thonny is a custom package - although unsupported - it most likely work.
But you have to realize that installing python packages is not done using pip.
Python packages installs using pacman and all has a prefix followed by the package name like this example python-<pkgname>
Manjaro is not Fedora - I played a little with qt6 a while ago - it is a fairly simple piece - just for the exercise.
https://github.com/fhdk/python-118dk
I just tested it still works as expected.
You may need to educate yourself
Using thonny usually implies creating a virtual environment. If the modules is not available in this environment you will get issues.
For the exercise - I tested my little phone/address parser - in thonny - with a little modification of the requirements.txt - I could install the necessary packages in the virtual environment and run the app.
With that in mind it is a local issue - most likely your configuration - I cannot say what or what not - but thonny can work on Manjaro
Summary
If you wanna try it out - there is three files
requirements.txt
PySide6
beautifulsoup4
certifi
phonebook.py
#!/usr/bin/python3
# -*- coding: utf8 -*-
# Copyright 2021 Frede Hundewadt
# Permission is hereby granted, free of charge,
# to any person obtaining a copy of this software and
# associated documentation files (the "Software"),
# to deal in the Software without restriction,
# including without limitation the rights to use,
# copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software,
# and to permit persons to whom the Software is furnished
# to do so, subject to the following conditions:
# The above copyright notice and this permission notice
# shall be included in all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
# EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
# IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM,
# DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
# ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
from PySide6 import QtCore, QtWidgets
import sys
import parse_url
class Lookup(QtWidgets.QWidget):
def __init__(self):
super().__init__()
self.buttonLookup = QtWidgets.QPushButton("Lav opslag 118.dk")
self.labelAddressHint = QtWidgets.QLabel("Husnummer kan bruges som afgrænsning på større områder.\nEksempel: Ryhaven, 8210 eller Bispehavevej 121, 8210")
self.textAddress = QtWidgets.QLineEdit("vejnavn [nr], postnummer")
self.textResult = QtWidgets.QTextEdit("")
self.textResult.setReadOnly(True)
self.textResult.setFontFamily("monospace")
self.layout = QtWidgets.QVBoxLayout(self)
self.layout.addWidget(self.labelAddressHint)
self.layout.addWidget(self.textAddress)
self.layout.addWidget(self.buttonLookup)
self.layout.addWidget(self.textResult)
self.buttonLookup.clicked.connect(self.lookup)
@QtCore.Slot()
def lookup(self):
""" run lookup """
self.textResult.clear()
if self.textAddress.text() == "vejnavn [nr], postnummer":
self.textResult.setPlainText("kan ikke findes")
return
# run lookup
self.textResult.setPlainText("Vent venligst ...")
results = parse_url.parse_url(self.textAddress.text())
txt = ""
for result in results:
txt = f"{txt}Adresse : {result['address']}\n"
txt = f"{txt} Navn : {result['name']}\n"
for number in result["phones"]:
txt = f"{txt} Tlf : {number}\n"
txt = f"{txt}---------------------\n"
self.textResult.setPlainText(txt)
if __name__ == "__main__":
app = QtWidgets.QApplication([])
widget = Lookup()
widget.resize(600, 600)
widget.show()
sys.exit(app.exec())
parse_url.py
#!/usr/bin/python3
from bs4 import BeautifulSoup
from operator import itemgetter
import argparse
import urllib.request
import urllib.parse
import urllib
# 118.dk
# person søgning : https://www.118.dk/search/go?pageSize=100&page=1&listingType=residential&where=
# firma søgning : https://www.118.dk/search/go?pageSize=100&page=1&listingType=business&where=
# alle søgning : https://www.118.dk/search/go?pageSize=100&page=1&listingType=&where=
# ingen grund til at fortælle at dette er et script
USER_AGENT = {"User-Agent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/42.0.2311.135 Safari/537.36 Edge/12.246"}
SEARCH_118_URL = "https://www.118.dk/search/go?pageSize=100&page=1&listingType=residential&where="
SITE = "118.dk"
def parse_url(address):
strings = list()
entries = list()
phones = list()
contacts = list()
url = f"{SEARCH_118_URL}{urllib.parse.quote_plus(address)}"
req = urllib.request.Request(url=url, headers=USER_AGENT)
with urllib.request.urlopen(req) as res:
page = res.read()
soup = BeautifulSoup(page, "html.parser", from_encoding='utf-8')
for script in soup(["script", "style", "ul", "input", "form", "title", "ins", "h1", "h2", "h4",
"fieldset", "iframe", "strong", "img", "head", "meta", "link"]):
script.extract()
for string in soup.stripped_strings:
if string.startswith("Geo") or \
string.startswith("FAG") or \
string.startswith("< til") or \
string.startswith("Tlf") or \
string.startswith("118.dk") or \
string.startswith("Vi kan") or \
string.startswith("Læs mere") or \
string.startswith("Copyright") or \
string.startswith("close") or \
string.startswith("Fjernelse") or \
string.startswith("Her kan") or \
string.startswith("Husnummer"):
continue
if string == "se kort":
entries.append(tuple(strings))
strings.clear()
else:
strings.append(string)
for entry in entries:
ad_protect = str(entry[1])
if ad_protect.startswith("Reklame"):
continue
try:
same_house = False
number = entry[2]
name = entry[0]
iterate = [x for x in contacts if x["name"] == name]
for c in iterate:
if number not in c["phones"]:
same_house = True
c["phones"] = c["phones"] + [number]
if not same_house:
person = {
"name": entry[0],
"address": entry[1],
"phones": [number]
contacts.append(person)
except (Exception,):
continue
return sorted(contacts, key=itemgetter("address"))
if __name__ == '__main__':
parser = argparse.ArgumentParser()
parser.add_argument("-a", "--adresse", required=True, type=str, help="vejnavn [nr], postnummer")
args = parser.parse_args()
results = parse_url(args.adresse)
print(f"Adresse : {result['address']}")
print(f" Navn : {result['name']}")
print(f" Tlf : {number}")
print(f"---------------------")
