hello , while customizing my Manjaro KDE plasma i installed zsh shell and ohmyzsh config as the theme, i choose to go with agnostar theme over to robbyrussle ,and after that python virual env name is not showing ,when ever i type source env/bin/activate . I want that prompt working againg what should i have to do.
In zsh i have a very nice theme which i like with that setting but not like that it’s not showing the virtual env names , please tell me a config option that turns on the virtual env names .
It sometimes messing up while installing packages because i sometimes download packages which i donot want in my main python system.
From what I can quickly find, that theme does not make use of $(virtualenv_prompt_info)
So … you can either fix that by editing the theme (on beginning of line PROMPT
), or you will need to remove the plugin virtualenv
(this will allow it to revert to a simpler script that should work over the plugin)
yeah i worked a bit and figure out what went wrong there thanks for the kind help
