qBittorrent segmentation fault
I have started to get a segmentation fault after attempting to launch qbittorrent :
qbittorrent
Please file a bug report at https://bug.qbittorrent.org and provide the following information:
qBittorrent version: v5.1.2
Caught signal: SIGSEGV
 0# getStacktrace[abi:cxx11]() in qbittorrent
 1# 0x00000000001D709E in qbittorrent
 2# 0x000000000003E540 in /usr/lib/libc.so.6
 3# BitTorrent::TorrentImpl::updateTrackerEntryStatus(libtorrent::announce_entry const&, QHash<boost::asio::ip::basic_endpoint<boost::asio::ip::tcp>, QMap<int, int> > const&) in qbittorrent
 4# 0x000000000025968A in qbittorrent
 5# QObject::event(QEvent*) in /usr/lib/libQt6Core.so.6
 6# QApplicationPrivate::notify_helper(QObject*, QEvent*) in /usr/lib/libQt6Widgets.so.6
 7# QCoreApplication::notifyInternal2(QObject*, QEvent*) in /usr/lib/libQt6Core.so.6
 8# QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) in /usr/lib/libQt6Core.so.6
 9# 0x000000000044DB18 in /usr/lib/libQt6Core.so.6
10# 0x000000000005EF4D in /usr/lib/libglib-2.0.so.0
11# 0x0000000000060617 in /usr/lib/libglib-2.0.so.0
12# g_main_context_iteration in /usr/lib/libglib-2.0.so.0
13# QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) in /usr/lib/libQt6Core.so.6
14# QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) in /usr/lib/libQt6Core.so.6
15# QCoreApplication::exec() in /usr/lib/libQt6Core.so.6
16# Application::exec() in qbittorrent
17# main in qbittorrent
18# 0x0000000000027675 in /usr/lib/libc.so.6
19# __libc_start_main in /usr/lib/libc.so.6
20# _start in qbittorrent
zsh: segmentation fault (core dumped)  qbittorrent
I have tried to remove and reinstall qbittorrent, but the segmentation fault persists.
pamac remove qbittorrent
pamac install qbittorrent
I have also tried to delete the following directories in between the remove and install commands, but qbittorrent still crashes.
~/.cache/qBittorent
~/.config/qBittorrent
~/.local/share/qBittorrent
How do I get qbittorrent to launch without crashing ? Thanks.
I am on the testing branch. System details below :
inxi --no-host --filter-uuid --filter-vulnerabilities --verbosity 8
  Kernel: 6.17.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.17-x86_64 root=UUID=<filter> rw
    rootflags=subvol=@ quiet cryptdevice=UUID=<filter>
    root=/dev/mapper/luks-ae3bd9c5-2194-4777-84cc-36cc9b70e330 splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A info: frameworks v: 6.19.0
  Type: Laptop System: LENOVO product: 20UAS13N00 v: ThinkPad X1 Carbon Gen 8
  Mobo: LENOVO model: 20UAS13N00 v: SDK0J40697 WIN
    serial: <superuser required> part-nu: LENOVO_MT_20UA_BU_Think_FM_ThinkPad
    X1 Carbon Gen 8 uuid: <superuser required> UEFI: LENOVO
    v: N2WET50W (1.40 ) date: 07/04/2025
  ID-1: BAT0 charge: 38.6 Wh (74.3%) condition: 52/51 Wh (101.9%) power: 4 W
    volts: 15.91 min: 15.4 model: LGC 5B10W13930 type: Li-poly serial: 6564
    charging: status: discharging control: start: 0% end: 100% cycles: 436
  System RAM: total: 16 GiB available: 15.28 GiB used: 2.64 GiB (17.3%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: LPDDR3 detail: synchronous size: 8 GiB
    speed: 2133 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: N/A serial: N/A
  Device-2: ChannelB-DIMM0 type: LPDDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0x100
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 400 min/max: 400/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 33599
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
    rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
    vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Vulnerabilities: <filter>
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9b41
    class-ID: 0300
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04f2:b6cb
    class-ID: fe01 serial: 0001
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: LG Display 0x0608 built: 2018 res: mode: 1920x1080
    hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2 chroma: red: x: 0.639 y: 0.329
    green: x: 0.306 y: 0.608 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
    modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9b41 memory: 14.92 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.328 layers: 1 device: 0 type: integrated-gpu name: Intel
    UHD Graphics (CML GT2) driver: mesa intel v: 25.2.5-arch1.1
    device-ID: 8086:9b41 surfaces: N/A
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo
    driver: sof-audio-pci-intel-cnl alternate: snd_soc_avs,
    snd_sof_pci_intel_cnl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:02c8
    class-ID: 0403
  API: ALSA v: k6.17.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  IF: wlp0s20f3 state: up mac: 34:7d:f6:b9:bc:07
  IP v4: 192.168.60.64/24 type: dynamic noprefixroute scope: global
    broadcast: 192.168.60.255
  IP v6: fe80::a4f6:6b69:d8eb:f8ec/64 type: noprefixroute scope: link
  Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
  IF: enp0s31f6 state: down mac: 00:2b:67:a3:f4:bd
  IF-ID-1: wwan0 state: down mac: N/A
  WAN IP: 203.211.75.192
  Device-1: luks-ae3bd9c5-2194-4777-84cc-36cc9b70e330 maj-min: 253:0
    type: LUKS dm: dm-0 size: 238.18 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 238.18 GiB
  Local Storage: total: 238.47 GiB used: 165 GiB (69.2%)
    model: MZVLB256HBHQ-000L7 size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: S4ELNF6N529586
    fw-rev: 5M2QEXH7 temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
    used: 165 GiB (69.3%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-ae3bd9c5-2194-4777-84cc-36cc9b70e330 label: N/A
    uuid: <filter>
    used: 912 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: <filter>
  ID-3: /home raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
    uuid: <filter>
  ID-4: /swap raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
    uuid: <filter>
  ID-5: /var/cache raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
    uuid: <filter>
  ID-6: /var/log raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
    uuid: <filter>
  ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-3:2 info: Lenovo 300 Wireless Compact Mouse type: mouse
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 17ef:60ac class-ID: 0301
  Device-2: 1-8:3 info: Chicony Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b6cb class-ID: fe01
    serial: 0001
  Device-3: 1-9:4 info: Synaptics Prometheus MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 06cb:00bd class-ID: ff00 serial: 483073957c26
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 37.0 C pch: 43.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0
  Packages: pm: pacman pkgs: 1311 libs: 359 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors2.manjaro.org/testing/$repo/$arch
    2: https://mirrors.manjaro.org/repo/testing/$repo/$arch
    3: https://mirrors.cicku.me/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 285
  1: cpu: 18.6% command: firefox pid: 1473 mem: 543.0 MiB (3.4%)
  2: cpu: 11.0% command: firefox pid: 2573 mem: 341.4 MiB (2.1%)
  3: cpu: 10.8% command: firefox pid: 2957 mem: 348.5 MiB (2.2%)
  4: cpu: 8.7% command: kwin_wayland pid: 867 mem: 213.3 MiB (1.3%)
  5: cpu: 3.3% command: firefox pid: 2149 mem: 341.5 MiB (2.1%)
  Memory top: 5 of 285
  1: mem: 543.0 MiB (3.4%) command: firefox pid: 1473 cpu: 18.6%
  2: mem: 348.5 MiB (2.2%) command: firefox pid: 2957 cpu: 10.8%
  3: mem: 342.8 MiB (2.1%) command: plasmashell pid: 1074 cpu: 0.8%
  4: mem: 341.5 MiB (2.1%) command: firefox pid: 2149 cpu: 3.3%
  5: mem: 341.4 MiB (2.1%) command: firefox pid: 2573 cpu: 11.0%
  Processes: 285 Power: uptime: 35m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.39
I also had this on CachyOS and over on their forum someone said to downgrade libtorrent-rasterbar which was a temporary fix that worked for me too, but the update today to qbittorrent 5.1.2-2 fixed it.
Thanks for the tip and the link. Downgrading libtorrent-rasterbar from 2.0.11-5 to 2.0.11-4 fixed it. I didn’t need to go back to 2.0.10-5 as stated in the link. I’ll wait for qbittorrent 5.1.2-2 to hit testing.
