Hello when i try to run “pip install” it gives me this error :
ERROR: Exception:
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/cli/base_command.py", line 160, in exc_logging_wrapper
status = run_func(*args)
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/cli/req_command.py", line 247, in wrapper
return func(self, options, args)
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/commands/install.py", line 326, in run
session = self.get_default_session(options)
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/cli/req_command.py", line 98, in get_default_session
self._session = self.enter_context(self._build_session(options))
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/cli/req_command.py", line 125, in _build_session
session = PipSession(
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/network/session.py", line 343, in __init__
self.headers["User-Agent"] = user_agent()
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/network/session.py", line 175, in user_agent
setuptools_dist = get_default_environment().get_distribution("setuptools")
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/metadata/importlib/_envs.py", line 188, in get_distribution
return next(matches, None)
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/metadata/importlib/_envs.py", line 185, in <genexpr>
for distribution in self.iter_all_distributions()
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/metadata/base.py", line 612, in iter_all_distributions
for dist in self._iter_distributions():
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/metadata/importlib/_envs.py", line 176, in _iter_distributions
for dist in finder.find_eggs(location):
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/metadata/importlib/_envs.py", line 144, in find_eggs
yield from self._find_eggs_in_dir(location)
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/metadata/importlib/_envs.py", line 111, in _find_eggs_in_dir
from pip._vendor.pkg_resources import find_distributions
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2164, in <module>
register_finder(pkgutil.ImpImporter, find_on_path)
AttributeError: module 'pkgutil' has no attribute 'ImpImporter'. Did you mean: 'zipimporter'?
File "/home/femscout/.local/bin/pip", line 8, in <module>
sys.exit(main())
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/cli/main.py", line 70, in main
return command.main(cmd_args)
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/cli/base_command.py", line 101, in main
return self._main(args)
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/cli/base_command.py", line 216, in _main
self.handle_pip_version_check(options)
File "/home/femscout/.local/lib/python3.12/site-packages/pip/_internal/cli/req_command.py", line 179, in handle_pip_version_check
session = self._build_session(
am trying to use “Comfyui” and it fails to auto install cause of pip not working as intended
