No, version 1:25.2.1-4 is still crashing the whole QEMU session (running out of memory on the host !) if this mesa version is installed in the guest (both manjaro AND debian 13). Installed on the host is no problem, it affects only the guest os ! I notice after few minutes that our swap disk is getting accessed, filling the whole disk in 10-15 minutes, until the whole thing is full. Never saw that before…
Host: imac Kernel: 5.10.242-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 15.2.1
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop System: Apple product: iMac16,2 v: 1.0
serial: <superuser required> Chassis: type: 13 v: Mac-FFE5EF870D7BA81A
Mobo: Apple model: Mac-FFE5EF870D7BA81A v: iMac16,2
serial: <superuser required> UEFI: Apple v: 489.0.0.0.0 date: 10/07/2023
Info: quad core model: Intel Core i5-5675R bits: 64 type: MCP
arch: Broadwell rev: 1 cache: L1: 256 KiB L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 3352 min/max: 800/3600 cores: 1: 3352 2: 3352 3: 3352
4: 3352 bogomips: 24753
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Iris Pro Graphics 6200 vendor: Apple driver: i915 v: kernel
arch: Gen-8 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1622
Device-2: Apple FaceTime HD Camera (Built-in) driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-7:3 chip-ID: 05ac:8511
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 4096x2304 s-dpi: 192
Monitor-1: DP-3 model: Apple iMac res: 4096x2304 hz: 60 dpi: 219
diag: 545mm (21.5")
API: EGL v: 1.5 platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
drv: iris surfaceless: drv: iris x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Pro Graphics 6200
(BDW GT3) device-ID: 8086:1622
API: Vulkan v: 1.4.321 surfaces: N/A device: 0 type: integrated-gpu
driver: mesa intel device-ID: 8086:1622
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
Device-2: Intel 9 Series Family HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:8ca0
API: ALSA v: k5.10.242-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 14e4:43ba
IF: wlan0 state: up mac: 28:f0:76:77:58:72
IP v4: 192.168.129.3/23 type: dynamic noprefixroute scope: global
broadcast: 192.168.129.255
Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
chip-ID: 14e4:1686
IF: eno1 state: down mac: a8:60:b6:1e:2f:b3
WAN IP: 62.235.34.220
Device-1: Apple Bluetooth USB Host Controller
driver: btusb,hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
bus-ID: 1-8:5 chip-ID: 05ac:8294
Local Storage: total: 1.36 TiB used: 181.23 GiB (13.0%)
ID-1: /dev/sda vendor: Apple model: HDD HTS541010A9E662 size: 931.51 GiB
speed: 3.0 Gb/s serial: JD8002D825WUDD
ID-2: /dev/sdb vendor: Samsung model: Portable SSD T3 size: 465.76 GiB
type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 serial: S2WENP0HA05448V
ID-1: / size: 449.76 GiB used: 181.2 GiB (40.3%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 299.4 MiB used: 24.4 MiB (8.2%) fs: vfat
dev: /dev/sdb1
ID-1: swap-1 type: partition size: 7.42 GiB used: 256 KiB (0.0%)
priority: -2 dev: /dev/sdb3
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.64 GiB used: 3.65 GiB (47.8%)
Processes: 213 Power: uptime: 52m wakeups: 0 Init: systemd v: 257
default: graphical
Packages: pm: pacman pkgs: 1400 Compilers: gcc: 15.2.1 Shell: Bash
v: 5.3.3 running-in: mate-terminal inxi: 3.3.39
