I want to run mopidy through pulseaudio.
So, i change the /boot/config.txt like this:
cat /boot/config.txt
# See /boot/overlays/README for all available options
dtoverlay=vc4-kms-v3d,noaudio
# Disable compensation for displays with overscan
display_auto_detect=1
# Uncomment to enable bluetooth
#dtparam=krnbt=on
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[pi4]
# Run as fast as firmware / board allows
arm_boost=1
dtoverlay=iqaudio-dacplus
I config mopidy to send to pulseaudio and put pulseaudio to hear.
But from pulseaudio im getting a “dummy output” (with no sound…), but receiving from mopidy (that is working…)
Also if i do, i get:
aplay -l
aplay: device_list:274: no soundcards found...
But if i run alsamixer i get (it is there):
Also create asound.conf in /etc like this:
cat /etc/asound.conf
pcm.!default {
type hw card 0
ctl.!default {
type hw card 0
also:
lsmod | grep snd
snd_soc_pcm512x_i2c 16384 1
snd_soc_pcm512x 32768 1 snd_soc_pcm512x_i2c
snd_soc_iqaudio_dac 16384 0
snd_soc_bcm2835_i2s 16384 2
snd_bcm2835 24576 0
snd_soc_hdmi_codec 16384 0
snd_soc_core 225280 5 snd_soc_pcm512x,vc4,snd_soc_iqaudio_dac,snd_soc_hdmi_codec,snd_soc_bcm2835_i2s
snd_compress 20480 1 snd_soc_core
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_pcm 114688 7 snd_compress,snd_soc_pcm512x,snd_pcm_dmaengine,snd_soc_hdmi_codec,snd_soc_bcm2835_i2s,snd_bcm2835,snd_soc_core
snd_timer 32768 1 snd_pcm
snd 77824 7 snd_compress,snd_soc_pcm512x,snd_soc_hdmi_codec,snd_timer,snd_bcm2835,snd_soc_core,snd_pcm
also:
cat /proc/asound/cards
0 [IQaudIODAC ]: IQaudIODAC - IQaudIODAC
IQaudIODAC
So… what is going on here?
Thanks!
