Oh that’s great — the problem is intermittent, and sound is working correctly now. I’ll chime in if it’s a problem once more for me but for now it seems alright.
Sound issues only happen when there is no other audio. When there is another audio source transmitting sound ALSA applications (like Pidgin) exhibit no issues. So what’s being limited when there’s no sound?
The input is corked, which basically means the audio input isn’t open at all times. But because of said corking,(from my supposition) whenever there is a burst sound event like a notification PA doesn’t uncork in time for the sound to go through entirely, leading to garbled and incomplete playback.
I’ve dealt with PA issues with editing certain files before on Ubuntu, but audio corking was never a problem, rather it was microphone issues with boost not being adjustable in alsamixer. Gonna see what making the state not corked does for me.
Edit: Disabling cork plugin in default.pa didn’t resolve it.
Catching list-sink-inputs data is not easy on Pidgin. The command only recognises an active audio stream and the audio notifications in Pidgin are very short, so have to be quick to catch it (or use a longer audio file)
Yeah I legit can’t figure this out. I’m good at Linux, and I’ve shown some exemplary competency with certain subjects on here but PulseAudio – when it goes wrong — is above my pay grade.
I’ve disabled both corking and suspend on idle in default.pa and nothing changes with either ALSA or Automatic in Pidgin. Mind, none of thiis happens with the EQ turned off, and this never happens in the live session, in spite of using the same version, built with the same tarball.
I had also started fresh, with a formatted home and root part. After updating everything, the problem happens. And I really do not want to go through the effort of reinstalling again and installing packages one-by-one on a USB-attached media to figure it out.
