after a restart my pulse audio settings reset themself
input audio gets very low after i change it and restart it gets back to the old position
i tried the method describer here but it didnt work
Try clearing PulseAudio databases in home folder of any old level settings
rm ~/.config/pulse/*.tdb ~/.config/pulse/cookie
And reboot system so PulseAudio creates new files when restarted
You might also want to try reinstating a PulseAudio setting for ‘flat-volumes’.
The setting is disabled by default because most users disliked having audio level reset to 100%
Use this command to reconfigure PulseAudio
echo 'flat-volumes = 1' | tee -a ~/.config/pulse/daemon.conf
then this to restart PulseAudio
systemctl --user restart pulseaudio
This command may also be needed to check if reconfiguration is effective
pulseaudio --dump-conf | grep flat
