So the most recent large update (~1.1gb) to Qonos 21.2.0 I think it was, broke my dual-monitor support on Prime.
Prior to that I was happily using Prime on xorg with dual-monitors via the 495 NV driver and enjoying decent desktop and gaming performance. Since the update hit I have these options:
- Use my laptop screen only (by selecting Wayland… Intel)
- Use my TV screen only (by selecting xorg… nvidia)
I would like to be able to use both together again.
Things I have tried:
- Upgrading to latest version of Prime.
- I have tried upgrading to the 5.15 kernel (from 5.10 LTS) just in case it’s required for latest NV driver.
Here are some logs which may be of use if anyone is able to assist (from my xorg/nvidia/TV login).
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=fd7209c8-38d6-4ae4-9306-da051cd67194 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: Dell product: Inspiron 15 7000 Gaming v: N/A
Mobo: Dell model: 065C71 v: A00 serial: <superuser required> UEFI: Dell
v: 1.13.1 date: 12/18/2020
ID-1: BAT0 charge: 71.1 Wh (100.0%) condition: 71.1/74.0 Wh (96.1%)
volts: 12.5 min: 11.1 model: Samsung SDI DELL 0GFJ679 type: Li-ion
serial: <filter> status: Full
RAM: total: 15.37 GiB used: 2.42 GiB (15.7%)
RAM Report:
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1449 high: 1863 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1332 2: 1863 3: 1542
4: 1489 5: 1543 6: 1587 7: 1239 8: 1004 bogomips: 44817
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0300
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-12:7 chip-ID: 1bcf:28c1 class-ID: 0e02
Display: x11 server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: modesetting,nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
vendor: Dell driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel bus-ID: 03:00.0
chip-ID: 8086:3165 class-ID: 0280
IF-ID-1: anbox0 state: down mac: <filter>
IP v4: <filter> scope: global
bus-ID: 1-4:5 chip-ID: 8087:0a2a class-ID: e001
Device-1: luks-5f2ba54f-9809-4737-84e0-17acea13f6b3 maj-min: 254:0
type: LUKS dm: dm-0 size: 931.51 GiB
Components:
p-1: sdb1 maj-min: 8:17 size: 931.51 GiB
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.94 TiB used: 843.74 GiB (42.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung
model: SSD PM871b M.2 2280 128GB size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 2D0Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ABD100
type: HDD rpm: 5400 serial: <filter> rev: 3D scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD10EAVS-00D7B1 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.75 scheme: MBR
ID-1: / raw-size: 103.74 GiB size: 103.74 GiB (100.00%)
used: 50.16 GiB (48.4%) fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: fd7209c8-38d6-4ae4-9306-da051cd67194
ID-2: /boot/efi raw-size: 500 MiB size: 496 MiB (99.20%)
used: 286.3 MiB (57.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: ESP
uuid: B2E8-7CF1
ID-3: /home raw-size: 103.74 GiB size: 103.74 GiB (100.00%)
ID-4: /mnt/homextra raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 437.93 GiB (47.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5f2ba54f-9809-4737-84e0-17acea13f6b3 label: homextra
uuid: c8146705-d73f-4dce-9651-7abb7e2d9d0f
ID-5: /run/media/sam/EXT_BKUP raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 355.36 GiB (38.1%) fs: btrfs dev: /dev/sdc1
maj-min: 8:33 label: EXT_BKUP uuid: 498e2912-5101-4c5d-a73a-1be0819cb132
ID-6: /run/timeshift/backup raw-size: 103.74 GiB
size: 103.74 GiB (100.00%) used: 50.16 GiB (48.4%) fs: btrfs dev: /dev/sda3
maj-min: 8:3 label: N/A uuid: fd7209c8-38d6-4ae4-9306-da051cd67194
ID-7: /var/cache raw-size: 103.74 GiB size: 103.74 GiB (100.00%)
ID-8: /var/log raw-size: 103.74 GiB size: 103.74 GiB (100.00%)
ID-1: /dev/sda2 maj-min: 8:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda4 maj-min: 8:4 size: 464 MiB fs: ntfs label: WINRETOOLS
uuid: 3E48C3C648C37AE3
ID-3: /dev/sda5 maj-min: 8:5 size: 13.37 GiB fs: ntfs label: Image
uuid: 18AEC403AEC3D800
ID-4: /dev/sda6 maj-min: 8:6 size: 1.06 GiB fs: ntfs label: N/A
uuid: 361AE9021AE8BFCB
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-2:2 info: Unknown Manufacturer ports: 4 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0a05:0002 class-ID: 0900
Device-1: 1-2.1:4 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2521 class-ID: 0301
Hub-3: 1-2.2:6 info: Dell Multimedia Pro Keyboard Hub ports: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 413c:1005 class-ID: 0900
Device-1: 1-2.2.1:9 info: Dell Multimedia Pro Keyboard type: Keyboard,HID
power: 90mA chip-ID: 413c:2011 class-ID: 0300
Device-2: 1-2.3:8 info: Microsoft Wireless keyboard (All-in-One-Media)
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 045e:0800 class-ID: 0300
Device-3: 1-3:3
info: Western Digital My Book Essential Edition 2.0 (WDH1U)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 1058:1100 class-ID: 0806
serial: <filter>
Device-4: 1-4:5 info: Intel Bluetooth wireless interface type: Bluetooth
Device-5: 1-12:7 info: Sunplus Innovation Integrated_Webcam_HD type: Video
Hub-4: 2-0:1 info: Super-speed hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 55.0 C pch: 47.5 C mobo: 43.0 C sodimm: SODIMM C
gpu: nvidia temp: 50 C
Fan Speeds (RPM): cpu: 0
Processes: 338 Uptime: 30m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1424 pacman: 1413 lib: 459
flatpak: 7 snap: 4 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.11[/code]
xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 1600mm x 900mm
1920x1080 60.00*+ 59.94 50.00 23.98 60.05 60.00 50.04
1280x1024 60.02
1280x720 60.00 59.94 50.00
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
