Hi,
I have a python script which copy the full path of text files opened in gedit:
#!/usr/bin/env python3
import subprocess
import sys
name = subprocess.check_output(["xdotool", "getactivewindow", "getwindowname"]).decode("utf-8").strip()
if all(["(" in name, ")" in name]):
path = name[name.find("(")+1:name.find(")")]
if sys.argv[1] == "-file":
fname = name[:name.find("(")]
elif sys.argv[1] == "-path":
fname = ""
command = "echo "+'"'+path+"/"+fname+'"'+" | tr -d '\n' | sed 's/.$//' | xclip -selection clipboard"
subprocess.Popen(["/bin/bash", "-c", command])
Works as expected, but I’d like to have the result reported inside quotes:
“path/to/file”
I’ve tried various attempts using sed, but the code looks “ugly”, “strange” and doesn’t work, maybe because this part
already have various quotation, and adding quotes to the code cause a mess.
How to achieve in the best way?
cscs
May 20, 2023, 8:42am
2
I might use something like
printf '"path/to/file"'
You could use the format command
command = f"echo '{path}/{fname}' | tr -d '\n' | sed 's/.$//' | xclip -selection clipboard"
It would most likely be easier for you to use pyperclip
The path is still reported without quotes.
How to implement it? I am not expert with python; I found such script on stackexchange.
On my system it output as exepcted
$ python
Python 3.11.3 (main, Apr 5 2023, 15:52:25) [GCC 12.2.1 20230201] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> path = "/path/to"
>>> fname = "fname"
>>> command = f"echo '{path}/{fname}'"
>>> print(command)
echo '/path/to/fname'
So not a problem with python.
It is likely your post processing in bash which strips your quotes - but I am not a shark on bash.
This is how I edit it:
import subprocess
import sys
fname = ""
So? Sorry, but I don’t know anything about python…
I have no clue of what you are doing - but I know a little about python.
What I can see is that you genrating a command to executed by bash.
You could try escaping a set of double quotes
command = f"echo \"{path}/{fname}\" | tr -d '\n' | sed 's/.$//' | xclip -selection clipboard"
Well it is not a python issue - to illustrate how Python generates the correct string using python print() I had to escape the \
in the delimiter \n
- other than that python creates the expected string.
$ python
>>> path = "/path/to"
>>> fname = "fname"
>>> print(command)
echo '/path/to/fname' | tr -d '
>>> command = f"echo '{path}/{fname}' | tr -d '\\n' | sed 's/.$//' | xclip -selection clipboard"
>>> print(command)
echo '/path/to/fname' | tr -d '\n' | sed 's/.$//' | xclip -selection clipboard
>>> command = f"echo \"{path}/{fname}\" | tr -d '\\n' | sed 's/.$//' | xclip -selection clipboard"
>>> print(command)
echo "/path/to/fname" | tr -d '\n' | sed 's/.$//' | xclip -selection clipboard
A computer is stupid - if you don’t get the result you expect then you are asking the wrong question - in other words your are providing the wrong input.
D.Dave
May 20, 2023, 9:33am
12
This is how I edited it again:
import subprocess
import sys
fname = ""
But I don’t still get quotes.
I suggest you go over your input - see what happens.
You can use print(variable)
to see in real time what happens.
dmt
May 20, 2023, 9:41am
14
D.Dave:
Still no quotes
Try more backslashes.
command = f"echo \\"{path}/{fname}\\" | tr -d '\n' | sed 's/.$//' | xclip -selection clipboard"
$ python
>>> import subprocess
>>> import sys
>>> path="/path/to"
>>> names={"x","y","z"]
File "<stdin>", line 1
names={"x","y","z"]
SyntaxError: closing parenthesis ']' does not match opening parenthesis '{'
>>> names=["x","y","z"]
>>> for fname in names:
... command=f"echo \"{path}/{fname}\" | tr -d '\\n' | sed 's/.$//' | xclip -selection clipboard"
... print(command)
echo "/path/to/x" | tr -d '\n' | sed 's/.$//' | xclip -selection clipboard
echo "/path/to/y" | tr -d '\n' | sed 's/.$//' | xclip -selection clipboard
echo "/path/to/z" | tr -d '\n' | sed 's/.$//' | xclip -selection clipboard
Check your input …
And please - this is not a Manjaro issue - so stop wasting time - have a nice day.
dmt
May 20, 2023, 9:53am
17
Well it works for me.
>>> command = f'echo \"{path}/{fname} \"'
>>> subprocess.run(command, shell=True)
/path/to/fname
CompletedProcess(args='echo "/path/to/fname "', returncode=0)
>>> command = f'echo \\"{path}/{fname} \\"'
"/path/to/fname "
CompletedProcess(args='echo \\"/path/to/fname \\"', returncode=0)
<Popen: returncode: None args: ['/bin/bash', '-c', 'echo \\"/path/to/fname \...>
>>> "/path/to/fname "
subprocess.Popen(["echo", f"\"{path}/{fname}\""])
<Popen: returncode: None args: ['echo', '"/path/to/fname"']>
>>> "/path/to/fname"
Not sure why the last 2 end up being printed as commands though but I rarely use the python command line or popen. @linux-aarhus Any ideas?
D.Dave
May 20, 2023, 9:59am
18
I originally opened this discussion in the Member Hub, but has been moved, by a moderator, in this section. If you think that is inappropriate, feel free to delete this discussion.
fasto
May 20, 2023, 1:48pm
19
This would be a better question for https://stackoverflow.com/
D.Dave
May 20, 2023, 5:32pm
20
I solved with a bash script:
#!/bin/bash
path=$(xdotool getactivewindow getwindowname | grep -oP '\(\K[^)]+')
path2="${path/#\~/$HOME}"
filename=$(xdotool getactivewindow getwindowname | cut -d"(" -f1 | rev | cut -c2- | rev)
echo "\"$path2/$filename"\" | tr -d '\n' | xclip -selection clipboard
And so, I got, eg: "/home/dave/Documents/text file"
system
Closed
May 23, 2023, 7:33am
21
