I am trying to remove qemu. There are many qemu related applications, many depend on each other and refuse to go away. How can I remove all unique qemu applications without breaking the system?
They were most likely all installed as dependencies. Do you still have something that requires them?
pacman -Qi qemu-desktop | grep 'Required By'
No, that is gone / was not found.
What qemu
packages do you still have installed?
pacman -Qs qemu
Either way, they’re probably orphans.
Yes, they seem to be:
pamac remove -o
Preparing...
Checking dependencies...
To remove (59):
gtk-vnc 1.3.1-1 extra
libvirt-glib 4.0.0-2 community
qemu-ui-dbus 7.1.0-10 extra
virt-install 4.1.0-1 community
libvirt-python 1:8.8.0-1 (Orphan Of: virt-install) community
cpio 2.13-2 (Orphan Of: virt-install) extra
qemu-virtiofsd 7.1.0-10 extra
qemu-ui-egl-headless 7.1.0-10 extra
qemu-hw-display-virtio-gpu 7.1.0-10 extra
alsa-card-profiles 1:0.3.59-2 extra
qemu-audio-sdl 7.1.0-10 extra
qemu-ui-curses 7.1.0-10 extra
python-importlib-metadata 5.0.0-1 community
python-zipp 3.10.0-1 (Orphan Of: python-importlib-metadata) community
geocode-glib 3.26.4-1 extra
qemu-pr-helper 7.1.0-10 extra
multipath-tools 0.9.2-2 (Orphan Of: qemu-pr-helper) community
gtest 1.12.1-1 community
qemu-block-curl 7.1.0-10 extra
qemu-hw-usb-redirect 7.1.0-10 extra
qemu-hw-usb-smartcard 7.1.0-10 extra
qemu-hw-display-virtio-gpu-pci-gl 7.1.0-10 extra
qemu-system-x86-firmware 7.1.0-10 (Orphan Of: qemu-system-x86) extra
qemu-img 7.1.0-10 extra
qemu-audio-spice 7.1.0-10 extra
qemu-hw-display-qxl 7.1.0-10 extra
<cut>
qemu-common 7.1.0-10 (Orphan Of: qemu-audio-sdl) extra
sdl2_image 2.6.2-2 (Orphan Of: qemu-ui-sdl) extra
Total removed size: 202,1 MB
thanks!
