Pulseaudio tray plugin not showing above panel - it used to
I swear it used to. I have literally no evidence of this.
how it currently looks:
How I remember it from… some time ago. (artist’s rendition)
system info:
  Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=3c4af43d-de9b-4b63-ad1a-007be98ffe30 rw quiet apparmor=1
    security=apparmor resume=UUID=707ca9e3-c14e-4cbd-86d7-a5246b51143f
    udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
    vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: Gigabyte product: B450 AORUS PRO WIFI v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: B450 AORUS PRO WIFI-CF v: x.x
    serial: <superuser required> UEFI: American Megatrends v: F51
    date: 07/29/2020
  RAM: total: 15.63 GiB used: 4.25 GiB (27.2%)
  RAM Report:
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3952 high: 4115 min/max: 2200/4208 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3731 2: 4107
    3: 4081 4: 3918 5: 4108 6: 4082 7: 3523 8: 4110 9: 4056 10: 3978 11: 4115
    12: 3619 bogomips: 86270
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
    sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    conditional, RSB filling
  Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASUSTeK
    driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:73ff class-ID: 0300
  Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
    loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
    s-diag: 1055mm (41.5")
  Monitor-1: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 82
    size: 598x336mm (23.5x13.2") diag: 686mm (27")
  Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 92
    size: 531x299mm (20.9x11.8") diag: 609mm (24")
  Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
    driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 1002:ab28
    class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
    class-ID: 0403
  Device-3: Corsair CORSAIR VIRTUOSO Wireless Gaming Headset type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:5 chip-ID: 1b1c:0a5c
    class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.19 running: no
  Sound Server-4: PulseAudio v: 15.0 running: yes
  Sound Server-5: PipeWire v: 0.3.42 running: yes
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    port: f000 bus-ID: 03:00.0 chip-ID: 8086:1539 class-ID: 0200
  Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 04:00.0
    chip-ID: 8086:2526 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
    v: 0.8 bus-ID: 1-5:3 chip-ID: 8087:0025 class-ID: e001
  Local Storage: total: 4.23 TiB used: 2.54 TiB (60.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM000-1F2168
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: HDD rpm: 5900 serial: <filter> rev: CC52 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Intel model: SSDSC2CT120A3
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 300i scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
    type: SSD serial: <filter> rev: 2B6Q scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Netac model: OnlyDisk
    size: 29 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: 0000 scheme: MBR
  ID-1: / raw-size: 94.3 GiB size: 92.26 GiB (97.84%) used: 62.88 GiB (68.2%)
    fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: 3c4af43d-de9b-4b63-ad1a-007be98ffe30
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
    uuid: 4C8A-6D46
  ID-3: /media/Victoria raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
    used: 2.48 TiB (68.1%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Victoria
    uuid: 3092E79392E75C3A
  ID-4: /run/media/tether/2849-307C raw-size: 29 GiB
    size: 28.99 GiB (99.95%) used: 2.03 GiB (7.0%) fs: vfat dev: /dev/sdd1
    maj-min: 8:49 label: N/A uuid: 2849-307C
  ID-1: swap-1 type: partition size: 17.2 GiB used: 47.2 MiB (0.3%)
    priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
    uuid: 707ca9e3-c14e-4cbd-86d7-a5246b51143f
  ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sda3 maj-min: 8:3 size: 1.95 GiB fs: ntfs label: Backup_Boot
    uuid: 4C6AF9AC6AF99346
  ID-3: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: vfat label: N/A
    uuid: 342D-15CF
  ID-4: /dev/sdc2 maj-min: 8:34 size: 16 MiB fs: <superuser required>
  ID-5: /dev/sdc3 maj-min: 8:35 size: 465.16 GiB fs: ntfs
    label: Zephyr Aspiration uuid: 40362E0A362E0210
  ID-6: /dev/sdc4 maj-min: 8:36 size: 499 MiB fs: ntfs label: N/A
    uuid: 1C74D7F474D7CEA0
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-4:5 info: Corsair CORSAIR VIRTUOSO Wireless Gaming Headset
    type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 5
    rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:0a5c class-ID: 0300
    serial: <filter>
  Device-2: 1-5:3 info: Intel Wireless-AC 9260 Bluetooth Adapter
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 8087:0025 class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-3:2 info: Netac OnlyDisk type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 496mA
    chip-ID: 0dd8:2004 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-4: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 2109:3431 class-ID: 0900
  Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-3:2 info: Microsoft Xbox One Controller
    type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 045e:02d1 class-ID: ff00 serial: <filter>
  Device-2: 5-4:3 info: IBM NetVista Full Width Keyboard type: Keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
    power: 100mA chip-ID: 04b3:3025 class-ID: 0301
  Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 38.0 C mem: 38.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 352 Uptime: 1d 1h 56m wakeups: 1 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.1.0 Packages: 1214 pacman: 1205 lib: 341
  flatpak: 6 snap: 3 Shell: fish v: 3.3.1 running-in: xfce4-terminal
  inxi: 3.3.11
see if this helps:
@ishaan2479 I don’t see how that’s related?
seems to work as i remember it if panel is at the top of my screen.
you want to reserve space.
was already unticked, and ticking it doesn’t change anything.
Didn’t think to check this last night.
It works on one of my monitors, but not the other:
