Hello, i have some problems with my disk permissions, i guess its related to software applications so i am asking here. Perhaps someone could help me.
I have two disks, one SSD where all the main system is installed and HDD. HDD is empty for now. Whenever i set the download path to SSD everythign works fine and qbittorents downloads fine. But whenever i set the download path to the HDD i get the error Couldn’t write file. Permision denied. Torrent is curenctly in '‘upload mode only’'
So i know that this has something to do with HDD file permissions. I tried some ways to fix but following some guide on the net but with no success. The HDD is automatically mounted on boot as /data after i write the key for its encryption.
I had problems at first with it where i could not even create file but then i changed the permissions so the owner is /root and the group to user.
What could i do to fix this issue ? From my understanding qbittorent runs as user so it should be able to download the files to there just like i could make a new folder there as a user.
