fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f3d6630df95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f3d67fa2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007f3d67d4f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007f3d67e3a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007f3d68cafe4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007f3d67ec9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007f3d682a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f3d6832a0dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1433 (org_kde_powerde) dumped core
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Process 1433 (org_kde_powerde) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Jul 08 13:50:50 BambiPC systemd[910]: Failed to start Powerdevil.
░░ The job identifier is 682 and the job result is failed.
Jul 08 13:50:50 BambiPC systemd[910]: Failed to start Proxies GTK DBus menus to a Plasma readable format.
░░ The job identifier is 1064 and the job result is failed.
Jul 08 13:50:50 BambiPC systemd[910]: Failed to start Handle legacy xembed system tray icons.
░░ The job identifier is 1024 and the job result is failed.
Jul 08 13:50:50 BambiPC org_kde_powerdevil[1514]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vkkhrdisplay, vnc, xcb, wayland-egl, wayland.
Jul 08 13:50:50 BambiPC systemd-coredump[1519]: Process 1514 (org_kde_powerde) of user 1000 dumped core.
Stack trace of thread 1514:
#0 0x00007fab45aeee44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fab45a96a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fab45a7e4c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fab44a8c643 n/a (libQt6Core.so.6 + 0x8c643)
#4 0x00007fab44a8cde7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8cde7)
#5 0x00007fab452daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007fab4537b038 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17b038)
#7 0x00007fab44b48c65 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148c65)
#8 0x00007fab4537b0ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17b0ce)
#9 0x00007fab45373cdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173cdd)
#10 0x0000555e74ec80ac n/a (org_kde_powerdevil + 0x70ac)
#11 0x00007fab45a7fc88 n/a (libc.so.6 + 0x25c88)
#12 0x00007fab45a7fd4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x0000555e74ec8995 n/a (org_kde_powerdevil + 0x7995)
Stack trace of thread 1515:
#0 0x00007fab45b6239d __poll (libc.so.6 + 0x10839d)
#1 0x00007fab433708fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fab4330df95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fab44da2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
#4 0x00007fab44b4f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
#5 0x00007fab44c3a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
#6 0x00007fab45c73e4e n/a (libQt6DBus.so.6 + 0x2de4e)
#7 0x00007fab44cc9747 n/a (libQt6Core.so.6 + 0x2c9747)
#8 0x00007fab45aecded n/a (libc.so.6 + 0x92ded)
#9 0x00007fab45b700dc n/a (libc.so.6 + 0x1160dc)
░░ Subject: Process 1514 (org_kde_powerde) dumped core
░░ Process 1514 (org_kde_powerde) crashed and dumped core.
░░ Subject: A start job for unit UNIT has failed
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 1044 and the job result is failed.
░░ The job identifier is 1084 and the job result is failed.
Jul 08 13:56:10 BambiPC pipewire[1439]: spa.alsa: 'plug:{SLAVE="a52:1,'hw:%f,3'"}': playback open failed: No such device
Jul 08 13:56:10 BambiPC pipewire[1439]: mod.adapter: usage: node.name=<string>
Jul 08 14:14:39 BambiPC rclone[829]: ERROR : /home/evan/Drive: Unmounted rclone mount
Jul 08 14:14:40 BambiPC dbus-broker-launch[739]: Activation request for 'org.bluez' failed.
Jul 08 14:14:40 BambiPC dbus-broker-launch[739]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
I’ve tried reinstalling qt5-wayland and pacman -Syu runs fine and says there’s nothing to do. I’ve also reinstalled the nvidia-all drivers just to make sure that’s not an issue. I had a bunch of AUR packages installed including the xorg-wayland-explicit-sync-git and the xwaylandvideobridge packages but uninstalled them in favor of the system packages to make sure they weren’t causing any weirdness.
I’ve also tried adding environment variables such as QT_PLUGIN_PATH=/usr/lib/qt/plugins to see if that helped. I’ve followed some of the information in other forum posts [SOLVED] qt.qpa.plugin: Could not find the Qt platform plugin "xcb" in "" | Qt Forum and How to fix broken KDE Desktop (Qt).
Any help or guidance would be most appreciated! And any advice on how to avoid these issues or improve my log analysis to be able to correct future problems would be always welcomed! Thanks!
