Qt creator crashes
hi,
qt creator crashes on startup, this is what I see in dmesg:
[ 3119.820810] qtcreator[19475]: segfault at 0 ip 00007f1f65dabd41 sp 00007fffbf16c0d0 error 4 in libQt6Widgets.so.6.10.1[5abd41,7f1f658ea000+4e0000] likely on CPU 2 (core 0, socket 0)
[ 3119.820826] Code: 15 0c c3 18 00 84 c0 75 0e 4c 89 ee 49 8d 7c 24 40 ff 15 da ec 18 00 48 8b 43 18 49 8b bc 24 d8 00 00 00 48 8d b0 88 00 00 00 <48> 8b 07 ff 90 30 01 00 00 84 c0 75 12 5b 41 5c 41 5d 41 5e 5d c3
any help would be appreciated
Formatting tip
When posting terminal output - quote may look nice - but code looks better
Example: select the text and presse the </> button in the toolbar or press Ctrl+E
All I can say is: Make sure your system is up-to-date.
If it is up-to-date I would be suspicious of text
EDIT:
I have verified on my main workstation
KDE Plasma Version: 6.5.4
KDE Frameworks Version: 6.21.0
Qt Version: 6.10.1
Kernel Version: 6.18.2-1-MANJARO (64-bit)
qtcreator does not segfault on my system - that does not imply anything but the fact that I cannot reproduce it.
Qt creator works fine for me.
This would be the first thing. Please check the version numbers of Qt creator and the qt6-... packages. If this is ok, test with another user just to be sure. If it runs into the same segfault you need a stack trace that is helpful. You find these with coredumpctl list and you symbolise a specific entry (if the corefile is still present) with coredumpctl debug [PID].
