I recently did a clean install of Manjaro with XFCE because Cinnamon was crashing my video driver frequently. I use QGIS regularly for work, and it was working initially, but now qgis will not launch, and will not even register a process when I attempt to launch it. I have tried uninstalling and reinstalling, and clearing the cache between installations, as well as reinstalling all the qgis dependencies, and I have had no luck. I have also tried several different I managed to find someone who asked just this on the forums, but the post is private and I was not able to find it later.
¿Anybody know what I can do as next steps to figure out what the problem is?
With the disclaimer that I’m not familiar with that application, have you tried starting the application from a terminal window? That should provide for at least some verbosity.
Yes, terminal output will help
First guess: something is wrong with QGis finding its python support.
Secong guess: something is wrong with a plugin (and python). Try to start from terminal with qgis --noplugins
So, I managed to get the mariadb-libs installed. I rolled back to the most recent lts kernel, and it worked, QGIS is now up and running. Big thanks to everyone who took the time to help.
