May I asked for the newest version of PyCharm? It is on AUR.
It is also in the unstable branch.
It is super simple to get
Download the tarred archive
Unpack and run the new <unpacked>/bin/pycharm.sh
This kind of programs that don’t have significant dependencies (and Manjaro does not modify) can even be installed directly from Arch (or unstable):
sudo pacman -U https://archlinux.org/packages/extra/x86_64/pycharm-community-edition/download/
I didn’t had it installed before, but it didn’t pull any other dependency. And it works fine.
That said, I only recommend this if you know what are you doing.
