I updated my system today after having problems to start QSynth.
Running on a Fujitsu Esprimo with Intel i-5, 12 GB ram.
Jack is not giving any errors.
After update I am still getting as before:
22:15:05.980 Qsynth1: Creating synthesizer engine...
22:15:05.989 Qsynth1: Creating audio driver (jack)...
22:15:06.006 Qsynth1: Creating MIDI router (alsa_seq)...
22:15:06.006 Qsynth1: Creating MIDI driver (alsa_seq)...
22:15:06.008 Qsynth1: fluid_synth_set_reverb_on(1)
22:15:06.008 Qsynth1: fluid_synth_set_chorus_on(1)
22:15:06.009 Qsynth1: Synthesizer engine started.
22:15:06.010 Qsynth1: fluid_synth_set_gain(1)
22:15:06.010 Qsynth1: fluid_synth_set_reverb(0.2,0,0.5,0.9)
22:15:06.010 Qsynth1: fluid_synth_set_chorus(3,1,0.3,8,0)
ALSA lib pcm_dsnoop.c:566:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_dmix.c:999:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
Cannot lock down 107341340 byte memory area (Kan inte allokera minne)
ALSA lib pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib pcm_a52.c:1001:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib confmisc.c:160:(snd_config_get_card) Invalid field card
ALSA lib pcm_usb_stream.c:482:(_snd_pcm_usb_stream_open) Invalid card 'card'
fluidsynth: error: requested set value for setting 'synth.midi-channels' out of range
fluidsynth: warning: Requested audio-channels to high. Limiting this setting to audio-groups.
fluidsynth: Connection of Midi Through Port-0 succeeded
fluidsynth: warning: No preset found on channel 0 [bank=0 prog=0]
fluidsynth: warning: No preset found on channel 1 [bank=0 prog=1]
fluidsynth: warning: No preset found on channel 2 [bank=0 prog=2]
fluidsynth: warning: No preset found on channel 3 [bank=0 prog=3]
fluidsynth: warning: No preset found on channel 4 [bank=0 prog=4]
fluidsynth: warning: No preset found on channel 5 [bank=0 prog=5]
fluidsynth: warning: No preset found on channel 6 [bank=0 prog=6]
fluidsynth: warning: No preset found on channel 7 [bank=0 prog=7]
fluidsynth: warning: No preset found on channel 8 [bank=0 prog=8]
fluidsynth: warning: No preset found on channel 9 [bank=128 prog=9]
fluidsynth: warning: No preset found on channel 10 [bank=0 prog=10]
fluidsynth: warning: No preset found on channel 11 [bank=0 prog=11]
fluidsynth: warning: No preset found on channel 12 [bank=0 prog=12]
fluidsynth: warning: No preset found on channel 13 [bank=0 prog=13]
fluidsynth: warning: No preset found on channel 14 [bank=0 prog=14]
fluidsynth: warning: No preset found on channel 15 [bank=0 prog=15]
fluidsynth: warning: Failed to set thread to high priority
I don’t understand most of this message. Will be grateful for help!
