Python + Gradience Package Errors
Hey Everyone,
I’m getting errors when installing the following packages:
Packages (14) pacman-6.1.0-4  python-fastjsonschema-2.19.1-1  python-ordered-set-4.1.0-4  python-platformdirs-4.2.0-1  python-pyproject-hooks-1.0.0-5  python-tomli-2.0.1-3
              python-trove-classifiers-2024.3.3-1  python-validate-pyproject-0.13-1  python-build-1.1.1-2  python-installer-0.7.0-4  python-setuptools-1:69.0.3-4
              python-setuptools-scm-8.0.4-1  python-toml-0.10.2-9  python-wheel-0.43.0-1
Total Download Size:    0.92 MiB
Total Installed Size:  12.42 MiB
Net Upgrade Size:       7.63 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 pacman-6.1.0-4-x86_64                                                      937.2 KiB  2.54 MiB/s 00:00 [--------------------------------------------------------------] 100%
(14/14) checking keys in keyring        [--------------------------------------------------------------] 100%
(14/14) checking package integrity        [--------------------------------------------------------------] 100%
(14/14) loading package files        [--------------------------------------------------------------] 100%
(14/14) checking for file conflicts        [--------------------------------------------------------------] 100%
(14/14) checking available disk space        [--------------------------------------------------------------] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
( 1/14) installing python-installer        [--------------------------------------------------------------] 100%
( 2/14) installing python-ordered-set        [--------------------------------------------------------------] 100%
( 3/14) installing python-platformdirs        [--------------------------------------------------------------] 100%
( 4/14) installing python-tomli        [--------------------------------------------------------------] 100%
( 5/14) installing python-fastjsonschema        [--------------------------------------------------------------] 100%
( 6/14) installing python-trove-classifiers                                                             [--------------------------------------------------------------] 100%
( 7/14) installing python-validate-pyproject                                                            [--------------------------------------------------------------] 100%
( 8/14) installing python-setuptools        [--------------------------------------------------------------] 100%
( 9/14) installing python-setuptools-scm        [--------------------------------------------------------------] 100%
(10/14) installing python-toml        [--------------------------------------------------------------] 100%
(11/14) installing python-wheel        [--------------------------------------------------------------] 100%
Optional dependencies for python-wheel
    python-keyring: for wheel.signatures
    python-xdg: for wheel.signatures [installed]
(12/14) installing python-pyproject-hooks                                                               [--------------------------------------------------------------] 100%
(13/14) installing python-build        [--------------------------------------------------------------] 100%
Optional dependencies for python-build
    python-virtualenv: Use virtualenv for build isolation
(14/14) upgrading pacman        [--------------------------------------------------------------] 100%
(1/3) Reloading system manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Checking which packages need to be rebuilt
 core is up to date
 extra is up to date
 multilib is up to date
warning: plymouth: local (24.004.60-7) is newer than extra (22.02.122-17)
resolving dependencies...
Packages (2) libsass-3.6.6-1  sassc-3.6.2-4
Total Installed Size:  2.20 MiB
(2/2) checking keys in keyring        [--------------------------------------------------------------] 100%
(2/2) checking package integrity        [--------------------------------------------------------------] 100%
(2/2) loading package files        [--------------------------------------------------------------] 100%
(2/2) checking for file conflicts        [--------------------------------------------------------------] 100%
(2/2) checking available disk space        [--------------------------------------------------------------] 100%
(1/2) installing libsass        [--------------------------------------------------------------] 100%
(2/2) installing sassc        [--------------------------------------------------------------] 100%
(1/1) Arming ConditionNeedsUpdate...
==> Making package: python-cssutils 2.9.0-1 (Sat 23 Mar 2024 11:24:24 AM CDT)
==> Retrieving sources...
  -> Found cssutils-2.9.0.tar.gz
    cssutils-2.9.0.tar.gz ... Passed
==> Extracting sources...
  -> Extracting cssutils-2.9.0.tar.gz with bsdtar
==> Sources are ready.
==> Making package: python-cssutils 2.9.0-1 (Sat 23 Mar 2024 11:24:26 AM CDT)
==> WARNING: Using existing $srcdir/ tree
==> Removing existing $pkgdir/ directory...
==> Starting build()...
* Getting build dependencies for wheel...
running egg_info
writing cssutils.egg-info/PKG-INFO
writing dependency_links to cssutils.egg-info/dependency_links.txt
writing entry points to cssutils.egg-info/entry_points.txt
writing requirements to cssutils.egg-info/requires.txt
writing top-level names to cssutils.egg-info/top_level.txt
reading manifest file 'cssutils.egg-info/SOURCES.txt'
adding license file 'COPYING'
adding license file 'COPYING.LESSER'
writing manifest file 'cssutils.egg-info/SOURCES.txt'
* Building wheel...
running bdist_wheel
running build
running build_py
creating build
creating build/lib
creating build/lib/cssutils
copying cssutils/css2productions.py -> build/lib/cssutils
copying cssutils/_fetchgae.py -> build/lib/cssutils
copying cssutils/_fetch.py -> build/lib/cssutils
copying cssutils/__init__.py -> build/lib/cssutils
copying cssutils/serialize.py -> build/lib/cssutils
copying cssutils/parse.py -> build/lib/cssutils
copying cssutils/script.py -> build/lib/cssutils
copying cssutils/settings.py -> build/lib/cssutils
copying cssutils/util.py -> build/lib/cssutils
copying cssutils/prodparser.py -> build/lib/cssutils
copying cssutils/tokenize2.py -> build/lib/cssutils
copying cssutils/codec.py -> build/lib/cssutils
copying cssutils/helper.py -> build/lib/cssutils
copying cssutils/profiles.py -> build/lib/cssutils
copying cssutils/sac.py -> build/lib/cssutils
copying cssutils/cssproductions.py -> build/lib/cssutils
copying cssutils/errorhandler.py -> build/lib/cssutils
creating build/lib/encutils
copying encutils/__init__.py -> build/lib/encutils
creating build/lib/cssutils/scripts
copying cssutils/scripts/cssparse.py -> build/lib/cssutils/scripts
copying cssutils/scripts/__init__.py -> build/lib/cssutils/scripts
copying cssutils/scripts/csscapture.py -> build/lib/cssutils/scripts
copying cssutils/scripts/csscombine.py -> build/lib/cssutils/scripts
creating build/lib/cssutils/stylesheets
copying cssutils/stylesheets/medialist.py -> build/lib/cssutils/stylesheets
copying cssutils/stylesheets/__init__.py -> build/lib/cssutils/stylesheets
copying cssutils/stylesheets/mediaquery.py -> build/lib/cssutils/stylesheets
copying cssutils/stylesheets/stylesheet.py -> build/lib/cssutils/stylesheets
copying cssutils/stylesheets/stylesheetlist.py -> build/lib/cssutils/stylesheets
creating build/lib/cssutils/css
copying cssutils/css/__init__.py -> build/lib/cssutils/css
copying cssutils/css/colors.py -> build/lib/cssutils/css
copying cssutils/css/cssvalue.py -> build/lib/cssutils/css
copying cssutils/css/cssnamespacerule.py -> build/lib/cssutils/css
copying cssutils/css/cssimportrule.py -> build/lib/cssutils/css
copying cssutils/css/selectorlist.py -> build/lib/cssutils/css
copying cssutils/css/cssfontfacerule.py -> build/lib/cssutils/css
copying cssutils/css/cssproperties.py -> build/lib/cssutils/css
copying cssutils/css/cssrule.py -> build/lib/cssutils/css
copying cssutils/css/cssstyledeclaration.py -> build/lib/cssutils/css
copying cssutils/css/cssmediarule.py -> build/lib/cssutils/css
copying cssutils/css/marginrule.py -> build/lib/cssutils/css
copying cssutils/css/cssstylesheet.py -> build/lib/cssutils/css
copying cssutils/css/cssvariablesdeclaration.py -> build/lib/cssutils/css
copying cssutils/css/csspagerule.py -> build/lib/cssutils/css
copying cssutils/css/value.py -> build/lib/cssutils/css
copying cssutils/css/cssstylerule.py -> build/lib/cssutils/css
copying cssutils/css/csscharsetrule.py -> build/lib/cssutils/css
copying cssutils/css/property.py -> build/lib/cssutils/css
copying cssutils/css/selector.py -> build/lib/cssutils/css
copying cssutils/css/csscomment.py -> build/lib/cssutils/css
copying cssutils/css/cssvariablesrule.py -> build/lib/cssutils/css
copying cssutils/css/cssrulelist.py -> build/lib/cssutils/css
copying cssutils/css/cssunknownrule.py -> build/lib/cssutils/css
creating build/lib/cssutils/tests
copying cssutils/tests/test_selector.py -> build/lib/cssutils/tests
copying cssutils/tests/test_csscharsetrule.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssstylerule.py -> build/lib/cssutils/tests
copying cssutils/tests/basetest.py -> build/lib/cssutils/tests
copying cssutils/tests/test_profiles.py -> build/lib/cssutils/tests
copying cssutils/tests/test_parse.py -> build/lib/cssutils/tests
copying cssutils/tests/test_x.py -> build/lib/cssutils/tests
copying cssutils/tests/test_settings.py -> build/lib/cssutils/tests
copying cssutils/tests/__init__.py -> build/lib/cssutils/tests
copying cssutils/tests/test_scripts_csscombine.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssstylesheet.py -> build/lib/cssutils/tests
copying cssutils/tests/test_errorhandler.py -> build/lib/cssutils/tests
copying cssutils/tests/test_properties.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssvariablesdeclaration.py -> build/lib/cssutils/tests
copying cssutils/tests/test_stylesheet.py -> build/lib/cssutils/tests
copying cssutils/tests/test_csscomment.py -> build/lib/cssutils/tests
copying cssutils/tests/test_encutils.py -> build/lib/cssutils/tests
copying cssutils/tests/test_marginrule.py -> build/lib/cssutils/tests
copying cssutils/tests/test_domimplementation.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssutilsimport.py -> build/lib/cssutils/tests
copying cssutils/tests/test_codec.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssrule.py -> build/lib/cssutils/tests
copying cssutils/tests/test_property.py -> build/lib/cssutils/tests
copying cssutils/tests/test_mediaquery.py -> build/lib/cssutils/tests
copying cssutils/tests/test_value.py -> build/lib/cssutils/tests
copying cssutils/tests/test_medialist.py -> build/lib/cssutils/tests
copying cssutils/tests/test_tokenize2.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssproperties.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssvariablesrule.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssrulelist.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssutils.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssvalue.py -> build/lib/cssutils/tests
copying cssutils/tests/test_selectorlist.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssimportrule.py -> build/lib/cssutils/tests
copying cssutils/tests/test_prodparser.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssmediarule.py -> build/lib/cssutils/tests
copying cssutils/tests/test_serialize.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssfontfacerule.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssunknownrule.py -> build/lib/cssutils/tests
copying cssutils/tests/test_helper.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssstyledeclaration.py -> build/lib/cssutils/tests
copying cssutils/tests/test_cssnamespacerule.py -> build/lib/cssutils/tests
copying cssutils/tests/test_csspagerule.py -> build/lib/cssutils/tests
copying cssutils/tests/test_util.py -> build/lib/cssutils/tests
running egg_info
creating build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/096.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/097.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/1.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/1ascii.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/1import.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/1inherit-ascii.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/1inherit-iso.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/1inherit-utf8.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/1utf.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/2inherit-iso.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/2resolve.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/acid2.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/all.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/atrule.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/bad.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/basic.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/bundle.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/cases.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/csscombine-1.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/csscombine-2.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/csscombine-proxy.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/cthedot_default.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/default_html4.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/hacks.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/html.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/html20.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/html40.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/import.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/import3.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/ll.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/ll2.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/multiple-values.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/page_test.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/sample_5.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/sample_7.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/simple.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/single-color.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/slashcode.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/t-HACKS.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/test-unicode.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/test.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/tigris.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/tigris2.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/u_simple.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/v_simple.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/vars.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/varsimport.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/xhtml2.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/xhtml22.css -> build/lib/cssutils/tests/sheets
copying cssutils/tests/sheets/yuck.css -> build/lib/cssutils/tests/sheets
creating build/lib/cssutils/tests/sheets/import
copying cssutils/tests/sheets/import/import-impossible.css -> build/lib/cssutils/tests/sheets/import
copying cssutils/tests/sheets/import/import2.css -> build/lib/cssutils/tests/sheets/import
creating build/lib/cssutils/tests/sheets/var
copying cssutils/tests/sheets/var/start.css -> build/lib/cssutils/tests/sheets/var
copying cssutils/tests/sheets/var/use.css -> build/lib/cssutils/tests/sheets/var
copying cssutils/tests/sheets/var/vars.css -> build/lib/cssutils/tests/sheets/var
copying cssutils/tests/sheets/var/vars2.css -> build/lib/cssutils/tests/sheets/var
creating build/lib/cssutils/tests/sheets/images
copying cssutils/tests/sheets/images/example.gif -> build/lib/cssutils/tests/sheets/images
creating build/lib/cssutils/tests/sheets/import/images2
copying cssutils/tests/sheets/import/images2/example2.gif -> build/lib/cssutils/tests/sheets/import/images2
installing to build/bdist.linux-x86_64/wheel
running install
running install_lib
creating build/bdist.linux-x86_64
creating build/bdist.linux-x86_64/wheel
creating build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/css2productions.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/_fetchgae.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/_fetch.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/__init__.py -> build/bdist.linux-x86_64/wheel/cssutils
creating build/bdist.linux-x86_64/wheel/cssutils/scripts
copying build/lib/cssutils/scripts/cssparse.py -> build/bdist.linux-x86_64/wheel/cssutils/scripts
copying build/lib/cssutils/scripts/__init__.py -> build/bdist.linux-x86_64/wheel/cssutils/scripts
copying build/lib/cssutils/scripts/csscapture.py -> build/bdist.linux-x86_64/wheel/cssutils/scripts
copying build/lib/cssutils/scripts/csscombine.py -> build/bdist.linux-x86_64/wheel/cssutils/scripts
creating build/bdist.linux-x86_64/wheel/cssutils/stylesheets
copying build/lib/cssutils/stylesheets/medialist.py -> build/bdist.linux-x86_64/wheel/cssutils/stylesheets
copying build/lib/cssutils/stylesheets/__init__.py -> build/bdist.linux-x86_64/wheel/cssutils/stylesheets
copying build/lib/cssutils/stylesheets/mediaquery.py -> build/bdist.linux-x86_64/wheel/cssutils/stylesheets
copying build/lib/cssutils/stylesheets/stylesheet.py -> build/bdist.linux-x86_64/wheel/cssutils/stylesheets
copying build/lib/cssutils/stylesheets/stylesheetlist.py -> build/bdist.linux-x86_64/wheel/cssutils/stylesheets
copying build/lib/cssutils/serialize.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/parse.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/script.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/settings.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/util.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/prodparser.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/tokenize2.py -> build/bdist.linux-x86_64/wheel/cssutils
creating build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/__init__.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/colors.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssvalue.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssnamespacerule.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssimportrule.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/selectorlist.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssfontfacerule.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssproperties.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssrule.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssstyledeclaration.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssmediarule.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/marginrule.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssstylesheet.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssvariablesdeclaration.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/csspagerule.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/value.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssstylerule.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/csscharsetrule.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/property.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/selector.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/csscomment.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssvariablesrule.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssrulelist.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/css/cssunknownrule.py -> build/bdist.linux-x86_64/wheel/cssutils/css
copying build/lib/cssutils/codec.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/helper.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/profiles.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/sac.py -> build/bdist.linux-x86_64/wheel/cssutils
creating build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_selector.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_csscharsetrule.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssstylerule.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/basetest.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_profiles.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_parse.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_x.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_settings.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/__init__.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_scripts_csscombine.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssstylesheet.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_errorhandler.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_properties.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssvariablesdeclaration.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_stylesheet.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_csscomment.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_encutils.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_marginrule.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_domimplementation.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssutilsimport.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_codec.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssrule.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_property.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_mediaquery.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_value.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_medialist.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_tokenize2.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssproperties.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssvariablesrule.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssrulelist.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssutils.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssvalue.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
creating build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/html40.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/html20.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/1ascii.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/bad.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/single-color.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/1utf.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/tigris.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/import.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/1inherit-iso.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/page_test.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/xhtml2.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/yuck.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/ll2.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/all.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/multiple-values.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/csscombine-1.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/slashcode.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/atrule.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/v_simple.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/test-unicode.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/sample_5.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/varsimport.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/097.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/2inherit-iso.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/import3.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/hacks.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/1.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/default_html4.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/sample_7.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
creating build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/import
copying build/lib/cssutils/tests/sheets/import/import2.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/import
copying build/lib/cssutils/tests/sheets/import/import-impossible.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/import
creating build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/import/images2
copying build/lib/cssutils/tests/sheets/import/images2/example2.gif -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/import/images2
creating build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/var
copying build/lib/cssutils/tests/sheets/var/start.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/var
copying build/lib/cssutils/tests/sheets/var/vars2.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/var
copying build/lib/cssutils/tests/sheets/var/use.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/var
copying build/lib/cssutils/tests/sheets/var/vars.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/var
copying build/lib/cssutils/tests/sheets/csscombine-proxy.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/test.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/acid2.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/ll.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/simple.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/tigris2.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/csscombine-2.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/bundle.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/1import.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/vars.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
creating build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/images
copying build/lib/cssutils/tests/sheets/images/example.gif -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets/images
copying build/lib/cssutils/tests/sheets/2resolve.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/096.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/u_simple.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/1inherit-ascii.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/cases.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/basic.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/cthedot_default.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/1inherit-utf8.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/xhtml22.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/t-HACKS.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/sheets/html.css -> build/bdist.linux-x86_64/wheel/cssutils/tests/sheets
copying build/lib/cssutils/tests/test_selectorlist.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssimportrule.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_prodparser.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssmediarule.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_serialize.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssfontfacerule.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssunknownrule.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_helper.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssstyledeclaration.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_cssnamespacerule.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_csspagerule.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/tests/test_util.py -> build/bdist.linux-x86_64/wheel/cssutils/tests
copying build/lib/cssutils/cssproductions.py -> build/bdist.linux-x86_64/wheel/cssutils
copying build/lib/cssutils/errorhandler.py -> build/bdist.linux-x86_64/wheel/cssutils
creating build/bdist.linux-x86_64/wheel/encutils
copying build/lib/encutils/__init__.py -> build/bdist.linux-x86_64/wheel/encutils
running install_egg_info
Copying cssutils.egg-info to build/bdist.linux-x86_64/wheel/cssutils-2.9.0-py3.11.egg-info
running install_scripts
creating build/bdist.linux-x86_64/wheel/cssutils-2.9.0.dist-info/WHEEL
creating '/home/aahmad/.cache/yay/python-cssutils/src/cssutils-2.9.0/dist/.tmp-itqrpjbo/cssutils-2.9.0-py3-none-any.whl' and adding 'build/bdist.linux-x86_64/wheel' to it
adding 'cssutils/__init__.py'
adding 'cssutils/_fetch.py'
adding 'cssutils/_fetchgae.py'
adding 'cssutils/codec.py'
adding 'cssutils/css2productions.py'
adding 'cssutils/cssproductions.py'
adding 'cssutils/errorhandler.py'
adding 'cssutils/helper.py'
adding 'cssutils/parse.py'
adding 'cssutils/prodparser.py'
adding 'cssutils/profiles.py'
adding 'cssutils/sac.py'
adding 'cssutils/script.py'
adding 'cssutils/serialize.py'
adding 'cssutils/settings.py'
adding 'cssutils/tokenize2.py'
adding 'cssutils/util.py'
adding 'cssutils/css/__init__.py'
adding 'cssutils/css/colors.py'
adding 'cssutils/css/csscharsetrule.py'
adding 'cssutils/css/csscomment.py'
adding 'cssutils/css/cssfontfacerule.py'
adding 'cssutils/css/cssimportrule.py'
adding 'cssutils/css/cssmediarule.py'
adding 'cssutils/css/cssnamespacerule.py'
adding 'cssutils/css/csspagerule.py'
adding 'cssutils/css/cssproperties.py'
adding 'cssutils/css/cssrule.py'
adding 'cssutils/css/cssrulelist.py'
adding 'cssutils/css/cssstyledeclaration.py'
adding 'cssutils/css/cssstylerule.py'
adding 'cssutils/css/cssstylesheet.py'
adding 'cssutils/css/cssunknownrule.py'
adding 'cssutils/css/cssvalue.py'
adding 'cssutils/css/cssvariablesdeclaration.py'
adding 'cssutils/css/cssvariablesrule.py'
adding 'cssutils/css/marginrule.py'
adding 'cssutils/css/property.py'
adding 'cssutils/css/selector.py'
adding 'cssutils/css/selectorlist.py'
adding 'cssutils/css/value.py'
adding 'cssutils/scripts/__init__.py'
adding 'cssutils/scripts/csscapture.py'
adding 'cssutils/scripts/csscombine.py'
adding 'cssutils/scripts/cssparse.py'
adding 'cssutils/stylesheets/__init__.py'
adding 'cssutils/stylesheets/medialist.py'
adding 'cssutils/stylesheets/mediaquery.py'
adding 'cssutils/stylesheets/stylesheet.py'
adding 'cssutils/stylesheets/stylesheetlist.py'
adding 'cssutils/tests/__init__.py'
adding 'cssutils/tests/basetest.py'
adding 'cssutils/tests/test_codec.py'
adding 'cssutils/tests/test_csscharsetrule.py'
adding 'cssutils/tests/test_csscomment.py'
adding 'cssutils/tests/test_cssfontfacerule.py'
adding 'cssutils/tests/test_cssimportrule.py'
adding 'cssutils/tests/test_cssmediarule.py'
adding 'cssutils/tests/test_cssnamespacerule.py'
adding 'cssutils/tests/test_csspagerule.py'
adding 'cssutils/tests/test_cssproperties.py'
adding 'cssutils/tests/test_cssrule.py'
adding 'cssutils/tests/test_cssrulelist.py'
adding 'cssutils/tests/test_cssstyledeclaration.py'
adding 'cssutils/tests/test_cssstylerule.py'
adding 'cssutils/tests/test_cssstylesheet.py'
adding 'cssutils/tests/test_cssunknownrule.py'
adding 'cssutils/tests/test_cssutils.py'
adding 'cssutils/tests/test_cssutilsimport.py'
adding 'cssutils/tests/test_cssvalue.py'
adding 'cssutils/tests/test_cssvariablesdeclaration.py'
adding 'cssutils/tests/test_cssvariablesrule.py'
adding 'cssutils/tests/test_domimplementation.py'
adding 'cssutils/tests/test_encutils.py'
adding 'cssutils/tests/test_errorhandler.py'
adding 'cssutils/tests/test_helper.py'
adding 'cssutils/tests/test_marginrule.py'
adding 'cssutils/tests/test_medialist.py'
adding 'cssutils/tests/test_mediaquery.py'
adding 'cssutils/tests/test_parse.py'
adding 'cssutils/tests/test_prodparser.py'
adding 'cssutils/tests/test_profiles.py'
adding 'cssutils/tests/test_properties.py'
adding 'cssutils/tests/test_property.py'
adding 'cssutils/tests/test_scripts_csscombine.py'
adding 'cssutils/tests/test_selector.py'
adding 'cssutils/tests/test_selectorlist.py'
adding 'cssutils/tests/test_serialize.py'
adding 'cssutils/tests/test_settings.py'
adding 'cssutils/tests/test_stylesheet.py'
adding 'cssutils/tests/test_tokenize2.py'
adding 'cssutils/tests/test_util.py'
adding 'cssutils/tests/test_value.py'
adding 'cssutils/tests/test_x.py'
adding 'cssutils/tests/sheets/096.css'
adding 'cssutils/tests/sheets/097.css'
adding 'cssutils/tests/sheets/1.css'
adding 'cssutils/tests/sheets/1ascii.css'
adding 'cssutils/tests/sheets/1import.css'
adding 'cssutils/tests/sheets/1inherit-ascii.css'
adding 'cssutils/tests/sheets/1inherit-iso.css'
adding 'cssutils/tests/sheets/1inherit-utf8.css'
adding 'cssutils/tests/sheets/1utf.css'
adding 'cssutils/tests/sheets/2inherit-iso.css'
adding 'cssutils/tests/sheets/2resolve.css'
adding 'cssutils/tests/sheets/acid2.css'
adding 'cssutils/tests/sheets/all.css'
adding 'cssutils/tests/sheets/atrule.css'
adding 'cssutils/tests/sheets/bad.css'
adding 'cssutils/tests/sheets/basic.css'
adding 'cssutils/tests/sheets/bundle.css'
adding 'cssutils/tests/sheets/cases.css'
adding 'cssutils/tests/sheets/csscombine-1.css'
adding 'cssutils/tests/sheets/csscombine-2.css'
adding 'cssutils/tests/sheets/csscombine-proxy.css'
adding 'cssutils/tests/sheets/cthedot_default.css'
adding 'cssutils/tests/sheets/default_html4.css'
adding 'cssutils/tests/sheets/hacks.css'
adding 'cssutils/tests/sheets/html.css'
adding 'cssutils/tests/sheets/html20.css'
adding 'cssutils/tests/sheets/html40.css'
adding 'cssutils/tests/sheets/import.css'
adding 'cssutils/tests/sheets/import3.css'
adding 'cssutils/tests/sheets/ll.css'
adding 'cssutils/tests/sheets/ll2.css'
adding 'cssutils/tests/sheets/multiple-values.css'
adding 'cssutils/tests/sheets/page_test.css'
adding 'cssutils/tests/sheets/sample_5.css'
adding 'cssutils/tests/sheets/sample_7.css'
adding 'cssutils/tests/sheets/simple.css'
adding 'cssutils/tests/sheets/single-color.css'
adding 'cssutils/tests/sheets/slashcode.css'
adding 'cssutils/tests/sheets/t-HACKS.css'
adding 'cssutils/tests/sheets/test-unicode.css'
adding 'cssutils/tests/sheets/test.css'
adding 'cssutils/tests/sheets/tigris.css'
adding 'cssutils/tests/sheets/tigris2.css'
adding 'cssutils/tests/sheets/u_simple.css'
adding 'cssutils/tests/sheets/v_simple.css'
adding 'cssutils/tests/sheets/vars.css'
adding 'cssutils/tests/sheets/varsimport.css'
adding 'cssutils/tests/sheets/xhtml2.css'
adding 'cssutils/tests/sheets/xhtml22.css'
adding 'cssutils/tests/sheets/yuck.css'
adding 'cssutils/tests/sheets/images/example.gif'
adding 'cssutils/tests/sheets/import/import-impossible.css'
adding 'cssutils/tests/sheets/import/import2.css'
adding 'cssutils/tests/sheets/import/images2/example2.gif'
adding 'cssutils/tests/sheets/var/start.css'
adding 'cssutils/tests/sheets/var/use.css'
adding 'cssutils/tests/sheets/var/vars.css'
adding 'cssutils/tests/sheets/var/vars2.css'
adding 'encutils/__init__.py'
adding 'cssutils-2.9.0.dist-info/COPYING'
adding 'cssutils-2.9.0.dist-info/COPYING.LESSER'
adding 'cssutils-2.9.0.dist-info/METADATA'
adding 'cssutils-2.9.0.dist-info/WHEEL'
adding 'cssutils-2.9.0.dist-info/entry_points.txt'
adding 'cssutils-2.9.0.dist-info/top_level.txt'
adding 'cssutils-2.9.0.dist-info/RECORD'
removing build/bdist.linux-x86_64/wheel
Successfully built cssutils-2.9.0-py3-none-any.whl
==> Starting check()...
============================================================================ test session starts ============================================================================
platform linux -- Python 3.11.8, pytest-8.1.1, pluggy-1.4.0
rootdir: /home/aahmad/.cache/yay/python-cssutils/src/cssutils-2.9.0
configfile: pytest.ini
plugins: jaraco.test-5.4.0
collected 444 items
cssutils/tests/test_codec.py ......        [  1%]
cssutils/tests/test_csscharsetrule.py ..........        [  3%]
cssutils/tests/test_csscomment.py .......        [  5%]
cssutils/tests/test_cssfontfacerule.py ...........        [  7%]
cssutils/tests/test_cssimportrule.py ..............        [ 10%]
cssutils/tests/test_cssmediarule.py .................        [ 14%]
cssutils/tests/test_cssnamespacerule.py ..........        [ 16%]
cssutils/tests/test_csspagerule.py ..............        [ 20%]
cssutils/tests/test_cssproperties.py ...        [ 20%]
cssutils/tests/test_cssrule.py ....        [ 21%]
cssutils/tests/test_cssrulelist.py ..        [ 22%]
cssutils/tests/test_cssstyledeclaration.py ........................        [ 27%]
cssutils/tests/test_cssstylerule.py ............        [ 30%]
cssutils/tests/test_cssstylesheet.py ............................        [ 36%]
cssutils/tests/test_cssunknownrule.py .......        [ 38%]
cssutils/tests/test_cssutils.py ........        [ 39%]
cssutils/tests/test_cssutilsimport.py .        [ 40%]
cssutils/tests/test_cssvalue.py xxxxXxxxxxxxxxxxxxxxx        [ 44%]
cssutils/tests/test_cssvariablesdeclaration.py .........        [ 46%]
cssutils/tests/test_cssvariablesrule.py ..........        [ 49%]
cssutils/tests/test_domimplementation.py FFFF        [ 50%]
cssutils/tests/test_encutils.py .......        [ 51%]
cssutils/tests/test_errorhandler.py ....        [ 52%]
cssutils/tests/test_helper.py .....        [ 53%]
cssutils/tests/test_marginrule.py ........        [ 55%]
cssutils/tests/test_medialist.py .........        [ 57%]
cssutils/tests/test_mediaquery.py ....        [ 58%]
cssutils/tests/test_parse.py ..............        [ 61%]
cssutils/tests/test_prodparser.py .................        [ 65%]
cssutils/tests/test_profiles.py ........xxxxxx.............xxxxx        [ 72%]
cssutils/tests/test_properties.py ..        [ 72%]
cssutils/tests/test_property.py ........        [ 74%]
cssutils/tests/test_scripts_csscombine.py ..        [ 75%]
cssutils/tests/test_selector.py ........        [ 77%]
cssutils/tests/test_selectorlist.py .....        [ 78%]
cssutils/tests/test_serialize.py .............................        [ 84%]
cssutils/tests/test_settings.py .        [ 84%]
cssutils/tests/test_stylesheet.py .        [ 85%]
cssutils/tests/test_tokenize2.py .............        [ 88%]
cssutils/tests/test_util.py .....................        [ 92%]
cssutils/tests/test_value.py .F...................xxxxxxxxxx        [ 99%]
cssutils/tests/test_x.py x        [100%]
================================================================================= FAILURES ==================================================================================
______________________________________________________________ TestDOMImplementation.test_createCSSStyleSheet _______________________________________________________________
self = <cssutils.tests.test_domimplementation.TestDOMImplementation object at 0x7fa1ae6d9b50>
    def test_createCSSStyleSheet(self):
        "DOMImplementationCSS.createCSSStyleSheet()"
        title, media = 'Test Title', cssutils.stylesheets.MediaList('all')
        with warnings.catch_warnings():
            warnings.simplefilter('ignore')
>           sheet = self.domimpl.createCSSStyleSheet(title, media)
E           AttributeError: 'TestDOMImplementation' object has no attribute 'domimpl'
/home/aahmad/.cache/yay/python-cssutils/src/cssutils-2.9.0/cssutils/tests/test_domimplementation.py:19: AttributeError
_________________________________________________________________ TestDOMImplementation.test_createDocument _________________________________________________________________
self = <cssutils.tests.test_domimplementation.TestDOMImplementation object at 0x7fa1ae4a6010>
    def test_createDocument(self):
        "DOMImplementationCSS.createDocument()"
>       doc = self.domimpl.createDocument(None, None, None)
/home/aahmad/.cache/yay/python-cssutils/src/cssutils-2.9.0/cssutils/tests/test_domimplementation.py:26: AttributeError
_______________________________________________________________ TestDOMImplementation.test_createDocumentType _______________________________________________________________
self = <cssutils.tests.test_domimplementation.TestDOMImplementation object at 0x7fa1ae4a7290>
    def test_createDocumentType(self):
        "DOMImplementationCSS.createDocumentType()"
>       doctype = self.domimpl.createDocumentType('foo', 'bar', 'raboof')
/home/aahmad/.cache/yay/python-cssutils/src/cssutils-2.9.0/cssutils/tests/test_domimplementation.py:31: AttributeError
___________________________________________________________________ TestDOMImplementation.test_hasFeature ___________________________________________________________________
self = <cssutils.tests.test_domimplementation.TestDOMImplementation object at 0x7fa1ae285610>
    def test_hasFeature(self):
        "DOMImplementationCSS.hasFeature()"
        tests = [
            ('css', '1.0'),
            ('css', '2.0'),
            ('stylesheets', '1.0'),
            ('stylesheets', '2.0'),
        for name, version in tests:
>           assert self.domimpl.hasFeature(name, version)
/home/aahmad/.cache/yay/python-cssutils/src/cssutils-2.9.0/cssutils/tests/test_domimplementation.py:43: AttributeError
______________________________________________________________________ TestPropertyValue.test_cssText _______________________________________________________________________
self = <cssutils.tests.test_value.TestPropertyValue object at 0x7fa1ade46b10>
    def test_cssText(self):
        "PropertyValue.cssText"
        tests = {
            '0': (None, 1, None),
            '0 0': (None, 2, None),
            '0, 0': (None, 2, None),
            '0,0': ('0, 0', 2, None),
            '0  ,   0': ('0, 0', 2, None),
            '0/0': (None, 2, None),
            '/**/ 0 /**/': (None, 1, '0'),
            '0 /**/ 0 /**/ 0': (None, 3, '0 0 0'),
            '0, /**/ 0, /**/ 0': (None, 3, '0, 0, 0'),
            '0//**/ 0//**/ 0': (None, 3, '0/0/0'),
            '/**/ red': (None, 1, 'red'),
            '/**/red': ('/**/ red', 1, 'red'),
            'red /**/': (None, 1, 'red'),
            'red/**/': ('red /**/', 1, 'red'),
            'a()1,-1,+1,1%,-1%,1px,-1px,"a",a,url(a),#aabb44': (
                'a() 1, -1, +1, 1%, -1%, 1px, -1px, "a", a, url(a), #ab4',
                12,
            # calc values
            'calc(1)': (None, 1, 'calc(1)'),
            'calc( 1)': ('calc(1)', 1, 'calc(1)'),
            'calc(1 )': ('calc(1)', 1, 'calc(1)'),
            'calc(1px)': (None, 1, 'calc(1px)'),
            'calc(1p-x-)': (None, 1, 'calc(1p-x-)'),
            'calc(1%)': (None, 1, 'calc(1%)'),
            'calc(-1)': (None, 1, 'calc(-1)'),
            'calc(+1)': (None, 1, 'calc(+1)'),
            'calc(1  +   1px)': ('calc(1 + 1px)', 1, 'calc(1 + 1px)'),
            'calc(1 - 1px)': (None, 1, 'calc(1 - 1px)'),
            'calc(1*1px)': ('calc(1 * 1px)', 1, 'calc(1 * 1px)'),
            'calc(1  /  1px)': ('calc(1 / 1px)', 1, 'calc(1 / 1px)'),
            'calc( 1*1px)': ('calc(1 * 1px)', 1, 'calc(1 * 1px)'),
            'calc( 1  /  1px)': ('calc(1 / 1px)', 1, 'calc(1 / 1px)'),
            'calc(1*1px )': ('calc(1 * 1px)', 1, 'calc(1 * 1px)'),
            'calc(1  /  1px )': ('calc(1 / 1px)', 1, 'calc(1 / 1px)'),
            'calc( 1*1px )': ('calc(1 * 1px)', 1, 'calc(1 * 1px)'),
            'calc( 1  /  1px )': ('calc(1 / 1px)', 1, 'calc(1 / 1px)'),
            'calc(calc(1px + 5px) * 4)': (
                'calc(calc(1px + 5px) * 4)',
                1,
            'calc( calc(1px + 5px)*4 )': (
                1,
            'calc(var(X))': (None, 1, None),
            'calc(2 * var(X))': (None, 1, None),
            'calc(2px + var(X))': (None, 1, None),
            # issue #24
            'rgb(0, 10, 255)': (None, 1, 'rgb(0, 10, 255)'),
            'hsl(10, 10%, 25%)': (None, 1, 'hsl(10, 10%, 25%)'),
            'rgba(0, 10, 255, 0.5)': (None, 1, 'rgba(0, 10, 255, 0.5)'),
            'hsla(10, 10%, 25%, 0.5)': (None, 1, 'hsla(10, 10%, 25%, 0.5)'),
            # issue #27
            'matrix(0.000092, 0.2500010, -0.250000, 0.000092, 0, 0)': (
                'matrix(0.000092, 0.250001, -0.25, 0.000092, 0, 0)',
                1,
        for cssText, (c, len, v) in list(tests.items()):
            if c is None:
                c = cssText
            if v is None:
                v = c
            pv = cssutils.css.PropertyValue(cssText)
            assert c == pv.cssText
            assert len == pv.length
            assert v == pv.value
        tests = {
            '0 0px -0px +0px': ('0 0 0 0', 4),
            '1 2 3 4': (None, 4),
            '-1 -2 -3 -4': (None, 4),
            '-1 2': (None, 2),
            '-1px red "x"': (None, 3),
            'a, b c': (None, 3),
            '1px1 2% 3': ('1px1 2% 3', 3),
            'f(+1pX, -2, 5%) 1': ('f(+1px, -2, 5%) 1', 2),
            '0 f()0': ('0 f() 0', 3),
            'f()0': ('f() 0', 2),
            'f()1%': ('f() 1%', 2),
            'f()1px': ('f() 1px', 2),
            'f()"str"': ('f() "str"', 2),
            'f()ident': ('f() ident', 2),
            'f()#123': ('f() #123', 2),
            'f()url()': ('f() url()', 2),
            'f()f()': ('f() f()', 2),
            'url(x.gif)0 0': ('url(x.gif) 0 0', 3),
            'url(x.gif)no-repeat': ('url(x.gif) no-repeat', 2),
        for cssText, (c, len) in list(tests.items()):
            if c is None:
                c = cssText
        tests = {
            # hash and rgb/a
            '#112234': '#112234',
            '#112233': '#123',
            'rgb(1,2,3)': 'rgb(1, 2, 3)',
            'rgb(  1  ,  2  ,  3  )': 'rgb(1, 2, 3)',
            'rgba(1,2,3,4)': 'rgba(1, 2, 3, 4)',
            'rgba(  1  ,  2  ,  3  ,  4 )': 'rgba(1, 2, 3, 4)',
            'rgb(-1,+2,0)': 'rgb(-1, +2, 0)',
            'rgba(-1,+2,0, 0)': 'rgba(-1, +2, 0, 0)',
            # FUNCTION
            'f(1,2)': 'f(1, 2)',
            'f(  1  ,  2  )': 'f(1, 2)',
            'f(-1,+2)': 'f(-1, +2)',
            'f(  -1  ,  +2  )': 'f(-1, +2)',
            'fun(  -1  ,  +2  )': 'fun(-1, +2)',
            'local( x )': 'local(x)',
            'test(1px, #111, y, 1, 1%, "1", y(), var(x))': 'test(1px, #111, y, 1, 1%, "1", y(), var(x))',
            'test(-1px, #111, y, -1, -1%, "1", -y())': 'test(-1px, #111, y, -1, -1%, "1", -y())',
            'url(y)  format( "x" ,  "y" )': 'url(y) format("x", "y")',
            'f(1 2,3 4)': 'f(1 2, 3 4)',
            # IE expression
            r'Expression()': 'Expression()',
            r'expression(-1 < +2)': 'expression(-1<+2)',
            r'expression(document.width == "1")': 'expression(document.width=="1")',
            'alpha(opacity=80)': 'alpha(opacity=80)',
            'alpha( opacity = 80 , x=2  )': 'alpha(opacity=80, x=2)',
            'expression(eval(document.documentElement.scrollTop))': 'expression(eval(document.documentElement.scrollTop))',
            # TODO
            #            u'expression((function(ele){ele.style.behavior="none";})(this))':
            #                u'expression((function(ele){ele.style.behavior="none";})(this))',
            # unicode-range
            'u+f': 'u+f',
            'U+ABCdef': 'u+abcdef',
            # url
            'url(a)': 'url(a)',
            'uRl(a)': 'url(a)',
            'u\\rl(a)': 'url(a)',
            'url("a")': 'url(a)',
            'url(  "a"  )': 'url(a)',
            'url(";")': 'url(";")',
            'url(",")': 'url(",")',
            'url(")")': 'url(")")',
            '''url("'")''': '''url("'")''',
            '''url('"')''': '''url("\\"")''',
            # operator
            '1': '1',
            '1 2': '1 2',
            '1   2': '1 2',
            '1,2': '1, 2',
            '1,  2': '1, 2',
            '1  ,2': '1, 2',
            '1  ,  2': '1, 2',
            '1/2': '1/2',
            '1/  2': '1/2',
            '1  /2': '1/2',
            '1  /  2': '1/2',
            # comment
            '1/**/2': '1 /**/ 2',
            '1 /**/2': '1 /**/ 2',
            '1/**/ 2': '1 /**/ 2',
            '1 /**/ 2': '1 /**/ 2',
            '1  /*a*/  /*b*/  2': '1 /*a*/ /*b*/ 2',
            # , before
            '1,/**/2': '1, /**/ 2',
            '1 ,/**/2': '1, /**/ 2',
            '1, /**/2': '1, /**/ 2',
            '1 , /**/2': '1, /**/ 2',
            # , after
            '1/**/,2': '1 /**/, 2',
            '1/**/ ,2': '1 /**/, 2',
            '1/**/, 2': '1 /**/, 2',
            '1/**/ , 2': '1 /**/, 2',
            # all
            '1/*a*/  ,/*b*/  2': '1 /*a*/, /*b*/ 2',
            '1  /*a*/,  /*b*/2': '1 /*a*/, /*b*/ 2',
            '1  /*a*/  ,  /*b*/  2': '1 /*a*/, /*b*/ 2',
            # list
            'a b1,b2 b2,b3,b4': 'a b1, b2 b2, b3, b4',
            'a b1  ,   b2   b2  ,  b3  ,   b4': 'a b1, b2 b2, b3, b4',
            'u+1  ,   u+2-5': 'u+1, u+2-5',
            'local( x ),  url(y)  format( "x" ,  "y" )': 'local(x), url(y) format("x", "y")',
            # FUNCTION
            'attr( href )': 'attr(href)',
            # PrinceXML extende FUNC syntax with nested FUNC
            'target-counter(attr(href),page)': 'target-counter(attr(href), page)',
>       self.do_equal_r(tests)
/home/aahmad/.cache/yay/python-cssutils/src/cssutils-2.9.0/cssutils/tests/test_value.py:230:
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
self = <cssutils.tests.test_value.TestPropertyValue object at 0x7fa1ade46b10>, tests = {'#112233': '#123', '#112234': '#112234', '1': '1', '1   2': '1 2', ...}
att = 'cssText'
    def do_equal_r(self, tests, att='cssText'):
        # set attribute att of self.r and assert Equal
        for test, expected in tests.items():
>           self.r.__setattr__(att, test)
E           AttributeError: 'TestPropertyValue' object has no attribute 'r'
/home/aahmad/.cache/yay/python-cssutils/src/cssutils-2.9.0/cssutils/tests/basetest.py:41: AttributeError
============================================================================= warnings summary ==============================================================================
cssutils/tests/test_encutils.py::TestAutoEncoding::test_getEncodingInfo
  /home/aahmad/.cache/yay/python-cssutils/src/cssutils-2.9.0/encutils/__init__.py:652: DeprecationWarning: The 'warn' method is deprecated, use 'warning' instead
    log.warn(
-- Docs: https://docs.pytest.org/en/stable/how-to/capture-warnings.html
========================================================================== short test summary info ==========================================================================
FAILED cssutils/tests/test_domimplementation.py::TestDOMImplementation::test_createCSSStyleSheet - AttributeError: 'TestDOMImplementation' object has no attribute 'domimpl'
FAILED cssutils/tests/test_domimplementation.py::TestDOMImplementation::test_createDocument - AttributeError: 'TestDOMImplementation' object has no attribute 'domimpl'
FAILED cssutils/tests/test_domimplementation.py::TestDOMImplementation::test_createDocumentType - AttributeError: 'TestDOMImplementation' object has no attribute 'domimpl'
FAILED cssutils/tests/test_domimplementation.py::TestDOMImplementation::test_hasFeature - AttributeError: 'TestDOMImplementation' object has no attribute 'domimpl'
FAILED cssutils/tests/test_value.py::TestPropertyValue::test_cssText - AttributeError: 'TestPropertyValue' object has no attribute 'r'
===================================================== 5 failed, 396 passed, 42 xfailed, 1 xpassed, 2 warnings in 4.68s ======================================================
==> ERROR: A failure occurred in check().
    Aborting...
 -> Failed to install layer, rolling up to next layer.error:error making: python-cssutils - exit status 4
 core is up to date
 extra is up to date
warning: sassc-3.6.2-4 is up to date -- reinstalling
Packages (1) sassc-3.6.2-4
Total Installed Size:  0.02 MiB
Net Upgrade Size:      0.00 MiB
(1/1) checking keys in keyring        [--------------------------------------------------------------] 100%
(1/1) checking package integrity        [--------------------------------------------------------------] 100%
(1/1) loading package files        [--------------------------------------------------------------] 100%
(1/1) checking for file conflicts        [--------------------------------------------------------------] 100%
(1/1) checking available disk space        [--------------------------------------------------------------] 100%
(1/1) reinstalling sassc        [--------------------------------------------------------------] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Checking which packages need to be rebuilt
==> Making package: python-cssutils 2.9.0-1 (Sat 23 Mar 2024 11:24:41 AM CDT)
==> Making package: python-cssutils 2.9.0-1 (Sat 23 Mar 2024 11:24:43 AM CDT)
running egg_info
* Building wheel...
running bdist_wheel
running build
running build_py
creating build
creating build/lib
running egg_info
running install
running install_lib
creating '/home/aahmad/.cache/yay/python-cssutils/src/cssutils-2.9.0/dist/.tmp-8nwrigu0/cssutils-2.9.0-py3-none-any.whl' and adding 'build/bdist.linux-x86_64/wheel' to it
collected 444 items
self = <cssutils.tests.test_domimplementation.TestDOMImplementation object at 0x7f6d8a44f010>
self = <cssutils.tests.test_domimplementation.TestDOMImplementation object at 0x7f6d8a44e8d0>
self = <cssutils.tests.test_domimplementation.TestDOMImplementation object at 0x7f6d8a44ee90>
self = <cssutils.tests.test_domimplementation.TestDOMImplementation object at 0x7f6d8a44c750>
        tests = [
            ('css', '1.0'),
            ('css', '2.0'),
self = <cssutils.tests.test_value.TestPropertyValue object at 0x7f6d89e3e690>
        tests = {
                12,
            # calc values
                1,
                1,
            # issue #24
            # issue #27
                1,
            if c is None:
                c = cssText
            if v is None:
                v = c
        tests = {
            '-1 2': (None, 2),
            if c is None:
                c = cssText
        tests = {
            # hash and rgb/a
            '#112233': '#123',
            # FUNCTION
            # IE expression
            # TODO
            # unicode-range
            'u+f': 'u+f',
            # url
            'url(a)': 'url(a)',
            'uRl(a)': 'url(a)',
            # operator
            '1': '1',
            '1 2': '1 2',
            '1   2': '1 2',
            '1,2': '1, 2',
            '1,  2': '1, 2',
            '1  ,2': '1, 2',
            '1  ,  2': '1, 2',
            '1/2': '1/2',
            '1/  2': '1/2',
            '1  /2': '1/2',
            '1  /  2': '1/2',
            # comment
            # , before
            # , after
            # all
            # list
            # FUNCTION
self = <cssutils.tests.test_value.TestPropertyValue object at 0x7f6d89e3e690>, tests = {'#112233': '#123', '#112234': '#112234', '1': '1', '1   2': '1 2', ...}
att = 'cssText'
    log.warn(
===================================================== 5 failed, 396 passed, 42 xfailed, 1 xpassed, 2 warnings in 4.32s ======================================================
    Aborting...
 -> error making: python-cssutils-exit status 4
==> Making package: gradience 0.4.1_patch1-1 (Sat 23 Mar 2024 11:24:49 AM CDT)
==> Missing dependencies:
  -> python-cssutils
==> ERROR: Could not resolve all dependencies.
 -> error making: gradience-exit status 8
checking dependencies...
:: python optionally requires python-setuptools: for building Python packages using tooling that is usually bundled with Python
:: python-cffi optionally requires python-setuptools: "limited api" version checking in cffi.setuptools_ext
:: python-future optionally requires python-setuptools: futurize and pasteurize scripts
Packages (15) libsass-3.6.6-1  python-fastjsonschema-2.19.1-1  python-ordered-set-4.1.0-4  python-platformdirs-4.2.0-1  python-pyproject-hooks-1.0.0-5  python-tomli-2.0.1-3
              python-setuptools-scm-8.0.4-1  python-toml-0.10.2-9  python-wheel-0.43.0-1  sassc-3.6.2-4
Total Removed Size:  9.83 MiB
:: Do you want to remove these packages? [Y/n]
( 1/15) removing python-build        [--------------------------------------------------------------] 100%
( 2/15) removing python-pyproject-hooks        [--------------------------------------------------------------] 100%
( 3/15) removing python-wheel        [--------------------------------------------------------------] 100%
( 4/15) removing python-toml        [--------------------------------------------------------------] 100%
( 5/15) removing python-setuptools-scm        [--------------------------------------------------------------] 100%
( 6/15) removing python-setuptools        [--------------------------------------------------------------] 100%
( 7/15) removing python-validate-pyproject                                                              [--------------------------------------------------------------] 100%
( 8/15) removing python-trove-classifiers                                                               [--------------------------------------------------------------] 100%
( 9/15) removing python-fastjsonschema        [--------------------------------------------------------------] 100%
(10/15) removing python-tomli        [--------------------------------------------------------------] 100%
(11/15) removing python-platformdirs        [--------------------------------------------------------------] 100%
(12/15) removing python-ordered-set        [--------------------------------------------------------------] 100%
(13/15) removing python-installer        [--------------------------------------------------------------] 100%
(14/15) removing sassc        [--------------------------------------------------------------] 100%
(15/15) removing libsass        [--------------------------------------------------------------] 100%
 -> Failed to install the following packages. Manual intervention is required:
gradience - exit status 8
Any help would be greatly appreciated, thank you!
Please remove those images of text and post properly formatted text: [HowTo] Post command output and file content as formatted text
Sure, any quick thoughts on what the issue might be as I fix my OP? Thank you.
Please remove the screenshots - they are useless.
I will echo the request - do not post screenshots of text - you could as easily have copy/pasted the text into a new topic.
To make sure custom packages using custom scripts from AUR works as expected you are required to use unstable branch.
sudo pacman-mirrors -aS unstable
sudo pacman -Syu
For python specific packages make sure they conform to Arch Package standards for Python packages.
Installing custom python packages into the global python site-packages is generally a bad idea - especially if they do not conform to the package standard.
In such non-conform installation using sudo pip or otherwise it may create file conflicts with repo packages.
It is generally recommended to use a virtual environment or pipx for custom packages.
Quite obviously, you have missing build-time dependencies, and the maintainer of that PKGBUILD hasn’t bothered to check for them and pull them in.
My advice would be to contact the maintainer on their GitHub page.
Should I just remove the python-cssutils and Gradience packages then? For the easiest and cleanest fix?
If you don’t need them, then yes, you can remove them. They are after all both AUR packages and thus not part of the main system.
Done, thanks!
I dropped gradience from the repos. If you hadn’t even noticed it wasn’t working properly for over a year, then you probably don’t need it. :wink:
