Summary:
QGIS fails to start on the latest Manjaro ARM KDE 6.3.5 image due to a broken dependency. The application requires libgdal.so.36 (GDAL 3.10.x), but only a newer version of GDAL is installed on the system, resulting in the following error:
qgis: error while loading shared libraries: libgdal.so.36: cannot open shared object file: No such file or directory
Steps to Reproduce:
Update to or install Manjaro ARM KDE 6.3.5 image.
Install QGIS from the repository.
Attempt to launch QGIS from the command line.
Expected Behavior:
QGIS should start without shared library errors.
Actual Behavior:
QGIS fails to start, indicating a missing dependency on libgdal.so.36.
Suggested Fix:
Rebuild or update the QGIS package to link against the currently provided version of GDAL (or provide the matching libgdal.so.36 library).
Additional Information:
QGIS version: [latest in repo]
GDAL version installed: [output of pacman -Qs gdal]
We do not maintain arch-arm packages. I would say let them know on the arch-arm forums but the package was flagged out of date 2 weeks ago so they know about it.
I did try to rebuild the package but it would not build and tried to build qgis latest v3.43.3 and it would not build either so guessing that is the reason arc-arm has not updated it yet.
