Qemu/kvm - Win10 VM freezes at boot when I enable Hyper-V features
I managed to get my GPU passed-through to the VM nicely along with one of my SSD’s. I then went to enable Hyper-V features in the Windows 10 install and the virtual machine no longer boots.
I do have
/etc/modprobe.d/kvm.conf
options kvm_intel nested=1
and
cat /sys/module/kvm_intel/parameters/nested
Y
.XML for VM
<domain type="kvm">
  <name>win10</name>
  <uuid>eb0aa41d-6abd-491e-bcad-5a6f49834fcd</uuid>
  <metadata>
    <libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
      <libosinfo:os id="http://microsoft.com/win/10"/>
    </libosinfo:libosinfo>
  </metadata>
  <memory unit="KiB">16777216</memory>
  <currentMemory unit="KiB">16777216</currentMemory>
  <vcpu placement="static">18</vcpu>
  <os firmware="efi">
    <type arch="x86_64" machine="pc-q35-8.0">hvm</type>
    <firmware>
      <feature enabled="no" name="enrolled-keys"/>
      <feature enabled="yes" name="secure-boot"/>
    </firmware>
    <loader readonly="yes" secure="yes" type="pflash">/usr/share/edk2/x64/OVMF_CODE.secboot.4m.fd</loader>
    <nvram template="/usr/share/edk2/x64/OVMF_VARS.4m.fd">/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
    <bootmenu enable="yes"/>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv mode="custom">
      <relaxed state="on"/>
      <vapic state="on"/>
      <spinlocks state="on" retries="8191"/>
    </hyperv>
    <kvm>
      <hidden state="on"/>
    </kvm>
    <vmport state="off"/>
    <smm state="on"/>
  </features>
  <cpu mode="host-passthrough" check="none" migratable="on">
    <topology sockets="1" dies="1" cores="9" threads="2"/>
  </cpu>
  <clock offset="localtime">
    <timer name="hpet" present="yes"/>
    <timer name="hypervclock" present="yes"/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled="no"/>
    <suspend-to-disk enabled="no"/>
  </pm>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
    <disk type="file" device="cdrom">
      <driver name="qemu" type="raw"/>
      <source file="/home/val/Downloads/Win10_22H2_English_x64v1.iso"/>
      <target dev="sda" bus="sata"/>
      <readonly/>
      <boot order="1"/>
      <address type="drive" controller="0" bus="0" target="0" unit="0"/>
    </disk>
      <source file="/home/val/Downloads/virtio-win-0.1.229.iso"/>
      <target dev="sdb" bus="sata"/>
      <readonly/>
      <boot order="2"/>
      <address type="drive" controller="0" bus="0" target="0" unit="1"/>
    </disk>
    <controller type="usb" index="0" model="qemu-xhci" ports="15">
      <address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
    </controller>
    <controller type="pci" index="0" model="pcie-root"/>
    <controller type="pci" index="1" model="pcie-root-port">
      <model name="pcie-root-port"/>
      <target chassis="1" port="0x8"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0" multifunction="on"/>
    </controller>
    <controller type="pci" index="2" model="pcie-root-port">
      <target chassis="2" port="0x9"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x1"/>
    </controller>
    <controller type="pci" index="3" model="pcie-root-port">
      <target chassis="3" port="0xa"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x2"/>
    </controller>
    <controller type="pci" index="4" model="pcie-root-port">
      <target chassis="4" port="0xb"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x3"/>
    </controller>
    <controller type="pci" index="5" model="pcie-root-port">
      <target chassis="5" port="0xc"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x4"/>
    </controller>
    <controller type="pci" index="6" model="pcie-root-port">
      <target chassis="6" port="0xd"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x5"/>
    </controller>
    <controller type="pci" index="7" model="pcie-root-port">
      <target chassis="7" port="0xe"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x6"/>
    </controller>
    <controller type="pci" index="8" model="pcie-root-port">
      <target chassis="8" port="0xf"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x7"/>
    </controller>
    <controller type="pci" index="9" model="pcie-root-port">
      <target chassis="9" port="0x10"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
    </controller>
    <controller type="pci" index="10" model="pcie-root-port">
      <target chassis="10" port="0x11"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
    </controller>
    <controller type="pci" index="11" model="pcie-root-port">
      <target chassis="11" port="0x12"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
    </controller>
    <controller type="pci" index="12" model="pcie-root-port">
      <target chassis="12" port="0x13"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
    </controller>
    <controller type="pci" index="13" model="pcie-root-port">
      <target chassis="13" port="0x14"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
    </controller>
    <controller type="pci" index="14" model="pcie-root-port">
      <target chassis="14" port="0x15"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
    </controller>
    <controller type="sata" index="0">
      <address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
    </controller>
    <interface type="bridge">
      <mac address="52:54:00:7a:4a:5d"/>
      <source bridge="virbr0"/>
      <model type="virtio"/>
      <address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
    </interface>
    <input type="mouse" bus="ps2"/>
    <input type="keyboard" bus="ps2"/>
    <audio id="1" type="none"/>
    <hostdev mode="subsystem" type="pci" managed="yes">
      <source>
        <address domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
      </source>
      <address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
    </hostdev>
      <source>
        <address domain="0x0000" bus="0x01" slot="0x00" function="0x1"/>
      </source>
      <address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
    </hostdev>
      <source>
        <address domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
      </source>
      <boot order="3"/>
      <address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
    </hostdev>
    <hostdev mode="subsystem" type="usb" managed="yes">
      <source>
        <vendor id="0x0b05"/>
        <product id="0x184d"/>
      </source>
      <address type="usb" bus="0" port="1"/>
    </hostdev>
      <source>
        <vendor id="0x1532"/>
        <product id="0x0045"/>
      </source>
      <address type="usb" bus="0" port="2"/>
    </hostdev>
    <watchdog model="itco" action="reset"/>
    <memballoon model="virtio">
      <address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
    </memballoon>
  </devices>
</domain>
I’m obviously doing something wrong, but I can’t for the life of me figure out what that is.
I wouldn;t have to do this if my game collection ran on linux natively.
I Guess I should mention I am using QEMU / KVM and Virt-Manager
Maybe try to follow what this guy did: https://leduccc.medium.com/improving-the-performance-of-a-windows-10-guest-on-qemu-a5b3f54d9cf5#c5b9
Thank you,
I will work my way through that and hopefully it will fix it :slight_smile:
I went through everything on
and the referenced previous article
https://leduccc.medium.com/simple-dgpu-passthrough-on-a-dell-precision-7450-ebe65b2e648e
Make changes to emulate what they did. however the VM still hangs right after displaying the setup cd-rom prompt ‘push any key’ to start window install… it’s fine until I enable Hyper-V.
Updated XML
<domain type="kvm">
  <name>win10</name>
  <uuid>6df8c86c-0e7f-4e02-a022-a36ff712d448</uuid>
  <metadata>
      <libosinfo:os id="http://microsoft.com/win/11"/>
  </metadata>
  <vcpu placement="static">14</vcpu>
  <iothreads>1</iothreads>
  <cputune>
    <vcpupin vcpu="0" cpuset="1"/>
    <vcpupin vcpu="1" cpuset="2"/>
    <vcpupin vcpu="2" cpuset="3"/>
    <vcpupin vcpu="3" cpuset="4"/>
    <vcpupin vcpu="4" cpuset="5"/>
    <vcpupin vcpu="5" cpuset="6"/>
    <vcpupin vcpu="6" cpuset="7"/>
    <vcpupin vcpu="7" cpuset="9"/>
    <vcpupin vcpu="8" cpuset="10"/>
    <vcpupin vcpu="9" cpuset="11"/>
    <vcpupin vcpu="10" cpuset="12"/>
    <vcpupin vcpu="11" cpuset="13"/>
    <vcpupin vcpu="12" cpuset="14"/>
    <vcpupin vcpu="13" cpuset="15"/>
    <emulatorpin cpuset="0,8"/>
    <iothreadpin iothread="1" cpuset="0,8"/>
  </cputune>
  <os firmware="efi">
    <firmware>
      <feature enabled="no" name="secure-boot"/>
    </firmware>
    <loader readonly="yes" type="pflash">/usr/share/edk2/x64/OVMF_CODE.fd</loader>
    <nvram template="/usr/share/edk2/x64/OVMF_VARS.fd">/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
      <vapic state="on"/>
      <vpindex state="on"/>
      <synic state="on"/>
      <stimer state="on"/>
      <reset state="on"/>
    </hyperv>
  </features>
    <topology sockets="1" dies="1" cores="7" threads="2"/>
  </cpu>
    <timer name="rtc" tickpolicy="catchup"/>
    <timer name="pit" tickpolicy="delay"/>
    <timer name="hpet" present="no"/>
  </clock>
  <pm>
  </pm>
  <devices>
      <readonly/>
      <boot order="1"/>
    </disk>
      <readonly/>
      <boot order="3"/>
    </disk>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
      <mac address="52:54:00:55:0d:ca"/>
    </interface>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
      <boot order="2"/>
    </hostdev>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
    </memballoon>
  </devices>
</domain>
Installation should be done without any modifications, because for example the virtio drivers are not available on a windows setup.
and why would you want to enable that?
in a VM whose CPU is not the native one, but a virtual one emulating certain features of the real one
As I understand it
you can pass through certain hardware (graphics)
… but the native CPU? …
The reasoning behind wanting to enable hyper-V in windows is so I can ‘hide’ the vm from certain programs that would otherwise prevent me from playing.
I have been wanting to ditch windows for a while and use linux as my main os. in doing so a game I like to play and run a server for “SCUM” will not allow me to play online due to it detecting the VM. as I have been mostly trying to follow what SomeOrdinaryGamers does in his tutorial as a way of playing such games.
In his video he also enables Hyper-V inside his VM… on a few other sites I’ve read that it is the their solution too.
As it currently stand my solution is to “stream” the game from my spare winblows bare-metal pc to my main(linux) pc… but that is not my ideal solution.
I will do it all again from the beginning.
