So when i use the volume keys i cant go up in volume and its very jumpy and when useing the slider it also very jumpy but i can use it can any one help with this
Hi Cola. I see this is your first post - welcome! I’m not sure how to help you, other than to suggest that you try using the arrow keys when you are adjusting volume. It would also be useful for people to know which desktop you are using, especially with these sorts of issues. Hopefully you find a solution soon. All the best meantime, R
