Hi.
I’m trying to use qomui to connect to my vpn (surfshark).
I can add it as a provider, but when trying to connect, it will just stay in “Connecting to…” forever.
Logs:
2022-02-15 13:18:59,507 - INFO - Deleted cgroup
2022-02-15 13:21:42,787 - INFO - Connecting to us-orl.prod.surfshark.com_udp....
2022-02-15 13:21:42,796 - INFO - iptables: created rule for 198.147.22.133
2022-02-15 13:22:28,942 - DEBUG - Killed all running instances of OpenVPN
2022-02-15 13:22:28,943 - DEBUG - Saved iptables rules
2022-02-15 13:22:28,944 - DEBUG - Saved ip6tables rules
2022-02-15 13:22:28,945 - INFO - (Re-)enabled ipv6
When I check “Activate firewall” in configs I get this:
2022-02-15 13:32:41,634 - INFO - Configuration changes applied successfully
2022-02-15 13:32:41,636 - INFO - (Re-)enabled ipv6
2022-02-15 13:32:41,642 - INFO - iptables: flushed existing rules
2022-02-15 13:32:41,691 - INFO - iptables: activated firewall
2022-02-15 13:32:41,694 - WARNING - iptables: failed to apply ['-t', 'mangle', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'MARK', '--set-mark', '11']
2022-02-15 13:32:41,696 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'POSTROUTING', '-m', 'cgroup', '--cgroup', '0x00110011', '-o', 'tun0', '-j', 'MASQUERADE']
2022-02-15 13:32:41,697 - WARNING - iptables: failed to apply ['-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'ACCEPT']
2022-02-15 13:32:41,699 - WARNING - iptables: failed to apply ['-D', 'INPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'ACCEPT']
2022-02-15 13:32:41,701 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-p', 'tcp', '--dport', '53', '-j', 'REDIRECT', '--to-ports', '5354']
2022-02-15 13:32:41,702 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-p', 'udp', '--dport', '53', '-j', 'REDIRECT', '--to-ports', '5354']
2022-02-15 13:32:41,704 - WARNING - iptables: failed to apply ['-t', 'mangle', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'MARK', '--set-mark', '11']
2022-02-15 13:32:41,706 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'POSTROUTING', '-m', 'cgroup', '--cgroup', '0x00110011', '-o', 'tun0', '-j', 'MASQUERADE']
2022-02-15 13:32:41,707 - WARNING - iptables: failed to apply ['-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'ACCEPT']
2022-02-15 13:32:41,708 - WARNING - iptables: failed to apply ['-D', 'INPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'ACCEPT']
2022-02-15 13:32:41,710 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-p', 'tcp', '--dport', '53', '-j', 'REDIRECT', '--to-ports', '5354']
2022-02-15 13:32:41,712 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-p', 'udp', '--dport', '53', '-j', 'REDIRECT', '--to-ports', '5354']
2022-02-15 13:32:41,712 - INFO - Deleted cgroup
Log when I first open app:
2022-02-15 13:37:22,453 - DEBUG - Killed all running instances of OpenVPN
2022-02-15 13:37:22,455 - DEBUG - Saved iptables rules
2022-02-15 13:37:22,456 - DEBUG - Saved ip6tables rules
2022-02-15 13:37:22,457 - INFO - (Re-)enabled ipv6
2022-02-15 13:37:22,450 - DEBUG - Successfully connected to qomui-service via DBus
2022-02-15 13:37:22,469 - INFO - Qomui version 0.8.2
2022-02-15 13:37:22,473 - WARNING - [Errno 2] No such file or directory: '/home/user/.qomui/profile.json': Could not open /home/user/.qomui/profile.json
2022-02-15 13:37:22,474 - INFO - Total number of server: 310
2022-02-15 13:37:23,272 - ERROR - Could not identify default gateway for ipv6 - no network connectivity
2022-02-15 13:37:23,273 - INFO - Detected new network connection
2022-02-15 13:37:23,279 - WARNING - iptables: failed to apply ['-t', 'mangle', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'MARK', '--set-mark', '11']
2022-02-15 13:37:23,280 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'POSTROUTING', '-m', 'cgroup', '--cgroup', '0x00110011', '-o', 'tun0', '-j', 'MASQUERADE']
2022-02-15 13:37:23,281 - WARNING - iptables: failed to apply ['-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'ACCEPT']
2022-02-15 13:37:23,283 - WARNING - iptables: failed to apply ['-D', 'INPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'ACCEPT']
2022-02-15 13:37:23,285 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-p', 'tcp', '--dport', '53', '-j', 'REDIRECT', '--to-ports', '5354']
2022-02-15 13:37:23,288 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-p', 'udp', '--dport', '53', '-j', 'REDIRECT', '--to-ports', '5354']
2022-02-15 13:37:23,289 - WARNING - iptables: failed to apply ['-t', 'mangle', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'MARK', '--set-mark', '11']
2022-02-15 13:37:23,291 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'POSTROUTING', '-m', 'cgroup', '--cgroup', '0x00110011', '-o', 'tun0', '-j', 'MASQUERADE']
2022-02-15 13:37:23,292 - WARNING - iptables: failed to apply ['-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'ACCEPT']
2022-02-15 13:37:23,294 - WARNING - iptables: failed to apply ['-D', 'INPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-j', 'ACCEPT']
2022-02-15 13:37:23,296 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-p', 'tcp', '--dport', '53', '-j', 'REDIRECT', '--to-ports', '5354']
2022-02-15 13:37:23,298 - WARNING - iptables: failed to apply ['-t', 'nat', '-D', 'OUTPUT', '-m', 'cgroup', '--cgroup', '0x00110011', '-p', 'udp', '--dport', '53', '-j', 'REDIRECT', '--to-ports', '5354']
2022-02-15 13:37:23,298 - INFO - Deleted cgroup
I have looked in /usr/share/qomui/ to see and try to find configs for surkshark, but no luck (I wanted to check user/password because qomui’s behavior is a little odd when adding the provider).
One last thing: when it’s stuck in “trying to connect” and I click cancel, this message pops up:
Error: Qomui-service is not available
Do you want restart it or quit Qomui?
Then it asks for root to run systemctl.
Cheers
